Biocef Posted May 6, 2022 Share #151 Posted May 6, 2022 il y a 53 minutes, Peter Suh a dit : You must perform an update before you can perform a fullupgrade. ./rploader.sh update now Thanks, it was a firewall issue, sorry for that... 1 Quote Link to comment Share on other sites More sharing options...
MrGarak Posted May 6, 2022 Share #152 Posted May 6, 2022 3 hours ago, Peter Suh said: Is the recognition of four disks using TC auto-mapping? You can also manually map the pcie_root/ata_port part of the ds920p.dts file, which of the two methods did you use? And, if possible, rather than using dts for 1621, It would be better to add ports 5 and 6 to the existing ds920p.dts as below. And, avoid automatic build of TC and need manual build. Thanks for the help 🤗 I just ran ./m.sh DS920+ the first time (and assumed auto-mapping) then rebooted after completion. Found with Synology Assistant, uploaded DSM .pat no problem but then had disk missing issue. I'll try your steps 👌 1 Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted May 6, 2022 Author Share #153 Posted May 6, 2022 (edited) m shell (m.sh / my.sh / myv.sh) This is today's version upgrade. # Update : add noconfig, noclean, manual combination options # 2022.05.06 You can also use three options at the same time. The pat file that you have already downloaded to the auxfiles directory is not downloaded again. It can be stored with the noclean option and recycled to the next build. Option processing function has been added as shown in the help below. Please refer to the pre-shared post below for the purpose of each script. Usage: ./my.sh <Synology Model Name> <Option> <Option> <Option> Options: noconfig, noclean, manual - noconfig: SKIP automatic detection change processing such as SN/Mac/Vid/Pid/SataPortMap of user_config.json file. - noclean: SKIP the 💊 RedPill LKM/LOAD directory without clearing it with the Clean now command. However, m shell delete the Cache directory and loader.img. - manual: Options for manual extension processing and manual dtc processing in build action (skipping extension auto detection) Please type Synology Model Name after ./my.sh ./my.sh DS918+ ./my.sh DS3617xs ./my.sh DS3615xs ./my.sh DS3622xs+ ./my.sh DVA3221 ./my.sh DS920+ ./my.sh DS1621+ You can use it like this. ./my.sh DS918+ noconfig noclean manual You can meet this infomation message. SN Gen/Mac Gen/Vid/Pid/SataPortMap detection skipped!! DSM PAT file pre-downloading in progress... https://global.download.synology.com/download/DSM/release/7.1/42661-1/DSM_DS920+_42661.pat Found locally cached pat file ds920p_42661.pat in /mnt/sda3/auxfiles Downloadng Skipped!!! Loader Building in progress... Loader Manual Building in progress... Backup in progress... Cleaning redpill-load directory and pat files in auxfiles directory skipped!!! Edited May 6, 2022 by Peter Suh Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted May 6, 2022 Author Share #154 Posted May 6, 2022 (edited) 2 hours ago, MrGarak said: Thanks for the help 🤗 I just ran ./m.sh DS920+ the first time (and assumed auto-mapping) then rebooted after completion. Found with Synology Assistant, uploaded DSM .pat no problem but then had disk missing issue. I'll try your steps 👌 @MrGarak I updated it for you and for someone else who needs this feature.^^ You can use it like this. ./my.sh DS920+ noconfig noclean manual Edited May 6, 2022 by Peter Suh 1 Quote Link to comment Share on other sites More sharing options...
Elias Jara Posted May 6, 2022 Share #155 Posted May 6, 2022 Hello, I have tried all the methods you have written but I cannot pass this part, it is always the same error, it should be noted that I previously installed version 6.2 and I did not have this problem. I tried to copy the portmap as it was with 6.2 and it still didn't work. Could you help me please Quote Link to comment Share on other sites More sharing options...
