TImberman 1 Posted May 9 Share Posted May 9 (edited) Hi All, I have just installed DSM 6.2.3-25426 and am now getting a lot of problems. I can only access the NAS locally. The "Network" tab doesn't save, it looks like it should save, but doesn't do it. See: https://community.synology.com/enu/forum/17/post/84969 When opening the control panel app it says: "The operation failed. Please log in to DSM again and retry" The same thing happens whenever i try to manually install a new DSM I have not set my USB settings in the usb, could this cause these issues? Does anyone know what is happening & how to solve these issues? Edited May 9 by TImberman Quote Link to post Share on other sites
0 Solution TImberman 1 Posted May 10 Author Solution Share Posted May 10 I solved this problem, the issue was the .xpenoboot folder which I needed to delete. After doing that all the problems magically disappeared 1 Quote Link to post Share on other sites
TImberman 1
Hi All,
Edited by TImbermanI have just installed DSM 6.2.3-25426 and am now getting a lot of problems.
1 answer to this question
