Yet Another Jun's Mod
27 minutes ago, jumkey said:
add redpill-qjs-dtb and qjs-runtime
Manually unzip custom.gz to see if there are any missing files
The custum.gz file of 1,386,687 bytes was obtained from the USB stick.
But I can't unzip the file.
Was it created incorrectly during the jun mode build process?
Spoiler
/home/tc/redpill-load/build/1657288480/rd-ds1520p_42218-unpacked /home/tc/redpill-load
hint: Using 'master' as the name for the initial branch. This default branch name
hint: is subject to change. To configure the initial branch name to use in all
hint: of your new repositories, which will suppress this warning, call:
hint:
hint:   git config --global init.defaultBranch <name>
hint:
hint: Names commonly chosen instead of 'master' are 'main', 'trunk' and
hint: 'development'. The just-created branch can be renamed via this command:
hint:
hint:   git branch -m <name>
Initialized empty Git repository in /home/tc/redpill-load/build/1657288480/rd-ds1520p_42218-unpacked/.git/
[master (root-commit) ff57e0f] import ramdisk
 567 files changed, 19339 insertions(+)
 create mode 120000 bin
 create mode 120000 etc.defaults
 create mode 100755 etc/VERSION
 create mode 100644 etc/avahi/avahi-daemon.conf
 create mode 100644 etc/crontab
 create mode 120000 etc/dhclient/ipv4
 create mode 100644 etc/fstab
 create mode 100644 etc/ftpusers
 create mode 100644 etc/group
 create mode 100644 etc/group_desc
 create mode 100644 etc/host.conf
 create mode 100644 etc/hosts
 create mode 100644 etc/hosts.allow
 create mode 100644 etc/hosts.deny
 create mode 100644 etc/inetd.conf
 create mode 100755 etc/mke2fs.conf
 create mode 100644 etc/model.dtb
 create mode 100644 etc/modules.conf
 create mode 100644 etc/motd
 create mode 120000 etc/mtab
 create mode 100644 etc/nsswitch.conf
 create mode 100644 etc/passwd
 create mode 100644 etc/profile
 create mode 100644 etc/protocols
 create mode 100755 etc/rc
 create mode 100755 etc/rc.fan
 create mode 100755 etc/rc.network
 create mode 100755 etc/rc.network_routing
 create mode 100755 etc/rc.scanusbdev
 create mode 100755 etc/rc.subr
 create mode 100644 etc/resolv.conf
 create mode 100644 etc/rpc
 create mode 100644 etc/services
 create mode 100644 etc/shadow
 create mode 100644 etc/shells
 create mode 100755 etc/ssl/certs/ca-certificates.crt
 create mode 100755 etc/synogrinst.sh
 create mode 100755 etc/synoinfo.conf
 create mode 100644 etc/synouser.conf
 create mode 100644 etc/sysconfig/network
 create mode 100644 etc/sysconfig/network-scripts/ifcfg-eth0
 create mode 100644 etc/sysconfig/network-scripts/ifcfg-eth1
 create mode 100644 etc/sysconfig/network-scripts/ifcfg-eth2
 create mode 100644 etc/sysconfig/network-scripts/ifcfg-eth3
 create mode 120000 etc/sysconfig/network-scripts/ifcfg-lo
 create mode 100644 etc/sysconfig/network-scripts/ifcfg-tun
 create mode 100644 etc/sysconfig/networking/ifcfg-lo
 create mode 100644 etc/sysctl.conf
 create mode 100644 etc/termcap
 create mode 120000 init
 create mode 120000 lib
 create mode 120000 lib32
 create mode 120000 lib64
 create mode 120000 linuxrc
 create mode 100755 linuxrc.syno
 create mode 100755 linuxrc.syno.impl
 create mode 100644 root/.profile
 create mode 120000 sbin
 create mode 120000 usr/bin/[
 create mode 120000 usr/bin/[[
 create mode 120000 usr/bin/arch
 create mode 120000 usr/bin/ash
 create mode 120000 usr/bin/basename
 create mode 100755 usr/bin/busybox
 create mode 120000 usr/bin/cat
 create mode 120000 usr/bin/chattr
 create mode 120000 usr/bin/chgrp
 create mode 120000 usr/bin/chmod
 create mode 120000 usr/bin/chown
 create mode 100755 usr/bin/cksum
 create mode 120000 usr/bin/cp
 create mode 100755 usr/bin/curl
 create mode 120000 usr/bin/cut
 create mode 120000 usr/bin/date
 create mode 120000 usr/bin/dd
 create mode 120000 usr/bin/df
 create mode 120000 usr/bin/dirname
 create mode 120000 usr/bin/dmesg
 create mode 120000 usr/bin/dnsdomainname
 create mode 120000 usr/bin/du
 create mode 120000 usr/bin/echo
 create mode 120000 usr/bin/egrep
 create mode 120000 usr/bin/env
 create mode 120000 usr/bin/expr
 create mode 120000 usr/bin/false
 create mode 120000 usr/bin/fgrep
 create mode 120000 usr/bin/free
 create mode 120000 usr/bin/ftpget
 create mode 120000 usr/bin/get_key_value
 create mode 120000 usr/bin/grep
 create mode 120000 usr/bin/gunzip
 create mode 120000 usr/bin/head
 create mode 120000 usr/bin/hostname
 create mode 120000 usr/bin/ipcalc
 create mode 120000 usr/bin/kill
 create mode 120000 usr/bin/killall
 create mode 120000 usr/bin/ln
 create mode 120000 usr/bin/logger
 create mode 120000 usr/bin/login
 create mode 120000 usr/bin/ls
 create mode 120000 usr/bin/lsattr
 create mode 100755 usr/bin/minissdpd
 create mode 120000 usr/bin/mkdir
 create mode 120000 usr/bin/mknod
 create mode 120000 usr/bin/more
 create mode 120000 usr/bin/mount
 create mode 120000 usr/bin/mv
 create mode 100755 usr/bin/nbnsd
 create mode 120000 usr/bin/netstat
 create mode 120000 usr/bin/nslookup
 create mode 120000 usr/bin/ping
 create mode 120000 usr/bin/printf
 create mode 120000 usr/bin/ps
 create mode 120000 usr/bin/pwd
 create mode 120000 usr/bin/resize
 create mode 120000 usr/bin/rm
 create mode 120000 usr/bin/rmdir
 create mode 120000 usr/bin/seq
 create mode 120000 usr/bin/sh
 create mode 120000 usr/bin/sleep
 create mode 120000 usr/bin/sort
 create mode 120000 usr/bin/sync
 create mode 120000 usr/bin/synodd
 create mode 120000 usr/bin/tail
 create mode 120000 usr/bin/tar
 create mode 120000 usr/bin/tee
 create mode 120000 usr/bin/test
 create mode 120000 usr/bin/top
 create mode 120000 usr/bin/touch
 create mode 120000 usr/bin/true
 create mode 120000 usr/bin/umount
 create mode 120000 usr/bin/uname
 create mode 120000 usr/bin/unxz
 create mode 120000 usr/bin/uptime
 create mode 120000 usr/bin/vi
 create mode 120000 usr/bin/wc
 create mode 120000 usr/bin/wget
 create mode 120000 usr/bin/xargs
 create mode 120000 usr/bin/xz
 create mode 120000 usr/bin/xzcat
 create mode 120000 usr/bin/yes
 create mode 120000 usr/bin/zcat
 create mode 100755 usr/lib/firmware/i915/bxt_dmc_ver1_07.bin
 create mode 100755 usr/lib/firmware/i915/glk_dmc_ver1_04.bin
 create mode 120000 usr/lib/i686
 create mode 100755 usr/lib/iptables/libipt_DNAT.so
 create mode 100755 usr/lib/iptables/libipt_SNAT.so
 create mode 100755 usr/lib/ld-2.26.so
 create mode 120000 usr/lib/ld-linux-x86-64.so.2
 create mode 100755 usr/lib/libanl-2.26.so
 create mode 120000 usr/lib/libanl.so.1
 create mode 100644 usr/lib/libavahi-common.so.3
 create mode 100644 usr/lib/libavahi-core.so.7
 create mode 100755 usr/lib/libc-2.26.so
