Peter Suh Posted May 26, 2022 Author Share #301 Posted May 26, 2022 9 minutes ago, ulissessantos said: tc@box:~$ ./rploader.sh update now Checking Internet Access -> OK Checking if a newer version exists on the repo -> Found newversion : 0.7.1.7 Current version : 0.7.1.7 There is a newer version of the script on the repo should we use that ? [yY/nN]y OK, updating, please re-run after updating Updating tinycore loader with latest updates Backing up files to /mnt/sdc3//mydata.tgz Done. tc@box:~$ ./rploader.sh fullupgrade now Performing a full TCRP upgrade Warning some of your local files will be moved to /home/tc/old/xxxx.2022-May-24- 18-06 Updating custom_config.json % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 100 33806 100 33806 0 0 67477 0 --:--:-- --:--:-- --:--:-- 67477 Updating custom_config_jun.json % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 100 8940 100 8940 0 0 17738 0 --:--:-- --:--:-- --:--:-- 17738 Updating global_config.json % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 100 5692 100 5692 0 0 11932 0 --:--:-- --:--:-- --:--:-- 11932 Updating modules.alias.3.json.gz mv: cannot stat 'modules.alias.3.json.gz': No such file or directory % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 100 5591 100 5591 0 0 18824 0 --:--:-- --:--:-- --:--:-- 18824 Updating modules.alias.4.json.gz mv: cannot stat 'modules.alias.4.json.gz': No such file or directory % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 100 89007 100 89007 0 0 225k 0 --:--:-- --:--:-- --:--:-- 225k Updating rpext-index.json % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 100 211k 100 211k 0 0 375k 0 --:--:-- --:--:-- --:--:-- 1230k Updating user_config.json % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 100 431 100 431 0 0 872 0 --:--:-- --:--:-- --:--:-- 872 Updating dtc % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 100 146k 100 146k 0 0 268k 0 --:--:-- --:--:-- --:--:-- 464k Updating rploader.sh % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 100 88522 100 88522 0 0 229k 0 --:--:-- --:--:-- --:--:-- 229k Updating ds1621p.dts % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 100 3026 100 3026 0 0 5887 0 --:--:-- --:--:-- --:--:-- 5887 Updating ds920p.dts % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 100 2423 100 2423 0 0 4714 0 --:--:-- --:--:-- --:--:-- 4714 Please make sure you are using the latest 1GB img before using backup option Current /home/tc size is 3.8M , try to keep it less than 1GB as it might not fit into your image Should i update the sdc with your current files [Yy/Nn] y Backing up home files to sdc : Backing up files to /mnt/sdc3//mydata.tgz Done. tc@box:~$ ./rploader.sh serialgen DS3622xs+ Serial Number for Model : 2150SQRAKJT3B Mac Address for Model DS3622xs+ : 00:11:32:61:9E:67 Should i update the user_config.json with these values ? [Yy/Nn] y tc@box:~$ ./rploader.sh identifyusb now Found Verbatim STORE SerialNumber: 0173000000021AAB Vendor ID : 0x18a5 Product ID : 0x0302 Should i update the user_config.json with these values ? [Yy/Nn] y tc@box:~$ /rploader.sh satamap now -sh: /rploader.sh: not found tc@box:~$ ./rploader.sh satamap now Found "00:1f.2 Intel Corporation 82801IBM/IEM (ICH9M/ICH9M-E) 4 port SATA Contro ller [AHCI mode] (rev 03)" 2 drive(s) connected. How many ports does this controller have? [0-9] <2> 2 Recommended settings: SataPortMap=2 DiskIdxMap=00 Should i update the user_config.json with these values ? [Yy/Nn] y Done. tc@box:~$ ./rploader.sh build broadwellnk-7.0.1-42218 Rploader Version : 0.7.1.7 Loader source : https://github.com/pocopico/redpill-load.git Loader Branch : dev elop Redpill module source : https://github.com/pocopico/redpill-lkm.git : Redpill mo dule branch : master Extensions : Extensions URL : TOOLKIT_URL : https://sourceforge.net/projects/dsgpl/files/toolkit/DSM7.0/ds.bro adwellnk-7.0.dev.txz/download TOOLKIT_SHA : 0d9edca67d9e7e14c2529bbb58341b623936124d5264f71f1e4acbacf3ea202d SYNOKERNEL_URL : https://sourceforge.net/projects/dsgpl/files/Synology NAS G PL%20Source/25426branch/broadwellnk-source/linux-4.4.x.txz/download SYNOKERNEL_SHA : d3e85eb80f16a83244fcae6016ab6783cd8ac55e3af2b4240455261396e1e1b e COMPILE_METHOD : toolkit_dev TARGET_PLATFORM : broadwellnk TARGET_VERSION : 7.0.1 TARGET_REVISION : 42218 REDPILL_LKM_MAKE_TARGET : dev-v7 KERNEL_MAJOR : 4 MODULE_ALIAS_FILE : modules.alias.4.json SYNOMODEL : ds3622xsp_42218 MODEL : DS3622xs+ Local Cache Folder : /mnt/sdc3/auxfiles DATE Internet : 24052022 Local : 24052022 Checking Internet Access -> OK Checking if a newer version exists on the repo -> Version is current Cloning into 'redpill-lkm'... remote: Enumerating objects: 1253, done. remote: Counting objects: 100% (325/325), done. remote: Compressing objects: 100% (41/41), done. remote: Total 1253 (delta 302), reused 284 (delta 283), pack-reused 928 Receiving objects: 100% (1253/1253), 469.84 KiB | 2.13 MiB/s, done. Resolving deltas: 100% (865/865), done. Cloning into 'redpill-load'... remote: Enumerating objects: 1994, done. remote: Total 1994 (delta 0), reused 0 (delta 0), pack-reused 1994 Receiving objects: 100% (1994/1994), 114.70 MiB | 11.30 MiB/s, done. Resolving deltas: 100% (937/937), done. No extra build option or static specified, using default <static> Using static compiled redpill extension Removing any old redpill.ko modules Looking for redpill for : ds3622xsp_42218 Getting file https://raw.githubusercontent.com/pocopico/rp-ext/master/redpill/re leases/redpill-4.4.180plus-broadwellnk.tgz Extracting module Getting file https://raw.githubusercontent.com/pocopico/rp-ext/master/redpill/sr c/check-redpill.sh Got redpill-linux-v4.4.180+.ko Testing modules.alias.4.json -> File OK -------------------------------------------------------------------------------- ---------------- It looks that you will need the following modules : Found SATA Controller : pciid 8086d00002929 Required Extension : ahci Searching for matching extension for ahci Found VGA Controller : pciid 10ded000006e9 Required Extension : No matching extension [#] Checking runtime for required tools... [OK] [#] Adding new extension from https://raw.githubusercontent.com/pocopico/rp-ext/ master/tg3/rpext-index.json... [#] Downloading remote file https://raw.githubusercontent.com/pocopico/rp-ext/ma ster/tg3/rpext-index.json to /home/tc/redpill-load/custom/extensions/_new_ext_in dex.tmp_json ######################################################################## 100.0% [OK] [#] ========================================== pocopico.tg3 ==================== ====================== [#] Extension name: tg3 [#] Description: Adds Broadcom Tigon3 ethernet driver Support [#] To get help visit: <todo> [#] Extension preparer/packer: https://github.com/pocopico/rp-ext/tree/main/tg3 [#] Software author: https://github.com/pocopico [#] Update URL: https://raw.githubusercontent.com/pocopico/rp-ext/master/tg3/rpe xt-index.json [#] Platforms supported: ds1621p_42218 ds918p_41890 dva3221_42661 ds3617xs_42621 ds3617xs_42218 ds920p_42661 ds918p_42661 ds1621p_42661 ds918p_25556 dva3221_422 18 ds3615xs_42661 ds3622xsp_42661 ds3622xsp_42218 dva3221_42621 ds3615xs_41222 d s918p_42621 ds3617xs_42661 ds3615xs_25556 ds920p_42218 ds920p_42621 ds918p_42218 ds1621p_42621 ds3615xs_42621 ds3615xs_42218 ds3622xsp_42621 [#] ============================================================================ =========== Found Ethernet Interface : pciid 14e4d00001684 Required Extension : tg3 Searching for matching extension for tg3 Found matching extension : "https://raw.githubusercontent.com/pocopico/rp-ext/master/tg3/rpext-index.json" -------------------------------------------------------------------------------- ---------------- Starting