Peter Suh Posted May 14 Author Share #201 Posted May 14 4 minutes ago, proc said: Hi Peter, I am trying to install 918+ 7.1 on a Lenovo pc, but keep getting these errors. Can you please help? Thank you! I installed 7.1 on this same pc successfully last month. No idea why I keep getting this error this time. Tried different USB drives, tried 920+, tried more than 10 times yerterday...no luck. These are the latest outputs: tc@box:~$ ./rploader.sh build apollolake-7.0.1-42218 .... Mounting /dev/sda1 to localdiskp1 /dev/sda2 localdiskp2 cp: error writing 'localdiskp1/zImage': No space left on device Creating tinycore entry .... tc@box:~$ ./rploader.sh build apollolake-7.1.0-42661 ... Mounting /dev/sda1 to localdiskp1 /dev/sda2 localdiskp2 cp: error writing 'localdiskp1/boot/grub/i386-pc/gcry_tiger.mod': No space left on device cp: error writing 'localdiskp1/boot/grub/locale/ru.mo': No space left on device cp: error writing 'localdiskp1/boot/grub/x86_64-efi/gcry_sha512.mod': No space left on device cp: error writing 'localdiskp1/custom.gz': No space left on device cp: error writing 'localdiskp1/rd.gz': No space left on device cp: error writing 'localdiskp1/zImage': No space left on device Creating tinycore entry ... This pc has a 4G RAM. I used tinycore-redpill-uefi.v0.4.6.img and followed these steps: ./rploader.sh update now ./rploader.sh fullupgrade now ./rploader.sh serialgen DS918+ ./rploader.sh identifyusb now ./rploader.sh satamap now ./rploader.sh build apollolake-7.0.1-42218 ./rploader.sh clean now ./rploader.sh build apollolake-7.1.0-42661 ./rploader.sh clean now; rm -rf /mnt/sdb3/auxfiles; rm -rf /home/tc/custom-module; ./rploader.sh backup now; If I use this USB drive to boot the pc, I can see these outputs and then the pc reboots. And then "Booting RedPill" again, and then the pc reboots again. It is a loop. Booting 'RedPill BS918+ v7.1.0-42261 (USB, Verbose)' Loading Linux... Loading initramfs... Starting kernel with USB boot It would be nice to receive and use the m-shell below that helps loader building in TC. I often see some kind of low-space message The m-shell appropriately uses clean to free up space for the build. Quote Link to comment Share on other sites More sharing options...
proc Posted May 14 Share #202 Posted May 14 14 minutes ago, Peter Suh said: It would be nice to receive and use the m-shell below that helps loader building in TC. I often see some kind of low-space message The m-shell appropriately uses clean to free up space for the build. Thanks for your response! I just tried "./my.sh DS918+". This script is powerful! But still got the same error. Mounting /dev/sda1 to localdiskp1 /dev/sda2 localdiskp2 cp: error writing 'localdiskp1/boot/grub/locale/ru.mo': No space left on device cp: error writing 'localdiskp1/boot/grub/x86_64-efi/gcry_sha512.mod': No space left on device cp: error writing 'localdiskp1/custom.gz': No space left on device cp: error writing 'localdiskp1/rd.gz': No space left on device cp: error writing 'localdiskp1/zImage': No space left on device Creating tinycore entry menuentry 'Tiny Core Image Build' { savedefault set root=(hd0,msdos3) echo Loading Linux... linux /vmlinuz64 loglevel=3 cde waitusb=5 vga=791 echo Loading initramfs... initrd /corepure64.gz echo Booting TinyCore for loader creation } Entries in Localdisk bootloader : ======================================================================= menuentry 'RedPill DS918+ v7.1.0-42661 (USB, Verbose)' { menuentry 'RedPill DS918+ v7.1.0-42661 (SATA, Verbose)' { menuentry 'Tiny Core Image Build' { Caching files for future use Found /home/tc/redpill-load/cache/ds918p_42661.pat, copying to cache directory : /mnt/sda3/auxfiles Saving user session for future use. Saving current extensions -> OK ! Saving current user_config.json -> OK ! Backup in progress... Clearing local redpill files Please make sure you are using the latest 1GB img before using backup option Current /home/tc size is 2.3M , try to keep it less than 1GB as it might not fit into your image Should i update the sda with your current files [Yy/Nn] Backing up home files to sda : Backing up files to /mnt/sda3//mydata.tgz Done. tc@box:~$ df -h Filesystem Size Used Avail Use% Mounted on rootfs 3.4G 42M 3.4G 2% / tmpfs 1.9G 0 1.9G 0% /dev/shm /dev/sda3 899M 52M 847M 6% /mnt/sda3 It is a 4GB USB drive and I guess the space is enough... Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted May 14 Author Share #203 Posted May 14 6 minutes ago, proc said: Thanks for your response! I just tried "./my.sh DS918+". This script is powerful! But still got the same error. Mounting /dev/sda1 to localdiskp1 /dev/sda2 localdiskp2 cp: error writing 'localdiskp1/boot/grub/locale/ru.mo': No space left on device cp: error writing 'localdiskp1/boot/grub/x86_64-efi/gcry_sha512.mod': No space left on device cp: error writing 'localdiskp1/custom.gz': No space left on device cp: error writing 'localdiskp1/rd.gz': No space left on device cp: error writing 'localdiskp1/zImage': No space left on device Creating tinycore entry menuentry 'Tiny Core Image Build' { savedefault set root=(hd0,msdos3) echo Loading Linux... linux /vmlinuz64 loglevel=3 cde waitusb=5 vga=791 echo Loading initramfs... initrd /corepure64.gz echo Booting TinyCore for loader creation } Entries in Localdisk bootloader : ======================================================================= menuentry 'RedPill DS918+ v7.1.0-42661 (USB, Verbose)' { menuentry 'RedPill DS918+ v7.1.0-42661 (SATA, Verbose)' { menuentry 'Tiny Core Image Build' { Caching files for future use Found /home/tc/redpill-load/cache/ds918p_42661.pat, copying to cache directory : /mnt/sda3/auxfiles Saving user session for future use. Saving current extensions -> OK ! Saving current user_config.json -> OK ! Backup in progress... Clearing local redpill files Please make sure you are using the latest 1GB img before using backup option Current /home/tc size is 2.3M , try to keep it less than 1GB as it might not fit into your image Should i update the sda with your current files [Yy/Nn] Backing up home files to sda : Backing up files to /mnt/sda3//mydata.tgz Done. tc@box:~$ df -h Filesystem Size Used Avail Use% Mounted on rootfs 3.4G 42M 3.4G 2% / tmpfs 1.9G 0 1.9G 0% /dev/shm /dev/sda3 899M 52M 847M 6% /mnt/sda3 It is a 4GB USB drive and I guess the space is enough... There seems to be enough space, but the result of the df-h command is a little different from mine. 4.6 Is the image recording wrong with USB? Or is it because the USB stick is damaged and the restoration of my data.tgz file is not working well? For your information, I've