 create mode 120000 usr/lib/libc.so.6
 create mode 100755 usr/lib/libcrypt-2.26.so
 create mode 120000 usr/lib/libcrypt.so.1
 create mode 120000 usr/lib/libcurl.so
 create mode 120000 usr/lib/libcurl.so.4
 create mode 100755 usr/lib/libcurl.so.4.7.0
 create mode 100755 usr/lib/libdl-2.26.so
 create mode 120000 usr/lib/libdl.so.2
 create mode 120000 usr/lib/libexpat.so
 create mode 120000 usr/lib/libexpat.so.1
 create mode 100755 usr/lib/libexpat.so.1.6.11
 create mode 120000 usr/lib/libfdt.so
 create mode 100644 usr/lib/libfdt.so.1
 create mode 100644 usr/lib/libgcc_s.so
 create mode 100644 usr/lib/libgcc_s.so.1
 create mode 120000 usr/lib/libip4tc.so
 create mode 120000 usr/lib/libip4tc.so.2
 create mode 100755 usr/lib/libip4tc.so.2.0.0
 create mode 120000 usr/lib/libip6tc.so
 create mode 120000 usr/lib/libip6tc.so.2
 create mode 100755 usr/lib/libip6tc.so.2.0.0
 create mode 120000 usr/lib/libiptc.so
 create mode 120000 usr/lib/libiptc.so.0
 create mode 100755 usr/lib/libiptc.so.0.0.0
 create mode 100755 usr/lib/libm-2.26.so
 create mode 120000 usr/lib/libm.so.6
 create mode 120000 usr/lib/libmbedcrypto.so
 create mode 100755 usr/lib/libmbedcrypto.so.5
 create mode 120000 usr/lib/libmbedtls.so
 create mode 100755 usr/lib/libmbedtls.so.13
 create mode 120000 usr/lib/libmbedx509.so
 create mode 100755 usr/lib/libmbedx509.so.1
 create mode 120000 usr/lib/libmsgpackc.so
 create mode 120000 usr/lib/libmsgpackc.so.2
 create mode 100755 usr/lib/libmsgpackc.so.2.0.0
 create mode 100755 usr/lib/libmvec-2.26.so
 create mode 120000 usr/lib/libmvec.so.1
 create mode 100755 usr/lib/libnsl-2.26.so
 create mode 120000 usr/lib/libnsl.so.1
 create mode 100755 usr/lib/libnss_dns-2.26.so
 create mode 120000 usr/lib/libnss_dns.so.2
 create mode 100755 usr/lib/libnss_files-2.26.so
 create mode 120000 usr/lib/libnss_files.so.2
 create mode 100755 usr/lib/libpthread-2.26.so
 create mode 120000 usr/lib/libpthread.so.0
 create mode 100755 usr/lib/libresolv-2.26.so
 create mode 120000 usr/lib/libresolv.so.2
 create mode 100755 usr/lib/librt-2.26.so
 create mode 120000 usr/lib/librt.so.1
 create mode 100755 usr/lib/libsodium.so
 create mode 120000 usr/lib/libstdc++.so.6
 create mode 100755 usr/lib/libstdc++.so.6.0.24
 create mode 120000 usr/lib/libsynocodesign-ng-virtual-junior-wins.so
 create mode 100755 usr/lib/libsynocodesign-ng-virtual-junior-wins.so.7
 create mode 100755 usr/lib/libutil-2.26.so
 create mode 120000 usr/lib/libutil.so.1
 create mode 120000 usr/lib/libuuid.so
 create mode 120000 usr/lib/libuuid.so.1
 create mode 100755 usr/lib/libuuid.so.1.3.0
 create mode 120000 usr/lib/libxtables.so
 create mode 120000 usr/lib/libxtables.so.12
 create mode 100755 usr/lib/libxtables.so.12.2.0
 create mode 100644 usr/lib/modules-load.d/70-network-0006-realtek-r8168-driver.conf
 create mode 100644 usr/lib/modules/cdc-acm.ko
 create mode 100644 usr/lib/modules/etxhci-hcd.ko
 create mode 100644 usr/lib/modules/fat.ko
 create mode 100644 usr/lib/modules/grace.ko
 create mode 100644 usr/lib/modules/hid.ko
 create mode 100644 usr/lib/modules/i2c-algo-bit.ko
 create mode 100644 usr/lib/modules/ip6_udp_tunnel.ko
 create mode 100644 usr/lib/modules/ip_tables.ko
 create mode 100644 usr/lib/modules/iptable_nat.ko
 create mode 100644 usr/lib/modules/leds-lp3943.ko
 create mode 100644 usr/lib/modules/lockd.ko
 create mode 100644 usr/lib/modules/nf_conntrack.ko
 create mode 100644 usr/lib/modules/nf_conntrack_ipv4.ko
 create mode 100644 usr/lib/modules/nf_defrag_ipv4.ko
 create mode 100644 usr/lib/modules/nf_nat.ko
 create mode 100644 usr/lib/modules/nf_nat_ipv4.ko
 create mode 100644 usr/lib/modules/nfs.ko
 create mode 100644 usr/lib/modules/nfsv3.ko
 create mode 100644 usr/lib/modules/phy_alloc.ko
 create mode 100644 usr/lib/modules/r8168.ko
 create mode 100644 usr/lib/modules/sunrpc.ko
 create mode 100644 usr/lib/modules/syno_hddmon.ko
 create mode 100644 usr/lib/modules/synobios.ko
 create mode 100644 usr/lib/modules/udp_tunnel.ko
 create mode 100644 usr/lib/modules/usb-common.ko
 create mode 100644 usr/lib/modules/usb-storage.ko
 create mode 100644 usr/lib/modules/usbcore.ko
 create mode 100644 usr/lib/modules/usbhid.ko
 create mode 100644 usr/lib/modules/vfat.ko
 create mode 100644 usr/lib/modules/vxlan.ko
 create mode 100644 usr/lib/modules/x_tables.ko
 create mode 100644 usr/lib/modules/xhci-hcd.ko
 create mode 100644 usr/lib/modules/xhci-pci.ko
 create mode 100644 usr/lib/modules/xt_nat.ko
 create mode 120000 usr/lib64
 create mode 120000 usr/sbin/arp
 create mode 120000 usr/sbin/arping
 create mode 100755 usr/sbin/burnin_test
 create mode 120000 usr/sbin/chroot
 create mode 120000 usr/sbin/dnsd
 create mode 120000 usr/sbin/e2fsck
 create mode 120000 usr/sbin/fdisk
 create mode 120000 usr/sbin/fsck.ext3
 create mode 120000 usr/sbin/fsck.ext4
 create mode 120000 usr/sbin/getty
 create mode 120000 usr/sbin/halt
 create mode 100755 usr/sbin/hotplug
 create mode 120000 usr/sbin/httpd
 create mode 120000 usr/sbin/ifconfig
 create mode 120000 usr/sbin/inetd
 create mode 120000 usr/sbin/init
 create mode 100755 usr/sbin/init.post
 create mode 120000 usr/sbin/insmod
 create mode 120000 usr/sbin/ip
 create mode 120000 usr/sbin/ip6tables
 create mode 120000 usr/sbin/ip6tables-legacy
 create mode 120000 usr/sbin/ip6tables-legacy-restore
 create mode 120000 usr/sbin/ip6tables-legacy-save
 create mode 120000 usr/sbin/ip6tables-restore
 create mode 120000 usr/sbin/ip6tables-save
 create mode 120000 usr/sbin/iptables
 create mode 120000 usr/sbin/iptables-legacy
 create mode 120000 usr/sbin/iptables-legacy-restore
 create mode 120000 usr/sbin/iptables-legacy-save
 create mode 120000 usr/sbin/iptables-restore
 create mode 120000 usr/sbin/iptables-save
 create mode 120000 usr/sbin/klogd
 create mode 120000 usr/sbin/lsmod
 create mode 100755 usr/sbin/mdadm
 create mode 100755 usr/sbin/memtester
 create mode 120000 usr/sbin/mke2fs
 create mode 100755 usr/sbin/mke2fsck
 create mode 120000 usr/sbin/mkfs.ext3
 create mode 120000 usr/sbin/mkfs.ext4
 create mode 120000 usr/sbin/mkswap
 create mode 100755 usr/sbin/nvme
 create mode 120000 usr/sbin/poweroff
 create mode 120000 usr/sbin/raidtool
 create mode 120000 usr/sbin/reboot
 create mode 100755 usr/sbin/remote_command.sh
 create mode 120000 usr/sbin/rmmod
 create mode 120000 usr/sbin/route
 create mode 120000 usr/sbin/sfdisk
 create mode 100755 usr/sbin/socket_client
 create mode 100755 usr/sbin/socket_server
 create mode 100755 usr/sbin/sparted
 create mode 120000 usr/sbin/swapoff
 create mode 120000 usr/sbin/swapon
 create mode 120000 usr/sbin/switch_root
