pLastUn Posted June 19 Share #676 Posted June 19 21 час назад, Peter Suh сказал: Did you use WEBUI when building the loader? WEBUI is known to operate as withfriend by default. If you built the loader with a command using the console, try converting it to FRIEND by adding more withfriends as well. FRIEND is much less likely to encounter a 58% file corruption message than the conventional method without withfriend. Now it's like this: Quote Link to comment Share on other sites More sharing options...
Al lex Posted June 20 Share #677 Posted June 20 I have already written to Peter in his thread. Synology seems changed pat 64570 with update 1 with no warnings At least I don't remember this subscripture 1 Quote Link to comment Share on other sites More sharing options...
pocopico Posted June 20 Author Share #678 Posted June 20 9 hours ago, pLastUn said: Now it's like this: Your cmdline is incomplete. can you cat your /mnt/tcrp/user_config.json please ? Quote Link to comment Share on other sites More sharing options...
pLastUn Posted June 20 Share #679 Posted June 20 2 часа назад, pocopico сказал: Your cmdline is incomplete. can you cat your /mnt/tcrp/user_config.json please ? { "general": { "model": "DS3617xs", "version": "7.2.0-64570", "smallfixnumber": "0", "zimghash": "", "rdhash": "", "usb_line": "", "sata_line": "", "redpillmake": "prod", "friendautoupd": "true", "staticboot": "false", "hidesensitive": "false" }, "ipsettings": { "ipset": "", "ipaddr": "", "ipgw": "", "ipdns": "", "ipproxy": "" }, "extra_cmdline": { "pid": "0x4300", "vid": "0x13FE", "sn": "1430ODN019268", "mac1": "001132DD8CD9", "mac2": "001132DD8CDA", "netif_num": "2", "SataPortMap": "6", "DiskIdxMap": "00" }, "synoinfo": { "internalportcfg": "0xffff", "maxdisks": "16", "support_bde_internal_10g": "no", "support_disk_compatibility": "no", "support_memory_compatibility": "no" }, "ramdisk_copy": {} } Quote Link to comment Share on other sites More sharing options...
pocopico Posted June 20 Author Share #680 Posted June 20 2 minutes ago, pLastUn said: { "general": { "model": "DS3617xs", "version": "7.2.0-64570", "smallfixnumber": "0", "zimghash": "", "rdhash": "", "usb_line": "", "sata_line": "", "redpillmake": "prod", "friendautoupd": "true", "staticboot": "false", "hidesensitive": "false" }, "ipsettings": { "ipset": "", "ipaddr": "", "ipgw": "", "ipdns": "", "ipproxy": "" }, "extra_cmdline": { "pid": "0x4300", "vid": "0x13FE", "sn": "1430ODN019268", "mac1": "001132DD8CD9", "mac2": "001132DD8CDA", "netif_num": "2", "SataPortMap": "6", "DiskIdxMap": "00" }, "synoinfo": { "internalportcfg": "0xffff", "maxdisks": "16", "support_bde_internal_10g": "no", "support_disk_compatibility": "no", "support_memory_compatibility": "no" }, "ramdisk_copy": {} } something is wrong, can you please try to rebuild using the latest image and HTML Builder ? Quote Link to comment Share on other sites More sharing options...
pocopico Posted June 20 Author Share #681 Posted June 20 2 hours ago, Al lex said: I have already written to Peter in his thread. Synology seems changed pat 64570 with update 1 with no warnings At least I don't remember this subscripture I've updated the TCPR config files Quote Link to comment Share on other sites More sharing options...
pLastUn Posted June 20 Share #682 Posted June 20 1 час назад, pocopico сказал: something is wrong, can you please try to rebuild using the latest image and HTML Builder ? Ок, Downloaded the latest TCRP image today. Started it up and did all the actions from the HTML. The screenshot says "Failed to install file. File may be corrupted". PAT file DSM_DS3617xs_42962.pat is original, downloaded from Synology website. Quote Link to comment Share on other sites More sharing options...
djvas335 Posted June 20 Share #683 Posted June 20 I have below error when trying to build latest loader and DSM [#] Verifying /home/tc/redpill-load/custom/extensions/disks/ds3622xsp_64570/install.sh file... [ERR] [!] Checksum mismatch - expected 63d8722edb9c5f7cb7160bead82e2909bb977a1aad96dff74f39629fde03c3bf but computed d1f4003ea029a2f44db3c105e04f245a87e6c0d0b1685ff237d2278b55e43481 *** Process will exit *** 1 Quote Link to comment Share on other sites More sharing options...
