TinyCore RedPill Loader Build Support Tool ( M-Shell )
Peter Suh
1 час назад, Captainfingerbang сказал:
Just doing my due diligence here out of curiousity. I Can see an Arc loader here. https://github.com/AuxXxilium/arc/releases/tag/24.2.10
and i see a LIST of patches here: https://github.com/AuxXxilium/arc-patches
But i dont see an "Arc Loader with Arc Patch" any where. could you please point me to the patch portion or is it included? I'm a lil lost
Just install Arc Loader and select "With Arc Patch" when config it !
@Captainfingerbang
I asked you a favor, but didn't you see it?
This begs one question ONLY from curiousity, could one use 1 set serial/mac on 2 different machines at same time? And Keep QC?
I don't think this will work.
In my case, I had DS918+ SN and QC and migrated to DS920+.
It means that there was no ban in this process alone.
23 hours ago, dj_nsk said:
test only ==> Arc Loader with Arc Patch
11 hours ago, Peter Suh said:
I understand that Arc loader provides various crack tools for violating the license that can irritate Synology.
This is a sensitive matter.
@dj_nsk, @Captainfingerbang  I hope you two will no longer mention ARC's license violations in this topic.
I do not agree with ARC's violations.
Please inquire in the ARC section.
You have both been asked by Peter Suh not to derail the thread with the ARC loader which is a separate loader.
If you have questions or comments about that loader, create a new thread.
12 минут назад, Polanskiman сказал:
Yes, I apologize to my dear @Peter Suh
(I didn't pay attention to which branch I was responding to)
Hi
while checking about AMD GPU support in XPEnology, I ran into this post :
https://jim.plus/blog/post/jim/amd-gpu-drivers-for-synology
apparently, he managed to get AMD GPU working with Synology SA6400.
I unfortunately do not have a full understanding of the explanation given and I was wondering how could this work be integrated in the loader to get proper gpu integration and hardware acceleration support in Plex for instance
thanks
fishton
So what i just attempted was:  I used my real serial and mac from my original 918+ but now using SA6400 TCRP FRIEND new test build, of course i turned off the 918+,
im able to login to Synology site from DSM but when i go to enable QC i get this error: I dns already set to 8.8.8.8. 8.8.4.4  so i dont know if i have to wait??
Peter how did you get this working?
On 2/12/2024 at 9:29 AM, Peter Suh said:
I'm sorry. Even though I knew that the 5900X was a model without an iGPU, I overlooked it.
If you decide to migrate to a model other than DS918+, I recommend trying SA6400 instead of DS2422+.
If you have an Intel iGPU in the original SA6400, H/W transcoding is easily handled.
There is no need to install AME, nor does it require a genuine Serial or Mac. Codec patches are also unnecessary.
However, I am also curious about how the SA6400 operates without an iGPU.
If H/W transcoding is not possible, at least S/W transcoding should work.
I also have Works that can be run with only a Xeon CPU without an iGPU.
I will tell you the results of testing how the SA6400 works.
I can confirm that running SA6400 with no IGPU on 5900x fully works with creating thumbnails. All 4k videos have thumbnails.
EDIT! THIS IS INCORRECT ITS ONLY MAKING THUMBNAILS FOR 4k VIDEO THAT IS AVC,  NOT HEVC.
What is WEIRD is that my DS918+ build with Real Serial Mac DOES convert 4k Hevc WITHOUT IGPU on X99 E5-2680v4
The very scary thing that happened with this machine was, i built the loader with 2422. Somehow it got switched to SA6400.
Is there something in your tools that maybe "suggests" the proper loader based on hardware, then selects it?
This really freaked me out.
Edited by Captainfingerbang
I have a couple things left to do guys and still using TCRP Friend by Peter Suh for new build.
  • I need to get my QC from 918+ working over to SA6400 machine , its not allowing me.
  • Then move 10 ssd shr over without issue.
  • Peter, are you suggesting that because the DS920+ is the Successor to the DS918+ is why QC still works? Like same family?
  • Now i need a solution for Creating video thumbnails for 4k videos that are HEVC
Backing up 918+ now.
Any suggestions?
I want to just throw this all away and purchase new INTEL setup with IGPU. Frustrating.
Can please tell me how can I set M-shell to assign my existing hdd synology bootloader to show in grub? Right now it only showing Tinycore Redpill Image on list.