 create mode 100755 usr/sbin/syno_memtester.sh
 create mode 120000 usr/sbin/syslogd
 create mode 120000 usr/sbin/telnetd
 create mode 120000 usr/sbin/udhcpc
 create mode 100755 usr/sbin/xtables-legacy-multi
 create mode 100755 usr/share/udhcpc/default.script
 create mode 120000 usr/syno/bin/findhostd
 create mode 120000 usr/syno/bin/mantool
 create mode 100755 usr/syno/bin/reg_ssdp_service
 create mode 100755 usr/syno/bin/scemd
 create mode 120000 usr/syno/bin/syno_extract_system_patch
 create mode 120000 usr/syno/bin/syno_led_mask_on
 create mode 120000 usr/syno/bin/syno_microp_control
 create mode 100755 usr/syno/bin/syno_poweroff_task
 create mode 120000 usr/syno/bin/syno_pstore_collect
 create mode 120000 usr/syno/bin/syno_slot_mapping
 create mode 120000 usr/syno/bin/syno_swap_ctl
 create mode 120000 usr/syno/bin/synocfgen
 create mode 120000 usr/syno/bin/synocheckpartition
 create mode 120000 usr/syno/bin/synochecksum
 create mode 120000 usr/syno/bin/synocleanpartition
 create mode 120000 usr/syno/bin/synocodesign
 create mode 120000 usr/syno/bin/synodiskport
 create mode 120000 usr/syno/bin/synodiskupdatehclport
 create mode 120000 usr/syno/bin/synogetmaxpartition
 create mode 120000 usr/syno/bin/synohdcfgen
 create mode 120000 usr/syno/bin/synohwctrl
 create mode 120000 usr/syno/bin/synonetseqadj
 create mode 100755 usr/syno/bin/synosearchagent
 create mode 120000 usr/syno/bin/synossdcache
 create mode 120000 usr/syno/bin/synostgcore
 create mode 120000 usr/syno/bin/synoupgrade
 create mode 100644 usr/syno/etc/ncq_off_list
 create mode 100644 usr/syno/etc/pci_vendor_ids.conf
 create mode 100755 usr/syno/etc/rc.d/J01httpd.sh
 create mode 100755 usr/syno/etc/rc.d/J03ssdpd.sh
 create mode 100755 usr/syno/etc/rc.d/J04synoagentregisterd.sh
 create mode 100755 usr/syno/etc/rc.d/J30DisableNCQ.sh
 create mode 100755 usr/syno/etc/rc.d/J80ADTFanControl.sh
 create mode 100755 usr/syno/etc/rc.d/J98nbnsd.sh
 create mode 100755 usr/syno/etc/rc.d/J99avahi.sh
 create mode 100755 usr/syno/hotplug.d/default/default.hotplug
 create mode 120000 usr/syno/hotplug/block.agent
 create mode 100755 usr/syno/hotplug/firmware.agent
 create mode 100755 usr/syno/hotplug/hotplug.functions
 create mode 120000 usr/syno/hotplug/usb.agent
 create mode 100755 usr/syno/hotplug/usb.agent.junior
 create mode 100755 usr/syno/sbin/avahi-daemon
 create mode 100755 usr/syno/sbin/backup_junior_log.sh
 create mode 100755 usr/syno/sbin/bootup-smallupdate.sh
 create mode 100755 usr/syno/sbin/check_root_junior_match.sh
 create mode 100755 usr/syno/sbin/check_rootfs_health.sh
 create mode 100755 usr/syno/sbin/installer.sh
 create mode 100755 usr/syno/sbin/make_system_fs.sh
 create mode 120000 usr/syno/sbin/manutild
 create mode 100755 usr/syno/sbin/reset_root_compatiblie_bit.sh
 create mode 120000 usr/syno/sbin/synoagentregisterd
 create mode 100755 usr/syno/sbin/upgrade.sh
 create mode 100755 usr/syno/share/assemble_system_raid.sh
 create mode 100755 usr/syno/share/autoinstall.sh
 create mode 100755 usr/syno/share/autoinstall/cleanup_rootdevice.sh
 create mode 100755 usr/syno/share/autoinstall/prepare_files.sh
 create mode 100755 usr/syno/share/autoinstall/prepare_files_from_extracted.sh
 create mode 100755 usr/syno/share/autoinstall/prepare_files_from_patch_mnt.sh
 create mode 100755 usr/syno/share/autoinstall/prepare_files_rename.sh
 create mode 100644 usr/syno/share/dsmupdate/decide_rootmnt_datamnt.sh
 create mode 100644 usr/syno/share/dsmupdate/decide_system_partition.sh
 create mode 100644 usr/syno/share/dsmupdate/dsmupdate.subr
 create mode 100755 usr/syno/share/dsmupdate/extract_upgrade_tarballs.sh
 create mode 100644 usr/syno/share/environments.sh
 create mode 100644 usr/syno/share/get_installable_devices.sh
 create mode 100644 usr/syno/share/mkfs.sh
 create mode 100644 usr/syno/share/rootdevice.sh
 create mode 100755 usr/syno/share/synogrinst/grinst-common.sh
 create mode 100644 usr/syno/share/synomemtester/syno_memtester_util.sh
 create mode 100644 usr/syno/share/util.sh
 create mode 100644 usr/syno/web/assets/04c4d99411f46211f875b22774743761.png
 create mode 100644 usr/syno/web/assets/04fb2662509fe724c953ef002b8370a0.png
 create mode 100644 usr/syno/web/assets/057e1d71163cb81f8e5bf2bf9d817f51.svg
 create mode 100644 usr/syno/web/assets/06297c75da79b2043b5d8ded22aa9ddd.png
 create mode 100644 usr/syno/web/assets/09f81f8e0bb4f313a32200d7fbf89143.png
 create mode 100644 usr/syno/web/assets/1066fd4184af341f2b34fea25d720295.png
 create mode 100644 usr/syno/web/assets/10918506d8c833390fe809e8e3da9e46.png
 create mode 100644 usr/syno/web/assets/12c77ec4894a7da175e28f117fe3bff5.png
 create mode 100644 usr/syno/web/assets/1479c43a9b586395fa8a58b2386d5bb6.png
 create mode 100644 usr/syno/web/assets/18e7b4966e26864ce01ef329ad418f6f.png
 create mode 100644 usr/syno/web/assets/1ce3d62f0e64872578d354bdc80fc3c0.png
 create mode 100644 usr/syno/web/assets/1dd49eeaa72e19fb4d56c23753b3b84d.png
 create mode 100644 usr/syno/web/assets/1de815232722c710f26f12946e7be647.png
 create mode 100644 usr/syno/web/assets/224ec4f4d2210b29f95c4cd61dda0c95.preload.png
 create mode 100644 usr/syno/web/assets/2371337078580051d80168cd64fb3ee2.png
 create mode 100644 usr/syno/web/assets/23fa5fc465b3120356a41a0ef1d97718.png
 create mode 100644 usr/syno/web/assets/2536c53f4045e72e7743ea61488cbfe4.png
 create mode 100644 usr/syno/web/assets/2787a7fba33f2cf479adf9c40566a948.png
 create mode 100644 usr/syno/web/assets/30e52bb9ffee656efa379bf0e0529e64.png
 create mode 100644 usr/syno/web/assets/322b327fadf9ffab7e84a963c23ead52.png
 create mode 100644 usr/syno/web/assets/3233a6e695537238e8ed78e871916c7b.png
 create mode 100644 usr/syno/web/assets/3418e9e8bf5852ec15a2d0264ebe579f.png
 create mode 100644 usr/syno/web/assets/36db3eae30b72b7fea7c7062bcb8de74.png
 create mode 100644 usr/syno/web/assets/3904c68eb6bbf1b48049a98e7e439735.png
 create mode 100644 usr/syno/web/assets/3e882190990e069e12132f641a919251.png
 create mode 100644 usr/syno/web/assets/4045646406e24fd9bede45ef0ef14f1c.png
 create mode 100644 usr/syno/web/assets/427ee9d0089241b7c40a6f9e5e2c7a4c.png
 create mode 100644 usr/syno/web/assets/42ab2518741307c010e104204d150e9e.png
 create mode 100644 usr/syno/web/assets/49fe85b581d4198832e640629277e6e3.png
 create mode 100644 usr/syno/web/assets/4c5a44af44c4aa4164507c3bffde83e9.png
 create mode 100644 usr/syno/web/assets/4e79a6bb0b196c849dc1f02fc0a37dd7.png
 create mode 100644 usr/syno/web/assets/508c8c62223be228a0e2fc680aa328bb.png
 create mode 100644 usr/syno/web/assets/5aa8b42f301ec49709a274ce402de781.png