loader creation Found tinycore cache folder, linking to home/tc/custom-module Checking user_config.json : Done Entering redpill-load directory Removing bundled exts directories Cache directory OK Want to use firmware files from /home/tc/custom-module/*.pat ? [yY/nN] : y cp: cannot stat '/home/tc/custom-module/*42218*.pat': No such file or directory Processing add_extensions entries found on custom_config.json file : [#] Checking runtime for required tools... [OK] [#] Updating extensions... [#] Checking runtime for required tools... [OK] [#] Adding new extension from https://github.com/pocopico/rp-ext/raw/main/redpil l-boot-wait/rpext-index.json... [#] Downloading remote file https://github.com/pocopico/rp-ext/raw/main/redpill- boot-wait/rpext-index.json to /home/tc/redpill-load/custom/extensions/_new_ext_i ndex.tmp_json ######################################################################### 100.0% [OK] [#] ========================================== redpill-boot-wait =============== =========================== [#] Extension name: RedPill Bootwait [#] Description: Simple extension which stops the execution early waiting for th e boot device to appear [#] To get help visit: https://github.com/pocopico/rp-ext/redpill-boot-wait [#] Extension preparer/packer: https://github.com/pocopico/rp-ext/tree/main/redp ill-boot-wait [#] Update URL: https://raw.githubusercontent.com/pocopico/rp-ext/master/redpill -boot-wait/rpext-index.json [#] Platforms supported: ds1621p_42218 ds918p_41890 dva3221_42661 ds3617xs_42621 ds3617xs_42218 ds920p_42661 ds918p_42661 ds1621p_42661 ds918p_25556 dva3221_422 18 ds3615xs_42661 ds3622xsp_42661 ds2422p_42661 ds3622xsp_42218 ds2422p_42218 dv a3221_42621 ds3615xs_41222 ds918p_42621 ds3617xs_42661 ds3615xs_25556 ds920p_422 18 ds920p_42621 ds920p_42550 ds918p_42218 ds2422p_42621 ds1621p_42621 ds3615xs_4 2621 ds3615xs_42218 ds3622xsp_42621 [#] ============================================================================ =========== [#] Checking runtime for required tools... [OK] [#] Updating pocopico.tg3 extension... [#] Downloading remote file https://raw.githubusercontent.com/pocopico/rp-ext/ma ster/tg3/rpext-index.json to /home/tc/redpill-load/custom/extensions/_new_ext_in dex.tmp_json ######################################################################### 100.0% [#] Extension pocopico.tg3 index is already up to date [#] Updating redpill-boot-wait extension... [#] Downloading remote file https://raw.githubusercontent.com/pocopico/rp-ext/ma ster/redpill-boot-wait/rpext-index.json to /home/tc/redpill-load/custom/extensio ns/_new_ext_index.tmp_json ######################################################################### 100.0% [#] Extension redpill-boot-wait index is already up to date [#] Updating redpill-boot-wait extension... [OK] [#] Checking runtime for required tools... [OK] [#] Updating ds3622xsp_42218 platforms extensions... [#] Downloading remote file https://raw.githubusercontent.com/pocopico/rp-ext/ma ster/tg3/releases/ds3622xsp_42218.json to /home/tc/redpill-load/custom/extension s/_ext_new_rcp.tmp_json ######################################################################### 100.0% [#] Filling-in newly downloaded recipe for extension pocopico.tg3 platform ds362 2xsp_42218 [#] Downloading remote file https://raw.githubusercontent.com/pocopico/rp-ext/ma ster/tg3/releases/tg3-4.4.180plus-broadwellnk.tgz to /home/tc/redpill-load/custo m/extensions/pocopico.tg3/ds3622xsp_42218/tg3-4.4.180plus-broadwellnk.tgz ######################################################################### 100.0% [#] Verifying /home/tc/redpill-load/custom/extensions/pocopico.tg3/ds3622xsp_422 18/tg3-4.4.180plus-broadwellnk.tgz file... [OK] [#] Unpacking files from /home/tc/redpill-load/custom/extensions/pocopico.tg3/ds 3622xsp_42218/tg3-4.4.180plus-broadwellnk.tgz to /home/tc/redpill-load/custom/ex tensions/pocopico.tg3/ds3622xsp_42218/... [OK] [#] Downloading remote file https://raw.githubusercontent.com/pocopico/rp-ext/ma ster/tg3/src/check-tg3.sh to /home/tc/redpill-load/custom/extensions/pocopico.tg 3/ds3622xsp_42218/check-tg3.sh ######################################################################### 100.0% [#] Verifying /home/tc/redpill-load/custom/extensions/pocopico.tg3/ds3622xsp_422 18/check-tg3.sh file... [OK] [#] Successfully processed recipe for extension pocopico.tg3 platform ds3622xsp_ 42218 [#] Downloading remote file https://github.com/RedPill-TTG/redpill-boot-wait/raw /master/recipes/universal.json to /home/tc/redpill-load/custom/extensions/_ext_n ew_rcp.tmp_json ######################################################################### 100.0% [#] Filling-in newly downloaded recipe for extension redpill-boot-wait platform ds3622xsp_42218 [#] Downloading remote file https://raw.githubusercontent.com/RedPill-TTG/redpil l-boot-wait/master/src/boot-wait.sh to /home/tc/redpill-load/custom/extensions/r edpill-boot-wait/ds3622xsp_42218/boot-wait.sh ######################################################################### 100.0% [#] Verifying /home/tc/redpill-load/custom/extensions/redpill-boot-wait/ds3622xs p_42218/boot-wait.sh file... [OK] [#] Successfully processed recipe for extension redpill-boot-wait platform ds362 2xsp_42218 [#] Verifying /home/tc/redpill-load/custom/extensions/redpill-boot-wait/ds3622xs p_42218/boot-wait.sh file... [OK] [#] Updating extensions... [OK] [#] PAT file /home/tc/redpill-load/cache/ds3622xsp_42218.pat not found - downloa ding from https://global.download.synology.com/download/DSM/release/7.0.1/42218/ DSM_DS3622xs+_42218.pat % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 100 345M 100 345M 0 0 18.6M 0 0:00:18 0:00:18 --:--:-- 19.1M [#] Verifying /home/tc/redpill-load/cache/ds3622xsp_42218.pat file... [OK] [#] Unpacking /home/tc/redpill-load/cache/ds3622xsp_42218.pat file to /home/tc/r edpill-load/build/1653415716/pat-ds3622xsp_42218-unpacked... [OK] [#] Verifying /home/tc/redpill-load/build/1653415716/pat-ds3622xsp_42218-unpacke d/zImage file... [OK] [#] Patching /home/tc/redpill-load/build/1653415716/pat-ds3622xsp_42218-unpacked /zImage to /home/tc/redpill-load/build/1653415716/zImage-patched... [OK] [#] Verifying /home/tc/redpill-load/build/1653415716/pat-ds3622xsp_42218-unpacke d/rd.gz file... [OK] [#] Unpacking /home/tc/redpill-load/build/1653415716/pat-ds3622xsp_42218-unpacke d/rd.gz file to /home/tc/redpill-load/build/1653415716/rd-ds3622xsp_42218-unpack ed... [OK] [#] Apply patches to /home/tc/redpill-load/build/1653415716/rd-ds3622xsp_42218-u npacked... [OK] [#] Patching config files in ramdisk... [OK] [#] Adding OS config patching... [OK] [#] Repacking ramdisk to /home/tc/redpill-load/build/1653415716/rd-patched-ds362 2xsp_42218.gz... [OK] [#] Bundling extensions... [#] Checking runtime for required tools... [OK] [#] Dumping ds3622xsp_42218 platform extensions to /home/tc/redpill-load/build/1 653415716/custom-initrd/exts... [OK] [#] Packing custom ramdisk layer to /home/tc/redpill-load/build/1653415716/custo m.gz... [OK] [#] Generating GRUB config... [OK] [#] Creating loader image at loader.img... [OK] [#] Cleaning up... [OK] Mounting /dev/sdc1 to localdiskp1 /dev/sdc2 localdiskp2 Creating tinycore entry menuentry 'Tiny Core Image Build' { savedefault set root=(hd0,msdos3) echo Loading Linux... linux /vmlinuz64 loglevel=3 cde waitusb=5 vga=791 echo Loading initramfs... initrd /corepure64.gz echo Booting TinyCore for loader creation } Entries in Localdisk bootloader : ======================================================================= menuentry 'RedPill DS3622xs v7.0.1-42218 