Casper1982 0 Posted April 28 Share Posted April 28 Hello, I have successfully installed DSM 7.0.1 42218 with TC redpill in virtualbox on a virtual ds3622xs+ I've added 2 HDD's as data drives and there both visible in DSM. When I want to make a storage pool and volume I get a error that the entry for the field modify allocated size is invalid. Even if I choose MAX (which is 3) I still get the error. No matter if I choose 1 or 2. Google on this error did not give me a solution. Anybody knows what is going on? Quote Link to post Share on other sites
scoobdriver 23 Posted April 28 Share Posted April 28 You drive sizes are too small , you cant create volumes under 10GB . From website:- The minimum volume capacity must be at least 10 GB. Volume capacity of less than 1 GB cannot be used. For example, only 100 GB is usable if the total capacity of a volume is 100.5 GB. Quote Link to post Share on other sites
Casper1982 0 Posted April 28 Author Share Posted April 28 thank you! sometimes the solution is simple..... Quote Link to post Share on other sites