 create mode 100644 usr/syno/web/assets/5d0f1d653efd8f191c79697af160e442.png
 create mode 100644 usr/syno/web/assets/5e82ac965a2fb41f0af06a5638c1bf48.png
 create mode 100644 usr/syno/web/assets/5f537602eeff6aec70f5129d3713e995.png
 create mode 100644 usr/syno/web/assets/628aaba9aced771c27ada58a74480e00.png
 create mode 100644 usr/syno/web/assets/64f33ab9efaa47bdd9be22567508b74e.png
 create mode 100644 usr/syno/web/assets/652c8a6ce457422a1297de3fb67fbc35.png
 create mode 100644 usr/syno/web/assets/676ca886d7b770c0463e7d22680a861d.png
 create mode 100644 usr/syno/web/assets/6813d550c46547038091cf81ed89300f.png
 create mode 100644 usr/syno/web/assets/718b696d39bcbfabe3f5abd9efa831d7.png
 create mode 100644 usr/syno/web/assets/71be476554827c8c40746c207561df61.png
 create mode 100644 usr/syno/web/assets/73560a855e6ae3b225423f1207c5d906.png
 create mode 100644 usr/syno/web/assets/7d751ee48336bc1bff01e3acfe3c8eff.png
 create mode 100644 usr/syno/web/assets/801cb062e3427dfca989330959c12747.png
 create mode 100644 usr/syno/web/assets/8415ba881d15dfd2814d63a73e94ed5d.png
 create mode 100644 usr/syno/web/assets/857e914ade36819c1758237d060ce5d9.png
 create mode 100644 usr/syno/web/assets/86c199aa3683a3f7e6886f50837b8f95.png
 create mode 100644 usr/syno/web/assets/8710c149eda822e2cea65d04294fe3b4.png
 create mode 100644 usr/syno/web/assets/874ad8f22c93f5144798db5b392a7eb2.png
 create mode 100644 usr/syno/web/assets/8763b5769219c0d03f63fd7d2eb4a0ce.png
 create mode 100644 usr/syno/web/assets/89ebc9bce047b4f6d62a4c7353dab343.png
 create mode 100644 usr/syno/web/assets/8f99cb4a84f808263737a9801cc59763.png
 create mode 100644 usr/syno/web/assets/904030103b4c9b432fffa743680347ba.png
 create mode 100644 usr/syno/web/assets/9135693d6266ca5497970e4b5364da96.png
 create mode 100644 usr/syno/web/assets/914c29754b1e299d57eaeaf288b64343.png
 create mode 100644 usr/syno/web/assets/93ae4193127af4f1ad5253fe2e6f9bea.png
 create mode 100644 usr/syno/web/assets/95a9615f74d941642d8125d6caa0639f.png
 create mode 100644 usr/syno/web/assets/9ae4429e4979bbf5fa0fad8cc00b368a.png
 create mode 100644 usr/syno/web/assets/9b0f1457b0abb63b9c9bdccc8033e8fb.png
 create mode 100644 usr/syno/web/assets/a3132358f1faea027ca1625099f9f7dc.png
 create mode 100644 usr/syno/web/assets/a3b3b91037e09b0ffc8ec1ec698dfae1.png
 create mode 100644 usr/syno/web/assets/a8923f1edf07de43789141d1e3ec82ec.png
 create mode 100644 usr/syno/web/assets/a900fb59a3e03e016083a018cf32f53b.png
 create mode 100644 usr/syno/web/assets/a924f13e48938e91a51b01a8853c77fc.png
 create mode 100644 usr/syno/web/assets/acb27906627a2e78a2eaf77f29f008da.png
 create mode 100644 usr/syno/web/assets/b02f9e3f07196e00365ab151b65b8ab9.png
 create mode 100644 usr/syno/web/assets/b1bb2ad9cb6b7e7093832e990d6c9bf7.png
 create mode 100644 usr/syno/web/assets/b705dbd6f0a024ec89a772f117d03d35.png
 create mode 100644 usr/syno/web/assets/b8de195a71326592fe5997f0f6a4ec2e.png
 create mode 100644 usr/syno/web/assets/bd313f935fb44a57c6860fa43665267f.png
 create mode 100644 usr/syno/web/assets/c08f13c80d123b9c8e9f45e05d4b8bb1.png
 create mode 100644 usr/syno/web/assets/c2e4f340a3a6d07554a17aa90b0ae54f.png
 create mode 100644 usr/syno/web/assets/c37a6ee9d094bab66790ad3be81e5039.png
 create mode 100644 usr/syno/web/assets/c413499a8a4598546cc4177658703408.png
 create mode 100644 usr/syno/web/assets/c55d6006fefa7365d1384970f1e283ad.png
 create mode 100644 usr/syno/web/assets/c86633b5a914a5ef73b62bd92c0e35ed.png
 create mode 100644 usr/syno/web/assets/c88b84289f17b0e81c1988491fc25c84.png
 create mode 100644 usr/syno/web/assets/cc037ab2a9c4ebecfe92efae2d6de93e.png
 create mode 100644 usr/syno/web/assets/cc68fa85fa4bf1e420cffc0f1859bb95.preload.png
 create mode 100644 usr/syno/web/assets/ccb6b11702e028c313fb956b9de336fd.png
 create mode 100644 usr/syno/web/assets/d1630775688715d1b30600c340017c18.png
 create mode 100644 usr/syno/web/assets/d1ab84f3d2153853b07ea7803b8343ed.png
 create mode 100644 usr/syno/web/assets/d5dbff884dc200e502ea46e943f54957.png
 create mode 100644 usr/syno/web/assets/d8b258b1d95b0775869166bf9c929920.png
 create mode 100644 usr/syno/web/assets/d9f44f5faac1e5afc7dbf39389585d5a.png
 create mode 100644 usr/syno/web/assets/dc799651418d0f2226fd429216cef175.png
 create mode 100644 usr/syno/web/assets/dd31e5257bf9b65e1e50e8ff93879d78.png
 create mode 100644 usr/syno/web/assets/ded275e6e855bdb421f9aed96433c5de.png
 create mode 100644 usr/syno/web/assets/e1722eaca6356b2af4425e49a3c8a5b1.png
 create mode 100644 usr/syno/web/assets/e1be3f1a55c03c3e395c0afa27f3d3df.png
 create mode 100644 usr/syno/web/assets/e421cf8b22055046ac03f4bc77898524.png
 create mode 100644 usr/syno/web/assets/e5f3ef585da256aab17e075446261e6c.png
 create mode 100644 usr/syno/web/assets/e8104ebeb834b453e4c82264dc7636c6.png
 create mode 100644 usr/syno/web/assets/e823129f2cdb1a9d18dbfce447a8b977.png
 create mode 100644 usr/syno/web/assets/e8cd756c231384653a617238d1e779ae.png
 create mode 100644 usr/syno/web/assets/e9087ed3a24f4f1e4f30d52ce4123c82.png
 create mode 100644 usr/syno/web/assets/ee16afb3e2aa1f786e2583c3e947c352.png
 create mode 100644 usr/syno/web/assets/f0b98932e1c85f73fea670a64e3200d5.png
 create mode 100644 usr/syno/web/assets/f14250b527a42d4e0676943aa51bf1ed.png
 create mode 100644 usr/syno/web/assets/f1cbdb19756532907cf317bd5e5f93da.png
 create mode 100644 usr/syno/web/assets/f33f3e7dd5004d485e06539a602afb8e.png
 create mode 100644 usr/syno/web/assets/f63a1e9e584774bb47c4474edff1791b.png
 create mode 100644 usr/syno/web/assets/f87bfa5184c3fbe48d7a256d64b29328.png
 create mode 100644 usr/syno/web/assets/fa2c83ee1e071befa729f1cce7ec3984.png
 create mode 100644 usr/syno/web/assets/fd95b7fa22cf11250e5aaa818dda9d42.png
 create mode 100644 usr/syno/web/assets/fee495dc9f7d0f6957d7caa2c4d4d06a.svg
 create mode 100644 usr/syno/web/favicon.png
 create mode 100644 usr/syno/web/httpd.conf
 create mode 100755 usr/syno/web/images/favicon.png
 create mode 100644 usr/syno/web/main.js
 create mode 100644 usr/syno/web/main.min.css
 create mode 100644 usr/syno/web/texts/installer/chs/strings
 create mode 100644 usr/syno/web/texts/installer/cht/strings
 create mode 100644 usr/syno/web/texts/installer/csy/strings
 create mode 100644 usr/syno/web/texts/installer/dan/strings
 create mode 100644 usr/syno/web/texts/installer/enu/strings
 create mode 100644 usr/syno/web/texts/installer/fre/strings
 create mode 100644 usr/syno/web/texts/installer/ger/strings
 create mode 100644 usr/syno/web/texts/installer/hun/strings
 create mode 100644 usr/syno/web/texts/installer/ita/strings
 create mode 100644 usr/syno/web/texts/installer/jpn/strings
