I try to install Xpenology NAS in my SHUTTLE XPC with Esxi. I had modify Xpenoboot_DS3615xs_5.2-5644.5.iso . and system stay in login screen after booting . At this monent i start install DSM_DS3615xs_5644.pat from my laptop . then I got this screen snap from vsphere client . then it won't be reboot anymore . anyone know what's going on ?
screen snap as below .
http://imgur.com/a/kaRps
Firstly, make sure that you set the boot drive to Independent and non-persistent. The boot drive gets wiped during the DSM install - making it non-persistent means that ESXi will undo the wipe after powering off the VM.
I see that you're trying to warm reboot after the install, this doesn't give ESXi a chance to undo the wipe, so it's trying to boot of a wiped disk. If you power down the VM at this point and restart, you should find that it works just fine (assuming that you've setup the boot drive correctly).
