Peter Suh Posted May 21, 2022 Author Share #276 Posted May 21, 2022 (edited) @pocopico @jumkey modified the install_rd.sh file of dtb ext 14 hours ago in his repo, The sha256sum of your ds920p_42661.json points to the sha256sum of the old file, so you get a mismatch error. Please fix it with the sha256sum value of the new install_rd.sh file. Edited May 21, 2022 by Peter Suh Quote Link to comment Share on other sites More sharing options...
luutuananh Posted May 22, 2022 Share #277 Posted May 22, 2022 (edited) I tried on another system, which is running on ds918+ jun loader for a long time, now I have another error. This is the status of this system: VM or BareMetal : BareMetal Hardware (Motherboard/CPU) : ASUS STRIX GAMING B250-I, Core i5 7500T Hot Plug/Hot Swap Applied : Enabled on 4 HHD Network Interface 1 : Realtek® RTL8111H include with motherboard Loader : TCRP 0.4.6 version of rploader.sh : 0.7.1.5 Platform (DS3622xsp/DS918+/DS920+/DVA3221/DS1621+/DS3615xs/DS3617xs) : DS918+ Platform Version (6.2.4/7.0.1/7.1) : 7.1 Platform Revision (42218/42661/42661-U1) : 42661 GRUB Boot selection : USB Installation Steps : ./rploader.sh update now ./rploader.sh fullupgrade now ./rploader.sh serialgen DS918+ ./rploader.sh identifyusb now ./rploader.sh satamap now ./rploader.sh build apollolake-7.0.1-42218 ./rploader.sh clean now ./rploader.sh build apollolake-7.1.0-42661 ./rploader.sh clean now; rm -rf /mnt/sdb3/auxfiles; rm -rf /home/tc/custom-module; ./rploader.sh backup now; sudo reboot now Current Status : Boots to kernel, IP recived. Error on disk We've detected errors on the hard drives (1, 2), and the SATA ports have also been disabled. Please shut down your DS918+ to replace or remove the hard drives and try again. Edited May 22, 2022 by luutuananh Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted May 22, 2022 Author Share #278 Posted May 22, 2022 18 hours ago, luutuananh said: Hi, may be I found out whats going on. After a lot of trying, I go back and using Jun loader on dsm 6.2.3. And I can see that DSM recognize my hdd start at number 3. So the question now is how can I map the HDD properly. Is there any document or post on this forum let me allow loader skip the first sata port on the board. i mean, to map the first dsm sata port to mainboard sata port 3. Change the disk physically installed in Sata Port No. 3 to use Sata Port No. 1. Is there any other reason not to do this? Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted May 22, 2022 Author Share #279 Posted May 22, 2022 14 hours ago, Peter Suh said: @pocopico @jumkey modified the install_rd.sh file of dtb ext 14 hours ago in his repo, The sha256sum of your ds920p_42661.json points to the sha256sum of the old file, so you get a mismatch error. Please fix it with the sha256sum value of the new install_rd.sh file. @pocopico The install_rd.sh file as well as the sha256sum value in install.sh must be modified. 1 Quote Link to comment Share on other sites More sharing options...
luutuananh Posted May 23, 2022 Share #280 Posted May 23, 2022 Hi @Peter Suh, maybe I know what cause this problem. Because I have 2 M.2 slots on my motherboard, and there is no drive populated on those 2 ports. Is there anyway to let DSM know not to use those 2 M.2 slot? Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted May 23, 2022 Author Share #281 Posted May 23, 2022 24 minutes ago, luutuananh said: Hi @Peter Suh, maybe I know what cause this problem. Because I have 2 M.2 slots on my motherboard, and there is no drive populated on those 2 ports. Is there anyway to let DSM know not to use those 2 M.2 slot? If you're sure ports 1 and 2 are used for M.2, there doesn't seem to be a way to skip this port on DS918+. The alternative seems to be only DS920+ using dtc. Automatic mapping of SATA ports in DS920+ (no function in TC yet) The function was developed by @jumkey yesterday and is still in the verification stage. If we wait a little longer, there may be news that we can use it for TC. Please wait for now. 1 Quote Link to comment Share on other sites More sharing options...
ulissessantos Posted May 23, 2022 Share #282 Posted May 23, 2022 Hello everyone, I have 7.1.0-42661 DS3615xs(bromolow) installed, if I try to migrate to 7.1.0 DS3622xs+(broadwellnk), after following all the steps when I restart my system, after instal DSM 7.1 it gets stuck on STARTING KERNEL WITH USB, do not get IP. It´s a old pc Acer extensa 5630, witth Pentium core2 duo T9400. With a clean install the same thing happens. Thanks, Quote Link to comment Share on other sites More sharing options...