used up to 8GB sticks, but there was no problem. tc@box:~$ df -h Filesystem Size Used Avail Use% Mounted on rootfs 14G 84M 14G 1% / tmpfs 7.8G 0 7.8G 0% /dev/shm /dev/sdb3 899M 459M 441M 51% /mnt/sdb3 /dev/loop0 24K 24K 0 100% /tmp/tcloop/attr /dev/loop1 40K 40K 0 100% /tmp/tcloop/acl /dev/loop2 252K 252K 0 100% /tmp/tcloop/ncursesw /dev/loop3 144K 144K 0 100% /tmp/tcloop/readline /dev/loop4 484K 484K 0 100% /tmp/tcloop/bash /dev/loop5 5.3M 5.3M 0 100% /tmp/tcloop/binutils /dev/loop6 32K 32K 0 100% /tmp/tcloop/bzip2-dev /dev/loop7 1.8M 1.8M 0 100% /tmp/tcloop/openssl-1.1.1 /dev/loop8 148K 148K 0 100% /tmp/tcloop/ca-certificates /dev/loop9 24K 24K 0 100% /tmp/tcloop/libcap /dev/loop10 244K 244K 0 100% /tmp/tcloop/gmp /dev/loop11 2.3M 2.3M 0 100% /tmp/tcloop/coreutils /dev/loop12 88K 88K 0 100% /tmp/tcloop/cpio /dev/loop13 284K 284K 0 100% /tmp/tcloop/curl /dev/loop14 72K 72K 0 100% /tmp/tcloop/expat2 /dev/loop15 200K 200K 0 100% /tmp/tcloop/findutils /dev/loop16 3.9M 3.9M 0 100% /tmp/tcloop/git /dev/loop17 92K 92K 0 100% /tmp/tcloop/grep /dev/loop18 48K 48K 0 100% /tmp/tcloop/gzip /dev/loop19 816K 816K 0 100% /tmp/tcloop/isl /dev/loop20 216K 216K 0 100% /tmp/tcloop/jq /dev/loop21 68K 68K 0 100% /tmp/tcloop/jsoncpp /dev/loop22 52K 52K 0 100% /tmp/tcloop/liblz4 /dev/loop23 308K 308K 0 100% /tmp/tcloop/libzstd /dev/loop24 76K 76K 0 100% /tmp/tcloop/liblzma /dev/loop25 600K 600K 0 100% /tmp/tcloop/libxml2 /dev/loop26 56K 56K 0 100% /tmp/tcloop/lzo /dev/loop27 272K 272K 0 100% /tmp/tcloop/nettle3 /dev/loop28 384K 384K 0 100% /tmp/tcloop/libarchive /dev/loop29 24K 24K 0 100% /tmp/tcloop/libpci /dev/loop30 84K 84K 0 100% /tmp/tcloop/librhash /dev/loop31 128K 128K 0 100% /tmp/tcloop/udev-lib /dev/loop32 48K 48K 0 100% /tmp/tcloop/libusb /dev/loop33 68K 68K 0 100% /tmp/tcloop/libuv /dev/loop34 44K 44K 0 100% /tmp/tcloop/lsscsi /dev/loop35 60K 60K 0 100% /tmp/tcloop/m4 /dev/loop36 104K 104K 0 100% /tmp/tcloop/make /dev/loop37 492K 492K 0 100% /tmp/tcloop/raid-dm-5.10.3-tinycore64 /dev/loop38 352K 352K 0 100% /tmp/tcloop/mdadm /dev/loop39 4.0K 4.0K 0 100% /tmp/tcloop/mirrors /dev/loop40 232K 232K 0 100% /tmp/tcloop/mpfr /dev/loop41 48K 48K 0 100% /tmp/tcloop/mpc /dev/loop42 88K 88K 0 100% /tmp/tcloop/ncursesw-utils /dev/loop43 740K 740K 0 100% /tmp/tcloop/ncursesw-terminfo /dev/loop44 1.4M 1.4M 0 100% /tmp/tcloop/openssh /dev/loop45 76K 76K 0 100% /tmp/tcloop/patch /dev/loop46 276K 276K 0 100% /tmp/tcloop/pciutils /dev/loop47 80K 80K 0 100% /tmp/tcloop/sed /dev/loop48 220K 220K 0 100% /tmp/tcloop/tar /dev/loop49 288K 288K 0 100% /tmp/tcloop/usb-utils /dev/loop50 2.1M 2.1M 0 100% /tmp/tcloop/util-linux /dev/loop51 52K 52K 0 100% /tmp/tcloop/xz Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted May 14 Author Share #204 Posted May 14 (edited) @proc Mount the space on the loader 1st partition like this and check it again tc@box:~$ mkdir /home/tc/redpill-load/localdiskp1 mkdir: cannot create directory '/home/tc/redpill-load/localdiskp1': File exists tc@box:~$ sudo mount /dev/sda1 /home/tc/redpill-load/localdiskp1 tc@box:~$ df /home/tc/redpill-load/localdiskp1 Filesystem Size Used Avail Use% Mounted on /dev/sdb1 48M 39M 9.0M 82% /home/tc/redpill-load/localdiskp1 Edited May 14 by Peter Suh Quote Link to comment Share on other sites More sharing options...
