Prutzer Posted June 4, 2022 Share #326 Posted June 4, 2022 (edited) I am trying to install Xpenology 7.1 on a Gigabyte GA-N3150N-D3V mainboard with an Intel Celeron N3150 processor. I created a bootable usb drive with Tinycore Redpill 8.0.0. When booting I got the error: Failed in waitforx. Ok: Solution: Use a faster USB drive. I'm now booting with an USB 3.0 drive and X is starting. Edited June 4, 2022 by Prutzer Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted June 7, 2022 Author Share #327 Posted June 7, 2022 (edited) I would like to share again some of the misconceptions about the jun mode build of TCRP. Successfully updated from 7.0.1-42218 u4 to 7.1.0-42661 u2 on 6 models except for current ds920+. Last month, @pocopico released version 0.7.1.4 of TCRP on 5/17. He mentioned just one line, but I don't know if I didn't pay attention. Since then, the use of jun mode in TCRP has not been promoted and there is no guide, so it seems that some users misunderstand that jun mode is not available in TCRP. As in the text of the link above, you need to add one more jun option at the end. ./rploader.sh build broadwellnk-7.0.1-42218-JUN jun However, if you build like this without this jun option as shown below, there is no error. ./rploader.sh build broadwellnk-7.0.1-42218-JUN However, if you build like this, it will be built in abnormal mode, not in Jot mode or Jun mode. As if it was built in Jun mode, the grub boot menu called Yet Another Jun's Mode also looks changed, so it is easy to be mistaken. I also made a mistake on this part. It has been modified to enable normal build by adding the missing jun option to the m shell. ./my.sh DS918+J ./my.sh DS3615xsJ ./my.sh DS3617xsJ ./my.sh DS3622xs+J ./my.sh DVA3221J ./my.sh DS920+J jumkey ./my.sh DS1621+J jumkey When it is built in jun mode, the log that you normally can't see rises considerably. Finally, it seems that the process of making a new custum.gz file and patching it goes into it. It has been confirmed that it is currently working well on DS918+ DS3615xs DS3617xs DS3622xs DVA3221 DS1621+ baremetal. As shared by @dolbycat, it takes a while for all of JUN to recognize the LAN. Please take that into consideration and use it. Attached here are the test results. Edited June 7, 2022 by Peter Suh Quote Link to comment Share on other sites More sharing options...
berzek Posted June 7, 2022 Share #328 Posted June 7, 2022 On 5/30/2022 at 9:44 PM, pocopico said: A good alternative would be to change the usb port that you have your loader connected. Quoted in relation to DSM setup getting stalled at 55% or 66%. - After facing the same problem earlier, I managed to get to a working DS3622xs+ by simply trying out the USB Loader from another USB port on the Baremetal HW. .hth 1 Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted June 8, 2022 Author Share #329 Posted June 8, 2022 The second parameter "now" is a completely unnecessary parameter. It was initially misguided from pocopico. Even if "now" is removed and used, everything works normally. I am in the process of guiding again to remove this "now" from the guide I made. Quote Link to comment Share on other sites More sharing options...
cobra_mk Posted June 8, 2022 Share #330 Posted June 8, 2022 (edited) what is the difference between the normal and the jun version? is it only the point that i can use the old config file? And can i use the original origibal pat files from synology or is another file needed Edited June 8, 2022 by cobra_mk Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted June 9, 2022 Author Share #331 Posted June 9, 2022 8 hours ago, cobra_mk said: what is the difference between the normal and the jun version? is it only the point that i can use the old config file? And can i use the original origibal pat files from synology or is another file needed The difference between the regular version (JOT) and the JUN version is that in the JUN mode, it dynamically responds to DSM REVISION that is continuously updated in the future. It is also called JUN's OLD TRICK as it was used in JUN's DSM 6 in the past. The existing JOT mode sometimes requires a new loader build whenever a new DSM REVISION is released, but in the JUN mode, there is no need for that. Instead, JUN mode must start build from 7.0.1-42218. Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted June 9, 2022 Author Share #332 Posted June 9, 2022 And for the pat file used for XPE installation, the original file must be used in any case. Please avoid using PAT files that have undergone encryption/decryption process. Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted June 10, 2022 Author Share #333 Posted June 10, 2022 [NOTICE] It seems that @pocopico has been very busy lately. It was not possible to build the ds920+ jun mode because it was not fixed correctly yet. I made it possible to build it through my m shell. Download the latest version to ./my.sh again. You can build it like this. ./my.sh DS920+J jumkey Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted June 11, 2022 Author Share #334 Posted June 11, 2022 With the help of @dolbycat ds920+ / ds1621+ jun mode build for TC The nic waiting time was reduced from 3 minutes to 2 minutes and 10 seconds. Modification of sha256sum of ds920+ 42218 config.json requested by @pocopico may not be necessary at this time. As for the jun mode, it was completely switched to refer only to @jumkey's repo, and it was possible to build so that even the use of dynamic dtc patches was possible in TC without any problem. It has been changed to be able to respond to both dtc models in m shell. (jumkey option is whether or not to use dynamic dtc patch) ./my.sh ds920+J jumkey ./my.sh ds1621+J jumkey If additional ext is needed in the VM environment, use it as follows. ./myv.sh ds920+J jumkey ./myv.sh ds1621+J jumkey 2 Quote Link to comment Share on other sites More sharing options...
