Hello,
I have installed 7.1.0-42661 Update 1 on my vmware to test updates. I realized, that updating to "Update 2" ends in a recovery loop. This is what I tried next:
  • Applying Update 2 in DSM
  • Reboot after update directly to TCRP
  • ./rploader update (was already up to date)
  • ./rploader postupdate 918+
    • answered "yes" to both questions, whether 42661-2 shall be used
  • sudo reboot
After reboot, I can not see my DSM any more in network. What did I forget? Is the "postupdate" really the only command? Or is it necessary to apply again the "build" command afterwards?
2 minutes ago, pipsen said:
Hello,
  • sudo reboot
Please try:
sudo ./rploader postupdate 918+
After I used the "sudo" with the "postupdate"-command my test installation with DS3622xs+ boots correctly.
@Balrog
Thank you for your hint, but unfortunately, I have the same outcome. I attached the whole logfile starting with sudo su. The only logline which sounds strange is line 49 "unlzma: /mnt/sda2/rd.gz: Compressed data is corrupt".
tcrp.log
