problem about building the loader by using TCRP V8.0.1 for N54L
Sorry that i open another thread which is about building the loader for my N54L.
As i saw there is a new version of TCRP i tried to rebuild the USB loader to see if my problems can be solved or not. However, While the cmd "./rploader.sh build bromolow-7.0.1-42218" is run it said that
[-] Couldn't find bspatch in your $PATH
[#] Checking runtime for required tools... [ERR]
[!] Some tools weren't available - install them first
*** Process will exit ***
FAILED : Loader creation failed check the output for any errors
does anyone can help please?
below is my cmd log.
login as: tc
tc@192.168.1.211's password:
  /) TC (\   Core is distributed with ABSOLUTELY NO WARRANTY.
 (/-_--_-\)           www.tinycorelinux.net
tc@box:~$ ^C
tc@box:~$ ^C
tc@box:~$ ^C
tc@box:~$ ^C
tc@box:~$ ^C
tc@box:~$ ^C
tc@box:~$ ./rploader.sh update now
Checking Internet Access -> OK
Checking if a newer version exists on the main repo -> Found newversion : 0.8.0.1
Current version : 0.8.0.0
There is a newer version of the script on the repo should we use that ? [yY/nN]y
OK, updating, please re-run after updating
Updating tinycore loader with latest updates
Backing up files to /mnt/sdb3//mydata.tgz
Done.
Checking if a newer version exists on the main repo -> Version is current
tc@box:~$ ./rploader.sh fullupgrade now
Performing a full TCRP upgrade
Warning some of your local files will be moved to /home/tc/old/xxxx.2022-Apr-06-01-30
Updating custom_config.json
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
  0     0    0     0    0     0      0      0 --:--:-- --:--:-- --:--:--     0
100 33842  100 33842    0     0  43950      0 --:--:-- --:--:-- --:--:--  262k
Updating custom_config_jun.json
100  8954  100  8954    0     0  10919      0 --:--:-- --:--:-- --:--:-- 10919
Updating global_config.json
100  5692  100  5692    0     0   6984      0 --:--:-- --:--:-- --:--:--  6984
Updating modules.alias.3.json.gz
mv: cannot stat 'modules.alias.3.json.gz': No such file or directory
100  5591  100  5591    0     0  11049      0 --:--:-- --:--:-- --:--:-- 11049
Updating modules.alias.4.json.gz
mv: cannot stat 'modules.alias.4.json.gz': No such file or directory
100 89007  100 89007    0     0   168k      0 --:--:-- --:--:-- --:--:--  168k
Updating rpext-index.json
100  211k  100  211k    0     0   256k      0 --:--:-- --:--:-- --:--:--  256k
Updating user_config.json
100   431  100   431    0     0    542      0 --:--:-- --:--:-- --:--:--   542
Updating dtc
100  146k  100  146k    0     0   174k      0 --:--:-- --:--:-- --:--:--  174k
Updating rploader.sh
100 93168  100 93168    0     0   176k      0 --:--:-- --:--:-- --:--:--  176k
Updating ds1621p.dts
mv: cannot stat 'ds1621p.dts': No such file or directory
100  3026  100  3026    0     0   3945      0 --:--:-- --:--:-- --:--:--  3945
Updating ds920p.dts
mv: cannot stat 'ds920p.dts': No such file or directory
100  2423  100  2423    0     0   2973      0 --:--:-- --:--:-- --:--:--  2973
Please make sure you are using the latest 1GB img before using backup option
Current /home/tc size is 2.8M , try to keep it less than 1GB as it might not fit into your image
Should i update the sdb with your current files [Yy/Nn]
y
Backing up home files to sdb : Backing up files to /mnt/sdb3//mydata.tgz
Done.