proc Posted May 14 Share #205 Posted May 14 5 minutes ago, Peter Suh said: There seems to be enough space, but the result of the df-h command is a little different from mine. 4.6 Is the image recording wrong with USB? Or is it because the USB stick is damaged and the restoration of my data.tgz file is not working well? For your information, I've used up to 8GB sticks, but there was no problem. tc@box:~$ df -h Filesystem Size Used Avail Use% Mounted on rootfs 14G 84M 14G 1% / tmpfs 7.8G 0 7.8G 0% /dev/shm /dev/sdb3 899M 459M 441M 51% /mnt/sdb3 /dev/loop0 24K 24K 0 100% /tmp/tcloop/attr /dev/loop1 40K 40K 0 100% /tmp/tcloop/acl /dev/loop2 252K 252K 0 100% /tmp/tcloop/ncursesw /dev/loop3 144K 144K 0 100% /tmp/tcloop/readline /dev/loop4 484K 484K 0 100% /tmp/tcloop/bash /dev/loop5 5.3M 5.3M 0 100% /tmp/tcloop/binutils /dev/loop6 32K 32K 0 100% /tmp/tcloop/bzip2-dev /dev/loop7 1.8M 1.8M 0 100% /tmp/tcloop/openssl-1.1.1 /dev/loop8 148K 148K 0 100% /tmp/tcloop/ca-certificates /dev/loop9 24K 24K 0 100% /tmp/tcloop/libcap /dev/loop10 244K 244K 0 100% /tmp/tcloop/gmp /dev/loop11 2.3M 2.3M 0 100% /tmp/tcloop/coreutils /dev/loop12 88K 88K 0 100% /tmp/tcloop/cpio /dev/loop13 284K 284K 0 100% /tmp/tcloop/curl /dev/loop14 72K 72K 0 100% /tmp/tcloop/expat2 /dev/loop15 200K 200K 0 100% /tmp/tcloop/findutils /dev/loop16 3.9M 3.9M 0 100% /tmp/tcloop/git /dev/loop17 92K 92K 0 100% /tmp/tcloop/grep /dev/loop18 48K 48K 0 100% /tmp/tcloop/gzip /dev/loop19 816K 816K 0 100% /tmp/tcloop/isl /dev/loop20 216K 216K 0 100% /tmp/tcloop/jq /dev/loop21 68K 68K 0 100% /tmp/tcloop/jsoncpp /dev/loop22 52K 52K 0 100% /tmp/tcloop/liblz4 /dev/loop23 308K 308K 0 100% /tmp/tcloop/libzstd /dev/loop24 76K 76K 0 100% /tmp/tcloop/liblzma /dev/loop25 600K 600K 0 100% /tmp/tcloop/libxml2 /dev/loop26 56K 56K 0 100% /tmp/tcloop/lzo /dev/loop27 272K 272K 0 100% /tmp/tcloop/nettle3 /dev/loop28 384K 384K 0 100% /tmp/tcloop/libarchive /dev/loop29 24K 24K 0 100% /tmp/tcloop/libpci /dev/loop30 84K 84K 0 100% /tmp/tcloop/librhash /dev/loop31 128K 128K 0 100% /tmp/tcloop/udev-lib /dev/loop32 48K 48K 0 100% /tmp/tcloop/libusb /dev/loop33 68K 68K 0 100% /tmp/tcloop/libuv /dev/loop34 44K 44K 0 100% /tmp/tcloop/lsscsi /dev/loop35 60K 60K 0 100% /tmp/tcloop/m4 /dev/loop36 104K 104K 0 100% /tmp/tcloop/make /dev/loop37 492K 492K 0 100% /tmp/tcloop/raid-dm-5.10.3-tinycore64 /dev/loop38 352K 352K 0 100% /tmp/tcloop/mdadm /dev/loop39 4.0K 4.0K 0 100% /tmp/tcloop/mirrors /dev/loop40 232K 232K 0 100% /tmp/tcloop/mpfr /dev/loop41 48K 48K 0 100% /tmp/tcloop/mpc /dev/loop42 88K 88K 0 100% /tmp/tcloop/ncursesw-utils /dev/loop43 740K 740K 0 100% /tmp/tcloop/ncursesw-terminfo /dev/loop44 1.4M 1.4M 0 100% /tmp/tcloop/openssh /dev/loop45 76K 76K 0 100% /tmp/tcloop/patch /dev/loop46 276K 276K 0 100% /tmp/tcloop/pciutils /dev/loop47 80K 80K 0 100% /tmp/tcloop/sed /dev/loop48 220K 220K 0 100% /tmp/tcloop/tar /dev/loop49 288K 288K 0 100% /tmp/tcloop/usb-utils /dev/loop50 2.1M 2.1M 0 100% /tmp/tcloop/util-linux /dev/loop51 52K 52K 0 100% /tmp/tcloop/xz Sorry, I didn't upload the full log. I tried 3 USB drives, so I don't think they are damaged. tc@box:~$ df -h Filesystem Size Used Avail Use% Mounted on rootfs 3.4G 42M 3.4G 2% / tmpfs 1.9G 0 1.9G 0% /dev/shm /dev/sda3 899M 52M 847M 6% /mnt/sda3 /dev/loop0 24K 24K 0 100% /tmp/tcloop/attr /dev/loop1 40K 40K 0 100% /tmp/tcloop/acl /dev/loop2 252K 252K 0 100% /tmp/tcloop/ncursesw /dev/loop3 144K 144K 0 100% /tmp/tcloop/readline /dev/loop4 484K 484K 0 100% /tmp/tcloop/bash /dev/loop5 5.3M 5.3M 0 100% /tmp/tcloop/binutils /dev/loop6 32K 32K 0 100% /tmp/tcloop/bzip2-dev /dev/loop7 1.8M 1.8M 0 100% /tmp/tcloop/openssl-1.1.1 /dev/loop8 148K 148K 0 100% /tmp/tcloop/ca-certificates /dev/loop9 24K 24K 0 100% /tmp/tcloop/libcap /dev/loop10 244K 244K 0 100% /tmp/tcloop/gmp /dev/loop11 2.3M 2.3M 0 100% /tmp/tcloop/coreutils /dev/loop12 88K 88K 0 100% /tmp/tcloop/cpio /dev/loop13 284K 284K 0 100% /tmp/tcloop/curl /dev/loop14 72K 72K 0 100% /tmp/tcloop/expat2 /dev/loop15 200K 200K 0 100% /tmp/tcloop/findutils /dev/loop16 3.9M 3.9M 0 100% /tmp/tcloop/git /dev/loop17 92K 92K 0 100% /tmp/tcloop/grep /dev/loop18 48K 48K 0 100% /tmp/tcloop/gzip /dev/loop19 816K 816K 0 100% /tmp/tcloop/isl /dev/loop20 216K 216K 0 100% /tmp/tcloop/jq /dev/loop21 68K 68K 0 100% /tmp/tcloop/jsoncpp /dev/loop22 52K 52K 0 100% /tmp/tcloop/liblz4 /dev/loop23 308K 308K 0 100% /tmp/tcloop/libzstd /dev/loop24 76K 76K 0 100% /tmp/tcloop/liblzma /dev/loop25 600K 600K 0 100% /tmp/tcloop/libxml2 /dev/loop26 56K 56K 0 100% /tmp/tcloop/lzo /dev/loop27 272K 272K 0 100% /tmp/tcloop/nettle3 /dev/loop28 384K 384K 0 100% /tmp/tcloop/libarchive /dev/loop29 24K 24K 0 100% /tmp/tcloop/libpci /dev/loop30 84K 84K 0 100% /tmp/tcloop/librhash /dev/loop31 128K 128K 0 100% /tmp/tcloop/udev-lib /dev/loop32 48K 48K 0 100% /tmp/tcloop/libusb /dev/loop33 68K 68K 0 100% /tmp/tcloop/libuv /dev/loop34 44K 44K 0 100% /tmp/tcloop/lsscsi /dev/loop35 60K 60K 0 100% /tmp/tcloop/m4 /dev/loop36 104K 104K 0 100% /tmp/tcloop/make /dev/loop37 492K 492K 0 100% /tmp/tcloop/raid-dm-5.10.3-tinycore64 /dev/loop38 352K 352K 0 100% /tmp/tcloop/mdadm /dev/loop39 4.0K 4.0K 0 100% /tmp/tcloop/mirrors /dev/loop40 232K 232K 0 100% /tmp/tcloop/mpfr /dev/loop41 48K 48K 0 100% /tmp/tcloop/mpc /dev/loop42 88K 88K 0 100% /tmp/tcloop/ncursesw-utils /dev/loop43 740K 740K 0 100% /tmp/tcloop/ncursesw-terminfo /dev/loop44 1.4M 1.4M 0 100% /tmp/tcloop/openssh /dev/loop45 76K 76K 0 100% /tmp/tcloop/patch /dev/loop46 276K 276K 0 100% /tmp/tcloop/pciutils /dev/loop47 80K 80K 0 100% /tmp/tcloop/sed /dev/loop48 220K 220K 0 100% /tmp/tcloop/tar /dev/loop49 288K 288K 0 100% /tmp/tcloop/usb-utils /dev/loop50 2.1M 2.1M 0 100% /tmp/tcloop/util-linux /dev/loop51 52K 52K 0 100% /tmp/tcloop/xz It has 2.73GB unallocated space, so 4GB should be enough. Maybe sda1 and sda2 are too small? Quote Link to comment Share on other sites More sharing options...
proc Posted May 14 Share #206 Posted May 14 5 minutes ago, Peter Suh said: @proc Mount the space on the loader 1st partition like this and check it again tc@box:~$ mkdir /home/tc/redpill-load/localdiskp1 mkdir: cannot create directory '/home/tc/redpill-load/localdiskp1': File exists tc@box:~$ sudo mount /dev/sda1 /home/tc/redpill-load/localdiskp1 tc@box:~$ df /home/tc/redpill-load/localdiskp1 Filesystem Size Used Avail Use% Mounted on /dev/sdb1 48M 39M 9.0M 82% /home/tc/redpill-load/localdiskp1 tc@box:~$ df /home/tc/redpill-load/localdiskp1 Filesystem Size Used Avail Use% Mounted on /dev/sda1 48M 48M 0 100% /home/tc/redpill-load/localdiskp1 Quote Link to comment Share on other sites More sharing options...