pocopico Posted May 23, 2022 Share #283 Posted May 23, 2022 (edited) 5 hours ago, ulissessantos said: Hello everyone, I have 7.1.0-42661 DS3615xs(bromolow) installed, if I try to migrate to 7.1.0 DS3622xs+(broadwellnk), after following all the steps when I restart my system, after instal DSM 7.1 it gets stuck on STARTING KERNEL WITH USB, do not get IP. It´s a old pc Acer extensa 5630, witth Pentium core2 duo T9400. With a clean install the same thing happens. Thanks, can you please post the output of the loader creation from TCRP ? Edited May 23, 2022 by pocopico Quote Link to comment Share on other sites More sharing options...
Juga Posted May 23, 2022 Share #284 Posted May 23, 2022 On 5/21/2022 at 6:23 AM, SachinD said: Am facing a build issue with the ds920 platform, the loader detects my HDDs but is unable to create the dtb file correctly. See error below ######################################################################### 100.0% [#] Extension redpill-misc for ds920p_42661 platform is already up to date [#] Updating ds920p_42661 platforms extensions... [OK] Protocol spec without prior Class and Subclass spec at line 23281 Downloading dtc binary ######################################################################### 100.0% No cached dtb file found in /home/tc/custom-module/ds920p.dtb Found 4 disks and 0 nvme Collecting disk paths Found local disk sda with path 00:12.0, adding into internal_slot 1 with portnumber 0 Found local disk sdb with path 00:12.0, adding into internal_slot 2 with portnumber 1 Found local disk sdc with path 00:13.3,00.0, adding into internal_slot 3 with portnumber 2 Found local disk sdd with path 00:13.3,00.0, adding into internal_slot 4 with portnumber 3 NO NVME disks found, returning Patching USB to include your loader. Loader found in 1-4 port Converting dts file : ds920p.dts to dtb file : >ds920p.dtb dtb extension is not loaded and its required for DSM to find disks on ds920p_42661 Copy of the DTB file ds920p.dtb to was not succesfull. Please remember to replace the dtb extension model file ... execute manually : cp ds920p.dtb and re-run @Peter Suh Same problem here with DS920+ only DS920. DS918 is ok No cached dtb file found in /home/tc/custom-module/ds920p.dtb dts file for ds920p not found, trying to download ######################################################################## 100.0% Found 3 disks and 1 nvme Collecting disk paths Found local disk sda with path 00:17.0, adding into internal_slot 1 with portnum ber 0 Found local disk sdb with path 00:17.0, adding into internal_slot 2 with portnum ber 1 Found local disk sdc with path 00:17.0, adding into internal_slot 3 with portnum ber 2 Collecting nvme paths Found local nvme nvme0n1 with path 00:1b.0,00.0, adding into m2_card 1 Patching USB to include your loader. Loader found in 2-2 port Converting dts file : ds920p.dts to dtb file : >ds920p.dtb dtb extension is not loaded and its required for DSM to find disks on ds920p_426 61 Copy of the DTB file ds920p.dtb to was not succesfull. Please remember to replace the dtb extension model file ... execute manually : cp ds920p.dtb and re-run @Peter Suhthank you for your contributions. Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted May 24, 2022 Author Share #285 Posted May 24, 2022 1 hour ago, Juga said: @Peter Suh Same problem here with DS920+ only DS920. DS918 is ok No cached dtb file found in /home/tc/custom-module/ds920p.dtb dts file for ds920p not found, trying to download ######################################################################## 100.0% Found 3 disks and 1 nvme Collecting disk paths Found local disk sda with path 00:17.0, adding into internal_slot 1 with portnum ber 0 Found local disk sdb with path 00:17.0, adding into internal_slot 2 with portnum ber 1 Found local disk sdc with path 00:17.0, adding into internal_slot 3 with portnum ber 2 Collecting nvme paths Found local nvme nvme0n1 with path 00:1b.0,00.0, adding into m2_card 1 Patching USB to include your loader. Loader found in 2-2 port Converting dts file : ds920p.dts to dtb file : >ds920p.dtb dtb extension is not loaded and its required for DSM to find disks on ds920p_426 61 Copy of the DTB file ds920p.dtb to was not succesfull. Please remember to replace the dtb extension model file ... execute manually : cp ds920p.dtb and re-run @Peter Suhthank you for your contributions. The work @pocopico promised regarding the dtb of the ds920+ is still in progress. If you want a ds920+ build before this completion, I'll provide a few fixes. I will post again when the partition size is adjusted 0.4.6 img and the adjusted script is completed. 