 create mode 100644 usr/syno/web/texts/installer/krn/strings
 create mode 100644 usr/syno/web/texts/installer/nld/strings
 create mode 100644 usr/syno/web/texts/installer/nor/strings
 create mode 100644 usr/syno/web/texts/installer/plk/strings
 create mode 100644 usr/syno/web/texts/installer/ptb/strings
 create mode 100644 usr/syno/web/texts/installer/ptg/strings
 create mode 100644 usr/syno/web/texts/installer/rus/strings
 create mode 100644 usr/syno/web/texts/installer/spn/strings
 create mode 100644 usr/syno/web/texts/installer/sve/strings
 create mode 100644 usr/syno/web/texts/installer/tha/strings
 create mode 100644 usr/syno/web/texts/installer/trk/strings
 create mode 100644 usr/syno/web/texts/jslib/chs/strings
 create mode 100644 usr/syno/web/texts/jslib/cht/strings
 create mode 100644 usr/syno/web/texts/jslib/csy/strings
 create mode 100644 usr/syno/web/texts/jslib/dan/strings
 create mode 100644 usr/syno/web/texts/jslib/enu/strings
 create mode 100644 usr/syno/web/texts/jslib/fre/strings
 create mode 100644 usr/syno/web/texts/jslib/ger/strings
 create mode 100644 usr/syno/web/texts/jslib/hun/strings
 create mode 100644 usr/syno/web/texts/jslib/ita/strings
 create mode 100644 usr/syno/web/texts/jslib/jpn/strings
 create mode 100644 usr/syno/web/texts/jslib/krn/strings
 create mode 100644 usr/syno/web/texts/jslib/nld/strings
 create mode 100644 usr/syno/web/texts/jslib/nor/strings
 create mode 100644 usr/syno/web/texts/jslib/plk/strings
 create mode 100644 usr/syno/web/texts/jslib/ptb/strings
 create mode 100644 usr/syno/web/texts/jslib/ptg/strings
 create mode 100644 usr/syno/web/texts/jslib/rus/strings
 create mode 100644 usr/syno/web/texts/jslib/spn/strings
 create mode 100644 usr/syno/web/texts/jslib/sve/strings
 create mode 100644 usr/syno/web/texts/jslib/tha/strings
 create mode 100644 usr/syno/web/texts/jslib/trk/strings
 create mode 100644 usr/syno/web/web_index.html
 create mode 120000 usr/syno/web/webman/clean_button_flags.cgi
 create mode 100755 usr/syno/web/webman/env.cgi
 create mode 100755 usr/syno/web/webman/get_eula.cgi
 create mode 100755 usr/syno/web/webman/get_install_progress.cgi
 create mode 100755 usr/syno/web/webman/get_state.cgi
 create mode 100755 usr/syno/web/webman/get_state_dual.cgi
 create mode 100755 usr/syno/web/webman/index.cgi
 create mode 120000 usr/syno/web/webman/info.cgi
 create mode 100755 usr/syno/web/webman/inform_browser_ts.cgi
 create mode 120000 usr/syno/web/webman/install.cgi
 create mode 120000 usr/syno/web/webman/lock_check.cgi
 create mode 100755 usr/syno/web/webman/reboot.cgi
 create mode 120000 usr/syno/web/webman/recover.cgi
 create mode 120000 usr/syno/web/webman/search.cgi
 create mode 120000 usr/syno/web/webman/search_result.cgi
 create mode 120000 usr/syno/web/webman/session.cgi
 create mode 120000 usr/syno/web/webman/start_telnet.cgi
 create mode 100755 usr/syno/web/webman/uistring.cgi
 create mode 100755 usr/syno/web/webman/update_hcl.cgi
 create mode 100644 usr/syno/web_rd/httpd_rd.conf
 create mode 100644 usr/syno/web_rd/index.html
 create mode 100644 var/lib/disk-compatibility/ds1520+_host_v7.db
 create mode 100644 var/lib/disk-compatibility/ds1520+_host_v7.version
 create mode 100644 var/lib/disk-compatibility/eunit_rule.db
 create mode 100644 var/lib/disk-compatibility/eunit_rule.version
 create mode 100644 var/lib/disk-compatibility/host_rule.db
 create mode 100644 var/lib/disk-compatibility/host_rule.version
 create mode 120000 var/lock
 create mode 120000 var/run
[#] Apply patches to /home/tc/redpill-load/build/1657288480/rd-ds1520p_42218-unpacked... [OK]
[#] Patching config files in ramdisk... [OK]
[#] Adding OS config patching... [OK]
[#] Bundling extensions... [#] Checking runtime for required tools... [OK]
[#] Dumping ds1520p_42218 platform extensions to /home/tc/redpill-load/build/1657288480/custom-initrd/exts... [OK]
[#] Packing custom ramdisk layer to /home/tc/redpill-load/build/1657288480/custom.gz... 1+0 records in
1+0 records out
64 bytes copied, 0.000108613 s, 589 kB/s
[OK]
custom.gz
Edited by Peter Suh
  jun mode building log (Hide contents)
hint:
hint:
hint:
1+0 records out
[OK]
chmod +x config/_common/jun/usr/bin/patch
no change.
The phenomenon of not being able to execute exec.sh seems to be the same.
As you said, chmod is modified and reflected on github
This is the result of building using this load again.
When is this patch file used?
The init and jun.patch files are also in an unexecutable chmod state.
Shall we change both files as well?
SynologyNAS> cat linuxrc.syno.log
START /linuxrc.syno.impl
'/etc.defaults/model.dtb' -> '/var/run/model.dtb'
Insert basic USB modules...
:: Loading module usb-common ... [  OK  ]
:: Loading module usbcore ... [  OK  ]
:: Loading module xhci-hcd ... [  OK  ]
:: Loading module xhci-pci ... [  OK  ]
Insert net driver(Mindspeed only)...
Starting /usr/syno/bin/synocfgen...
/usr/syno/bin/synocfgen returns 0
Exit on error [1] DISK NOT INSTALLED...
Sat Jul  9 08:10:53 UTC 2022
none /sys/kernel/debug debugfs rw,relatime 0 0
Edited by Peter Suh
4 minutes ago, Peter Suh said:
no change.
cat linuxrc.syno.impl | grep "exts"
Check if linuxrc.syno.impl has been patched correctly
2 minutes ago, jumkey said:
/bin/patch --no-backup-if-mismatch -p1 < /etc/jun.patch
SynologyNAS> /bin/patch --no-backup-if-mismatch -p1 < /etc/jun.patch
patching file etc/passwd
patching file etc/synoinfo.conf
patching file linuxrc.syno.impl
patching file usr/sbin/init.post
SynologyNAS>
SynologyNAS> cat linuxrc.syno.impl | grep "exts"
(/bin/sh /exts/exec.sh load_kmods && /bin/sh /exts/exec.sh on_boot_scripts && echo "Extensions processed") || Exit 99 "rp ext init exec failure"
Edited by Peter Suh
SynologyNAS>
12 minutes ago, jumkey said:
Try it, the whole process should be clear
Adjust only the init file to be executable with chmod, as shown below
exec.sh was executed normally.
Thank you very much.
Finally, I met a 57% file corruption message during the DSM installation process.
I think boot-wait is interfering, so I'll delete it and try again.
Spoiler
:: Loading module usb-storage ... [  OK  ]
:: Loading kernel modules from extensions ...
Loading kmod #0 "e1000e.ko" for PeterSuh-Q3.e1000e (args: )
Loading kmod #0 "mii.ko" for PeterSuh-Q3.r8169 (args: )
Loading kmod #1 "r8169.ko" for PeterSuh-Q3.r8169 (args: )
Checking if kmods for thethorgroup.virtio should run using check-virtio.sh script
Checking for VirtIO
*No* VirtIO hypervisor detected
NOT loading kmods for thethorgroup.virtio
:: Loading kernel modules from extensions ... [  OK  ]
:: Executing "on_boot" custom scripts ...