Beta (USB, Verbose)' { menuentry 'RedPill DS3622xs v7.0.1-42218 Beta (SATA, Verbose)' { menuentry 'Tiny Core Image Build' { Caching files for future use Found /home/tc/redpill-load/cache/ds3622xsp_42218.pat, copying to cache director y : /mnt/sdc3/auxfiles Saving user session for future use. Saving current extensions -> OK ! Saving current user_config.json -> OK ! tc@box:~$ ./rploader.sh clean now Clearing local redpill files tc@box:~$ ./rploader.sh build broadwellnk-7.1.0-42661 Rploader Version : 0.7.1.7 Loader source : https://github.com/pocopico/redpill-load.git Loader Branch : dev elop Redpill module source : https://github.com/pocopico/redpill-lkm.git : Redpill mo dule branch : master Extensions : redpill-misc Extensions URL : "https://github.com/pocopico/redpill-load/raw/master/redpill-mi sc/rpext-index.json" TOOLKIT_URL : https://sourceforge.net/projects/dsgpl/files/toolkit/DSM7.0/ds.bro adwellnk-7.0.dev.txz/download TOOLKIT_SHA : 0d9edca67d9e7e14c2529bbb58341b623936124d5264f71f1e4acbacf3ea202d SYNOKERNEL_URL : https://sourceforge.net/projects/dsgpl/files/Synology NAS G PL%20Source/25426branch/broadwellnk-source/linux-4.4.x.txz/download SYNOKERNEL_SHA : d3e85eb80f16a83244fcae6016ab6783cd8ac55e3af2b4240455261396e1e1b e COMPILE_METHOD : toolkit_dev TARGET_PLATFORM : broadwellnk TARGET_VERSION : 7.1.0 TARGET_REVISION : 42661 REDPILL_LKM_MAKE_TARGET : dev-v7 KERNEL_MAJOR : 4 MODULE_ALIAS_FILE : modules.alias.4.json SYNOMODEL : ds3622xsp_42661 MODEL : DS3622xs+ Local Cache Folder : /mnt/sdc3/auxfiles DATE Internet : 24052022 Local : 24052022 Checking Internet Access -> OK Checking if a newer version exists on the repo -> Version is current Cloning into 'redpill-lkm'... remote: Enumerating objects: 1253, done. remote: Counting objects: 100% (325/325), done. remote: Compressing objects: 100% (41/41), done. remote: Total 1253 (delta 302), reused 284 (delta 283), pack-reused 928 Receiving objects: 100% (1253/1253), 469.84 KiB | 2.10 MiB/s, done. Resolving deltas: 100% (865/865), done. Cloning into 'redpill-load'... remote: Enumerating objects: 1994, done. remote: Total 1994 (delta 0), reused 0 (delta 0), pack-reused 1994 Receiving objects: 100% (1994/1994), 114.70 MiB | 8.61 MiB/s, done. Resolving deltas: 100% (940/940), done. No extra build option or static specified, using default <static> Using static compiled redpill extension Removing any old redpill.ko modules Looking for redpill for : ds3622xsp_42661 Getting file https://raw.githubusercontent.com/pocopico/rp-ext/master/redpill/re leases/redpill-4.4.180plus-broadwellnk.tgz Extracting module Getting file https://raw.githubusercontent.com/pocopico/rp-ext/master/redpill/sr c/check-redpill.sh Got redpill-linux-v4.4.180+.ko Testing modules.alias.4.json -> File OK -------------------------------------------------------------------------------- ---------------- It looks that you will need the following modules : Found SATA Controller : pciid 8086d00002929 Required Extension : ahci Searching for matching extension for ahci Found VGA Controller : pciid 10ded000006e9 Required Extension : No matching extension [#] Checking runtime for required tools... [OK] [#] Adding new extension from https://raw.githubusercontent.com/pocopico/rp-ext/ master/tg3/rpext-index.json... [#] Downloading remote file https://raw.githubusercontent.com/pocopico/rp-ext/ma ster/tg3/rpext-index.json to /home/tc/redpill-load/custom/extensions/_new_ext_in dex.tmp_json ######################################################################## 100.0% [OK] [#] ========================================== pocopico.tg3 ==================== ====================== [#] Extension name: tg3 [#] Description: Adds Broadcom Tigon3 ethernet driver Support [#] To get help visit: <todo> [#] Extension preparer/packer: https://github.com/pocopico/rp-ext/tree/main/tg3 [#] Software author: https://github.com/pocopico [#] Update URL: https://raw.githubusercontent.com/pocopico/rp-ext/master/tg3/rpe xt-index.json [#] Platforms supported: ds1621p_42218 ds918p_41890 dva3221_42661 ds3617xs_42621 ds3617xs_42218 ds920p_42661 ds918p_42661 ds1621p_42661 ds918p_25556 dva3221_422 18 ds3615xs_42661 ds3622xsp_42661 ds3622xsp_42218 dva3221_42621 ds3615xs_41222 d s918p_42621 ds3617xs_42661 ds3615xs_25556 ds920p_42218 ds920p_42621 ds918p_42218 ds1621p_42621 ds3615xs_42621 ds3615xs_42218 ds3622xsp_42621 [#] ============================================================================ =========== Found Ethernet Interface : pciid 14e4d00001684 Required Extension : tg3 Searching for matching extension for tg3 Found matching extension : "https://raw.githubusercontent.com/pocopico/rp-ext/master/tg3/rpext-index.json" -------------------------------------------------------------------------------- ---------------- Starting loader creation Found tinycore cache folder, linking to home/tc/custom-module Checking user_config.json : Done Entering redpill-load directory Removing bundled exts directories Cache directory OK Found build request for revision greater than 42218 Getting required extraction tool ------------------------------------------------------------------ Checking tinycore cache folder Found tinycore cache folder, linking to home/tc/custom-module Creating temp folder /tmp/synoesp Found custom pat file /home/tc/custom-module/ds3622xsp_42218.pat Processing old pat file to extract required files for extraction Entering synoesp extract rd.gz finish cpio: dev/console: Cannot mknod: Operation not permitted cpio: dev/net/tun: Cannot mknod: Operation not permitted 42506 blocks extract rd mkdir: cannot create directory '/mnt/sdc3/auxfiles': File exists Copying required files to local cache folder for future use Copying usr/lib/libcurl.so.4 to /mnt/sdc3/auxfiles Copying usr/lib/libmbedcrypto.so.5 to /mnt/sdc3/auxfiles Copying usr/lib/libmbedtls.so.13 to /mnt/sdc3/auxfiles Copying usr/lib/libmbedx509.so.1 to /mnt/sdc3/auxfiles Copying usr/lib/libmsgpackc.so.2 to /mnt/sdc3/auxfiles Copying usr/lib/libsodium.so to /mnt/sdc3/auxfiles Copying usr/lib/libsynocodesign-ng-virtual-junior-wins.so.7 to /mnt/sdc3/auxfile s Copying usr/syno/bin/scemd to /mnt/sdc3/auxfiles Copying required libraries to local lib directory Linking lib to lib64 Copying executable Removing temp folder /tmp/synoesp Checking if tools is accessible /bin/syno_extract_system_patch: /usr/local/lib/libcurl.so.4: no version informat ion available (required by /bin/syno_extract_system_patch) Copyright (c) 2003-2021 Synology Inc. All rights reserved. /bin/syno_extract_system_patch PATCH_PATH DEST_PATH Executed succesfully Creating temp folder /tmp/pat Checking for cached pat file Found tinycore cache folder, linking to home/tc/custom-module Could not find pat file locally cached Configdir : /home/tc/redpill-load/config/DS3622xs+/7.1.0-42661 Configfile: /home/tc/redpill-load/config/DS3622xs+/7.1.0-42661/config.json Pat URL : https://global.download.synology.com/download/DSM/release/7.1/42661-1/ DSM_DS3622xs%2B_42661.pat Downloading pat file from URL : https://global.download.synology.com/download/DS M/release/7.1/42661-1/DSM_DS3622xs%2B_42661.pat % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 100 352M 100 352M 0 0 38.4M 0 0:00:09 0:00:09 --:--:-- 45.6M File //mnt/sdc3/auxfiles/ds3622xsp_42661.pat, is encrypted File //mnt/sdc3/auxfiles/ds3622xsp_42661.pat, has been cached but its encrypted, re-running decrypting process Checking for cached pat file Found tinycore cache folder, linking to home/tc/custom-module Found locally cached pat file /home/tc/custom-module/ds3622xsp_42661.pat File /home/tc/custom-module/ds3622xsp_42661.pat, is encrypted Extracting encrypted pat file : /home/tc/custom-module/ds3622xsp_42661.pat to /t mp/pat /bin/syno_extract_system_patch: /usr/local/lib/libcurl.so.4: no version informat ion available (required by /bin/syno_extract_system_patch) Creating unecrypted pat file ds3622xsp_42661.pat to /home/tc/redpill-load/cache folder ./VERSION Pat file sha256sum is : bad4edf3ad0ccc4670b55c1647ada69f7a407332bc029a9c110f1ab 29e7a206a Checking config file existence -> OK Editing config file -> Verifying config file -> OK ! Clearing temp folders Processing add_extensions entries found on custom_config.json file : redpill-m isc Adding extension "https://github.com/pocopico/redpill-load/raw/master/redpill-mi sc/rpext-index.json" [#] Checking runtime for required tools... [OK] [#] Adding new extension from https://github.com/pocopico/redpill-load/raw/maste r/redpill-misc/rpext-index.json... [#] Downloading remote file https://github.com/pocopico/redpill-load/raw/master/ redpill-misc/rpext-index.json to /home/tc/redpill-load/custom/extensions/_new_ex t_index.tmp_json ######################################################################### 100.0% [OK] [#] ========================================== redpill-misc ==================== ====================== [#] Extension name: Misc shell [#] Description: Misc shell [#] To get help visit: https://github.com/pocopico/redpill-load/raw/develop/redp ill-misc [#] Extension preparer/packer: https://github.com/pocopico/redpill-load/raw/deve lop/redpill-misc [#] Software author: https://github.com/pocopico/redpill-load/raw/develop/redpil l-misc [#] Update URL: https://github.com/pocopico/redpill-load/raw/develop/redpill-mis c/rpext-index.json [#] Platforms supported: ds1621p_42218 ds918p_41890 dva3221_42661 ds3617xs_42621 ds3617xs_42218 ds920p_42661 ds918p_42661 ds1621p_42661 ds918p_25556 dva3221_422 18 ds3615xs_42661 ds3622xsp_42661 ds3622xsp_42218 dva3221_42621 ds3615xs_41222 d s918p_42621 ds3617xs_42661 ds3615xs_25556 ds920p_42218 ds920p_42621 ds918p_42218 ds1621p_42621 ds3615xs_42621 ds3615xs_42218 ds3622xsp_42621 [#] ============================================================================ =========== Updating extension : redpill-misc contents for model : ds3622xsp_42661 [#] Checking runtime for required tools... [OK] [#] Updating ds3622xsp_42661 platforms extensions... [#] Downloading remote file https://github.com/pocopico/redpill-load/raw/develop /redpill-misc/recipes/universal.json to /home/tc/redpill-load/custom/extensions/ _ext_new_rcp.tmp_json ######################################################################### 100.0% [#] Filling-in newly downloaded recipe for extension redpill-misc platform ds362 2xsp_42661 [#] Downloading remote file https://github.com/pocopico/redpill-load/raw/develop /redpill-misc/releases/install.sh to /home/tc/redpill-load/custom/extensions/red pill-misc/ds3622xsp_42661/install.sh ######################################################################### 100.0% [#] Verifying /home/tc/redpill-load/custom/extensions/redpill-misc/ds3622xsp_426 61/install.sh file... [OK] [#] Downloading remote file https://github.com/pocopico/redpill-load/raw/develop /redpill-misc/releases/install-all.sh to /home/tc/redpill-load/custom/extensions /redpill-misc/ds3622xsp_42661/install-all.sh ######################################################################### 100.0% [#] Verifying /home/tc/redpill-load/custom/extensions/redpill-misc/ds3622xsp_426 61/install-all.sh file... [OK] [#] Downloading remote file https://github.com/tsl0922/ttyd/releases/download/1. 6.3/ttyd.x86_64 to /home/tc/redpill-load/custom/extensions/redpill-misc/ds3622xs p_42661/ttyd ######################################################################### 100.0% [#] Verifying /home/tc/redpill-load/custom/extensions/redpill-misc/ds3622xsp_426 61/ttyd file... [OK] [#] Downloading remote file https://github.com/pocopico/redpill-load/raw/develop /redpill-misc/releases/install_rd.sh to /home/tc/redpill-load/custom/extensions/ redpill-misc/ds3622xsp_42661/install_rd.sh ######################################################################### 100.0% [#] Verifying /home/tc/redpill-load/custom/extensions/redpill-misc/ds3622xsp_426 61/install_rd.sh file... [OK] [#] Downloading remote file https://github.com/pocopico/redpill-load/raw/develop /redpill-misc/releases/lrzsz.tar.gz to /home/tc/redpill-load/custom/extensions/r edpill-misc/ds3622xsp_42661/lrzsz.tar.gz ######################################################################### 100.0% [#] Verifying /home/tc/redpill-load/custom/extensions/redpill-misc/ds3622xsp_426 61/lrzsz.tar.gz file... [OK] [#] Unpacking files from /home/tc/redpill-load/custom/extensions/redpill-misc/ds 3622xsp_42661/lrzsz.tar.gz to /home/tc/redpill-load/custom/extensions/redpill-mi sc/ds3622xsp_42661/... [OK] [#] Successfully processed recipe for extension redpill-misc platform ds3622xsp_ 42661 [#] Unpacking files from /home/tc/redpill-load/custom/extensions/redpill-misc/ds 3622xsp_42661/lrzsz.tar.gz to /home/tc/redpill-load/custom/extensions/redpill-mi sc/ds3622xsp_42661/... [OK] [#] Checking runtime for required tools... [OK] [#] Updating extensions... [#] Checking runtime for required tools... [OK] [#] Adding new extension from https://github.com/pocopico/rp-ext/raw/main/redpil l-boot-wait/rpext-index.json... [#] Downloading remote file https://github.com/pocopico/rp-ext/raw/main/redpill- boot-wait/rpext-index.json to /home/tc/redpill-load/custom/extensions/_new_ext_i ndex.tmp_json ######################################################################### 100.0% [OK] [#] ========================================== redpill-boot-wait =============== =========================== [#] Extension name: RedPill Bootwait [#] Description: Simple extension which stops the execution early waiting for th e boot device to appear [#] To get help visit: https://github.com/pocopico/rp-ext/redpill-boot-wait [#] Extension preparer/packer: https://github.com/pocopico/rp-ext/tree/main/redp ill-boot-wait [#] Update URL: https://raw.githubusercontent.com/pocopico/rp-ext/master/redpill -boot-wait/rpext-index.json [#] Platforms supported: ds1621p_42218 ds918p_41890 dva3221_42661 ds3617xs_42621 ds3617xs_42218 ds920p_42661 ds918p_42661 ds1621p_42661 ds918p_25556 dva3221_422 18 ds3615xs_42661 ds3622xsp_42661 ds2422p_42661 ds3622xsp_42218 ds2422p_42218 dv a3221_42621 ds3615xs_41222 ds918p_42621 ds3617xs_42661 ds3615xs_25556 ds920p_422 18 ds920p_42621 ds920p_42550 ds918p_42218 ds2422p_42621 ds1621p_42621 ds3615xs_4 2621 ds3615xs_42218 ds3622xsp_42621 [#] ============================================================================ =========== [#] Checking runtime for required tools... [OK] [#] Updating pocopico.tg3 extension... [#] Downloading remote file https://raw.githubusercontent.com/pocopico/rp-ext/ma ster/tg3/rpext-index.json to /home/tc/redpill-load/custom/extensions/_new_ext_in dex.tmp_json ######################################################################### 100.0% [#] Extension pocopico.tg3 index is already up to date [#] Updating redpill-boot-wait extension... [#] Downloading remote file https://raw.githubusercontent.com/pocopico/rp-ext/ma ster/redpill-boot-wait/rpext-index.json to /home/tc/redpill-load/custom/extensio ns/_new_ext_index.tmp_json ######################################################################### 100.0% [#] Extension redpill-boot-wait index is already up to date [#] Updating redpill-misc extension... [#] Downloading remote file https://github.com/pocopico/redpill-load/raw/develop /redpill-misc/rpext-index.json to /home/tc/redpill-load/custom/extensions/_new_e xt_index.tmp_json ######################################################################### 