proc Posted May 14 Share #207 Posted May 14 I just checked a brand new USB drive(without running any updates or scripts). It only has 35M free space. tc@box:~$ df /home/tc/redpill-load/localdiskp1 Filesystem Size Used Avail Use% Mounted on /dev/sda1 48M 14M 35M 29% /home/tc/redpill-load/localdiskp1 Quote Link to comment Share on other sites More sharing options...
pocopico Posted May 14 Share #208 Posted May 14 1 hour ago, proc said: ./rploader.sh update now ./rploader.sh fullupgrade now ./rploader.sh serialgen DS918+ ./rploader.sh identifyusb now ./rploader.sh satamap now ./rploader.sh build apollolake-7.0.1-42218 ./rploader.sh clean now ./rploader.sh build apollolake-7.1.0-42661 ./rploader.sh clean now; rm -rf /mnt/sdb3/auxfiles; rm -rf /home/tc/custom-module; ./rploader.sh backup now; Why are you using build two times ? one should be enough. Quote Link to comment Share on other sites More sharing options...
proc Posted May 14 Share #209 Posted May 14 26 minutes ago, pocopico said: Why are you using build two times ? one should be enough. Oh, I thought we should build 7.01 and then 7.1.0... But after the first build, I also got the "No space left on device" error. tc@box:~$ ./rploader.sh build apollolake-7.0.1-42218 .... Mounting /dev/sda1 to localdiskp1 /dev/sda2 localdiskp2 cp: error writing 'localdiskp1/zImage': No space left on device Creating tinycore entry .... Quote Link to comment Share on other sites More sharing options...
phone guy Posted May 14 Share #210 Posted May 14 4 hours ago, proc said: Hi Peter, I am trying to install 918+ 7.1 on a Lenovo pc, but keep getting these errors. Can you please help? Thank you! I installed 7.1 on this same pc successfully last month. No idea why I keep getting this error this time. Tried different USB drives, tried 920+, tried more than 10 times yerterday...no luck. These are the latest outputs: tc@box:~$ ./rploader.sh build apollolake-7.0.1-42218 .... Mounting /dev/sda1 to localdiskp1 /dev/sda2 localdiskp2 cp: error writing 'localdiskp1/zImage': No space left on device Creating tinycore entry .... tc@box:~$ ./rploader.sh build apollolake-7.1.0-42661 ... Mounting /dev/sda1 to localdiskp1 /dev/sda2 localdiskp2 cp: error writing 'localdiskp1/boot/grub/i386-pc/gcry_tiger.mod': No space left on device cp: error writing 'localdiskp1/boot/grub/locale/ru.mo': No space left on device cp: error writing 'localdiskp1/boot/grub/x86_64-efi/gcry_sha512.mod': No space left on device cp: error writing 'localdiskp1/custom.gz': No space left on device cp: error writing 'localdiskp1/rd.gz': No space left on device cp: error writing 'localdiskp1/zImage': No space left on device Creating tinycore entry ... This pc has a 4G RAM. I used tinycore-redpill-uefi.v0.4.6.img and followed these steps: ./rploader.sh update now ./rploader.sh fullupgrade now ./rploader.sh serialgen DS918+ ./rploader.sh identifyusb now ./rploader.sh satamap now ./rploader.sh build apollolake-7.0.1-42218 ./rploader.sh clean now ./rploader.sh build apollolake-7.1.0-42661 ./rploader.sh clean now; rm -rf /mnt/sdb3/auxfiles; rm -rf /home/tc/custom-module; ./rploader.sh backup now; If I use this USB drive to boot the pc, I can see these outputs and then the pc reboots. And then "Booting RedPill" again, and then the pc reboots again. It is a loop. Booting 'RedPill BS918+ v7.1.0-42261 (USB, Verbose)' Loading Linux... Loading initramfs... Starting kernel with USB boot What size is your usb drive? did you format or clean it between attempts? looks like the usb is out of space to complete the build. Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted May 15 Author Share #211 Posted May 15 (edited) @phone guy How to install TCRP on Proxmox Guide CLICK HERE This proxmox guide is written by you, are you waiting for approval? It says that this link cannot be found. I don't know why, but sometimes it's tricky. If a similar topic comes up again, it seems that there are cases of rejection occurs. So when a new guide is created, there are times when you have to appeal to the administrator for the necessity. Edited May 15 by Peter Suh Quote Link to comment Share on other sites More sharing options...