Also, when I use ./rploader.sh postupdate ds_model_version it throwing error.
tc@box:~$ ./rploader.sh postupdate ds918p-7.1.1-42962
platform_selected={
  "id": "ds918p-7.1.1-42962",
  "platform_name": "apollolake",
  "downloads": {
    "os": {
      "sha256": "9905e145f3bd88fcc938b00882be10281861867e5165ae98aefa37be0d5d34b5"
  "add_extensions": [
      "all-modules": "https://raw.githubusercontent.com/PeterSuh-Q3/tcrp-modules/master/all-modules/rpext-index.json",
      "powersched": "https://raw.githubusercontent.com/PeterSuh-Q3/tcrp-addons/master/powersched/rpext-index.json",
      "storagepanel": "https://raw.githubusercontent.com/PeterSuh-Q3/tcrp-addons/master/storagepanel/rpext-index.json"
Rploader Version  : 1.1.0.0
Extensions        :   all-modules
  powersched
  storagepanel
Extensions URL    : "https://raw.githubusercontent.com/PeterSuh-Q3/tcrp-modules/master/all-modules/rpext-index.json",
TARGET_PLATFORM   : ds918p
TARGET_VERSION    : 7.1.1
TARGET_REVISION   : 42962
KERNEL_MAJOR      : 4
MODULE_ALIAS_FILE : modules.alias.4.json
SYNOMODEL         : ds918p_42962
MODEL             : DS918+
KERNEL VERSION    : 5.10.55
Local Cache Folder : /mnt/sdb3/auxfiles
DATE Internet     : 18022024 Local : 18022024
Checking Internet Access -> OK
Loader sources already downloaded, pulling latest
Already up to date.
Removing any old redpill.ko modules
Looking for redpill for : ds918p_42962
parse error: Expected string key before ':' at line 1, column 4
Module does not contain platorm information for ds918p_42962
I want to boot in my nas drive. I previously had tinycore redpil apollolake 7.1.0 42661 update to 42962 via DSM GUI. After update I am in hdd recovery loop in Tinycore Redpill which showing old DSM model still. So I want to use M-shell.
platform_selected={
  "downloads": {
    "os": {
  "add_extensions": [
  powersched
  storagepanel
KERNEL_MAJOR      : 4
MODEL             : DS918+
Already up to date.
This is not a case where postupdate should be used.
postupdate is no longer needed.
Did you rebuild your loader for 7.1.1-42962?
Updates should not be made without rebuilding the loader.
sorry if this has been asked before, but can you use the nvme alone as storage pool?
i had install DS923+ m-shell to thinkcentre m715q with 1tb nvme and 256 ssd;
DSM 7.2.1-69057 Update 4 detected both SSD and nvme,
installed syno_enable_m2_volume.sh and was able to add nvme to storage pool;
is there a way to use the nvme alone? when i tried to remove the ssd, it did not work;
appreciate your help.
thanks.
Edited by sam juan
12 hours ago, dj_nsk said:
no, at least one SATA drive is required to run DSM :(
The current mechanism of nvmevolume addon is copied from 007revad, and volume is activated only when the schedule is executed at least once in the form of a service after DSM is installed.
I am trying to improve nvmevolume and change it to on the fly method.
I would like to try to see if volume conversion is possible at the DSM junior level with only nvme, which is what users want.
If you see an NVMe volume at the junior level, you probably don't need a separate SATA disk.
If the test succeeds or fails, we will share the results.
[NOTICE]
Distribution of nvmevolume-onthefly addon (immediate version)
This is an addon that further complements the existing nvme volume.
I originally tried to reflect the requests of users who asked if it could be operated alone without a SATA type disk by creating a volume using only nvme, but after testing for several days, it did not work well.
Instead, SATA disks still need to be present, but this is improved with out-of-the-box volumeting capabilities.
The reason why this immediate reflection version was developed is that the existing version uses a service scheduling method, so even though the libhwcontrol.so.1 file has been hexa-patched once at the DSM installation completion stage, at least one more boot is required for the volume to appear. It flies.
Because users were not aware of this, many of them received the patch script from the original author, @007revad, twice and processed it.
This improved, immediate version allows volume conversion to be confirmed immediately upon first login after installing DSM and creating an account.
Analyzing the original author @007revad's script, I found that it simply ended up patching only one hex value,
like when activating the nvme cache of DS918+ in the past.
One line of xxd command processing is enough.
Back up the original to /lib64/libhwcontrol.so.1.bak.
https://github.com/PeterSuh-Q3/tcrp-addons/blob/main/nvmevolume-onthefly/src/install.sh
I don't know if this is an appropriate expression since my native language is not English.
@007revad's script method is called "AFTER SHOT".
I think that most REDPILL ADDON methods should be “ON THE FLY”.
Otherwise, a reboot must always follow after script processing.
Testing has only been completed focusing on version 7.2, so I hope users can verify older versions.
As always, you must rebuild the loader to change to the new addon.
This addon seems to help maintain the continuity of volume that temporarily disappears after migrating to another model or installing a version upgrade.
Edited by Peter Suh
  • Like 2