TheInternets Posted June 13, 2022 Share #335 Posted June 13, 2022 (edited) Hey there, I just installed a 920+ baremetal on an asrock J4105 board. That one has 2 sata controllers on board - the intel one and an asmedia one - plus one that is plugged in via PCIE. I had a baremetal DS3622xs+ installation before which recognized all drives - not so much on the 920. Any idea what i need to change? I wanted to move to the 920p as the processor is closer to the one on the board and i've read that i could probably use hardware decoding by using the igpu. PS: Great work on the tc launcher - really makes installing so much easier! Edited June 13, 2022 by TheInternets 1 Quote Link to comment Share on other sites More sharing options...
maxime Posted June 14, 2022 Share #336 Posted June 14, 2022 Probably I'm stupid, but I can't understand how to upgrade working DS3622xs+ 7.0.1-42218 to DSM 7.1.0-42661 😥 Can someone help me to understand? If I understand, I should do this: 1. manual update DSM to 7.1.0-42661 (within DSM) 2. reboot the XPEnology server and choose TinyCore on startup (3rd menù item) 3. execute this commands: ./rploader.sh clean now ./rploader.sh ext broadwellnk-7.1.0-42661 add https://github.com/jimmyGALLAND/redpill-ext/raw/master/acpid/rpext-index.json ./rploader.sh build bromolow-7.1.0-42661 ./rploader.sh clean now; rm -rf /mnt/sdb3/auxfiles; rm -rf /home/tc/custom-module; ./rploader.sh backup now 4. reboot DSM 5. manual update DSM to 7.1.0-42661-1 (within DSM) 6. reboot DSM 7. manual update DSM to 7.1.0-42661-2 (within DSM) Is this correct? Thanks to all! Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted June 14, 2022 Author Share #337 Posted June 14, 2022 14 hours ago, TheInternets said: Hey there, I just installed a 920+ baremetal on an asrock J4105 board. That one has 2 sata controllers on board - the intel one and an asmedia one - plus one that is plugged in via PCIE. I had a baremetal DS3622xs+ installation before which recognized all drives - not so much on the 920. Any idea what i need to change? I wanted to move to the 920p as the processor is closer to the one on the board and i've read that i could probably use hardware decoding by using the igpu. PS: Great work on the tc launcher - really makes installing so much easier! In the case of ds920+ using jumkey's dynamic dtb, the maximum supported number of drives is only 4, and there is a restriction that only the built-in sata port should be used. Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted June 14, 2022 Author Share #338 Posted June 14, 2022 (edited) 9 minutes ago, maxime said: Probably I'm stupid, but I can't understand how to upgrade working DS3622xs+ 7.0.1-42218 to DSM 7.1.0-42661 😥 Can someone help me to understand? If I understand, I should do this: 1. manual update DSM to 7.1.0-42661 (within DSM) 2. reboot the XPEnology server and choose TinyCore on startup (3rd menù item) 3. execute this commands: ./rploader.sh clean now ./rploader.sh ext broadwellnk-7.1.0-42661 add https://github.com/jimmyGALLAND/redpill-ext/raw/master/acpid/rpext-index.json ./rploader.sh build bromolow-7.1.0-42661 ./rploader.sh clean now; rm -rf /mnt/sdb3/auxfiles; rm -rf /home/tc/custom-module; ./rploader.sh backup now 4. reboot DSM 5. manual update DSM to 7.1.0-42661-1 (within DSM) 6. reboot DSM 7. manual update DSM to 7.1.0-42661-2 (within DSM) Is this correct? Thanks to all! For DS3622xs+, it seems like the first thing to do is to unify them all with broadwellnk. Change everything to broadwellnk and rebuild from scratch. As below, perform the patch for 7.1.0-42661 update 2 once more. ./rploader.sh postupdate broadwellnk-7.1.0-42661 Edited June 14, 2022 by Peter Suh 1 Quote Link to comment Share on other sites More sharing options...
