Loader BUILD problem
jrockow
After using TinyCore to build DS920+, 7.1.0-42661, on mobo with Intel i5-11400 (11th gen), there is no /DRI directory.
If I use the same TinyCore stick to build DS920+, 7.1.0-42661, on mobo with Intel i7-4790 (4th gen), the /DRI directory and contents are there.
I read earlier that "syno's i915 supports everything up to 9th gen ootb"
Does this mean i915 doesn't apply to an 11th gen Intel i5-11400?
Is that why I'm not getting the /DRI directory, or is it another issue?
Is there any work-around?
