Met errors while running './rploader.sh fullupgrade'
The errors are attached below and seems like I cannot curl the URL.
Can someone share what will be downloaded and locate them where? I can manually do it. I guess because here in China the network is, you know, blocked...
Thanks!
tc@box:~$ ./rploader.sh fullupgrade
Performing a full TCRP upgrade
Warning some of your local files will be moved to /home/tc/old/xxxx.2022-Jun-14-15-16
Updating custom_config.json
mv: cannot stat 'custom_config.json': No such file or directory
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
  0     0    0     0    0     0      0      0 --:--:--  0:02:00 --:--:--     0
curl: (56) OpenSSL SSL_read: Success
Updating custom_config_jun.json
mv: cannot stat 'custom_config_jun.json': No such file or directory
  0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0
curl: (7) Failed to connect to raw.githubusercontent.com port 443: Connection refused
Updating global_config.json
mv: cannot stat 'global_config.json': No such file or directory
Updating modules.alias.3.json.gz
mv: cannot stat 'modules.alias.3.json.gz': No such file or directory
Updating modules.alias.4.json.gz
mv: cannot stat 'modules.alias.4.json.gz': No such file or directory
  0     0    0     0    0     0      0      0 --:--:--  0:00:31 --:--:--     0
  0     0    0     0    0     0      0      0 --:--:--  0:00:32 --:--:--     0
Updating rpext-index.json
mv: cannot stat 'rpext-index.json': No such file or directory
Updating user_config.json
mv: cannot stat 'user_config.json': No such file or directory
Updating dtc
mv: cannot stat 'dtc': No such file or directory
  0     0    0     0    0     0      0      0 --:--:--  0:00:33 --:--:--     0
Updating rploader.sh
Updating ds1621p.dts
mv: cannot stat 'ds1621p.dts': No such file or directory
Updating ds920p.dts
mv: cannot stat 'ds920p.dts': No such file or directory
chown: cannot access 'custom_config.json': No such file or directory
chown: cannot access 'custom_config_jun.json': No such file or directory
chown: cannot access 'global_config.json': No such file or directory
chown: cannot access 'modules.alias.3.json.gz': No such file or directory
chown: cannot access 'modules.alias.4.json.gz': No such file or directory
chown: cannot access 'rpext-index.json': No such file or directory
chown: cannot access 'user_config.json': No such file or directory
chown: cannot access 'dtc': No such file or directory
chown: cannot access 'rploader.sh': No such file or directory
chown: cannot access 'ds1621p.dts': No such file or directory
chown: cannot access 'ds920p.dts': No such file or directory
gzip: modules.alias.*.gz: No such file or directory
chmod: cannot access 'rploader.sh': No such file or directory
Please make sure you are using the latest 1GB img before using backup option
Current /home/tc size is 135M , try to keep it less than 1GB as it might not fit into your image
Should i update the sda with your current files [Yy/Nn]
n
OK, keeping last status
Edited by justinavril
8 answers to this question
I will try the solution below:
  • From my macbook, I ping the URL and get its IP:
justinwu@B-38DGMD6R-2252 ~ % ping raw.githubusercontent.com
PING raw.githubusercontent.com (185.199.108.133): 56 data bytes
64 bytes from 185.199.108.133: icmp_seq=0 ttl=46 time=74.897 ms
64 bytes from 185.199.108.133: icmp_seq=1 ttl=46 time=82.321 ms
64 bytes from 185.199.108.133: icmp_seq=2 ttl=46 time=80.831 ms
64 bytes from 185.199.108.133: icmp_seq=3 ttl=46 time=77.340 ms
64 bytes from 185.199.108.133: icmp_seq=4 ttl=46 time=74.921 ms
  • Add the ip and URL to /etc/hosts and see if the problem is fixed.
On 6/19/2022 at 11:39 PM, justinavril said:
I found a method of fixing the network issue and now the installation has been done.
Hi ,
could you share your method of fixing the network issue to fix this issue? thank you
Answer this question...