1 Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted May 24, 2022 Author Share #286 Posted May 24, 2022 (edited) 3 hours ago, Peter Suh said: The work @pocopico promised regarding the dtb of the ds920+ is still in progress. If you want a ds920+ build before this completion, I'll provide a few fixes. I will post again when the partition size is adjusted 0.4.6 img and the adjusted script is completed. In @pocopico's 0.4.6 img for legacy, the first partition is increased from 48mb to 96mb to secure space for the dtc utility to be copied, and it is an image that has been fully upgraded to the latest version 0.7.1.7. Download it from the Google link below, decompress the gz and record it on a new USB stick. And rploader.sh on my Github repo blocks the patchdtc function so that there are no errors like the log above, and also blocks the update of rploader.sh itself. https://drive.google.com/file/d/1Jxr0znrDxkqIhcbFPTyll44VwdvuPBu-/view?usp=sharing tc@box:~$ curl --location "https://github.com/PeterSuh-Q3/tinycore-redpill/raw/main/rploader.sh" --output rploader.sh Lastly, before processing the build action, please add the following jumkey.dtb ext first. mkdir /mnt/"$(mount | grep -i optional | grep cde | awk -F / '{print $3}' | uniq | cut -c 1-3)3"/auxfiles; sudo ln -s /mnt/"$(mount | grep -i optional | grep cde | awk -F / '{print $3}' | uniq | cut -c 1-3)3"/auxfiles /home/tc/custom-module; ./rploader.sh ext geminilake-7.1.0-42661 add https://github.com/jumkey/redpill-load/raw/develop/redpill-dtb/rpext-index.json ./rploader.sh build geminilake-7.1.0-42661 ./rploader.sh backup now P.S : For ds920+ using dtc, it takes a little longer to check the ip from nic. Edited May 24, 2022 by Peter Suh 1 Quote Link to comment Share on other sites More sharing options...
Darksplat Posted May 24, 2022 Share #287 Posted May 24, 2022 Hi All Are we able to clean this up to be a proper guide? It is very confusing with all the posts and we(the Community) don't know where to start and end as there are fixes all over the place. So we don't know if we start on the first post or on the 20th? Cheers Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted May 24, 2022 Author Share #288 Posted May 24, 2022 3 hours ago, Darksplat said: Hi All Are we able to clean this up to be a proper guide? It is very confusing with all the posts and we(the Community) don't know where to start and end as there are fixes all over the place. So we don't know if we start on the first post or on the 20th? Cheers Only ds920+ and ds1621+ have not been fixed yet. Other models of loader builds have no problem. There is no need to set the standard from the 20th. Quote Link to comment Share on other sites More sharing options...
Ribb Posted May 24, 2022 Share #289 Posted May 24, 2022 On 5/23/2022 at 9:51 AM, luutuananh said: Hi @Peter Suh, maybe I know what cause this problem. Because I have 2 M.2 slots on my motherboard, and there is no drive populated on those 2 ports. Is there anyway to let DSM know not to use those 2 M.2 slot? Maybe disable m.2 slots in bios would help Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted May 24, 2022 Author Share #290 Posted May 24, 2022 @Ribb, @luutuananh This is the post I already shared above, how to build a new DS920+. You don't need to worry about mappings related to SataPortMap etc or any Sata port at all. Just build and use. It is recommended because it is a method that can also skip the M.2 slot. Try this method. 1 Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted May 24, 2022 Author Share #291 Posted May 24, 2022 [NOTICE] M Shell, Tinycore jun mode build function added distribution I don't have time So, I only applied my.sh. The rest of the shells will be updated soon. DSM 7.0.1-42218, which is a required pat file for the current Jun Mode application, is changed to update 4. The contents of the download pat file have been changed again. In this changed state, pocopico's tinycore does not respond, so when building in jun mode, build is not possible due to sha256sum mismatch. In order to bypass this part in the m shell, DSM 7.0.1-42218 update 4 Download the pat file to avoid build errors. Automatic update is supported, so if you use "./my.sh model name" only once, it will be updated to the latest version. For new users, please download and decompress it using the command below in TC Linux. wget https://github.com/PeterSuh-Q3/tinycore-redpill/raw/main/my.sh.gz; tar -zxvf my.sh.gz; For jun mode, just add one more "J" after the existing model name. It's like this. ./my.sh DS918+J ./my.sh DS3622xsJ 1 Quote Link to comment Share on other sites More sharing options...
