pipsen Posted June 2, 2022 #1 Posted June 2, 2022 Dear all, I have used tinycore redpill during March / April several times and installed 918+ installations on several HP ProCurve Hardware machines. Everytime I was successful. Today I had the same task, but this time something is different. I installed like always - the only difference is, that there is now a version v0.8.0.0 available since two days ago. I tried now with two different PCs, two different USB sticks, two different hard disks and two different platforms (918+ / 920+). Everytime I have the same result: - Build process without any errors - DiskStation is visible after reboot "Welcome" - pat-file 7.1.0-42661 can be installed successfully -> Reboot - After reboot always the same: "Welcome Back! We have detected that you have moved your harddisk to a new DS918+. Please click on recovery to recover your settings" => Loop! Every time I press "Recover", the PC reboots and have the same situation. I have no idea, whether I am doing something wrong, but I fear it is something todo with the new 0.8.0.0 img? I need help Quote
flyride Posted June 2, 2022 #2 Posted June 2, 2022 Are you trying to install or upgrade to 42661-2? That results in a Recover loop at the moment. Quote
pipsen Posted June 2, 2022 Author #3 Posted June 2, 2022 I have Downloaded https://global.download.synology.com/download/DSM/release/7.1/42661-1/DSM_DS918%2B_42661.pat?model=DS918%2B&bays=4&dsm_version=7.1&build_number=42661 md5: 2c49260d2646a0944b56933f7d4029fb This seems to be 42661-1 but maybe DSM tries to auto-update, because it is online? I will retry, while I am disconnected from internet Quote
pipsen Posted June 3, 2022 Author #4 Posted June 3, 2022 Acknowledged: As soon as you try to install ANY 42661 from scratch, and the NAS is connected to the internet, it will automatically download the latest patch => recovery loop. Thank you for this tip, this brought me on the right path! 1 Quote
BrandonS Posted June 3, 2022 #5 Posted June 3, 2022 Have you sorted this? I'm in the same boat. Quote
flyride Posted June 3, 2022 #6 Posted June 3, 2022 https://xpenology.com/forum/topic/53817-redpill-tinycore-loader/?do=findComment&comment=284855 Quote