maxime Posted June 14, 2022 Share #339 Posted June 14, 2022 (edited) 8 minutes ago, Peter Suh said: As below, perform the patch for 7.1.0-42661 update 2 once more. ./rploader.sh postupdate bromolow-7.1.0-42661 Where on my list do I have to execute ./rploader.sh postupdate bromolow-7.1.0-42661? At the end of "3."? Edited June 14, 2022 by maxime Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted June 14, 2022 Author Share #340 Posted June 14, 2022 13 minutes ago, maxime said: Where on my list do I have to execute ./rploader.sh postupdate bromolow-7.1.0-42661? At the end of "3."? Yes 1 Quote Link to comment Share on other sites More sharing options...
maxime Posted June 14, 2022 Share #341 Posted June 14, 2022 (edited) error. sorry Edited June 14, 2022 by maxime Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted June 14, 2022 Author Share #342 Posted June 14, 2022 5 minutes ago, maxime said: error. sorry You're still not sure if it's broadwellnk or bromolow. Did you choose bromolow (DS3615xs), not DS3622xs+? Quote Link to comment Share on other sites More sharing options...
maxime Posted June 14, 2022 Share #343 Posted June 14, 2022 1 minute ago, Peter Suh said: You're still not sure if it's broadwellnk or bromolow. Did you choose bromolow (DS3615xs), not DS3622xs+? I wrote bromolow instead of broadwellnk 🤬 Quote Link to comment Share on other sites More sharing options...
maxime Posted June 14, 2022 Share #344 Posted June 14, 2022 51 minutes ago, Peter Suh said: You're still not sure if it's broadwellnk or bromolow. Did you choose bromolow (DS3615xs), not DS3622xs+? I did the procedure one more time. Now after "./rploader.sh postupdate broadwellnk-7.1.0-42661" I have to edit user_config.json and change SataPortMap=2 DiskIdxMap=00 After changed user_config.json and saved it, how do I apply the modified user_config.json? It seems that the system keep loading the original user_config.json... Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted June 14, 2022 Author Share #345 Posted June 14, 2022 8 minutes ago, maxime said: I did the procedure one more time. Now after "./rploader.sh postupdate broadwellnk-7.1.0-42661" I have to edit user_config.json and change SataPortMap=2 DiskIdxMap=00 After changed user_config.json and saved it, how do I apply the modified user_config.json? It seems that the system keep loading the original user_config.json... Please tell me the model name of your motherboard. Also, turn on all hot plug options in the bios. Are you using only 2 HDDs for the built-in sata port? Quote Link to comment Share on other sites More sharing options...