ulissessantos Posted May 24, 2022 Share #292 Posted May 24, 2022 On 5/23/2022 at 5:05 PM, pocopico said: can you please post the output of the loader creation from TCRP ? tc@box:~$ ./rploader.sh update now Checking Internet Access -> OK Checking if a newer version exists on the repo -> Found newversion : 0.7.1.7 Current version : 0.7.1.7 There is a newer version of the script on the repo should we use that ? [yY/nN]y OK, updating, please re-run after updating Updating tinycore loader with latest updates Backing up files to /mnt/sdc3//mydata.tgz Done. tc@box:~$ ./rploader.sh fullupgrade now Performing a full TCRP upgrade Warning some of your local files will be moved to /home/tc/old/xxxx.2022-May-24- 18-06 Updating custom_config.json % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 100 33806 100 33806 0 0 67477 0 --:--:-- --:--:-- --:--:-- 67477 Updating custom_config_jun.json % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 100 8940 100 8940 0 0 17738 0 --:--:-- --:--:-- --:--:-- 17738 Updating global_config.json % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 100 5692 100 5692 0 0 11932 0 --:--:-- --:--:-- --:--:-- 11932 Updating modules.alias.3.json.gz mv: cannot stat 'modules.alias.3.json.gz': No such file or directory % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 100 5591 100 5591 0 0 18824 0 --:--:-- --:--:-- --:--:-- 18824 Updating modules.alias.4.json.gz mv: cannot stat 'modules.alias.4.json.gz': No such file or directory % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 100 89007 100 89007 0 0 225k 0 --:--:-- --:--:-- --:--:-- 225k Updating rpext-index.json % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 100 211k 100 211k 0 0 375k 0 --:--:-- --:--:-- --:--:-- 1230k Updating user_config.json % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 100 431 100 431 0 0 872 0 --:--:-- --:--:-- --:--:-- 872 Updating dtc % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 100 146k 100 146k 0 0 268k 0 --:--:-- --:--:-- --:--:-- 464k Updating rploader.sh % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 100 88522 100 88522 0 0 229k 0 --:--:-- --:--:-- --:--:-- 229k Updating ds1621p.dts % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 100 3026 100 3026 0 0 5887 0 --:--:-- --:--:-- --:--:-- 5887 Updating ds920p.dts % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 100 2423 100 2423 0 0 4714 0 --:--:-- --:--:-- --:--:-- 4714 Please make sure you are using the latest 1GB img before using backup option Current /home/tc size is 3.8M , try to keep it less than 1GB as it might not fit into your image Should i update the sdc with your current files [Yy/Nn] y Backing up home files to sdc : Backing up files to /mnt/sdc3//mydata.tgz Done. tc@box:~$ ./rploader.sh serialgen DS3622xs+ Serial Number for Model : 2150SQRAKJT3B Mac Address for Model DS3622xs+ : 00:11:32:61:9E:67 Should i update the user_config.json with these values ? [Yy/Nn] y tc@box:~$ ./rploader.sh identifyusb now Found Verbatim STORE SerialNumber: 0173000000021AAB Vendor ID : 0x18a5 Product ID : 0x0302 Should i update the user_config.json with these values ? [Yy/Nn] y tc@box:~$ /rploader.sh satamap now -sh: /rploader.sh: not found tc@box:~$ ./rploader.sh satamap now Found "00:1f.2 Intel Corporation 82801IBM/IEM (ICH9M/ICH9M-E) 4 port SATA Contro ller [AHCI mode] (rev 03)" 2 drive(s) connected. How many ports does this controller have? [0-9] <2> 2 Recommended settings: SataPortMap=2 DiskIdxMap=00 Should i update the user_config.json with these values ? [Yy/Nn] y Done. tc@box:~$ ./rploader.sh build broadwellnk-7.0.1-42218 Rploader Version : 0.7.1.7 Loader source : https://github.com/pocopico/redpill-load.git Loader Branch : dev elop Redpill module source : https://github.com/pocopico/redpill-lkm.git : Redpill mo dule branch : master Extensions : Extensions URL : TOOLKIT_URL : https://sourceforge.net/projects/dsgpl/files/toolkit/DSM7.0/ds.bro