mattias93 Posted May 6, 2022 Share #156 Posted May 6, 2022 (edited) Hi! I'm having issues installing DSM 7.1 and keeping it installed. After successfully following the process and installing the DSM, if I reboot, often I have to reinstall the DSM from scratch (I'm shown the installation page and says "not installed". It may depend on any extra (official) package I installed? SynologyNAS> cat /var/log/*rc* START /linuxrc.syno.impl Insert Marvell 1475 SATA controller driver Insert basic USB modules... :: Loading module usb-common ... [ OK ] :: Loading module usbcore ... [ OK ] :: Loading module ehci-hcd ... [ OK ] :: Loading module ehci-pci ... [ OK ] :: Loading module xhci-hcd ... [ OK ] :: Loading module xhci-pci ... [ OK ] :: Loading module usb-storage ... [ OK ] :: Loading kernel modules from extensions ... Loading kmod #0 "e1000e.ko" for pocopico.e1000e (args: ) Loading kmod #0 "dca.ko" for pocopico.igb (args: ) Loading kmod #1 "igb.ko" for pocopico.igb (args: ) :: Loading kernel modules from extensions ... [ OK ] :: Executing "on_boot" custom scripts ... Running "check-e1000e.sh" for pocopico.e1000e->on_boot Loading module e1000e -> Module e1000e loaded succesfully Ran "check-e1000e.sh" for pocopico.e1000e->on_boot - exit=0 Running "check-igb.sh" for pocopico.igb->on_boot Loading module igb -> Module igb loaded succesfully Ran "check-igb.sh" for pocopico.igb->on_boot - exit=0 Running "boot-wait.sh" for redpill-boot-wait->on_boot Still waiting for boot device (waited 1 of 30 seconds) Still waiting for boot device (waited 2 of 30 seconds) Still waiting for boot device (waited 3 of 30 seconds) Still waiting for boot device (waited 4 of 30 seconds) The /dev/synoboot device exists but it does not contain expected partitions (>=3 partitions) ========== BEGIN DUMP OF ALL PARTITIONS DETECTED =========== /dev/sdc1 8192 16785407 16777216 fd /dev/sdc2 16785408 20979711 4194304 fd /dev/sdc5 21257952 7813827135 7792569184 fd /dev/sdd1 8192 16785407 16777216 fd /dev/sdd2 16785408 20979711 4194304 fd /dev/sdd5 21257952 7813827135 7792569184 fd /dev/sde1 2048 500103449 500101402 fd /dev/synoboot1 2048 100351 98304 83 /dev/synoboot2 100352 253951 153600 83 /dev/synoboot3 253952 2097151 1843200 83 ========== END OF DUMP OF ALL PARTITIONS DETECTED ========== Ran "boot-wait.sh" for redpill-boot-wait->on_boot - exit=1 Running "install_rd.sh" for redpill-misc->on_boot Starting ttyd, listening on port: 7681 Ran "install_rd.sh" for redpill-misc->on_boot - exit=0 ERROR: Some of the scripts failed! See above for any with exit != 0 :: Executing "on_boot" custom scripts ... [ OK ] Exit on error [99] rp ext init exec failure... Fri May 6 18:03:49 UTC 2022 none /sys/kernel/debug debugfs rw,relatime 0 0 Under /dev/ I see synoboot synoboot1 synoboot2 synoboot3 It's a Dell Precision 3630 Intel Xeon 2124 Coffee Lake with turbo boost disabled and no HyperThreading 4 cores 32GB UDIMM ECC 2x 4TB HDD 1x 256 Sata m2 ssd No graphic card (also run with a 1050ti, same issue) Thanks for this amazing work anyway!! mattias93log.txt Edited May 6, 2022 by mattias93 Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted May 6, 2022 Author Share #157 Posted May 6, 2022 (edited) 7 hours ago, Elias Jara said: Hello, I have tried all the methods you have written but I cannot pass this part, it is always the same error, it should be noted that I previously installed version 6.2 and I did not have this problem. I tried to copy the portmap as it was with 6.2 and it still didn't work. Could you help me please @Elias Jara Please let me know your motherboard model, CPU model, HBA model, etc. And, did you turn on the hot plug or hot swap of sataport in bios? Edited May 6, 2022 by Peter Suh Quote Link to comment Share on other sites More sharing options...