phone guy Posted May 15 Share #212 Posted May 15 (edited) 21 minutes ago, Peter Suh said: @phone guy How to install TCRP on Proxmox Guide CLICK HERE This proxmox guide is written by you, are you waiting for approval? It says that this link cannot be found. I don't know why, but sometimes it's tricky. If a similar topic comes up again, it seems that there are cases of rejection occurs. So when a new guide is created, there are times when you have to appeal to the administrator for the necessity. Yes I am waiting for the post to be approved. I assumed it would only take a day, thats why I posted the link and added to my signature. Hopefully it will be approved and released by Monday 05/16/22 ? As of now, I have not gotten any update - still says awaiting approval...Should I remove the signature until then? or wait and see what happens? btw: I link back to your tutorial on how to build the loader (this thread we are in now) I hope you dont mind. The tutorial I wrote up only discusses the proxmox part of installation, none of the redpill commands... I point them to your guide for that part Edited May 15 by phone guy Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted May 15 Author Share #213 Posted May 15 15 minutes ago, phone guy said: Yes I am waiting for the post to be approved. I assumed it would only take a day, thats why I posted the link and added to my signature. Hopefully it will be approved and released by Monday 05/16/22 ? As of now, I have not gotten any update - still says awaiting approval...Should I remove the signature until then? or wait and see what happens? btw: I link back to your tutorial on how to build the loader (this thread we are in now) I hope you dont mind. The tutorial I wrote up only discusses the proxmox part of installation, none of the redpill commands... I point them to your guide for that part Everything related to approval seems to depend on the will of the manager. There was a case where a user who was frustrated because it had not been approved for several days complained to me. I also requested approval of M SHELL's separate guide, but was ultimately rejected. Because the reason is not explained, there is no way to know, and there is no way to know the progress. No response from the manager is expected. That part is a little tedious. 1 Quote Link to comment Share on other sites More sharing options...
proc Posted May 15 Share #214 Posted May 15 4 hours ago, phone guy said: What size is your usb drive? did you format or clean it between attempts? looks like the usb is out of space to complete the build. It is a 4GB usb drive. I formatted it and re-wrote the image to it. I tested it on another computer and got the same error(cp: error writing 'localdiskp1/zImage': No space left on device). After expanding the space of the first partition of the usb drive to 98MB, now there is no error and I can see the Synology setup GUI lol Thanks for everyone's help! Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted May 15 Author Share #215 Posted May 15 I can't test because I don't have a 4GB USB stick, Instead, I checked the partition status of the 8GB stick. Please understand that it was captured in Korean because it was not translated into English in WIN PE. The block size per sector of an area of 48 MB is 2048 bytes. In case of 4GB, I wonder if this block size is 4096. If you look at the Korean capture next to it, 604 files are recorded, and there is a possibility that this space is insufficient because each small file occupies a block. Is my hypothesis correct? Quote Link to comment Share on other sites More sharing options...
phone guy Posted May 15 Share #216 Posted May 15 4 hours ago, proc said: It is a 4GB usb drive. I formatted it and re-wrote the image to it. I tested it on another computer and got the same error(cp: error writing 'localdiskp1/zImage': No space left on device). After expanding the space of the first partition of the usb drive to 98MB, now there is no error and I can see the Synology setup GUI lol Thanks for everyone's help! 30 minutes ago, Peter Suh said: I can't test because I don't have a 4GB USB stick, Instead, I checked the partition status of the 8GB stick. Please understand that it was captured in Korean because it was not translated into English in WIN PE. The block size per sector of an area of 48 MB is 2048 bytes. In case of 4GB, I wonder if this block size is 4096. If you look at the Korean capture next to it, 604 files are recorded, and there is a possibility that this space is insufficient because each small file occupies a block. Is my hypothesis correct? I guess the lesson here is use at least an 8gb usb drive for creating a red pill loader Glad you got it working Quote Link to comment Share on other sites More sharing options...
phone guy Posted May 15 Share #217 Posted May 15 4 hours ago, Peter Suh said: Everything related to approval seems to depend on the will of the manager. There was a case where a user who was frustrated because it had not been approved for several days complained to me. I also requested approval of M SHELL's separate guide, but was ultimately rejected. Because the reason is not explained, there is no way to know, and there is no way to know the progress. No response from the manager is expected. That part is a little tedious. Its only been 1 day, and I have not received anything from anyone suggesting approval or rejection, so I will wait before contacting anyone. Will wait until this Monday and see what the outcome is. Quote Link to comment Share on other sites More sharing options...