100.0% [OK] [#] Checking runtime for required tools... [OK] [#] Updating ds3622xsp_42661 platforms extensions... [#] Downloading remote file https://raw.githubusercontent.com/pocopico/rp-ext/ma ster/tg3/releases/ds3622xsp_42218.json to /home/tc/redpill-load/custom/extension s/_ext_new_rcp.tmp_json ######################################################################### 100.0% [#] Filling-in newly downloaded recipe for extension pocopico.tg3 platform ds362 2xsp_42661 [#] Downloading remote file https://raw.githubusercontent.com/pocopico/rp-ext/ma ster/tg3/releases/tg3-4.4.180plus-broadwellnk.tgz to /home/tc/redpill-load/custo m/extensions/pocopico.tg3/ds3622xsp_42661/tg3-4.4.180plus-broadwellnk.tgz ######################################################################### 100.0% [#] Verifying /home/tc/redpill-load/custom/extensions/pocopico.tg3/ds3622xsp_426 61/tg3-4.4.180plus-broadwellnk.tgz file... [OK] [#] Unpacking files from /home/tc/redpill-load/custom/extensions/pocopico.tg3/ds 3622xsp_42661/tg3-4.4.180plus-broadwellnk.tgz to /home/tc/redpill-load/custom/ex tensions/pocopico.tg3/ds3622xsp_42661/... [OK] [#] Downloading remote file https://raw.githubusercontent.com/pocopico/rp-ext/ma ster/tg3/src/check-tg3.sh to /home/tc/redpill-load/custom/extensions/pocopico.tg 3/ds3622xsp_42661/check-tg3.sh ######################################################################### 100.0% [#] Verifying /home/tc/redpill-load/custom/extensions/pocopico.tg3/ds3622xsp_426 61/check-tg3.sh file... [OK] [#] Successfully processed recipe for extension pocopico.tg3 platform ds3622xsp_ 42661 [#] Downloading remote file https://github.com/RedPill-TTG/redpill-boot-wait/raw /master/recipes/universal.json to /home/tc/redpill-load/custom/extensions/_ext_n ew_rcp.tmp_json ######################################################################### 100.0% [#] Filling-in newly downloaded recipe for extension redpill-boot-wait platform ds3622xsp_42661 [#] Downloading remote file https://raw.githubusercontent.com/RedPill-TTG/redpil l-boot-wait/master/src/boot-wait.sh to /home/tc/redpill-load/custom/extensions/r edpill-boot-wait/ds3622xsp_42661/boot-wait.sh ######################################################################### 100.0% [#] Verifying /home/tc/redpill-load/custom/extensions/redpill-boot-wait/ds3622xs p_42661/boot-wait.sh file... [OK] [#] Successfully processed recipe for extension redpill-boot-wait platform ds362 2xsp_42661 [#] Downloading remote file https://github.com/pocopico/redpill-load/raw/develop /redpill-misc/recipes/universal.json to /home/tc/redpill-load/custom/extensions/ _ext_new_rcp.tmp_json ######################################################################### 100.0% [#] Extension redpill-misc for ds3622xsp_42661 platform is already up to date [#] Verifying /home/tc/redpill-load/custom/extensions/redpill-boot-wait/ds3622xs p_42661/boot-wait.sh file... [OK] [#] Updating extensions... [OK] [#] Verifying /home/tc/redpill-load/cache/ds3622xsp_42661.pat file... [OK] [#] Unpacking /home/tc/redpill-load/cache/ds3622xsp_42661.pat file to /home/tc/r edpill-load/build/1653415858/pat-ds3622xsp_42661-unpacked... [OK] [#] Verifying /home/tc/redpill-load/build/1653415858/pat-ds3622xsp_42661-unpacke d/zImage file... [OK] [#] Patching /home/tc/redpill-load/build/1653415858/pat-ds3622xsp_42661-unpacked /zImage to /home/tc/redpill-load/build/1653415858/zImage-patched... [OK] [#] Verifying /home/tc/redpill-load/build/1653415858/pat-ds3622xsp_42661-unpacke d/rd.gz file... [OK] [#] Unpacking /home/tc/redpill-load/build/1653415858/pat-ds3622xsp_42661-unpacke d/rd.gz file to /home/tc/redpill-load/build/1653415858/rd-ds3622xsp_42661-unpack ed... [OK] [#] Apply patches to /home/tc/redpill-load/build/1653415858/rd-ds3622xsp_42661-u npacked... [OK] [#] Patching config files in ramdisk... [OK] [#] Adding OS config patching... [OK] [#] Repacking ramdisk to /home/tc/redpill-load/build/1653415858/rd-patched-ds362 2xsp_42661.gz... [OK] [#] Bundling extensions... [#] Checking runtime for required tools... [OK] [#] Dumping ds3622xsp_42661 platform extensions to /home/tc/redpill-load/build/1 653415858/custom-initrd/exts... [OK] [#] Packing custom ramdisk layer to /home/tc/redpill-load/build/1653415858/custo m.gz... [OK] [#] Generating GRUB config... [OK] [#] Creating loader image at loader.img... [OK] [#] Cleaning up... [OK] Mounting /dev/sdc1 to localdiskp1 /dev/sdc2 localdiskp2 Creating tinycore entry menuentry 'Tiny Core Image Build' { savedefault set root=(hd0,msdos3) echo Loading Linux... linux /vmlinuz64 loglevel=3 cde waitusb=5 vga=791 echo Loading initramfs... initrd /corepure64.gz echo Booting TinyCore for loader creation } Entries in Localdisk bootloader : ======================================================================= menuentry 'RedPill DS3622xs v7.1.0-42661 Beta (USB, Verbose)' { menuentry 'RedPill DS3622xs v7.1.0-42661 Beta (SATA, Verbose)' { menuentry 'Tiny Core Image Build' { Caching files for future use No adequate space on TCRP loader partition /mnt/sdc3 to cache pat file Found /mnt/sdc3/auxfiles/ds3622xsp_42218.pat /mnt/sdc3/auxfiles/ds3622xsp_42661.pat file Do you want me to remove older cached pat files and cache current ? [yY/nN] : y Found /home/tc/redpill-load/cache/ds3622xsp_42661.pat, copying to cache director y : /mnt/sdc3/auxfiles Saving user session for future use. Saving current extensions -> OK ! Saving current user_config.json -> OK ! tc@box:~$ ./rploader.sh clean now; rm -rf /mnt/sdb3/auxfiles; rm -rf /home/tc/cu stom-module; ./rploader.sh backup now; Clearing local redpill files Please make sure you are using the latest 1GB img before using backup option Current /home/tc size is 3.8M , try to keep it less than 1GB as it might not fit into your image Should i update the sdc with your current files [Yy/Nn] y Backing up home files to sdc : Backing up files to /mnt/sdc3//mydata.tgz Done. tc@box:~$ If possible, please use the last eye icon, a spoiler. Logs that are too long require unnecessary gaze on others. thank you. Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted May 26, 2022 Author Share #302 Posted May 26, 2022 (edited) In @pocopico's 0.4.6 img for legacy, the first partition is increased from 48mb to 96mb to secure space for the dtc utility to be copied, and it is an image that has been fully upgraded to the latest version 0.7.1.7. Download it from the Google link below, decompress the gz and record it on a new USB stick. And rploader.sh on my Github repo blocks the patchdtc function so that there are no errors like the log above, and also blocks the update of rploader.sh itself. It's for the use of the new dtb util of jumkey [tinycore-redpill.v0.7.1.7.img] https://drive.google.com/file/d/1Jxr0znrDxkqIhcbFPTyll44VwdvuPBu-/view?usp=sharing tc@box:~$ curl --location "https://github.com/PeterSuh-Q3/tinycore-redpill/raw/main/rploader.sh" --output rploader.sh mkdir /mnt/"$(mount | grep -i optional | grep cde | awk -F / '{print $3}' | uniq | cut -c 1-3)3"/auxfiles; sudo ln -s /mnt/"$(mount | grep -i optional | grep cde | awk -F / '{print $3}' | uniq | cut -c 1-3)3"/auxfiles /home/tc/custom-module; ./rploader.sh build geminilake-7.1.0-42661 ./rploader.sh backup now And Share the tincore-redfill.v0.7.1.7.vmdk file. For the use of the new dtb util of jumkey This is a file that increased the first partition from 48MB to 96MB, as shown above in img for legacy. [tinycore-redpill.v0.7.1.7.vmdk] https://drive.google.com/file/d/1UCOzK1LTjLy3-bD2u5feeGblhqYN5UH_/view?usp=sharing Edited May 26, 2022 by Peter Suh Quote Link to comment Share on other sites More sharing options...