Running "check-e1000e.sh" for PeterSuh-Q3.e1000e->on_boot
Loading module e1000e -> Module e1000e loaded succesfully
Ran "check-e1000e.sh" for PeterSuh-Q3.e1000e->on_boot - exit=0
Running "check-r8169.sh" for PeterSuh-Q3.r8169->on_boot
Loading module r8169 -> Module r8169 loaded succesfully
Ran "check-r8169.sh" for PeterSuh-Q3.r8169->on_boot - exit=0
Running "install_rd.sh" for jumkey.qjs.000->on_boot
qjs
hello world from qjs
Ran "install_rd.sh" for jumkey.qjs.000->on_boot - exit=0
Running "install_rd.sh" for jumkey.qjs.dtb->on_boot
dtc
dts.js
ds1520p_42218
dtb file not exists for this platform!!!
output.dts: Warning (unit_address_vs_reg): /DX517/pmp_slot@1: node has a unit name, but no reg or ranges property
output.dts: Warning (unit_address_vs_reg): /DX517/pmp_slot@2: node has a unit name, but no reg or ranges property
output.dts: Warning (unit_address_vs_reg): /DX517/pmp_slot@3: node has a unit name, but no reg or ranges property
output.dts: Warning (unit_address_vs_reg): /DX517/pmp_slot@4: node has a unit name, but no reg or ranges property
output.dts: Warning (unit_address_vs_reg): /DX517/pmp_slot@5: node has a unit name, but no reg or ranges property
output.dts: Warning (unit_address_vs_reg): /internal_slot@1: node has a unit name, but no reg or ranges property
output.dts: Warning (unit_address_vs_reg): /internal_slot@2: node has a unit name, but no reg or ranges property
output.dts: Warning (unit_address_vs_reg): /internal_slot@3: node has a unit name, but no reg or ranges property
output.dts: Warning (unit_address_vs_reg): /internal_slot@4: node has a unit name, but no reg or ranges property
output.dts: Warning (unit_address_vs_reg): /internal_slot@5: node has a unit name, but no reg or ranges property
output.dts: Warning (unit_address_vs_reg): /esata_port@1: node has a unit name, but no reg or ranges property
output.dts: Warning (unit_address_vs_reg): /esata_port@2: node has a unit name, but no reg or ranges property
output.dts: Warning (unit_address_vs_reg): /usb_slot@1: node has a unit name, but no reg or ranges property
output.dts: Warning (unit_address_vs_reg): /usb_slot@2: node has a unit name, but no reg or ranges property
output.dts: Warning (unit_address_vs_reg): /nvme_slot@1: node has a unit name, but no reg or ranges property
output.dts: Warning (unit_address_vs_reg): /nvme_slot@2: node has a unit name, but no reg or ranges property
start processing path:/sys/block/.
unsupported
start processing path:/sys/block/..
unsupported
start processing path:/sys/block/ram0
unsupported
start processing path:/sys/block/ram1
unsupported
start processing path:/sys/block/ram2
unsupported
start processing path:/sys/block/ram3
unsupported
start processing path:/sys/block/ram4
unsupported
start processing path:/sys/block/ram5
unsupported
start processing path:/sys/block/ram6
unsupported
start processing path:/sys/block/ram7
unsupported
start processing path:/sys/block/ram8
unsupported
start processing path:/sys/block/ram9
unsupported
start processing path:/sys/block/ram10
unsupported
start processing path:/sys/block/ram11
unsupported
start processing path:/sys/block/ram12
unsupported
start processing path:/sys/block/ram13
unsupported
start processing path:/sys/block/ram14
unsupported
start processing path:/sys/block/ram15
unsupported
start processing path:/sys/block/sata1
pciepath = 00:1f.2
ata_port_no = 3
driver = ahci
modify path /internal_slot@1/ahci/pcie_root
[ok] value "00:1f.2"
modify path /internal_slot@1/ahci/ata_port
[ok] value <0x03>
output.dts.out:15.14-20.5: Warning (unit_address_vs_reg): /DX517/pmp_slot@1: node has a unit name, but no reg or ranges property
output.dts.out:21.14-26.5: Warning (unit_address_vs_reg): /DX517/pmp_slot@2: node has a unit name, but no reg or ranges property
output.dts.out:27.14-32.5: Warning (unit_address_vs_reg): /DX517/pmp_slot@3: node has a unit name, but no reg or ranges property
output.dts.out:33.14-38.5: Warning (unit_address_vs_reg): /DX517/pmp_slot@4: node has a unit name, but no reg or ranges property
output.dts.out:39.14-44.5: Warning (unit_address_vs_reg): /DX517/pmp_slot@5: node has a unit name, but no reg or ranges property
output.dts.out:46.18-61.4: Warning (unit_address_vs_reg): /internal_slot@1: node has a unit name, but no reg or ranges property
output.dts.out:62.18-77.4: Warning (unit_address_vs_reg): /internal_slot@2: node has a unit name, but no reg or ranges property
output.dts.out:78.18-93.4: Warning (unit_address_vs_reg): /internal_slot@3: node has a unit name, but no reg or ranges property
output.dts.out:94.18-109.4: Warning (unit_address_vs_reg): /internal_slot@4: node has a unit name, but no reg or ranges property
output.dts.out:110.18-125.4: Warning (unit_address_vs_reg): /internal_slot@5: node has a unit name, but no reg or ranges property
output.dts.out:126.15-131.4: Warning (unit_address_vs_reg): /esata_port@1: node has a unit name, but no reg or ranges property
output.dts.out:132.15-137.4: Warning (unit_address_vs_reg): /esata_port@2: node has a unit name, but no reg or ranges property
output.dts.out:138.13-148.4: Warning (unit_address_vs_reg): /usb_slot@1: node has a unit name, but no reg or ranges property
output.dts.out:149.13-159.4: Warning (unit_address_vs_reg): /usb_slot@2: node has a unit name, but no reg or ranges property
output.dts.out:160.14-163.4: Warning (unit_address_vs_reg): /nvme_slot@1: node has a unit name, but no reg or ranges property
output.dts.out:164.14-167.4: Warning (unit_address_vs_reg): /nvme_slot@2: node has a unit name, but no reg or ranges property
'model_r2.dtb' -> '/etc.defaults/model.dtb'
'model_r2.dtb' -> '/var/run/model.dtb'
Ran "install_rd.sh" for jumkey.qjs.dtb->on_boot - exit=0
Running "install_rd.sh" for redpill-misc->on_boot
Starting ttyd, listening on port: 7681
Ran "install_rd.sh" for redpill-misc->on_boot - exit=0
Running "boot-wait.sh" for thethorgroup.boot-wait->on_boot
Still waiting for boot device (waited 1 of 30 seconds)
Still waiting for boot device (waited 2 of 30 seconds)
Still waiting for boot device (waited 3 of 30 seconds)
Still waiting for boot device (waited 4 of 30 seconds)
Still waiting for boot device (waited 5 of 30 seconds)
Still waiting for boot device (waited 6 of 30 seconds)
Still waiting for boot device (waited 7 of 30 seconds)
Still waiting for boot device (waited 8 of 30 seconds)
Still waiting for boot device (waited 9 of 30 seconds)
Still waiting for boot device (waited 10 of 30 seconds)
Still waiting for boot device (waited 11 of 30 seconds)
Still waiting for boot device (waited 12 of 30 seconds)
Still waiting for boot device (waited 13 of 30 seconds)
Still waiting for boot device (waited 14 of 30 seconds)
Still waiting for boot device (waited 15 of 30 seconds)
Still waiting for boot device (waited 16 of 30 seconds)
Still waiting for boot device (waited 17 of 30 seconds)
Still waiting for boot device (waited 18 of 30 seconds)
Still waiting for boot device (waited 19 of 30 seconds)
Still waiting for boot device (waited 20 of 30 seconds)
Still waiting for boot device (waited 21 of 30 seconds)
Still waiting for boot device (waited 22 of 30 seconds)
Still waiting for boot device (waited 23 of 30 seconds)
Still waiting for boot device (waited 24 of 30 seconds)
Still waiting for boot device (waited 25 of 30 seconds)
Still waiting for boot device (waited 26 of 30 seconds)
Still waiting for boot device (waited 27 of 30 seconds)
Still waiting for boot device (waited 28 of 30 seconds)
Still waiting for boot device (waited 29 of 30 seconds)
Still waiting for boot device (waited 30 of 30 seconds)
ERROR: Timeout waiting for /dev/synoboot device to appear.
Most likely your vid/pid configuration is not correct, or you don't have drivers needed for your USB/SATA controller
========== BEGIN DUMP OF ALL PARTITIONS DETECTED ===========
/dev/usb1p1                2048          198655          196608  83
/dev/usb1p2              198656          352255          153600  83
/dev/usb1p3              352256        61739007        61386752  83
/dev/sata1p1               2048         4982527         4980480  fd
/dev/sata1p2            4982528         9176831         4194304  fd
========== END OF DUMP OF ALL PARTITIONS DETECTED ==========
Ran "boot-wait.sh" for thethorgroup.boot-wait->on_boot - exit=1
ERROR: Some of the scripts failed! See above for any with exit != 0
:: Executing "on_boot" custom scripts ... [  OK  ]
Exit on error [99] rp ext init exec failure...
Sat Jul  9 08:46:17 UTC 2022
There is no /dev/synoboot partition, you need to confirm the value of pid vid or satadom
@jumkey
Today I add the FS2500 model based on v1000.
However, everything is fine, but the last part of dynamically mapping the found disk to the dts file is an error.