Elias Jara Posted May 7, 2022 Share #158 Posted May 7, 2022 12 hours ago, Peter Suh said: @Elias Jara Indique el modelo de su placa base, el modelo de CPU, el modelo de HBA, etc. Y, ¿activaste el hot plug o hot swap de sataport en bios? Unfortunately, my motherboard does not have a model, but I am attaching some screenshots of the bios. It has 4 sata ports. Regarding hba where can I see that? Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted May 7, 2022 Author Share #159 Posted May 7, 2022 15 minutes ago, Elias Jara said: Unfortunately, my motherboard does not have a model, but I am attaching some screenshots of the bios. It has 4 sata ports. Regarding hba where can I see that? You are using a translator from Spanish to English, and I am using a translator from Korean to English, but there seems to be some communication problem. I'm not sure what you mean by not knowing the model of your motherboard, but is it a total of 4 built-in SATA ports? Among them, the 3rd and 4th ports were talking about asking the motherboard model to find out if the port is a shared muxed port. Since we do not know the model, it may be more difficult to catch errors by guessing alone. Does not know the model of the motherboard mean that you cannot even disassemble the PC case? Try changing SataportMap to 4 instead of 6, and if the error is still repeated, install DSM in the state reduced to 1. If you are migrating from DSM 6 to 7, you may have to recognize all installed disks at once. New installation or migration? Quote Link to comment Share on other sites More sharing options...
Elias Jara Posted May 7, 2022 Share #160 Posted May 7, 2022 4 minutes ago, Peter Suh said: Usted está usando un traductor de español a inglés y yo estoy usando un traductor de coreano a inglés, pero parece haber algún problema de comunicación. No estoy seguro de lo que quiere decir con no saber el modelo de su placa base, pero ¿es un total de 4 puertos SATA integrados? Entre ellos, los puertos tercero y cuarto hablaban de preguntarle al modelo de la placa base para averiguar si el puerto es un puerto multiplexado compartido. Dado que no conocemos el modelo, puede ser más difícil detectar errores adivinando solo. ¿No sabe el modelo de la placa base, lo que significa que ni siquiera puede desmontar la carcasa de la PC? Intente cambiar SataportMap a 4 en lugar de 6 y, si el error aún se repite, instale DSM en el estado reducido a 1. Si está migrando de DSM 6 a 7, es posible que deba reconocer todos los discos instalados a la vez. ¿Nueva instalación o migración? Voy a escribir en español asi no tiene problemas con el tema de la traduccion, si desarme mi pc pero en la placa base no se ve el modelo o marca, mi placa tiene 4 puertos sata. ya intercambie satamap del 1 al 15 y no funciono. intente migrar pero no funciono, entonces borre todo y hice una instalacion limpia. Como seria instalar en estado reducido si me podria indicar por favor ? Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted May 7, 2022 Author Share #161 Posted May 7, 2022 14 minutes ago, Elias Jara said: Voy a escribir en español asi no tiene problemas con el tema de la traduccion, si desarme mi pc pero en la placa base no se ve el modelo o marca, mi placa tiene 4 puertos sata. ya intercambie satamap del 1 al 15 y no funciono. intente migrar pero no funciono, entonces borre todo y hice una instalacion limpia. Como seria instalar en estado reducido si me podria indicar por favor ? Así que estás diciendo que has intentado desmontarlo. Estás en el proceso de instalar uno nuevo. Si es así, ¿es posible dejar físicamente solo el disco WD de 750 GB en Sata Port1 y dejar el resto extraíble? ¿Y has probado con SATAportMap=1? No sé el modelo de la placa base, pero parece que hay un problema incluso cuando el Hot Plug está encendido, por lo que parece que MUXED, un puerto compartido, no se puede considerar. Si es así, es mejor considerar cambiar a DS920 en lugar de DS3622. Sé que el DS920 puede eludir este problema MUXED debido al enfoque DTC. Si es posible, intente la compilación DS920+ nuevamente usando mi M SHELL. DS920+ realiza la asignación de puertos mediante el método DTC y no se utiliza SataPortMap. Quote Link to comment Share on other sites More sharing options...
Elias Jara Posted May 7, 2022 Share #162 Posted May 7, 2022 Just now, Peter Suh said: Así que estás diciendo que has intentado desmontarlo. Estás en el proceso de instalar uno nuevo. Si es así, ¿es posible dejar físicamente solo el disco WD de 750 GB en Sata Port1 y dejar el resto extraíble? ¿Y has probado con SATAportMap=1? No sé el modelo de la placa base, pero parece que hay un problema incluso cuando el Hot Plug está encendido, por lo que parece que MUXED, un puerto compartido, no se puede considerar. Si es así, es mejor considerar cambiar a DS920 en lugar de DS3622. Sé que el DS920 puede eludir este problema MUXED debido al enfoque DTC. Si es posible, intente la compilación DS920+ nuevamente usando mi M SHELL. DS920+ realiza la asignación de puertos mediante el método DTC y no se utiliza SataPortMap. Si, hice eso pero con el DS918+. y no funciono le puse en sataportmap=1. Ahora voy a probar con la version que me dices. Instale windows para poder ver que placa madre tenia me dice: lntel H81 1150 Motherboard Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted May 7, 2022 Author Share #163 Posted May 7, 2022 4 minutes ago, Elias Jara said: Si, hice eso pero con el DS918+. y no funciono le puse en sataportmap=1. Ahora voy a probar con la version que me dices. Instale windows para poder ver que placa madre tenia me dice: lntel H81 1150 Motherboard No es necesario instalar Windows 10 para saber el modelo de placa base. Pruebe el siguiente enlace a la guía de instalación de M SHELL. Quote Link to comment Share on other sites More sharing options...