pocopico Posted June 20 Author Share #684 Posted June 20 58 minutes ago, djvas335 said: I have below error when trying to build latest loader and DSM [#] Verifying /home/tc/redpill-load/custom/extensions/disks/ds3622xsp_64570/install.sh file... [ERR] [!] Checksum mismatch - expected 63d8722edb9c5f7cb7160bead82e2909bb977a1aad96dff74f39629fde03c3bf but computed d1f4003ea029a2f44db3c105e04f245a87e6c0d0b1685ff237d2278b55e43481 *** Process will exit *** Fixed Quote Link to comment Share on other sites More sharing options...
pocopico Posted June 20 Author Share #685 Posted June 20 (edited) 1 hour ago, pLastUn said: Ок, Downloaded the latest TCRP image today. Started it up and did all the actions from the HTML. The screenshot says "Failed to install file. File may be corrupted". PAT file DSM_DS3617xs_42962.pat is original, downloaded from Synology website. Is this a proxmox VM ? Did you use the PAT file that you downloaded from Syno ? At 55% corrupted file the usb vid:pid is usually wrong and synoboot is not shimmed properly , can you check using http://yourip:7681 (root/no password) the existence of synoboot with fdisk -l ? Also lsusb can be helpful. Edited June 20 by pocopico Quote Link to comment Share on other sites More sharing options...
pLastUn Posted June 20 Share #686 Posted June 20 (edited) 27 минут назад, pocopico сказал: Is this a proxmox VM ? Did you use the PAT file that you downloaded from Syno ? At 55% corrupted file the usb vid:pid is usually wrong and synoboot is not shimmed properly , can you check using http://yourip:7681 (root/no password) the existence of synoboot with fdisk -l ? Also lsusb can be helpful. It's not a Proxmox VM, it's a hardware server, just located far away and managed via IPMI. The DS3615xs installed and updated successfully. How can I now add a second mac and change the sn and mac to the real ones I have? Over ssh to edit grub.cfg on a running system? Also, how can I change dev mode to prod and close port 7681? It will work on the real IP. Edited June 20 by pLastUn Quote Link to comment Share on other sites More sharing options...
renegadeBE Posted June 26 Share #687 Posted June 26 (edited) @pocopico Feedback from a mac address issue that is not affected by the user_config.json settings: I had tried ARPL on a machine, I had customized the SN & MAC before the build of the loader. After that, the tests were not conclusive (AMD processor causing a Kernel Panic), having finished my tests, I returned to my loves: TCRP. When rebuilding the loader, I affected an S/N & MAC of a real Syno. At startup, in Synology Assistant I see that the old mac entered !!! Verification of GRUB: everything is OK, the mac address is the one entered when building the loader. Restart and again the wrong MAC... To solve the problem I had to flash a usb stick again with arpl, boot on it and customize the mac address. Upon reboot to TCRP, the new mac entered ARPL appeared. Also in Synology Assistant. Edited June 26 by renegadeBE Quote Link to comment Share on other sites More sharing options...
Dougi Posted June 29 Share #688 Posted June 29 On 6/20/2023 at 1:18 PM, pLastUn said: Ок, Downloaded the latest TCRP image today. Started it up and did all the actions from the HTML. The screenshot says "Failed to install file. File may be corrupted". PAT file DSM_DS3617xs_42962.pat is original, downloaded from Synology website. Same here with fresh build DSM_DS3622xs+_64570.pat on esxi 6.7. DSM_DS3622xs+_42962.pat works as expected. Booth builds are done with same snapshot. Quote Link to comment Share on other sites More sharing options...
