martysport Posted August 3, 2016 #1 Posted August 3, 2016 I recently upgraded to a 4 core CPU (AMD x4 880K) Mainboard is a Fatal1ty FM2A88X+ Killer. Bare metal install DSM 5.2-5967 Update 2 Ploblem is I have no speed displayed for the LAN traffic, yet it functions fine? Screenshot was taken streaming a movie in Plex to my TV.
nemesis122 Posted August 3, 2016 #2 Posted August 3, 2016 Hi Mabye do you have more as one LAN adapter? Go and press on the lan arrow on the right side is there a LAN 2 ? BR Michael
malpensa Posted August 3, 2016 #4 Posted August 3, 2016 I have no problem about the Lan traffic DSM 5.2-5967 update 2 Under Virtual Box 5.0.26
martysport Posted August 4, 2016 Author #5 Posted August 4, 2016 Nor did I with my old mainboard, only since changing it. Looks like someone else has the same problem too (using the Atheros killer E2200 like I am), I found this post with a quick search. hy, With XPEnoboot 5.2-5644.1 theres no more stats for my ethernet card Atheros killer E2200 which use alx kernel module : cat /proc/net/dev Receive | Transmit Interface |bytes packets errs drop fifo frame compressed multicast|bytes packets errs drop fifo colls carrier compressed eth0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 It was working fine in the previous xpenoboot releases, that's a known bug of alx driver, and it was fixed few xpenoboot release ago. Would be great to fix this