As you can see in the sample, the FS2500 uses a pattern value of mv14xx instead of ahci, phy instead of ata_port.
Can you include this new pattern in the dtb patch utility as well?
Perhaps this file is an out.dts file with only the ahci pattern.
https://github.com/PeterSuh-Q3/redpill-load/blob/master/redpill-qjs-dtb/src/dts-js/out.dts
SynologyNAS> cat output.dts.out
/dts-v1/;
        compatible = "Synology";
        model = "synology_v1000_fs2500";
        version = <0x01>;
        syno_hdd_powerup_seq = "true";
        syno_smbus_hdd_type = "microp";
        syno_smbus_hdd_adapter = <0x01>;
        syno_smbus_hdd_address = <0x47>;
        syno_cmos_reg_secure_flash = <0xe0>;
        syno_cmos_reg_secure_boot = <0xe2>;
        syno_uart_logout_gpio = <0x07 0x01>;
        internal_slot@1 {
                protocol_type = "sata";
                led_type = "1475";
                mv14xx {
                        pcie_root = "00:01.1,00.0";
                        phy = <0x00>;
        internal_slot@2 {
                led_type = "1475";
                mv14xx {
                        phy = <0x01>;
        internal_slot@3 {
                led_type = "1475";
                mv14xx {
                        phy = <0x02>;
        internal_slot@4 {
                led_type = "1475";
                mv14xx {
                        phy = <0x03>;
        internal_slot@5 {
                led_type = "1475";
                mv14xx {
                        phy = <0x04>;
        internal_slot@6 {
                led_type = "1475";
                mv14xx {
                        phy = <0x05>;
        internal_slot@7 {
                led_type = "1475";
                mv14xx {
                        phy = <0x06>;
        internal_slot@8 {
                led_type = "1475";
                mv14xx {
                        phy = <0x07>;
        internal_slot@9 {
                led_type = "1475";
                mv14xx {
                        phy = <0x08>;
        internal_slot@10 {
                led_type = "1475";
                mv14xx {
                        phy = <0x09>;
        internal_slot@11 {
                led_type = "1475";
                mv14xx {
                        phy = <0x0a>;
        internal_slot@12 {
                led_type = "1475";
                mv14xx {
                        phy = <0x0b>;
        pcie_slot@1 {
                pcie_root = "00:01.2";
        usb_slot@1 {
                vbus {
                        syno_gpio = <0x2a 0x01>;
                usb2 {
                        usb_port = "1-2";
                usb3 {
                        usb_port = "2-2";
        usb_slot@2 {
                vbus {
                        syno_gpio = <0x0b 0x01>;
                usb2 {
                        usb_port = "1-3";
                usb3 {
                        usb_port = "2-3";
Edited by Peter Suh
1 hour ago, Peter Suh said:
@jumkey
/dts-v1/;
        version = <0x01>;
        internal_slot@1 {
                led_type = "1475";
                mv14xx {
                        phy = <0x00>;
        internal_slot@2 {
                led_type = "1475";
                mv14xx {
                        phy = <0x01>;
        internal_slot@3 {
                led_type = "1475";
                mv14xx {
                        phy = <0x02>;
        internal_slot@4 {
                led_type = "1475";
                mv14xx {
                        phy = <0x03>;
        internal_slot@5 {
                led_type = "1475";
                mv14xx {
                        phy = <0x04>;
        internal_slot@6 {
                led_type = "1475";
                mv14xx {
                        phy = <0x05>;
        internal_slot@7 {
                led_type = "1475";
                mv14xx {
                        phy = <0x06>;
        internal_slot@8 {
                led_type = "1475";
                mv14xx {
                        phy = <0x07>;
        internal_slot@9 {
                led_type = "1475";
                mv14xx {
                        phy = <0x08>;
        internal_slot@10 {
                led_type = "1475";
                mv14xx {
                        phy = <0x09>;
        internal_slot@11 {
                led_type = "1475";
                mv14xx {
                        phy = <0x0a>;
        internal_slot@12 {
                led_type = "1475";
                mv14xx {
                        phy = <0x0b>;
        pcie_slot@1 {
        usb_slot@1 {
                vbus {
                usb2 {
                        usb_port = "1-2";
                usb3 {
                        usb_port = "2-2";
        usb_slot@2 {
                vbus {
                usb2 {
                        usb_port = "1-3";
                usb3 {
                        usb_port = "2-3";
Can you provide the content of the syno_block_info file?
@jumkey
Brought back information as you wish.
SynologyNAS> ls /sys/block/*/device/syno_block_info
/sys/block/sata1/device/syno_block_info     /sys/block/sata2/device/syno_block_info     /sys/block/sata3/device/syno_block_info     /sys/block/synoboot/device/syno_block_info
SynologyNAS> cat /sys/block/*/device/syno_block_info
pciepath=00:1f.2
ata_port_no=0
driver=ahci
pciepath=00:1f.2
ata_port_no=1
driver=ahci
pciepath=00:1f.2
ata_port_no=3
driver=ahci
Edited by Peter Suh
On 6/22/2022 at 6:36 PM, Peter Suh said:
The DS920+ recommended 4 ports
As Dolbycat tested, there is no problem with operation even if you increase it to six.
I increased the maximum to 16 and changed it to be available.
So, on dtc DS920(4 port)+, DS1621+(6 port) Jun mode,
If you use the dynamic dtb mapping feature with the jumkey option, we have implemented it to extend to 16 ports so that automatic mapping is recognized.
"Jumkey.qjs.dtb" ext has been modified a little to force the use of the dtb file for 16 ports.
If you want to use the dts file manually, you can download it by referring to my GitHub.
https://github.com/PeterSuh-Q3/tinycore-redpill
After downloading and installing as shown below,
Build the load again
curl --location "https://github.com/PeterSuh-Q3/tinycore-redpill/raw/main/my.sh.gz" --output my.sh.gz; tar -zxvf my.sh.gz;
./my.sh DS920+J jumkey noclean
./my.sh DS1621+J jumkey noclean
Use the ll command to check if the model.dtb file is in the list
ll /home/tc/redpill-load/custom/extensions/jumkey.qjs.dtb/ds920p_42218
ll /home/tc/redpill-load/custom/extensions/jumkey.qjs.dtb/ds1621p_42218
If you check once again whether the script (spoiler) below looks like the one I modified with the cat command, it will definitely be applied.
cat /home/tc/redpill-load/custom/extensions/jumkey.qjs.dtb/ds920p_42218/install_rd.sh
cat /home/tc/redpill-load/custom/extensions/jumkey.qjs.dtb/ds1621p_42218/install_rd.sh
  install_rd.sh (Hide contents)
#!/bin/sh
tar -zxvf patch.tar.gz
# install dtc
chmod +x dtc
cp dtc /usr/sbin/dtc
# copy 16 ports dts file to /etc.defaults
#echo $PLATFORM_ID
if [ "${PLATFORM_ID}" = "ds920p_42218" ]; then
  echo "copy DS920+'s 16 ports ds920p_16ports.dts to /etc.defaults"
  ./dtc -I dts -O dtb -o model.dtb ds920p_16ports.dts
  cp -vf model.dtb /etc.defaults/model.dtb
elif [ "${PLATFORM_ID}" = "ds1621p_42218" ]; then
  echo "copy DS1621+'s 16 ports ds1621p_16ports.dts to /etc.defaults"
  ./dtc -I dts -O dtb -o model.dtb ds1621p_16ports.dts
fi
# copy file
if [ ! -f model_${PLATFORM_ID%%_*}.dtb ]; then
  # Dynamic generation
  ./dtc -I dtb -O dts -o output.dts /etc.defaults/model.dtb
  qjs --std ./dts.js output.dts output.dts.out
  if [ $? -ne 0 ]; then
    echo "auto generated dts file is broken"
    exit 0
  fi
  ./dtc -I dts -O dtb -o model_r2.dtb output.dts.out
  cp -vf model_r2.dtb /etc.defaults/model.dtb
  cp -vf model_r2.dtb /var/run/model.dtb
else
  cp -vf model_${PLATFORM_ID%%_*}.dtb /etc.defaults/model.dtb
  cp -vf model_${PLATFORM_ID%%_*}.dtb /var/run/model.dtb
fi
I've installed up to 14 discs.