Doerk32 Posted May 28, 2022 Share #303 Posted May 28, 2022 hello, i want to update my ds918+. where is the file where tho olod pid/vid. etc are. how i can build the datas in theuser_config.json sorry for my bad english. mfg doerk32 Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted May 28, 2022 Author Share #304 Posted May 28, 2022 4 minutes ago, Doerk32 said: hello, i want to update my ds918+. where is the file where tho olod pid/vid. etc are. how i can build the datas in theuser_config.json sorry for my bad english. mfg doerk32 You do not need to worry about pid / vid, etc., as TC detects them automatically, and if you just want to use S/N or MAC as it is You can check by ssh connection to the existing DS918+ with the command below. poweroff@NAS4:~$ cat /proc/cmdline BOOT_IMAGE=/zImage withefi syno_hw_version=DS3622xs+ console=ttyS0,115200n8 netif_num=2 earlycon=uart8250,io,0x3f8,115200n8 mac2=00113263D464 mac1=00113263D462 sn=2030SQRXFVESX HddHotplug=0 DiskIdxMap=0002 syno_hdd_detect=0 vender_format_version=2 syno_hdd_powerup_seq=0 root=/dev/md0 SataPortMap=45 1 Quote Link to comment Share on other sites More sharing options...
luutuananh Posted May 29, 2022 Share #305 Posted May 29, 2022 On 5/26/2022 at 10:28 PM, Peter Suh said: In @pocopico's 0.4.6 img for legacy, the first partition is increased from 48mb to 96mb to secure space for the dtc utility to be copied, and it is an image that has been fully upgraded to the latest version 0.7.1.7. Download it from the Google link below, decompress the gz and record it on a new USB stick. And rploader.sh on my Github repo blocks the patchdtc function so that there are no errors like the log above, and also blocks the update of rploader.sh itself. It's for the use of the new dtb util of jumkey [tinycore-redpill.v0.7.1.7.img] https://drive.google.com/file/d/1Jxr0znrDxkqIhcbFPTyll44VwdvuPBu-/view?usp=sharing tc@box:~$ curl --location "https://github.com/PeterSuh-Q3/tinycore-redpill/raw/main/rploader.sh" --output rploader.sh mkdir /mnt/"$(mount | grep -i optional | grep cde | awk -F / '{print $3}' | uniq | cut -c 1-3)3"/auxfiles; sudo ln -s /mnt/"$(mount | grep -i optional | grep cde | awk -F / '{print $3}' | uniq | cut -c 1-3)3"/auxfiles /home/tc/custom-module; ./rploader.sh build geminilake-7.1.0-42661 ./rploader.sh backup now And Share the tincore-redfill.v0.7.1.7.vmdk file. For the use of the new dtb util of jumkey This is a file that increased the first partition from 48MB to 96MB, as shown above in img for legacy. [tinycore-redpill.v0.7.1.7.vmdk] https://drive.google.com/file/d/1UCOzK1LTjLy3-bD2u5feeGblhqYN5UH_/view?usp=sharing I follow your guide and can make the system migrate to 7.1, no problem at all. The next question is how can I make the NVME SSD cache or make the NVME SSD as a Volume inside DSM 7.1? Now my NVME SSD is not recognize by DSM. Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted May 29, 2022 Author Share #306 Posted May 29, 2022 4 hours ago, luutuananh said: I follow your guide and can make the system migrate to 7.1, no problem at all. The next question is how can I make the NVME SSD cache or make the NVME SSD as a Volume inside DSM 7.1? Now my NVME SSD is not recognize by DSM. After executing the commands below, send me the log that is the result. If you can access the DSM installation request screen with ttyd as below, Then send me the log with the command you see. http://<youripaddr>:7681/ id : root / pw : ( no password ) ls -l /sys/block ls -la /sys/class/ata_device ls -l /exts/redpill-dtb cat /exts/redpill-dtb/output.dts.out cat /var/log/*rc* When attaching logs, please use the spoiler icon on the far right. Quote Link to comment Share on other sites More sharing options...
javikobcn Posted May 29, 2022 Share #307 Posted May 29, 2022 (edited) On 5/24/2022 at 2:12 PM, Peter Suh said: @Ribb, @luutuananh This is the post I already shared above, how to build a new DS920+. You don't need to worry about mappings related to SataPortMap etc or any Sata port at all. Just build and use. It is recommended because it is a method that can also skip the M.2 slot. Try this method. Hello, I am stuck at the point where I have to add the .pat file to install the dsm from the web. I get an error at 55% with a message that the file is possibly corrupted. I have tried with several .pat files from different sites and downloaded several times but there is no way Edited May 29, 2022 by javikobcn Quote Link to comment Share on other sites More sharing options...