Elias Jara Posted May 7, 2022 Share #164 Posted May 7, 2022 Instale el DS920+ y todo apunta a que funciona. el .Pat debo descargarlo de la pagina? Quote Link to comment Share on other sites More sharing options...
Elias Jara Posted May 7, 2022 Share #165 Posted May 7, 2022 34 minutes ago, Elias Jara said: Si, hice eso pero con el DS918+. y no funciono le puse en sataportmap=1. Ahora voy a probar con la version que me dices. Instale windows para poder ver que placa madre tenia me dice: lntel H81 1150 Motherboard Siiiii me funciono, solo tengo un pequeño problema. tengo un ADAPATADOR RJ45 TP-LINK USB 3.0 UE300 ETHERNET GIGABIT pero no me reconocio, debo instalar algun controlador extra, o debo hacer la instalacion de DSM de nuevo ? Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted May 7, 2022 Author Share #166 Posted May 7, 2022 (edited) 17 minutes ago, Elias Jara said: Siiiii me funciono, solo tengo un pequeño problema. tengo un ADAPATADOR RJ45 TP-LINK USB 3.0 UE300 ETHERNET GIGABIT pero no me reconocio, debo instalar algun controlador extra, o debo hacer la instalacion de DSM de nuevo ? Felicitaciones por la instalación exitosa de su DS920+. "UE300" parece ser su segunda NIC. No se requiere una instalación nueva de DSM. UE300 usa el chipset r8153 y es compatible con r8152. Por lo tanto, descargue la versión de GeminiLake del archivo spk desde el siguiente enlace. Instale manualmente dentro del administrador de paquetes y siga las instrucciones en el enlace a continuación para el resto del proceso. https://github.com/bb-qq/r8152/releases Edited May 7, 2022 by Peter Suh Quote Link to comment Share on other sites More sharing options...
Elias Jara Posted May 7, 2022 Share #167 Posted May 7, 2022 Me dice un error, he probado reiniciar pero igual no detecta Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted May 7, 2022 Author Share #168 Posted May 7, 2022 (edited) 59 minutes ago, Elias Jara said: Me dice un error, he probado reiniciar pero igual no detecta El español capturado por la imagen no se puede traducir, por lo que no puedo entenderlo. ¿Ejecutó los siguientes comandos por separado de acuerdo con la guía en ese enlace? Para la operación anterior, debe abrir el puerto SSH 22 en DS920+. La instalación fallará la primera vez. Después de eso, ejecute el siguiente comando desde la terminal SSH: sudo install -m 4755 -o root -D /var/packages/r8152/target/r8152/spk_su /opt/sbin/spk_su Si el error persiste incluso después de ejecutar el comando anterior No parece haber nada más que pueda hacer para ayudar. Pregunte a bb-qq en github por problemas. Edited May 7, 2022 by Peter Suh 1 Quote Link to comment Share on other sites More sharing options...
Elias Jara Posted May 7, 2022 Share #169 Posted May 7, 2022 esto fue lo que me salio Quote Link to comment Share on other sites More sharing options...
Elias Jara Posted May 7, 2022 Share #170 Posted May 7, 2022 1 minute ago, Elias Jara said: esto fue lo que me salio Ya funcionando cometi un error y no puse la contraseña. Muchisimas gracias por tu ayuda 1 Quote Link to comment Share on other sites More sharing options...