tc@box:~$ ./rploader.sh build bromolow-7.0.1-42218
Rploader Version : 0.8.0.1
Loader source : https://github.com/pocopico/redpill-load.git Loader Branch : develop
Redpill module source : https://github.com/pocopico/redpill-lkm.git : Redpill module branch : master
Extensions :
Extensions URL :
TOOLKIT_URL : https://sourceforge.net/projects/dsgpl/files/toolkit/DSM7.0/ds.bromolow-7.0.dev.txz/download
TOOLKIT_SHA : a5fbc3019ae8787988c2e64191549bfc665a5a9a4cdddb5ee44c10a48ff96cdd
SYNOKERNEL_URL : https://sourceforge.net/projects/dsgpl/files/Synology NAS GPL Source/25426branch/bromolow-source/linux-3.10.x.txz/download
SYNOKERNEL_SHA : 18aecead760526d652a731121d5b8eae5d6e45087efede0da057413af0b489ed
COMPILE_METHOD : toolkit_dev
TARGET_PLATFORM       : bromolow
TARGET_VERSION    : 7.0.1
TARGET_REVISION : 42218
REDPILL_LKM_MAKE_TARGET : dev-v7
KERNEL_MAJOR : 3
MODULE_ALIAS_FILE :  modules.alias.3.json
SYNOMODEL : ds3615xs_42218
MODEL : DS3615xs
Local Cache Folder : /mnt/sdb3/auxfiles
DATE Internet : 06042022 Local : 06042022
Cloning into 'redpill-lkm'...
remote: Enumerating objects: 1253, done.
remote: Counting objects: 100% (325/325), done.
remote: Compressing objects: 100% (41/41), done.
remote: Total 1253 (delta 302), reused 284 (delta 283), pack-reused 928
Receiving objects: 100% (1253/1253), 469.84 KiB | 2.25 MiB/s, done.
Resolving deltas: 100% (865/865), done.
Cloning into 'redpill-load'...
remote: Enumerating objects: 2016, done.
remote: Counting objects: 100% (22/22), done.
remote: Compressing objects: 100% (18/18), done.
remote: Total 2016 (delta 5), reused 12 (delta 4), pack-reused 1994
Receiving objects: 100% (2016/2016), 114.70 MiB | 6.65 MiB/s, done.
Resolving deltas: 100% (945/945), done.
No extra build option or static specified, using default <static>
Using static compiled redpill extension
Removing any old redpill.ko modules
Looking for redpill for : ds3615xs_42218
Getting file https://raw.githubusercontent.com/pocopico/rp-ext/master/redpill/releases/redpill-3.10.108.tgz
Extracting module
tar: redpill.ko: time stamp 2022-04-10 08:57:57 is 372421.097938581 s in the future
Got redpill-linux-v3.10.108.ko
Testing modules.alias.3.json -> File OK
It looks that you will need the following modules :
Found SATA Controller : pciid 1002d00004391  Required Extension :
No matching extension
Found VGA Controller : pciid 10ded00000a65  Required Extension :
[#] Checking runtime for required tools... [OK]
[#] Adding new extension from https://raw.githubusercontent.com/pocopico/rp-ext/master/tg3/rpext-index.json...
[#] Downloading remote file https://raw.githubusercontent.com/pocopico/rp-ext/master/tg3/rpext-index.json to /home/tc/redpill-load/custom/extensions/_new_ext_index.tmp_json
######################################################################## 100.0%
[OK]
[#] ========================================== pocopico.tg3 ==========================================
[#] Extension name: tg3
[#] Description: Adds Broadcom Tigon3 ethernet driver Support
[#] To get help visit: <todo>
[#] Extension preparer/packer: https://github.com/pocopico/rp-ext/tree/main/tg3
[#] Software author: https://github.com/pocopico
[#] Update URL: https://raw.githubusercontent.com/pocopico/rp-ext/master/tg3/rpext-index.json
[#] Platforms supported: ds1621p_42218 ds918p_41890 dva3221_42661 ds3617xs_42621 ds3617xs_42218 ds920p_42661 ds918p_42661 ds1621p_42661 ds918p_25556 dva3221_42218 ds3615xs_42661 ds3622xsp_42661 ds3622xsp_42218 dva3221_42621 ds3615xs_41222 ds918p_42621 ds3617xs_42661 ds3615xs_25556 ds920p_42218 ds920p_42621 ds918p_42218 ds1621p_42621 ds3615xs_42621 ds3615xs_42218 ds3622xsp_42621
Found Ethernet Interface : pciid 14e4d0000165b Required Extension : tg3
Searching for matching extension for tg3
Found matching extension :
"https://raw.githubusercontent.com/pocopico/rp-ext/master/tg3/rpext-index.json"
Starting loader creation
Found tinycore cache folder, linking to home/tc/custom-module
Checking user_config.json : Done
Entering redpill-load directory
Removing bundled exts directories
bsdiff binary was not downloaded
Cache directory OK
Want to use firmware files from /home/tc/custom-module/*.pat ? [yY/nN] :
y
cp: cannot stat '/home/tc/custom-module/*42218*.pat': No such file or directory
Processing add_extensions entries found on custom_config.json file :
8 answers to this question
login as: tc
tc@box:~$ ^C
tc@box:~$ ^C
tc@box:~$ ^C
tc@box:~$ ^C
tc@box:~$ ^C
tc@box:~$ ^C
Done.
