adam535 Posted May 25 Share #1 Posted May 25 hello i have motherboard that support wakeonlan , i setup my synology to wakeonlan ,, it actually worked my box turned on but the synology system not , it seems that wakeonlan does not support boot from usb is any way around this? Quote Link to comment Share on other sites More sharing options...
luutuananh Posted May 26 Share #2 Posted May 26 Wakeonlan is a motherboard feature, you need to find the proper setting in the bios to change that. The reason why DSM have that feature becasue in real Synology device they don't have bios interface so it needs to integrate that setting to the UI. Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted May 26 Share #3 Posted May 26 Even if the corresponding functions are all the same M/B, in some cases, WOL does not work with XPENOLOGY. So far, in my experience, GIGABYTE boards have worked flawlessly. It was impossible to operate on low-cost boards such as ECS. Quote Link to comment Share on other sites More sharing options...