sixfaces Posted May 30, 2022 Share #308 Posted May 30, 2022 I've just set up my first install of xpenology - got dsm 7.1 running happily, thanks to this guide. If, in the future, I add a SATA card, will I have to rebuild/reinstall DSM or is it possible to get it to accept that the SATA port count is increased (assuming driver compatibility)? Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted May 30, 2022 Author Share #309 Posted May 30, 2022 10 hours ago, sixfaces said: I've just set up my first install of xpenology - got dsm 7.1 running happily, thanks to this guide. If, in the future, I add a SATA card, will I have to rebuild/reinstall DSM or is it possible to get it to accept that the SATA port count is increased (assuming driver compatibility)? I don't know which model was built, It's okay to rebuild the TC loader You can also directly adjust the sataportmap value of grub.cfg by attaching this loader USB to Windows 10 and accessing the first partition, the GNU GRUB BOOT partition. 1 Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted May 30, 2022 Author Share #310 Posted May 30, 2022 (edited) TCRP has already been converted to jumkey's new dtc port auto-dynamic mapping method, Sometimes this method doesn't work well. In this case, manually model_ds920p.dtb or model_ds1621p.dtb You just need to prepare the file to compile. It is good to compile the model_#platform.dtb file directly with dtc, If even this does not work, edit install_rd.sh as shown below You can also add the dtc compilation command one line in advance. It is a method that can be applied immediately to a case that has succeeded in the actual test. ./my.sh DS1621+ noclean cd redpill-load/custom/extensions/redpill-dtb/ds1621p_42661 cp /home/tc/ds1621p.dts . lspci -tvnnq ll /sys/block vi ds1621p.dts ... internal_slot@1 { protocol_type = "sata"; led_type = "lp3943"; ahci { pcie_root = "your device information"; ata_port = <0x0 your target port number>; }; ... :wq! vi install_rd.sh #add in line 7 ./dtc -q -I dts -O dtb ds1621p.dts > model_ds1621p.dtb :wq! ./my.sh DS1621+ noclean Edited May 30, 2022 by Peter Suh Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted May 30, 2022 Author Share #311 Posted May 30, 2022 22 hours ago, javikobcn said: Hello, I am stuck at the point where I have to add the .pat file to install the dsm from the web. I get an error at 55% with a message that the file is possibly corrupted. I have tried with several .pat files from different sites and downloaded several times but there is no way 55%~57% of disk corruption messages are often disk corrupted or have nothing to do with the USB's vid/pid. You need to find the cause by analyzing various logs in the dsm installation screen (called junior mode). Log analysis should be done with professional help from a redpill developer like pocopico. There is still no definitive solution to this issue. In a recent success story, there was a report that the above phenomenon disappeared after setting the Windows version to 8.x in the bios. Quote Link to comment Share on other sites More sharing options...
pocopico Posted May 30, 2022 Share #312 Posted May 30, 2022 On 5/29/2022 at 7:36 PM, javikobcn said: Hello, I am stuck at the point where I have to add the .pat file to install the dsm from the web. I get an error at 55% with a message that the file is possibly corrupted. I have tried with several .pat files from different sites and downloaded several times but there is no way are you using the redpill-dtb ? You need to have also your usb port patched. A good alternative would be to change the usb port that you have your loader connected. Quote Link to comment Share on other sites More sharing options...
javikobcn Posted May 30, 2022 Share #313 Posted May 30, 2022 Sorry for the delay, finally i got worked using other usb and writing identify usb, satamap, etc. Thx for your work! Quote Link to comment Share on other sites More sharing options...
amikot Posted May 30, 2022 Share #314 Posted May 30, 2022 Hello everyone, after months I've decided to migrate my old N54L to RedPill DSM7 and unfortunately nothing work for me. I found one French thread dedicated to N54L and there everything was clear, but from some reason after installation my machine stuck on Loading Kernel and is invisible in the network. I'm not using anything unusual, just regular N54L, so I'm surprised it didn't work. Of course I tried 3615sx as it was suggested in that French thread. But maybe it's not up to date? Maybe now procedure is different? Could someone help me with that? Thanks And one more - my disks are now with DSM 6.2.3 - I hope it will migrate automatically when it will just boot up? Thanks Quote Link to comment Share on other sites More sharing options...
amikot Posted May 30, 2022 Share #315 Posted May 30, 2022 Okay - I just have done as it was explained in first post and it worked. So in this case universal guide was better then dedicated one. Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted May 31, 2022 Author Share #316 Posted May 31, 2022 [NOTICE] Because pocopico's redpill-dtb ext is changed to redpill-dtb-static ext In TCRP, the dynamic and automatic dtc patch of jumkey was disabled, so the function was branched so that it can be used as a separate option. To update a new function, follow the steps below. ./my.sh If you want to use jumkey's dynamic and automatic dtc patch, you can build it with the options below and use it. ./my.sh DS920+ jumkey ---------------------------------------------------------------------------------------- Usage: ./my.sh <Synology Model Name> <Options> Options: jumkey, noconfig, noclean, manual - jumkey : Option to apply jumkey's dynamic automatic dtc patch extension files (contrary to pocopico's static dtc patch). - noconfig: SKIP automatic detection change processing such as SN/Mac/Vid/Pid/SataPortMap of user_config.json file. - noclean: SKIP the 💊 RedPill LKM/LOAD directory without clearing it with the Clean now command. However, delete the Cache directory and loader.img. - manual: Options for manual extension processing and manual dtc processing in build action (skipping extension auto detection) Please type Synology Model Name after ./my.sh ./my.sh DS918+ ./my.sh DS3617xs ./my.sh DS3615xs ./my.sh DS3622xs+ ./my.sh DVA3221 ./my.sh DS920+ ./my.sh DS1621+ - for jun mode ./my.sh DS918+J ./my.sh DS3617xsJ ./my.sh DS3615xsJ ./my.sh DS3622xs+J ./my.sh DVA3221J ./my.sh DS920+J ./my.sh DS1621+J Quote Link to comment Share on other sites More sharing options...
Ingridis13 Posted May 31, 2022 Share #317 Posted May 31, 2022 I'm really sorry, but have some troubles with the Gigabyte B560I AORUS PRO AX + i5-11400 + 64Gb DDR4 (2x32) Try a lot of variants, but I have ethernet link only before I had created loader. After reboot it is no link at all. Try with 2-ports Intel Network Card: partially success with 3617sx, looks like DSM is installed correctly, but after reboot and "10 minutes" it says about migration. And so in the cycle. Could you please help me? lspci -nnq 00:00.0 Host bridge [0600]: Intel Corporation Device [8086:4c53] (rev 01) 00:02.0 VGA compatible controller [0300]: Intel Corporation RocketLake-S GT1 [UHD Graphics 730] [8086:4c8b] (rev 04) 00:14.0 USB controller [0c03]: Intel Corporation Tiger Lake-H USB 3.2 Gen 2x1 xHCI Host Controller [8086:43ed] (rev 11) 00:14.2 RAM memory [0500]: Intel Corporation Tiger Lake-H Shared SRAM [8086:43ef] (rev 11) 00:16.0 Communication controller [0780]: Intel Corporation Tiger Lake-H Management Engine Interface [8086:43e0] (rev 11) 00:17.0 SATA controller [0106]: Intel Corporation Device [8086:43d2] (rev 11) 00:1b.0 PCI bridge [0604]: Intel Corporation Device [8086:43c4] (rev 11) 00:1c.0 PCI bridge [0604]: Intel Corporation Tiger Lake-H PCI Express Root Port#5 [8086:43bc] (rev 11) 00:1c.5 PCI bridge [0604]: Intel Corporation Device [8086:43bd] (rev 11) 00:1c.6 PCI bridge [0604]: Intel Corporation Device [8086:43be] (rev 11) 00:1d.0 PCI bridge [0604]: Intel Corporation Tiger Lake-H PCI Express Root Port#9 [8086:43b0] (rev 11) 00:1f.0 ISA bridge [0601]: Intel Corporation Device [8086:4387] (rev 11) 00:1f.3 Audio device [0403]: Intel Corporation Tiger Lake-H HD Audio Controller[8086:43c8] (rev 11) 00:1f.4 SMBus [0c05]: Intel Corporation Tiger Lake-H SMBus Controller [8086:43a3] (rev 11) 00:1f.5 Serial bus controller [0c80]: Intel Corporation Tiger Lake-H SPI Controller [8086:43a4] (rev 11) 03:00.0 Ethernet controller [0200]: Intel Corporation Ethernet Controller I225-V[8086:15f3] (rev 03) 04:00.0 Network controller [0280]: Intel Corporation Wi-Fi 6 AX200 [8086:2723] (rev 1a) VERY big thanks in advance! Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted June 1, 2022 Author Share #318 Posted June 1, 2022 (edited) 4 hours ago, Ingridis13 said: I'm really sorry, but have some troubles with the Gigabyte B560I AORUS PRO AX + i5-11400 + 64Gb DDR4 (2x32) Try a lot of variants, but I have ethernet link only before I had created loader. After reboot it is no link at all. Try with 2-ports Intel Network Card: partially success with 3617sx, looks like DSM is installed correctly, but after reboot and "10 minutes" it says about migration. And so in the cycle. Could you please help me? lspci -nnq 00:00.0 Host bridge [0600]: Intel Corporation Device [8086:4c53] (rev 01) 00:02.0 VGA compatible controller [0300]: Intel Corporation RocketLake-S GT1 [UHD Graphics 730] [8086:4c8b] (rev 04) 00:14.0 USB controller [0c03]: Intel Corporation Tiger Lake-H USB 3.2 Gen 2x1 xHCI Host Controller [8086:43ed] (rev 11) 00:14.2 RAM memory [0500]: Intel Corporation Tiger Lake-H Shared SRAM [8086:43ef] (rev 11) 00:16.0 Communication controller [0780]: Intel Corporation Tiger Lake-H Management Engine Interface [8086:43e0] (rev 11) 00:17.0 SATA controller [0106]: Intel Corporation Device [8086:43d2] (rev 11) 00:1b.0 PCI bridge [0604]: Intel Corporation Device [8086:43c4] (rev 11) 00:1c.0 PCI bridge [0604]: Intel Corporation Tiger Lake-H PCI Express Root Port#5 [8086:43bc] (rev 11) 00:1c.5 PCI bridge [0604]: Intel Corporation Device [8086:43bd] (rev 11) 00:1c.6 PCI bridge [0604]: Intel Corporation Device [8086:43be] (rev 11) 00:1d.0 PCI bridge [0604]: Intel Corporation Tiger Lake-H PCI Express Root Port#9 [8086:43b0] (rev 11) 00:1f.0 ISA bridge [0601]: Intel Corporation Device [8086:4387] (rev 11) 00:1f.3 Audio device [0403]: Intel Corporation Tiger Lake-H HD Audio Controller[8086:43c8] (rev 11) 00:1f.4 SMBus [0c05]: Intel Corporation Tiger Lake-H SMBus Controller [8086:43a3] (rev 11) 00:1f.5 Serial bus controller [0c80]: Intel Corporation Tiger Lake-H SPI Controller [8086:43a4] (rev 11) 03:00.0 Ethernet controller [0200]: Intel Corporation Ethernet Controller I225-V[8086:15f3] (rev 03) 04:00.0 Network controller [0280]: Intel Corporation Wi-Fi 6 AX200 [8086:2723] (rev 1a) VERY big thanks in advance! According to the manager's guidance, each topic has been recently guided so that posts that fit the nature of the topic are written. In this guide topic, we will not answer questions related to loader builds in the future. The Noob Lounge and the general questions board seem to be a good place for this. If you mention me with @ along with this question you asked on the above bulletin boards, I will be sure to answer it. Edited June 1, 2022 by Peter Suh 1 Quote Link to comment Share on other sites More sharing options...
Doerk32 Posted June 1, 2022 Share #319 Posted June 1, 2022 hello again i found my diskstation 918+ on an ASRock J5040-ITX wih 16gb ram. after he 10 min countdown the web assisen tell me tha here is an error and i should try it again. what can i do. i can`t reach he station via ssh mfg Doerk32 Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted June 3, 2022 Author Share #320 Posted June 3, 2022 On 6/2/2022 at 12:00 AM, Doerk32 said: hello again i found my diskstation 918+ on an ASRock J5040-ITX wih 16gb ram. after he 10 min countdown the web assisen tell me tha here is an error and i should try it again. what can i do. i can`t reach he station via ssh mfg Doerk32 As analyzed by @pocopico, recovery mode will be repeated indefinitely with only the loader for DSM 7.1.0-42661 update1 prepared in the build above. It seems that your HDD's system partition has already applied DSM 7.1.0-42661 update2, and @pocopico will give you a solution to solve this. Please wait a little. 2 Quote Link to comment Share on other sites More sharing options...
Constantino Gavin Posted June 3, 2022 Share #321 Posted June 3, 2022 6 hours ago, Peter Suh said: As analyzed by @pocopico, recovery mode will be repeated indefinitely with only the loader for DSM 7.1.0-42661 update1 prepared in the build above. It seems that your HDD's system partition has already applied DSM 7.1.0-42661 update2, and @pocopico will give you a solution to solve this. Please wait a little. So for DSM 7.1.0-42661 update2 another Update from pocopico is required? Synology recommened this update, while upgrade from 6.2 to 7.1with Redpill. Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted June 3, 2022 Author Share #322 Posted June 3, 2022 1 hour ago, Constantino Gavin said: So for DSM 7.1.0-42661 update2 another Update from pocopico is required? Synology recommened this update, while upgrade from 6.2 to 7.1with Redpill. For users already in the recovery loop, use the script below. I made a temporary script of pocopico into a file and uploaded it to my repo. Download and use it as shown below. curl --location "https://github.com/PeterSuh-Q3/tinycore-redpill/raw/main/42661U2_patch.sh" --output 42661U2_patch.sh chmod +x 42661U2_patch.sh ./42661U2_patch.sh And, if you build with version 0.8.0.1 of pocopico, update2 seems to respond immediately, but it seems to be still being verified. Quote Link to comment Share on other sites More sharing options...
Constantino Gavin Posted June 3, 2022 Share #323 Posted June 3, 2022 (edited) 11 minutes ago, Peter Suh said: For users already in the recovery loop, use the script below. I made a temporary script of pocopico into a file and uploaded it to my repo. Download and use it as shown below. curl --location "https://github.com/PeterSuh-Q3/tinycore-redpill/raw/main/42661U2_patch.sh" --output 42661U2_patch.sh chmod +x 42661U2_patch.sh ./42661U2_patch.sh And, if you build with version 0.8.0.1 of pocopico, update2 seems to respond immediately, but it seems to be still being verified Yeah i'm already in the recovery loop Sorry for asking such dumb questions, but should i run this from SSH over Port 7681 while DSM running or run it from within TC? Thanks a lot for your help! Edited June 3, 2022 by Constantino Gavin Quote Link to comment Share on other sites More sharing options...
Constantino Gavin Posted June 3, 2022 Share #324 Posted June 3, 2022 (edited) 2 hours ago, Peter Suh said: For users already in the recovery loop, use the script below. I made a temporary script of pocopico into a file and uploaded it to my repo. Download and use it as shown below. curl --location "https://github.com/PeterSuh-Q3/tinycore-redpill/raw/main/42661U2_patch.sh" --output 42661U2_patch.sh chmod +x 42661U2_patch.sh ./42661U2_patch.sh And, if you build with version 0.8.0.1 of pocopico, update2 seems to respond immediately, but it seems to be still being verified. I'm online again! I used your script in TC, restarted and the Recovery was successfully! Thank you man, you made my day! Edited June 3, 2022 by Constantino Gavin 1 Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted June 3, 2022 Author Share #325 Posted June 3, 2022 [NOTICE] After applying DSM 7.1.0-42661 Update 2, a postupdate option has been added to solve the restore loop. No additional build is required. To update a new function, follow the steps below. ./my.sh you can patch it with the options below and use it. ./my.sh DS918+ postupdate ---------------------------------------------------------------------------------------- Usage: ./my.sh <Synology Model Name> <Options> Options: jumkey, noconfig, noclean, manual - postupdate : Option to patch the restore loop after applying DSM 7.1.0-42661 Update 2, no additional build required. - jumkey : Option to apply jumkey's dynamic automatic dtc patch extension files (contrary to pocopico's static dtc patch). - noconfig: SKIP automatic detection change processing such as SN/Mac/Vid/Pid/SataPortMap of user_config.json file. - noclean: SKIP the 💊 RedPill LKM/LOAD directory without clearing it with the Clean now command. However, delete the Cache directory and loader.img. - manual: Options for manual extension processing and manual dtc processing in build action (skipping extension auto detection) Please type Synology Model Name after ./my.sh ./my.sh DS918+ ./my.sh DS3617xs ./my.sh DS3615xs ./my.sh DS3622xs+ ./my.sh DVA3221 ./my.sh DS920+ ./my.sh DS1621+ - for jun mode ./my.sh DS918+J ./my.sh DS3617xsJ ./my.sh DS3615xsJ ./my.sh DS3622xs+J ./my.sh DVA3221J ./my.sh DS920+J ./my.sh DS1621+J 2 Quote Link to comment Share on other sites More sharing options...