mattias93 Posted May 7, 2022 Share #171 Posted May 7, 2022 Hi @Peter Suh, As you suggested, I tried to install DS920+. In this case, I can never access the DSM, after it reboots, it asks me for the PAT file again. I've attached the log. The log looks like the previous one. @pocopico Peter said that you could understand what's going on Spoiler SynologyNAS> more linuxrc.syno.log START /linuxrc.syno.impl '/etc.defaults/model.dtb' -> '/var/run/model.dtb' Insert basic USB modules... :: Loading module usb-common ... [ OK ] :: Loading module usbcore ... [ OK ] :: Loading module xhci-hcd ... [ OK ] :: Loading module xhci-pci ... [ OK ] :: Loading module usb-storage ... [ OK ] :: Loading kernel modules from extensions ... Loading kmod #0 "e1000e.ko" for pocopico.e1000e (args: ) Loading kmod #0 "igb.ko" for pocopico.igb (args: ) :: Loading kernel modules from extensions ... [ OK ] :: Executing "on_boot" custom scripts ... Running "check-e1000e.sh" for pocopico.e1000e->on_boot Loading module e1000e -> Module e1000e loaded succesfully Ran "check-e1000e.sh" for pocopico.e1000e->on_boot - exit=0 Running "check-igb.sh" for pocopico.igb->on_boot Loading module igb -> Module igb loaded succesfully Ran "check-igb.sh" for pocopico.igb->on_boot - exit=0 Running "boot-wait.sh" for redpill-boot-wait->on_boot Still waiting for boot device (waited 1 of 30 seconds) Still waiting for boot device (waited 2 of 30 seconds) Still waiting for boot device (waited 3 of 30 seconds) Still waiting for boot device (waited 4 of 30 seconds) The /dev/synoboot device exists but it does not contain expected partitions (>=3 partitions) ========== BEGIN DUMP OF ALL PARTITIONS DETECTED =========== /dev/sata1p1 8192 16785407 16777216 fd /dev/sata1p2 16785408 20979711 4194304 fd /dev/sata1p5 21257952 7813827135 7792569184 fd /dev/sata2p1 8192 16785407 16777216 fd /dev/sata2p2 16785408 20979711 4194304 fd /dev/sata2p5 21257952 7813827135 7792569184 fd /dev/sata3p1 2048 500103449 500101402 fd /dev/synobootp1 2048 100351 98304 83 /dev/synobootp2 100352 253951 153600 83 /dev/synobootp3 253952 2097151 1843200 83 ========== END OF DUMP OF ALL PARTITIONS DETECTED ========== Ran "boot-wait.sh" for redpill-boot-wait->on_boot - exit=1 Running "install_rd.sh" for redpill-dtb->on_boot 'model_ds920p.dtb' -> '/etc.defaults/model.dtb' 'model_ds920p.dtb' -> '/var/run/model.dtb' Ran "install_rd.sh" for redpill-dtb->on_boot - exit=0 Running "install_rd.sh" for redpill-misc->on_boot Starting ttyd, listening on port: 7681 Ran "install_rd.sh" for redpill-misc->on_boot - exit=0 ERROR: Some of the scripts failed! See above for any with exit != 0 :: Executing "on_boot" custom scripts ... [ OK ] Exit on error [99] rp ext init exec failure... Sat May 7 19:25:40 UTC 2022 none /sys/kernel/debug debugfs rw,relatime 0 0 linuxrc.syno.log Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted May 7, 2022 Author Share #172 Posted May 7, 2022 (edited) 2 hours ago, mattias93 said: Hi @Peter Suh, As you suggested, I tried to install DS920+. In this case, I can never access the DSM, after it reboots, it asks me for the PAT file again. I've attached the log. The log looks like the previous one. @pocopico Peter said that you could understand what's going on linuxrc.syno.log (Reveal hidden contents) SynologyNAS> more linuxrc.syno.log START /linuxrc.syno.impl '/etc.defaults/model.dtb' -> '/var/run/model.dtb' Insert basic USB modules... :: Loading module usb-common ... [ OK ] :: Loading module usbcore ... [ OK ] :: Loading module xhci-hcd ... [ OK ] :: Loading module xhci-pci ... [ OK ] :: Loading module usb-storage ... [ OK ] :: Loading kernel modules from extensions ... Loading kmod #0 "e1000e.ko" for pocopico.e1000e (args: ) Loading kmod #0 "igb.ko" for pocopico.igb (args: ) :: Loading kernel modules from extensions ... [ OK ] :: Executing "on_boot" custom scripts ... Running "check-e1000e.sh" for pocopico.e1000e->on_boot Loading module e1000e -> Module e1000e loaded succesfully Ran "check-e1000e.sh" for pocopico.e1000e->on_boot - exit=0 Running "check-igb.sh" for pocopico.igb->on_boot Loading module igb -> Module igb loaded succesfully Ran "check-igb.sh" for pocopico.igb->on_boot - exit=0 Running "boot-wait.sh" for redpill-boot-wait->on_boot Still waiting for boot device (waited 1 of 30 seconds) Still waiting for boot device (waited 2 of 30 seconds) Still waiting for boot device (waited 3 of 30 seconds) Still waiting for boot device (waited 4 of 30 seconds) The /dev/synoboot device exists but it does not contain expected partitions (>=3 partitions) ========== BEGIN DUMP OF ALL PARTITIONS DETECTED =========== /dev/sata1p1 8192 16785407 16777216 fd /dev/sata1p2 16785408 20979711 4194304 fd /dev/sata1p5 21257952 7813827135 7792569184 fd /dev/sata2p1 8192 16785407 16777216 fd /dev/sata2p2 16785408 20979711 4194304 fd /dev/sata2p5 21257952 7813827135 7792569184 fd /dev/sata3p1 2048 500103449 500101402 fd /dev/synobootp1 2048 100351 98304 83 /dev/synobootp2 100352 253951 153600 83 /dev/synobootp3 253952 2097151 1843200 83 ========== END OF DUMP OF ALL PARTITIONS DETECTED ========== Ran "boot-wait.sh" for redpill-boot-wait->on_boot - exit=1 Running "install_rd.sh" for redpill-dtb->on_boot 'model_ds920p.dtb' -> '/etc.defaults/model.dtb' 'model_ds920p.dtb' -> '/var/run/model.dtb' Ran "install_rd.sh" for redpill-dtb->on_boot - exit=0 Running "install_rd.sh" for redpill-misc->on_boot Starting ttyd, listening on port: 7681 Ran "install_rd.sh" for redpill-misc->on_boot - exit=0 ERROR: Some of the scripts failed! See above for any with exit != 0 :: Executing "on_boot" custom scripts ... [ OK ] Exit on error [99] rp ext init exec failure... Sat May 7 19:25:40 UTC 2022 none /sys/kernel/debug debugfs rw,relatime 0 0 linuxrc.syno.log 2.75 kB · 1 download Before you ask @pocopico, there are a few things I want to check. I saw the usb-storage in the log Did you use a USB external disk? I see a lot of devices attached to USB ports, but what are they all? If you are thinking of configuring XPENOLOGY only with USB-type disks, it is not a good idea. Send additional logs using lspci -tvnnq in tc Linux. Edited May 7, 2022 by Peter Suh Quote Link to comment Share on other sites More sharing options...
mattias93 Posted May 8, 2022 Share #173 Posted May 8, 2022 9 hours ago, Peter Suh said: Before you ask @pocopico, there are a few things I want to check. I saw the usb-storage in the log Did you use a USB external disk? I see a lot of devices attached to USB ports, but what are they all? If you are thinking of configuring XPENOLOGY only with USB-type disks, it is not a good idea. Send additional logs using lspci -tvnnq in tc Linux. Hi Peter, here's the result: Spoiler -[0000:00]-+-00.0 Intel Corporation 8th/9th Gen Core Processor Host Bridge/DRAM Registers [Coffee Lake] [8086:3e33] +-01.0-[01]--+-00.0 NVIDIA Corporation GF119 [NVS 310] [10de:107d] | \-00.1 NVIDIA Corporation GF119 HDMI Audio Controller [10de:0e08] +-08.0 Intel Corporation Skylake Gaussian Mixture Model [8086:1911] +-12.0 Intel Corporation Cannon Lake PCH Thermal Controller [8086:a379] +-14.0 Intel Corporation Cannon Lake PCH USB 3.1 xHCI Host Controller [8086:a36d] +-14.2 Intel Corporation Cannon Lake PCH Shared SRAM [8086:a36f] +-15.0 Intel Corporation Cannon Lake PCH Serial IO I2C Controller #0 [8086:a368] +-16.0 Intel Corporation Cannon Lake PCH HECI Controller [8086:a360] +-17.0 Intel Corporation Cannon Lake PCH SATA AHCI Controller [8086:a352] +-1b.0-[02]-- +-1b.4-[03]----00.0 Intel Corporation I210 Gigabit Network Connection [8086:1533] +-1d.0-[04]-- +-1d.2-[05-06]----00.0-[06]-- +-1f.0 Intel Corporation