Gronaldo Posted July 21 Share #689 Posted July 21 @pocopico Using the WEBUI and tinycore-redpill-uefi.v0.9.4.9.img I got a bare metal build operational. (Asus P9D-I serverboard / Xeon E3-1225v2) However, Info Center- General page was completely empty (no info) and the USB-bootdrive was visible and accessible in File Explorer (as 3 devices) Reverted back to tinycore-redpill-uefi.v0.9.4.8.img, used the manual SSH procedure (including updating loader) and all issues were resolved. Quote Link to comment Share on other sites More sharing options...
renegadeBE Posted August 18 Share #690 Posted August 18 (edited) Hi @pocopico, I tried to migrate a test machine (amd 64bit platform): 7.1.1 42962U5 -> 7.2 64570. First, used shell commands: unable to create loader. The ALX module is incompatible with the requested version. Then I tried with the WEBUI. The process worked, the server was detected and I was able to install DSM 7.2. On reboot, the server was in recoverable mode. I applied, on reboot I launched the built-in FRIEND function to rebuild the loader. It has detected an update and has rebuilt the charger. After that, the server rebooted, but now the server is totally not found. If I rebuild the loader (without the minor update) it is in recovery mode again, after repair the server reboots. If I don't apply the "postupdate" procedure from the grub menu, I stay in the loop. If I apply the procedure from the GRUB menu, the server becomes invisible. The network card LEDs are both on, the server does not boot (no disk noise at boot). It displays the usual message on the screen... I specify that the loader was built in static mode. An idea ? EDIT : i use TCRP v0.9.4.9c Edited August 18 by renegadeBE Quote Link to comment Share on other sites More sharing options...
Gronaldo Posted August 19 Share #691 Posted August 19 (edited) 21 hours ago, renegadeBE said: no disk noise at boot This indicates a hardware issue, not related to the loader. Drives should allways spin up when machine starts/boots. Edited August 19 by Gronaldo Quote Link to comment Share on other sites More sharing options...
renegadeBE Posted August 19 Share #692 Posted August 19 14 minutes ago, Gronaldo said: This indicates a hardware issue, not related to the loader. Drives should allways spin up when machine starts/boots. Hi, On startup, DSM loading, causes disk access (audible). In my case, no noise is emitted. I'm thinking more of a system crash (kernel panic?). I tried last night with the latest ARPL loader, direct boot mode. My server is fine and as usual, emitting disk access noises at startup. I was able to recover all the files and configurations. Do you think the problem will ever be solved? I have a preference for TCRP. THANKS :-) Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted August 20 Share #693 Posted August 20 (edited) On 8/18/2023 at 6:32 PM, renegadeBE said: Hi @pocopico, I tried to migrate a test machine (amd 64bit platform): 7.1.1 42962U5 -> 7.2 64570. First, used shell commands: unable to create loader. The ALX module is incompatible with the requested version. Then I tried with the WEBUI. The process worked, the server was detected and I was able to install DSM 7.2. On reboot, the server was in recoverable mode. I applied, on reboot I launched the built-in FRIEND function to rebuild the loader. It has detected an update and has rebuilt the charger. After that, the server rebooted, but now the server is totally not found. If I rebuild the loader (without the minor update) it is in recovery mode again, after repair the server reboots. If I don't apply the "postupdate" procedure from the grub menu, I stay in the loop. If I apply the procedure from the GRUB menu, the server becomes invisible. The network card LEDs are both on, the server does not boot (no disk noise at boot). It displays the usual message on the screen... I specify that the loader was built in static mode. An idea ? EDIT : i use TCRP v0.9.4.9c As in the script below I have in M-Shell for TCRP When installing 64570, I made some adjustments so that postupdate and repair are not required. The reason is that the VERSION file exists in the full version PAT file of the 7.2-64570-1 NanoPacked version provided by Synology. Strangely, this file is written with U0 even though it should point to U1. https://archive.synology.com/download/Os/DSM/7.2-64570-1-NanoPacked As a result, there is a problem that it is incorrectly recognized as U0 during the installation process, which should be fixed as U1. I made adjustments to rectify this. Line 38 below is related to this. https://github.com/PeterSuh-Q3/tcrp-modules/blob/main/all-modules/src/install.sh#L38 Edited August 20 by Peter Suh Quote Link to comment Share on other sites More sharing options...