Updating dtc
Updating ds920p.dts
y
Done.
Extensions :
Extensions URL :
KERNEL_MAJOR : 3
MODEL : DS3615xs
Extracting module
[OK]
Cache directory OK
y
I will have a look at it, but, I think its better to build 3622xs+ for N54L. I have it running for half a year with no issues.
Edited by pocopico
Hi pocopico, nice to meet you.
For what you suggest i try to build the loader again immediately, however seems the problem is still the same. Neither bromolow-7.0.1-42218 nor broadwellnk-7.0.1-42218 it tried but it is still cannot build it.
login as: tc
Access denied
Extensions :
Extensions URL :
KERNEL_MAJOR : 3
MODEL : DS3615xs
Redpill sources already downloaded, pulling latest
Already up to date.
Loader sources already downloaded, pulling latest
Already up to date.
Extracting module
tar: redpill.ko: time stamp 2022-04-10 08:57:57 is 301712.417259032 s in the future
[!] Extension is already added (index exists at /home/tc/redpill-load/custom/extensions/pocopico.tg3/pocopico.tg3.json). For more info use "ext-manager.sh info pocopico.tg3"
Cache directory OK
y
This is the user_config.json how it is built.
  "extra_cmdline": {
    "pid": "0x6008",
    "vid": "0x154b",
    "sn": "20C0SQRAR0MRS",
    "mac1": "0011323EB473",
    "SataPortMap": "6",
    "DiskIdxMap": "00"
  "synoinfo": {
    "internalportcfg": "0xffff",
    "maxdisks": "16",
    "support_bde_internal_10g": "no",
    "support_disk_compatibility": "no",
    "support_memory_compatibility": "no"
  "ramdisk_copy": {}
Can you please try 42661 ? I just did a loader from scratch on my test system and looks like its working fine as well.
start again but first do a ./rploader.sh clean
Edited by pocopico
Noted pocopico.
i re-clone the image to my USB to build the loader. could you please check below log ? Thank you.
login as: tc
tc@box:~$ ./rploader.sh clean
rploader.sh
Version : 0.8.0.0
Usage: ./rploader.sh <action> <platform version> <static or compile module> [extension manager arguments]
Actions: build, ext, download, clean, update, listmod, serialgen, identifyusb, patchdtc,
satamap, backup, backuploader, restoreloader, restoresession, mountdsmroot, postupdate,
mountshare, version, help
Available platform versions:
apollolake-7.0-41890
apollolake-7.0.1-42218
apollolake-7.0.1-42218-JUN
apollolake-7.1.0-42621
apollolake-7.1.0-42661
broadwell-7.0.1-42218
broadwell-7.0.1-42218-JUN
broadwell-7.1.0-42621
broadwell-7.1.0-42661
broadwellnk-7.0.1-42218-JUN
broadwellnk-7.1.0-42621
broadwellnk-7.1.0-42661
bromolow-7.0.1-42218-JUN
bromolow-7.1.0-42621
bromolow-7.1.0-42661
denverton-7.0.1-42218
denverton-7.0.1-42218-JUN
denverton-7.1.0-42621
denverton-7.1.0-42661
geminilake-7.0.1-42218
geminilake-7.0.1-42218-JUN
geminilake-7.1.0-42621
geminilake-7.1.0-42661
v1000-7.0.1-42218
v1000-7.0.1-42218-JUN
v1000-7.1.0-42621
v1000-7.1.0-42661
Check custom_config.json for platform settings.