Cannon Point-LP LPC Controller [8086:a309] +-1f.4 Intel Corporation Cannon Lake PCH SMBus Controller [8086:a323] +-1f.5 Intel Corporation Cannon Lake PCH SPI Controller [8086:a324] \-1f.6 Intel Corporation Ethernet Connection (7) I219-LM [8086:15bb] and Spoiler Protocol spec without prior Class and Subclass spec at line 23281 Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 001 Device 003: ID 1ea7:0907 SHARKOON Technologies GmbH Keyboard Bus 001 Device 002: ID 0951:1666 Kingston Technology DataTraveler 100 G3/G4/SE9 G2/50 Bus 001 Device 004: ID 046d:c52b Logitech, Inc. Unifying Receiver Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub There are 3 devices connected via USB: USB Stick, USB Keyboard and USB Mouse adapter (Logitech Unifying). No usb hard drive connected. Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted May 8, 2022 Author Share #174 Posted May 8, 2022 (edited) 1 hour ago, mattias93 said: Hi Peter, here's the result: lspci -tvnnq (Hide contents) -[0000:00]-+-00.0 Intel Corporation 8th/9th Gen Core Processor Host Bridge/DRAM Registers [Coffee Lake] [8086:3e33] +-01.0-[01]--+-00.0 NVIDIA Corporation GF119 [NVS 310] [10de:107d] | \-00.1 NVIDIA Corporation GF119 HDMI Audio Controller [10de:0e08] +-08.0 Intel Corporation Skylake Gaussian Mixture Model [8086:1911] +-12.0 Intel Corporation Cannon Lake PCH Thermal Controller [8086:a379] +-14.0 Intel Corporation Cannon Lake PCH USB 3.1 xHCI Host Controller [8086:a36d] +-14.2 Intel Corporation Cannon Lake PCH Shared SRAM [8086:a36f] +-15.0 Intel Corporation Cannon Lake PCH Serial IO I2C Controller #0 [8086:a368] +-16.0 Intel Corporation Cannon Lake PCH HECI Controller [8086:a360] +-17.0 Intel Corporation Cannon Lake PCH SATA AHCI Controller [8086:a352] +-1b.0-[02]-- +-1b.4-[03]----00.0 Intel Corporation I210 Gigabit Network Connection [8086:1533] +-1d.0-[04]-- +-1d.2-[05-06]----00.0-[06]-- +-1f.0 Intel Corporation Cannon Point-LP LPC Controller [8086:a309] +-1f.4 Intel Corporation Cannon Lake PCH SMBus Controller [8086:a323] +-1f.5 Intel Corporation Cannon Lake PCH SPI Controller [8086:a324] \-1f.6 Intel Corporation Ethernet Connection (7) I219-LM [8086:15bb] and lsusb (Hide contents) Protocol spec without prior Class and Subclass spec at line 23281 Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub Bus 001 Device 003: ID 1ea7:0907 SHARKOON Technologies GmbH Keyboard Bus 001 Device 002: ID 0951:1666 Kingston Technology DataTraveler 100 G3/G4/SE9 G2/50 Bus 001 Device 004: ID 046d:c52b Logitech, Inc. Unifying Receiver Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub There are 3 devices connected via USB: USB Stick, USB Keyboard and USB Mouse adapter (Logitech Unifying). No usb hard drive connected. I see a lot of controllers with unique names that I haven't seen before, is it APPLE Macintosh PC? Or a laptop? What is the model name of the motherboard? Edited May 8, 2022 by Peter Suh Quote Link to comment Share on other sites More sharing options...
mattias93 Posted May 8, 2022 Share #175 Posted May 8, 2022 (edited) 20 minutes ago, Peter Suh said: I see a lot of controllers with unique names that I haven't seen before, is it APPLE Macintosh PC? What is the model name of the main board? No, it's a Dell Precision 3630 https://www.dell.com/ko-kr/shop/cty/pdp/spd/precision-3630-workstation#configurations_section Dell produces the motherboard for this device, so it doesn't have a name. It has a Intel Xeon 2124 processor. So far I tried: ds3622xs+ could boot, after some reboots the reinstall loop happens. ds920+ reinstall loop. ds918+ reinstall loop. ds3615xs Could boot, running some test to see if it's stable ds3617xs no network ds1621+ no network dva3221 no network Edited May 8, 2022 by mattias93 Quote Link to comment Share on other sites More sharing options...