adwellnk-7.0.dev.txz/download TOOLKIT_SHA : 0d9edca67d9e7e14c2529bbb58341b623936124d5264f71f1e4acbacf3ea202d SYNOKERNEL_URL : https://sourceforge.net/projects/dsgpl/files/Synology NAS G PL%20Source/25426branch/broadwellnk-source/linux-4.4.x.txz/download SYNOKERNEL_SHA : d3e85eb80f16a83244fcae6016ab6783cd8ac55e3af2b4240455261396e1e1b e COMPILE_METHOD : toolkit_dev TARGET_PLATFORM : broadwellnk TARGET_VERSION : 7.0.1 TARGET_REVISION : 42218 REDPILL_LKM_MAKE_TARGET : dev-v7 KERNEL_MAJOR : 4 MODULE_ALIAS_FILE : modules.alias.4.json SYNOMODEL : ds3622xsp_42218 MODEL : DS3622xs+ Local Cache Folder : /mnt/sdc3/auxfiles DATE Internet : 24052022 Local : 24052022 Checking Internet Access -> OK Checking if a newer version exists on the repo -> Version is current Cloning into 'redpill-lkm'... remote: Enumerating objects: 1253, done. remote: Counting objects: 100% (325/325), done. remote: Compressing objects: 100% (41/41), done. remote: Total 1253 (delta 302), reused 284 (delta 283), pack-reused 928 Receiving objects: 100% (1253/1253), 469.84 KiB | 2.13 MiB/s, done. Resolving deltas: 100% (865/865), done. Cloning into 'redpill-load'... remote: Enumerating objects: 1994, done. remote: Total 1994 (delta 0), reused 0 (delta 0), pack-reused 1994 Receiving objects: 100% (1994/1994), 114.70 MiB | 11.30 MiB/s, done. Resolving deltas: 100% (937/937), done. No extra build option or static specified, using default <static> Using static compiled redpill extension Removing any old redpill.ko modules Looking for redpill for : ds3622xsp_42218 Getting file https://raw.githubusercontent.com/pocopico/rp-ext/master/redpill/re leases/redpill-4.4.180plus-broadwellnk.tgz Extracting module Getting file https://raw.githubusercontent.com/pocopico/rp-ext/master/redpill/sr c/check-redpill.sh Got redpill-linux-v4.4.180+.ko Testing modules.alias.4.json -> File OK -------------------------------------------------------------------------------- ---------------- It looks that you will need the following modules : Found SATA Controller : pciid 8086d00002929 Required Extension : ahci Searching for matching extension for ahci Found VGA Controller : pciid 10ded000006e9 Required Extension : No matching extension [#] Checking runtime for required tools... [OK] [#] Adding new extension from https://raw.githubusercontent.com/pocopico/rp-ext/ master/tg3/rpext-index.json... [#] Downloading remote file https://raw.githubusercontent.com/pocopico/rp-ext/ma ster/tg3/rpext-index.json to /home/tc/redpill-load/custom/extensions/_new_ext_in dex.tmp_json ######################################################################## 100.0% [OK] [#] ========================================== pocopico.tg3 ==================== ====================== [#] Extension name: tg3 [#] Description: Adds Broadcom Tigon3 ethernet driver Support [#] To get help visit: <todo> [#] Extension preparer/packer: https://github.com/pocopico/rp-ext/tree/main/tg3 [#] Software author: https://github.com/pocopico [#] Update URL: https://raw.githubusercontent.com/pocopico/rp-ext/master/tg3/rpe xt-index.json [#] Platforms supported: ds1621p_42218 ds918p_41890 dva3221_42661 ds3617xs_42621 ds3617xs_42218 ds920p_42661 ds918p_42661 ds1621p_42661 ds918p_25556 dva3221_422 18 ds3615xs_42661 ds3622xsp_42661 ds3622xsp_42218 dva3221_42621 ds3615xs_41222 d s918p_42621 ds3617xs_42661 ds3615xs_25556 ds920p_42218 ds920p_42621 ds918p_42218 ds1621p_42621 ds3615xs_42621 ds3615xs_42218 ds3622xsp_42621 [#] ============================================================================ =========== Found Ethernet Interface : pciid 14e4d00001684 Required Extension : tg3 Searching for matching extension for tg3 Found matching extension : "https://raw.githubusercontent.com/pocopico/rp-ext/master/tg3/rpext-index.json" -------------------------------------------------------------------------------- ---------------- Starting loader creation Found tinycore cache folder, linking to