MrHappy Posted August 21 Share #694 Posted August 21 Thanks @Peter Suh. This fixed my issue and can now install the latest version (for DS3622xs+ on my Proxmox VM) without any corruption errors. 1 Quote Link to comment Share on other sites More sharing options...
bobby1701 Posted September 3 Share #695 Posted September 3 Hi there, I wonder if someone could help. I am stuck on step 1. I had stable DSM6.2 system which reset so I had to start with a new USB with JUN 1.3b. Long story short, I ran in to connectivity problems reported elsewhere (with DSM 6.2.4-25556). I have been told to update to 7.x For this, given I have 43TB (27TB of data) in a 4 disk array, I want to be cautious with the steps. From page 1 of this thread, I cannot find the 0.8 version loader when I go to "stable" GitHub page. All I see is the latest v0.9.4.9 version. So my questions: 1. Where do I get the stable 0.8 version? Is 0.8 the best option? 2. I had a DS3617xs and want to migrate to DS3622xs+, so shall I go straight to DSM 7.1.0-42661? 3. Are there likely any risks to my data such as need to delete all my array in this migration process? If so, what shall I do? How can I avoid data loss? Appreciate any and all help Thank you. Quote Link to comment Share on other sites More sharing options...
cableguy Posted September 19 Share #696 Posted September 19 On 9/3/2023 at 6:47 AM, bobby1701 said: Hi there, I wonder if someone could help. I am stuck on step 1. I had stable DSM6.2 system which reset so I had to start with a new USB with JUN 1.3b. Long story short, I ran in to connectivity problems reported elsewhere (with DSM 6.2.4-25556). I have been told to update to 7.x For this, given I have 43TB (27TB of data) in a 4 disk array, I want to be cautious with the steps. From page 1 of this thread, I cannot find the 0.8 version loader when I go to "stable" GitHub page. All I see is the latest v0.9.4.9 version. So my questions: 1. Where do I get the stable 0.8 version? Is 0.8 the best option? 2. I had a DS3617xs and want to migrate to DS3622xs+, so shall I go straight to DSM 7.1.0-42661? 3. Are there likely any risks to my data such as need to delete all my array in this migration process? If so, what shall I do? How can I avoid data loss? Appreciate any and all help Thank you. I did the same upgrade and created 4 videos on how to get from 6.2.3 to 7.1.1 Update 4. They are long, but that is because I was doing an upgrade on my prod system and wanted to make sure everything was correct so the first video is a test run ("prep") on the same system but with a new SSD to test the upgrade process. Good luck! Here is the first: https://www.youtube.com/watch?v=SL91KIzNM_4&pp=ygUUdXBncmFkZSBkc20gNi4yIHRvIDc%3D 1 Quote Link to comment Share on other sites More sharing options...
altas Posted September 20 Share #697 Posted September 20 On 9/19/2023 at 2:52 PM, cableguy said: I did the same upgrade and created 4 videos on how to get from 6.2.3 to 7.1.1 Update 4. They are long, but that is because I was doing an upgrade on my prod system and wanted to make sure everything was correct so the first video is a test run ("prep") on the same system but with a new SSD to test the upgrade process. Good luck! Here is the first: https://www.youtube.com/watch?v=SL91KIzNM_4&pp=ygUUdXBncmFkZSBkc20gNi4yIHRvIDc%3D nice video.. maybe time now for me to updrade to the latest on my HP GEN8 Quote Link to comment Share on other sites More sharing options...
bobby1701 Posted Sunday at 09:37 AM Share #698 Posted Sunday at 09:37 AM On 9/19/2023 at 1:52 PM, cableguy said: I did the same upgrade and created 4 videos on how to get from 6.2.3 to 7.1.1 Update 4. They are long, but that is because I was doing an upgrade on my prod system and wanted to make sure everything was correct so the first video is a test run ("prep") on the same system but with a new SSD to test the upgrade process. Good luck! Here is the first: https://www.youtube.com/watch?v=SL91KIzNM_4&pp=ygUUdXBncmFkZSBkc20gNi4yIHRvIDc%3D Hi all, I tried this method using the video (great video) but ran into sata port mapping issues. My HDD were not getting detected. In the end I tried this video using ARPL arpl-i18n releases Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted Sunday at 10:36 AM Share #699 Posted Sunday at 10:36 AM (edited) 58 minutes ago, bobby1701 said: Hi all, I tried this method using the video (great video) but ran into sata port mapping issues. My HDD were not getting detected. In the end I tried this video using ARPL arpl-i18n releases This video guides the installation of the original ARPL by @fbelavenuto, which has discontinued development. Currently, ARPL-i18n, a fork of this repo, includes all the latest features. All installation processes in the video are the same, but it is recommended to use the actual link below. https://github.com/wjz304/arpl-i18n/releases Edited Sunday at 10:36 AM by Peter Suh Quote Link to comment Share on other sites More sharing options...