Done.
Warning some of your local files will be moved to /home/tc/old/xxxx.2022-Apr-06-21-35
100 33842  100 33842    0     0  42892      0 --:--:-- --:--:-- --:--:-- 42892
100  8954  100  8954    0     0  11054      0 --:--:-- --:--:-- --:--:-- 11054
100  5692  100  5692    0     0   7195      0 --:--:-- --:--:-- --:--:--  7195
100  5591  100  5591    0     0  11575      0 --:--:-- --:--:-- --:--:-- 11575
100 89007  100 89007    0     0   176k      0 --:--:-- --:--:-- --:--:--  176k
100  211k  100  211k    0     0   266k      0 --:--:-- --:--:-- --:--:--  266k
100   431  100   431    0     0    555      0 --:--:-- --:--:-- --:--:--  2628
Updating dtc
100  146k  100  146k    0     0   191k      0 --:--:-- --:--:-- --:--:-- 6377k
100 93168  100 93168    0     0   180k      0 --:--:-- --:--:-- --:--:--  180k
100  3026  100  3026    0     0   3712      0 --:--:-- --:--:-- --:--:--  3712
Updating ds920p.dts
100  2423  100  2423    0     0   4965      0 --:--:-- --:--:-- --:--:--  394k
y
Done.
tc@box:~$ ./rploader.sh serialgen DS3622xs+
Serial Number for Model : 2150SQRCH5VXG
Mac Address for Model DS3622xs+ : 00:11:32:4C:64:7B
Should i update the user_config.json with these values ? [Yy/Nn]
y
tc@box:~$ ./rploader.sh identifyusb now
Found PNY USB SerialNumber: 07016B6AAE276A40
Vendor ID : 0x154b Product ID : 0x6008
y
tc@box:~$ ./rploader.sh satamap now
Found "00:11.0 Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 SATA Controller [AHCI mode] (rev 40)"
Detected 6 ports/1 drives. Override # of ports or ENTER to accept <6>
Recommended settings:
SataPortMap=6
DiskIdxMap=00
Should i update the user_config.json with these values ? [Yy/Nn] y
Done.
tc@box:~$ ./rploader.sh build broadwellnk-7.1.0-42661
Extensions :   redpill-misc
Extensions URL : "https://github.com/pocopico/redpill-load/raw/master/redpill-misc/rpext-index.json"
TOOLKIT_URL : https://sourceforge.net/projects/dsgpl/files/toolkit/DSM7.0/ds.broadwellnk-7.0.dev.txz/download
TOOLKIT_SHA : 0d9edca67d9e7e14c2529bbb58341b623936124d5264f71f1e4acbacf3ea202d
SYNOKERNEL_URL : https://sourceforge.net/projects/dsgpl/files/Synology NAS GPL Source/25426branch/broadwellnk-source/linux-4.4.x.txz/download
SYNOKERNEL_SHA : d3e85eb80f16a83244fcae6016ab6783cd8ac55e3af2b4240455261396e1e1be
TARGET_PLATFORM       : broadwellnk
TARGET_VERSION    : 7.1.0
TARGET_REVISION : 42661
KERNEL_MAJOR : 4
MODULE_ALIAS_FILE :  modules.alias.4.json
SYNOMODEL : ds3622xsp_42661
MODEL : DS3622xs+
Receiving objects: 100% (1253/1253), 469.84 KiB | 2.22 MiB/s, done.
Receiving objects: 100% (2016/2016), 114.70 MiB | 4.70 MiB/s, done.
Looking for redpill for : ds3622xsp_42661
Getting file https://raw.githubusercontent.com/pocopico/rp-ext/master/redpill/releases/redpill-4.4.180plus-broadwellnk.tgz
Extracting module
tar: redpill.ko: time stamp 2022-04-09 12:23:56 is 225960.974995861 s in the future
Getting file https://raw.githubusercontent.com/pocopico/rp-ext/master/redpill/src/check-redpill.sh
Got redpill-linux-v4.4.180+.ko
Testing modules.alias.4.json -> File OK
Found SATA Controller : pciid 1002d00004391  Required Extension : ahci
Searching for matching extension for ahci
[OK]
Cache directory OK
Found build request for revision greater than 42218
Getting required extraction tool
Checking tinycore cache folder
Creating temp folder /tmp/synoesp
curl: (60) SSL certificate problem: certificate is not yet valid
More details here: https://curl.haxx.se/docs/sslcerts.html
curl failed to verify the legitimacy of the server and therefore could not
establish a secure connection to it. To learn more about this situation and
how to fix it, please visit the web page mentioned above.