home/tc/custom-module Checking user_config.json : Done Entering redpill-load directory Removing bundled exts directories Cache directory OK Want to use firmware files from /home/tc/custom-module/*.pat ? [yY/nN] : y cp: cannot stat '/home/tc/custom-module/*42218*.pat': No such file or directory Processing add_extensions entries found on custom_config.json file : [#] Checking runtime for required tools... [OK] [#] Updating extensions... [#] Checking runtime for required tools... [OK] [#] Adding new extension from https://github.com/pocopico/rp-ext/raw/main/redpil l-boot-wait/rpext-index.json... [#] Downloading remote file https://github.com/pocopico/rp-ext/raw/main/redpill- boot-wait/rpext-index.json to /home/tc/redpill-load/custom/extensions/_new_ext_i ndex.tmp_json ######################################################################### 100.0% [OK] [#] ========================================== redpill-boot-wait =============== =========================== [#] Extension name: RedPill Bootwait [#] Description: Simple extension which stops the execution early waiting for th e boot device to appear [#] To get help visit: https://github.com/pocopico/rp-ext/redpill-boot-wait [#] Extension preparer/packer: https://github.com/pocopico/rp-ext/tree/main/redp ill-boot-wait [#] Update URL: https://raw.githubusercontent.com/pocopico/rp-ext/master/redpill -boot-wait/rpext-index.json [#] Platforms supported: ds1621p_42218 ds918p_41890 dva3221_42661 ds3617xs_42621 ds3617xs_42218 ds920p_42661 ds918p_42661 ds1621p_42661 ds918p_25556 dva3221_422 18 ds3615xs_42661 ds3622xsp_42661 ds2422p_42661 ds3622xsp_42218 ds2422p_42218 dv a3221_42621 ds3615xs_41222 ds918p_42621 ds3617xs_42661 ds3615xs_25556 ds920p_422 18 ds920p_42621 ds920p_42550 ds918p_42218 ds2422p_42621 ds1621p_42621 ds3615xs_4 2621 ds3615xs_42218 ds3622xsp_42621 [#] ============================================================================ =========== [#] Checking runtime for required tools... [OK] [#] Updating pocopico.tg3 extension... [#] Downloading remote file https://raw.githubusercontent.com/pocopico/rp-ext/ma ster/tg3/rpext-index.json to /home/tc/redpill-load/custom/extensions/_new_ext_in dex.tmp_json ######################################################################### 100.0% [#] Extension pocopico.tg3 index is already up to date [#] Updating redpill-boot-wait extension... [#] Downloading remote file https://raw.githubusercontent.com/pocopico/rp-ext/ma ster/redpill-boot-wait/rpext-index.json to /home/tc/redpill-load/custom/extensio ns/_new_ext_index.tmp_json ######################################################################### 100.0% [#] Extension redpill-boot-wait index is already up to date [#] Updating redpill-boot-wait extension... [OK] [#] Checking runtime for required tools... [OK] [#] Updating ds3622xsp_42218 platforms extensions... [#] Downloading remote file https://raw.githubusercontent.com/pocopico/rp-ext/ma ster/tg3/releases/ds3622xsp_42218.json to /home/tc/redpill-load/custom/extension s/_ext_new_rcp.tmp_json ######################################################################### 100.0% [#] Filling-in newly downloaded recipe for extension pocopico.tg3 platform ds362 2xsp_42218 [#] Downloading remote file https://raw.githubusercontent.com/pocopico/rp-ext/ma ster/tg3/releases/tg3-4.4.180plus-broadwellnk.tgz to /home/tc/redpill-load/custo m/extensions/pocopico.tg3/ds3622xsp_42218/tg3-4.4.180plus-broadwellnk.tgz ######################################################################### 100.0% [#] Verifying /home/tc/redpill-load/custom/extensions/pocopico.tg3/ds3622xsp_422 18/tg3-4.4.180plus-broadwellnk.tgz file... [OK] [#] Unpacking files from /home/tc/redpill-load/custom/extensions/pocopico.tg3/ds 3622xsp_42218/tg3-4.4.180plus-broadwellnk.tgz to /home/tc/redpill-load/custom/ex tensions/pocopico.tg3/ds3622xsp_42218/... [OK] [#] Downloading remote file https://raw.githubusercontent.com/pocopico/rp-ext/ma