6 built-in sata
I used the following product, external 8 ports (Marvel 88SE9215 chip 4 ports + ASM1166 chip 2 ports [unrecognized]) X2.
https://ko.aliexpress.com/item/33016481933.html
73666528_2022-06-2211_55_21.thumb.png.94ed85b4f25dd3591b2ee43aa0a21854.png1079462593_2022-06-2211_55_42.thumb.png.6a364015ada93385724d8beea7f159d1.png377185929_2022-06-231_26_53.thumb.png.f316fecc687d3a20c76951c93b2f553d.png
Hey Peter, I need some help. I'm using Marvell 88se9215 4 x SATA 6Gb/s Host Controller. I can see only 2 ports out of four. Here my results, from post #203 to post #212. Any idea?
yeah... I'm interested as well as I've just bout a Marvell controller with 6 ports and I'm planning to add it to my Xpenology  DS918+ (see my signature). If there is a way to mod jumkey.qjs.dtb file for DS918 in order to correctly see all the ports of Marvell controllers would be very nice!
@giacomoleopardo
I am also using a 6 port SATA expansion card from the Marvell chipset similar to yours.
I bought the following products from aliexpress.
https://www.aliexpress.com/item/33016481933.html?spm=a2g0s.9042311.0.0.77174c4dEGhsZZ&gatewayAdapt=glo2kor
It will be helpful if you tell me the link where you bought it.
In my case, only 4 ports out of the above 6 ports are marked as Marvell chipset.
Some users said that the other 2 ports are ASM chipsets.
But I couldn't find the exact information.
In Linux, it is marked as such, but if a disk is installed in the remaining ports 5 and 6
Ports 3 and 4 do not work.
3, 4, 5, 6 showed the same result as dividing the two ports.
I don't know which Synology model you have installed Redpill on, but
I'm not sure if that's the correct solution.
Consider switching to DS920+ or DS1621+ with DTC support.
If you do not use only the HBA card, you may be able to use all 4 ports due to the new port mapping method.
I am currently using the none Device Tree model DS3622xs+.
Edited by Peter Suh
The DS918+ redpill-qjs-dtb ext you want is configured in my repo below.
However, it is not clear whether DS918+ is a dtc supported model.
You can find the model.dtb file in /etc.defaults , but that doesn't mean
It doesn't seem to be a device tree support model.
You can try it, but it may behave differently than expected.
https://github.com/PeterSuh-Q3/redpill-load/blob/master/redpill-qjs-dtb/rpext-index.json
And, we do not recommend the Marvell chipset 6 port controller you are referring to on Ali Express.
All 6 ports are not working.
This is the same place of purchase as the link I mentioned above.
Edited by Peter Suh
This is my pci-e card: 4 ports only
https://www.aliexpress.com/item/32905652066.html?spm=a2g0o.order_list.0.0.c5253696Uag58S&gatewayAdapt=glo2ita
918+
Edited by giacomoleopardo
42 minutes ago, giacomoleopardo said:
If you compare the two cards, are the model numbers or part numbers similar?
Probably two models made by the same manufacturer, my guess.
So it seems that there is a phenomenon similar to the problem I am having.
According to IG-88's recommendation, in REDPILL, an expansion card using only ASMEDIA chips seems to be more compatible.
The first thing you can try is to switch to the DTC model, but I don't think this method is recommended either.
743057878_2022-07-142_19_26.thumb.png.48217757a23a407a09d5d84cdf392356.png1186162026_2022-07-142_18_45.thumb.png.3ecd3abd1d80628b239a0d0b834ae7e5.png
Edited by Peter Suh
So according to you @Peter Suh and @IG-88 which is the low cost PCI SATA cards which are really compatible at the moment? An additional 6/8 ports would be very welcome. Consider that I'd like to stay on DS918+ model because I have real S/N for it but I might evaluate a change if it's really needed.
Edited by Hackaro
I tried with DS920+ model both with manual TC static and with your script ./my.sh DS920+J noconfig (manually inserted serial n and mac address, removing sataportmap and diskidmap from User Config). The result is the same: Marvell controller shows only 2 ports out of 4. Any suggestion?
At the moment, there doesn't seem to be a clear answer.
The list of Sata disks seen in junior is
Number of physical disks that can be mapped to DTC.
You can check it with ll /sys/block .
I know that the disks appearing here depend entirely on the ahci driver, but it would be difficult without the improvement of this ahci driver.
I'm not sure of what I'm looking at:
gio_admin@NAS920J:/$ ll /sys/block
total 0
drwxr-xr-x  2 root root 0 Jul 19 16:02 .
dr-xr-xr-x 12 root root 0 Jul 19 16:02 ..
lrwxrwxrwx  1 root root 0 Jul 19 16:02 dm-0 -> ../devices/virtual/block/dm-0
lrwxrwxrwx  1 root root 0 Jul 19 16:02 dm-1 -> ../devices/virtual/block/dm-1
lrwxrwxrwx  1 root root 0 Jul 19 16:02 dm-2 -> ../devices/virtual/block/dm-2
lrwxrwxrwx  1 root root 0 Jul 19 16:02 loop0 -> ../devices/virtual/block/loop0
lrwxrwxrwx  1 root root 0 Jul 19 16:02 loop1 -> ../devices/virtual/block/loop1
lrwxrwxrwx  1 root root 0 Jul 19 16:02 loop2 -> ../devices/virtual/block/loop2
lrwxrwxrwx  1 root root 0 Jul 19 16:02 loop3 -> ../devices/virtual/block/loop3
lrwxrwxrwx  1 root root 0 Jul 19 16:02 loop4 -> ../devices/virtual/block/loop4
lrwxrwxrwx  1 root root 0 Jul 19 16:02 loop5 -> ../devices/virtual/block/loop5
lrwxrwxrwx  1 root root 0 Jul 19 16:02 loop6 -> ../devices/virtual/block/loop6
lrwxrwxrwx  1 root root 0 Jul 19 16:02 loop7 -> ../devices/virtual/block/loop7
lrwxrwxrwx  1 root root 0 Jul 19 16:02 md0 -> ../devices/virtual/block/md0
lrwxrwxrwx  1 root root 0 Jul 19 16:02 md1 -> ../devices/virtual/block/md1
lrwxrwxrwx  1 root root 0 Jul 19 16:02 md2 -> ../devices/virtual/block/md2
lrwxrwxrwx  1 root root 0 Jul 19 16:02 ram0 -> ../devices/virtual/block/ram0
lrwxrwxrwx  1 root root 0 Jul 19 16:02 ram1 -> ../devices/virtual/block/ram1
lrwxrwxrwx  1 root root 0 Jul 19 16:02 ram10 -> ../devices/virtual/block/ram10
lrwxrwxrwx  1 root root 0 Jul 19 16:02 ram11 -> ../devices/virtual/block/ram11
lrwxrwxrwx  1 root root 0 Jul 19 16:02 ram12 -> ../devices/virtual/block/ram12
lrwxrwxrwx  1 root root 0 Jul 19 16:02 ram13 -> ../devices/virtual/block/ram13
lrwxrwxrwx  1 root root 0 Jul 19 16:02 ram14 -> ../devices/virtual/block/ram14
lrwxrwxrwx  1 root root 0 Jul 19 16:02 ram15 -> ../devices/virtual/block/ram15
lrwxrwxrwx  1 root root 0 Jul 19 16:02 ram2 -> ../devices/virtual/block/ram2
lrwxrwxrwx  1 root root 0 Jul 19 16:02 ram3 -> ../devices/virtual/block/ram3
lrwxrwxrwx  1 root root 0 Jul 19 16:02 ram4 -> ../devices/virtual/block/ram4
lrwxrwxrwx  1 root root 0 Jul 19 16:02 ram5 -> ../devices/virtual/block/ram5
lrwxrwxrwx  1 root root 0 Jul 19 16:02 ram6 -> ../devices/virtual/block/ram6
lrwxrwxrwx  1 root root 0 Jul 19 16:02 ram7 -> ../devices/virtual/block/ram7
lrwxrwxrwx  1 root root 0 Jul 19 16:02 ram8 -> ../devices/virtual/block/ram8
lrwxrwxrwx  1 root root 0 Jul 19 16:02 ram9 -> ../devices/virtual/block/ram9
lrwxrwxrwx  1 root root 0 Jul 19 16:02 sata1 -> ../devices/pci0000:00/0000:00:17.0/ata5/host4/target4:0:0/4:0:0:0/block/sata1
lrwxrwxrwx  1 root root 0 Jul 19 16:02 sata2 -> ../devices/pci0000:00/0000:00:17.0/ata6/host5/target5:0:0/5:0:0:0/block/sata2
lrwxrwxrwx  1 root root 0 Jul 19 16:02 synoboot -> ../devices/pci0000:00/0000:00:14.0/usb2/2-8/2-8:1.0/host10/target10:0:0/10:0:0:0/block/synoboot
lrwxrwxrwx  1 root root 0 Jul 19 16:02 zram0 -> ../devices/virtual/block/zram0
lrwxrwxrwx  1 root root 0 Jul 19 16:02 zram1 -> ../devices/virtual/block/zram1
PS: Dumb question: What does "DTC" stand for?