ferno Posted May 15 Share #218 Posted May 15 6 hours ago, phone guy said: I guess the lesson here is use at least an 8gb usb drive for creating a red pill loader Glad you got it working Hmm, I am using a 16GB and a 8GB stick but get this error also : !] Failed to copy /home/tc/redpill-load/build/1652617579/rd-patched-ds3615xs_42218.gz to /home/tc/redpill-load/build/1652617579/img-mnt/part-1/rd.gz /usr/local/bin/cp: error writing '/home/tc/redpill-load/build/1652617579/img-mnt/part-1/rd.gz': No space left on device *** Process will exit *** Any clues what I am doing wrong? Used RedPil on ESXi 7.0.2 and that worked fine. Am now trying to get this installed on my HPE Microserver Gen8 but cant get past this issue. Quote Link to comment Share on other sites More sharing options...
SachinD Posted May 15 Share #219 Posted May 15 Hi, I have built the image and it migrated my disk to DSM 7,1. I have a backup HDD connected to my "NAS" for local backups. On booting however the boot fails. It shows the error : Even booting the Tinyloader fails as follows : If i reboot with the HDD disconnected it works fine, Is there a way to enable RP with a USB HDD connected ? Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted May 15 Author Share #220 Posted May 15 7 minutes ago, SachinD said: Hi, I have built the image and it migrated my disk to DSM 7,1. I have a backup HDD connected to my "NAS" for local backups. On booting however the boot fails. It shows the error : Even booting the Tinyloader fails as follows : If i reboot with the HDD disconnected it works fine, Is there a way to enable RP with a USB HDD connected ? Use the USB LEGACY BOOT option in BIOS instead of USB UEFI BOOT. Quote Link to comment Share on other sites More sharing options...
SachinD Posted May 15 Share #221 Posted May 15 Just now, Peter Suh said: Use the USB LEGACY BOOT option in BIOS instead of USB UEFI BOOT. I use a J4105 ASRock board which supports UEFI only. This worked well with Jun's loader earlier.. Quote Link to comment Share on other sites More sharing options...
proc Posted May 15 Share #222 Posted May 15 (edited) 8 hours ago, phone guy said: I guess the lesson here is use at least an 8gb usb drive for creating a red pill loader Glad you got it working FYI, this is my 4G usb drive. If I extend sda1, after building apollolake-7.1.0-42661, it uses only 35M.... Disk /dev/sda: 3.76 GiB, 4037017600 bytes, 7884800 sectors Disk model: Flash Disk Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: dos Disk identifier: 0xf110ee87 tc@box:~$ df -h /dev/sda1 Filesystem Size Used Avail Use% Mounted on /dev/sda1 98M 35M 64M 36% /home/tc/redpill-load/localdiskp1 If I don't extend sda1, I get this error on two different computers. (Every time I use Rufus to re-write the usb drive before my tests. ) cp: error writing 'localdiskp1/zImage': No space left on device tc@box:~$ df /home/tc/redpill-load/localdiskp1 Filesystem Size Used Avail Use% Mounted on /dev/sda1 48M 48M 0 100% /home/tc/redpill-load/localdiskp1 Maybe the temp files in sda1 are too big? No idea... but extending sda1 solved the problem on my computers. Thank you! Edited May 15 by proc Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted May 15 Author Share #223 Posted May 15 30 minutes ago, SachinD said: I use a J4105 ASRock board which supports UEFI only. This worked well with Jun's loader earlier.. If so, have you ever tried using this img file, which is only for UEFI, not for legacy? Which of the two files was used to create the current USB? https://github.com/pocopico/tinycore-redpill/blob/main/tinycore-redpill-uefi.v0.4.6.img.gz Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted May 15 Author Share #224 Posted May 15 [Notice] M-SHELL's guide has been registered as a separate topic below. For inquiries about use of M-SHELL or request for improvement, please request it in the new topic below. 1 Quote Link to comment Share on other sites More sharing options...
-iliya- Posted May 15 Share #225 Posted May 15 2 часа назад, SachinD сказал: Hi, I have built the image and it migrated my disk to DSM 7,1. I have a backup HDD connected to my "NAS" for local backups. On booting however the boot fails. It shows the error : Even booting the Tinyloader fails as follows : If i reboot with the HDD disconnected it works fine, Is there a way to enable RP with a USB HDD connected ? i have a some problem with USB2.0 ports on my z87x-d3h mobo - in USB 3.0 loader works fine, but "./rploader.sh identifyusb now" ident vid id correct and can't write this in config Quote Link to comment Share on other sites More sharing options...