Entering synoesp
./rploader.sh: line 228: rd.gz: No such file or directory
extract rd.gz
finish
./rploader.sh: line 230: rd: No such file or directory
extract rd
mkdir: cannot create directory '/mnt/sdb3/auxfiles': File exists
Copying required files to local cache folder for future use
Copying usr/lib/libcurl.so.4 to /mnt/sdb3/auxfiles
cp: cannot stat 'usr/lib/libcurl.so.4': No such file or directory
Copying usr/lib/libmbedcrypto.so.5 to /mnt/sdb3/auxfiles
cp: cannot stat 'usr/lib/libmbedcrypto.so.5': No such file or directory
Copying usr/lib/libmbedtls.so.13 to /mnt/sdb3/auxfiles
cp: cannot stat 'usr/lib/libmbedtls.so.13': No such file or directory
Copying usr/lib/libmbedx509.so.1 to /mnt/sdb3/auxfiles
cp: cannot stat 'usr/lib/libmbedx509.so.1': No such file or directory
Copying usr/lib/libmsgpackc.so.2 to /mnt/sdb3/auxfiles
cp: cannot stat 'usr/lib/libmsgpackc.so.2': No such file or directory
Copying usr/lib/libsodium.so to /mnt/sdb3/auxfiles
cp: cannot stat 'usr/lib/libsodium.so': No such file or directory
Copying usr/lib/libsynocodesign-ng-virtual-junior-wins.so.7 to /mnt/sdb3/auxfiles
cp: cannot stat 'usr/lib/libsynocodesign-ng-virtual-junior-wins.so.7': No such file or directory
Copying usr/syno/bin/scemd to /mnt/sdb3/auxfiles
cp: cannot stat 'usr/syno/bin/scemd': No such file or directory
Copying required libraries to local lib directory
cp: cannot stat '/mnt/sdb3/auxfiles/extractor/lib*': No such file or directory
Linking lib to lib64
Copying executable
cp: cannot stat '/mnt/sdb3/auxfiles/extractor/scemd': No such file or directory
Removing temp folder /tmp/synoesp
Checking if tools is accessible
./rploader.sh: line 255: /bin/syno_extract_system_patch: No such file or directory
Cound not execute
Creating temp folder /tmp/pat
Checking for cached pat file
Could not find pat file locally cached
Configdir : /home/tc/redpill-load/config/DS3622xs+/7.1.0-42661
Configfile: /home/tc/redpill-load/config/DS3622xs+/7.1.0-42661/config.json
Pat URL : https://global.download.synology.com/download/DSM/release/7.1/42661-1/DSM_DS3622xs%2B_42661.pat
Downloading pat file from URL : https://global.download.synology.com/download/DSM/release/7.1/42661-1/DSM_DS3622xs%2B_42661.pat
Failed to download PAT file //mnt/sdb3/auxfiles/ds3622xsp_42661.pat from https://global.download.synology.com/download/DSM/release/7.1/42661-1/DSM_DS3622xs%2B_42661.pat
tc@box:~$
Try downloading the pat file of ds3622xs+ as below for SSL test. Also consider firewall issues.
curl --location  "https://global.download.synology.com/download/DSM/release/7.1/42661-1/DSM_DS3622xs+_42661.pat" --output /mnt/"$(mount | grep -i optional | grep cde | awk -F / '{print $3}' | uniq | cut -c 1-3)3"/auxfiles/ds3622xsp_42661.pat
22 hours ago, pocopico said:
SSL certificate erors are usually a time/date issue. Is your time set correctly ? The date is Ok as it looks.
Thx Pocopico. you are right. my BIOS clock is not correct. After re-setting the clock is try to rebuild the loader 3622xs one. My DSM is now back. Thanks very much.
Answer this question...
