I over speced a VM disk for my xpenology (Thick Provision) It was a added disk and not the disk I used to install the DSM, I want to cut the size of this disk in half so I can use the space on other VM's but dont want it to break my volume in DSM if I do this., I installed Plex on this volume for bit off added complexity, I could delete it and re install Plex not a massive issue but just wondering if there is a way to do this with out having to delete it? Or am I over thinking and its as simple as just resizing the disk in ESXI
Ysyn 0
1 answer to this question