maxime Posted June 14, 2022 Share #346 Posted June 14, 2022 4 minutes ago, Peter Suh said: Please tell me the model name of your motherboard. Also, turn on all hot plug options in the bios. Are you using only 2 HDDs for the built-in sata port? The mainboard is a ASUS P8H61-M LE/USB3; it has only 4 sata ports, I don't understand why the system find 6 ports... All the 4 sata ports are set as hotplug in the bios. The only way i found to install is set only 2 sata ports Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted June 15, 2022 Author Share #347 Posted June 15, 2022 (edited) 20 hours ago, maxime said: The mainboard is a ASUS P8H61-M LE/USB3; it has only 4 sata ports, I don't understand why the system find 6 ports... All the 4 sata ports are set as hotplug in the bios. The only way i found to install is set only 2 sata ports It is unfortunate that only 2 out of 4 Sata Ports can be used in DS3622xs which is None dtc method. It remains to be seen whether all motherboards with the H61 chipset are like that. Interesting fact. Alternatively, use the Linux DT (Device Tree) as a DS920+ or DS1621+ Try changing the installation model. There is no need to worry as the migration from the installed DS3622xs+ to DS920+ etc. will be smooth. Even if something goes wrong, install DS3622xs+ again and migrate once more. I will show you how to build more easily by using the m shell I developed. Download and decompress my.sh with the following command in TC linux. tc@box:~$ curl --location "https://github.com/PeterSuh-Q3/tinycore-redpill/raw/main/my.sh.gz" --output my.sh.gz; tar -zxvf my.sh.gz; After that, if you use the following command line, SN/MAC/VID/PID and build are processed at once. ./rploader.sh clean ./my.sh DS920+J jumkey This option builds DS920+ in jun mode with jumkey's dynamic dtc method. For jun mode, refer to the discussion in the forum, The advantage of jumkey's dynamic dtc is that it can avoid the issue of ghost ports or muxed ports (M.2 + Sata Mix) as above. Also, the newly added disk without using sataportmap automatically recognizes whether it is installed or not. DS920+ supports up to 4 disks, DS1621+ supports up to 6 disks, It must be used only with the built-in SATA port. Edited June 15, 2022 by Peter Suh Quote Link to comment Share on other sites More sharing options...
The_Mole Posted June 17, 2022 Share #348 Posted June 17, 2022 Hi there, you guys might be able to save me some time, figuring this out: System is a Fujitsu Esprimo P720 E90, running on a Xeon E3-1275L V3 (Haswell based). There are 13 disks in the system - 5 attached to the mainboard, 8 attached to a Fujitsu D2607-A21 SAS controller (LSI SAS2008), crossflashed to 9211-8i in IT Mode. Another one of those controllers is sitting there empty until I need to add more space. Currently, I'm running my install as DS3615xs on 6.2.3-25426 with Jun's loader 1.03b. I tried upgrading to Redpill as DS918+ on 7.1.0-42661 to enable video encoding but I only get the 5 disks on the mainboard to show up. The ones on the SAS controller that are working with mpt2sas-driver on 6.2.3 do not appear on 7.1.0, even if I add the driver to Redpill. Latest approach was: ./rploader.sh update now ./rploader.sh fullupgrade now ./rploader.sh serialgen DS918+ ./rploader.sh identifyusb now ./rploader.sh satamap now tce-load -wi nano #because I hate vi nano user_config.json #edited to hardware MAC, a different 918+ serial and set maxdisks to 24 ./rploader.sh ext apollolake-7.0.1-42218 add https://raw.githubusercontent.com/pocopico/rp-ext/master/mpt2sas/rpext-index.json ./rploader.sh build apollolake-7.0.1-42218 ./rploader.sh clean now ./rploader.sh ext apollolake-7.1.0-42661 add https://raw.githubusercontent.com/pocopico/rp-ext/master/mpt2sas/rpext-index.json ./rploader.sh build apollolake-7.1.0-42661 ./rploader.sh clean now; rm -rf /mnt/sdb3/auxfiles; rm -rf /home/tc/custom-module; ./rploader.sh backup now; sudo reboot Output from lspci -k (on 6.2.3) - Kernel driver won't show up on 7.1.0: 0000:01:00.0 Class 0104: Device 1000:0072 (rev 02) Subsystem: Device 1734:1177 Kernel driver in use: mpt2sas 0000:03:00.0 Class 0104: Device 1000:0072 (rev 03) Subsystem: Device 1734:1177 Kernel driver in use: mpt2sas Output from ll /sys/block (on 6.2.3) - only sda-sde appear on 7.1.0: lrwxrwxrwx 1 root root 0 Jun 17 14:47 sda -> ../devices/pci0000:00/0000:00:1f.2/ata1/host0/target0:0:0/0:0:0:0/block/sda lrwxrwxrwx 1 root root 0 Jun 17 14:47 sdb -> ../devices/pci0000:00/0000:00:1f.2/ata2/host1/target1:0:0/1:0:0:0/block/sdb lrwxrwxrwx 1 root root 0 Jun 17 14:47 sdc -> ../devices/pci0000:00/0000:00:1f.2/ata3/host2/target2:0:0/2:0:0:0/block/sdc lrwxrwxrwx 1 root root 0 Jun 17 14:47 sdd -> ../devices/pci0000:00/0000:00:1f.2/ata4/host3/target3:0:0/3:0:0:0/block/sdd lrwxrwxrwx 1 root root 0 Jun 17 14:47 sde -> ../devices/pci0000:00/0000:00:1f.2/ata5/host4/target4:0:0/4:0:0:0/block/sde lrwxrwxrwx 1 root root 0 Jun 17 14:47 sdh -> ../devices/pci0000:00/0000:00:1c.4/0000:03:00.0/host7/port-7:0/end_device-:0/target7:0:0/7:0:0:0/block/sdh lrwxrwxrwx 1 root root 0 Jun 17 14:47 sdi -> ../devices/pci0000:00/0000:00:1c.4/0000:03:00.0/host7/port-7:1/end_device-:1/target7:0:1/7:0:1:0/block/sdi lrwxrwxrwx 1 root root 0 Jun 17 14:47 sdj -> ../devices/pci0000:00/0000:00:1c.4/0000:03:00.0/host7/port-7:2/end_device-:2/target7:0:2/7:0:2:0/block/sdj lrwxrwxrwx 1 root root 0 Jun 17 14:47 sdk -> ../devices/pci0000:00/0000:00:1c.4/0000:03:00.0/host7/port-7:3/end_device-:3/target7:0:3/7:0:3:0/block/sdk lrwxrwxrwx 1 root root 0 Jun 17 14:47 sdl -> ../devices/pci0000:00/0000:00:1c.4/0000:03:00.0/host7/port-7:4/end_device-:4/target7:0:4/7:0:4:0/block/sdl lrwxrwxrwx 1 root root 0 Jun 17 14:47 sdm -> ../devices/pci0000:00/0000:00:1c.4/0000:03:00.0/host7/port-7:5/end_device-:5/target7:0:5/7:0:5:0/block/sdm lrwxrwxrwx 1 root root 0 Jun 17 14:47 sdn -> ../devices/pci0000:00/0000:00:1c.4/0000:03:00.0/host7/port-7:6/end_device-:6/target7:0:6/7:0:6:0/block/sdn lrwxrwxrwx 1 root root 0 Jun 17 14:47 sdo -> ../devices/pci0000:00/0000:00:1c.4/0000:03:00.0/host7/port-7:7/end_device-:7/target7:0:7/7:0:7:0/block/sdo I'd appreciate any ideas on how to get those disks on the SAS controller to show up on 7.1.0. Thanks for your time. Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted June 17, 2022 Author Share #349 Posted June 17, 2022 (edited) 48 minutes ago, The_Mole said: Hi there, you guys might be able to save me some time, figuring this out: System is a Fujitsu Esprimo P720 E90, running on a Xeon E3-1275L V3 (Haswell based). There are 13 disks in the system - 5 attached to the mainboard, 8 attached to a Fujitsu D2607-A21 SAS controller (LSI SAS2008), crossflashed to 9211-8i in IT Mode. Another one of those controllers is sitting there empty until I need to add more space. Currently, I'm running my install as DS3615xs on 6.2.3-25426 with Jun's loader 1.03b. I tried upgrading to Redpill as DS918+ on 7.1.0-42661 to enable video encoding but I only get the 5 disks on the mainboard to show up. The ones on the SAS controller that are working with mpt2sas-driver on 6.2.3 do not appear on 7.1.0, even if I add the driver to Redpill. The combination of DS918+ and HBA is still unstable. The current HBA and the most stable model is the DS3622xs+. I'm also using the HBA and DS3622xs+ as BIOS legacy storage options. Edited June 17, 2022 by Peter Suh 1 Quote Link to comment Share on other sites More sharing options...
yeric79 Posted June 18, 2022 Share #350 Posted June 18, 2022 hi, i try install DS3622XS+ or DS920+ on ESXI, but HDD no detect after boot also with No problem with DVA3221 or DS918+ an idea ? Thanks Quote Link to comment Share on other sites More sharing options...
