Guest Posted September 5, 2016 #1 Posted September 5, 2016 Hello friends When I download or upload from or to my XPEnology nas to my local computer, I usually get over 100 MB/sec. But when I download from a friend's house from my nas I only get from 0.5 to 0.8 MB/sec. But I don't get why this is? My nas can clearly handle it, and it's connected with cat6 directly to my router. My subscription has an upload of 6 MB/sec and I have called the company and they say everything from them to my router is ok. When I do an Ookla speedtest I get 6 MB/s of upload so I don't know it anymore. Nas is ok, changed motherboard to test, 4 WD RED's, cat6 direct to router and from router to internet 6 MB/sec. But in reality I get 1/12 of what I am capable of??? Thanks in advance!!
berwhale Posted September 6, 2016 #2 Posted September 6, 2016 What about your friends connection to the internet? What's the result of a speed test on his side, does his ISP throttle connections?
Guest Posted September 6, 2016 #3 Posted September 6, 2016 I don't think so because I have tried it at different houses and even 4G. They can download games from steam with 8 MB/sec.
bglf83 Posted September 7, 2016 #4 Posted September 7, 2016 6MBPS Upload is equivalent to about 600k of throughput. All your stuff is working correctly, limited by you Internet connection.
Guest Posted September 7, 2016 #5 Posted September 7, 2016 bglf83, why is this? Aren't you supposed to get what they advertise? So if I got a subscription of 20 MB/sec, you mean that I only get 2MB in reality?
bglf83 Posted September 7, 2016 #6 Posted September 7, 2016 This is the first thing that came up when I searched it. It looks like a good reference. http://home.earthlink.net/~flatlinecs/id48.html
berwhale Posted September 7, 2016 #7 Posted September 7, 2016 bglf83, why is this?Aren't you supposed to get what they advertise? So if I got a subscription of 20 MB/sec, you mean that I only get 2MB in reality? Internet speed is measured in MegaBITS per second (Mbps). File transfer speed is measured in MegaBYTES per second (MBps). There are 8 bits in a byte. If you factor in an extra couple of bits for transmission overheads (headers, error correction, etc.) then you can generally divide the Mbps value by 10 to get an idea of the file transfer speed in MB per second.