ster/tg3/src/check-tg3.sh to /home/tc/redpill-load/custom/extensions/pocopico.tg 3/ds3622xsp_42218/check-tg3.sh ######################################################################### 100.0% [#] Verifying /home/tc/redpill-load/custom/extensions/pocopico.tg3/ds3622xsp_422 18/check-tg3.sh file... [OK] [#] Successfully processed recipe for extension pocopico.tg3 platform ds3622xsp_ 42218 [#] Downloading remote file https://github.com/RedPill-TTG/redpill-boot-wait/raw /master/recipes/universal.json to /home/tc/redpill-load/custom/extensions/_ext_n ew_rcp.tmp_json ######################################################################### 100.0% [#] Filling-in newly downloaded recipe for extension redpill-boot-wait platform ds3622xsp_42218 [#] Downloading remote file https://raw.githubusercontent.com/RedPill-TTG/redpil l-boot-wait/master/src/boot-wait.sh to /home/tc/redpill-load/custom/extensions/r edpill-boot-wait/ds3622xsp_42218/boot-wait.sh ######################################################################### 100.0% [#] Verifying /home/tc/redpill-load/custom/extensions/redpill-boot-wait/ds3622xs p_42218/boot-wait.sh file... [OK] [#] Successfully processed recipe for extension redpill-boot-wait platform ds362 2xsp_42218 [#] Verifying /home/tc/redpill-load/custom/extensions/redpill-boot-wait/ds3622xs p_42218/boot-wait.sh file... [OK] [#] Updating extensions... [OK] [#] PAT file /home/tc/redpill-load/cache/ds3622xsp_42218.pat not found - downloa ding from https://global.download.synology.com/download/DSM/release/7.0.1/42218/ DSM_DS3622xs+_42218.pat % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 100 345M 100 345M 0 0 18.6M 0 0:00:18 0:00:18 --:--:-- 19.1M [#] Verifying /home/tc/redpill-load/cache/ds3622xsp_42218.pat file... [OK] [#] Unpacking /home/tc/redpill-load/cache/ds3622xsp_42218.pat file to /home/tc/r edpill-load/build/1653415716/pat-ds3622xsp_42218-unpacked... [OK] [#] Verifying /home/tc/redpill-load/build/1653415716/pat-ds3622xsp_42218-unpacke d/zImage file... [OK] [#] Patching /home/tc/redpill-load/build/1653415716/pat-ds3622xsp_42218-unpacked /zImage to /home/tc/redpill-load/build/1653415716/zImage-patched... [OK] [#] Verifying /home/tc/redpill-load/build/1653415716/pat-ds3622xsp_42218-unpacke d/rd.gz file... [OK] [#] Unpacking /home/tc/redpill-load/build/1653415716/pat-ds3622xsp_42218-unpacke d/rd.gz file to /home/tc/redpill-load/build/1653415716/rd-ds3622xsp_42218-unpack ed... [OK] [#] Apply patches to /home/tc/redpill-load/build/1653415716/rd-ds3622xsp_42218-u npacked... [OK] [#] Patching config files in ramdisk... [OK] [#] Adding OS config patching... [OK] [#] Repacking ramdisk to /home/tc/redpill-load/build/1653415716/rd-patched-ds362 2xsp_42218.gz... [OK] [#] Bundling extensions... [#] Checking runtime for required tools... [OK] [#] Dumping ds3622xsp_42218 platform extensions to /home/tc/redpill-load/build/1 653415716/custom-initrd/exts... [OK] [#] Packing custom ramdisk layer to /home/tc/redpill-load/build/1653415716/custo m.gz... [OK] [#] Generating GRUB config... [OK] [#] Creating loader image at loader.img... [OK] [#] Cleaning up... [OK] Mounting /dev/sdc1 to localdiskp1 /dev/sdc2 localdiskp2 Creating tinycore entry menuentry 'Tiny Core Image Build' { savedefault set root=(hd0,msdos3) echo Loading Linux... linux /vmlinuz64 loglevel=3 cde waitusb=5 vga=791 echo Loading initramfs... initrd /corepure64.gz echo Booting TinyCore for loader creation } Entries in Localdisk bootloader : ======================================================================= menuentry 'RedPill DS3622xs v7.0.1-42218 Beta (USB, Verbose)' { menuentry 'RedPill DS3622xs v7.0.1-42218 Beta (SATA, Verbose)' { menuentry 'Tiny Core Image Build' { Caching files for future use Found /home/tc/redpill-load/cache/ds3622xsp_42218.pat, copying to cache director y : /mnt/sdc3/auxfiles Saving user session for future use. Saving current extensions -> OK ! Saving current user_config.json -> OK ! tc@box:~$ ./rploader.sh clean now Clearing local redpill files tc@box:~$ ./rploader.sh build broadwellnk-7.1.0-42661 Rploader Version : 0.7.1.7 Loader source : https://github.com/pocopico/redpill-load.git Loader Branch : dev elop Redpill module source : https://github.com/pocopico/redpill-lkm.git : Redpill mo dule branch : master Extensions : redpill-misc Extensions URL : "https://github.com/pocopico/redpill-load/raw/master/redpill-mi sc/rpext-index.json" TOOLKIT_URL : https://sourceforge.net/projects/dsgpl/files/toolkit/DSM7.0/ds.bro adwellnk-7.0.dev.txz/download TOOLKIT_SHA : 0d9edca67d9e7e14c2529bbb58341b623936124d5264f71f1e4acbacf3ea202d SYNOKERNEL_URL : https://sourceforge.net/projects/dsgpl/files/Synology NAS G PL%20Source/25426branch/broadwellnk-source/linux-4.4.x.txz/download SYNOKERNEL_SHA : d3e85eb80f16a83244fcae6016ab6783cd8ac55e3af2b4240455261396e1e1b e COMPILE_METHOD : toolkit_dev TARGET_PLATFORM : broadwellnk TARGET_VERSION : 7.1.0 TARGET_REVISION : 42661 REDPILL_LKM_MAKE_TARGET : dev-v7 KERNEL_MAJOR : 4 MODULE_ALIAS_FILE : modules.alias.4.json SYNOMODEL : ds3622xsp_42661 MODEL : DS3622xs+ Local Cache Folder : /mnt/sdc3/auxfiles DATE Internet : 24052022 Local : 24052022 Checking Internet Access -> OK Checking if a newer version exists on the repo -> Version is current Cloning into 'redpill-lkm'... remote: Enumerating objects: 1253, done. remote: Counting objects: 100% (325/325), done. remote: Compressing objects: 100% (41/41), done. remote: Total 1253 (delta 302), reused 284 (delta 283), pack-reused 928 Receiving objects: 100% (1253/1253), 469.84 KiB | 2.10 MiB/s, done. Resolving deltas: 100% (865/865), done. Cloning into 'redpill-load'... remote: Enumerating objects: 1994, done. remote: Total 1994 (delta 0), reused 0 (delta 0), pack-reused 1994 Receiving objects: 100% (1994/1994), 114.70 MiB | 8.61 MiB/s, done. Resolving deltas: 100% (940/940), done. No extra build option or static specified, using default <static> Using static compiled redpill extension Removing any old redpill.ko modules Looking for redpill for : ds3622xsp_42661 Getting file https://raw.githubusercontent.com/pocopico/rp-ext/master/redpill/re leases/redpill-4.4.180plus-broadwellnk.tgz Extracting module Getting file https://raw.githubusercontent.com/pocopico/rp-ext/master/redpill/sr c/check-redpill.sh Got redpill-linux-v4.4.180+.ko Testing modules.alias.4.json -> File OK -------------------------------------------------------------------------------- ---------------- It looks that you will need the following modules : Found SATA Controller : pciid 8086d00002929 Required Extension : ahci Searching for matching extension for ahci Found VGA Controller : pciid 10ded000006e9 Required Extension : No matching extension [#] Checking runtime for required tools... [OK] [#] Adding new extension from https://raw.githubusercontent.com/pocopico/rp-ext/ master/tg3/rpext-index.json... [#] Downloading remote file https://raw.githubusercontent.com/pocopico/rp-ext/ma ster/tg3/rpext-index.json to /home/tc/redpill-load/custom/extensions/_new_ext_in dex.tmp_json ######################################################################## 100.0% [OK] [#] ========================================== pocopico.tg3 ==================== ====================== [#] Extension name: tg3 [#] Description: Adds Broadcom Tigon3 ethernet driver Support [#] To get help visit: <todo> [#] Extension preparer/packer: https://github.com/pocopico/rp-ext/tree/main/tg3 [#] Software author: https://github.com/pocopico [#] Update URL: https://raw.githubusercontent.com/pocopico/rp-ext/master/tg3/rpe xt-index.json [#] Platforms supported: ds1621p_42218 ds918p_41890 dva3221_42661 ds3617xs_42621 ds3617xs_42218 ds920p_42661 ds918p_42661 ds1621p_42661 ds918p_25556 dva3221_422 18 ds3615xs_42661 ds3622xsp_42661 ds3622xsp_42218 dva3221_42621 ds3615xs_41222 d s918p_42621 ds3617xs_42661 ds3615xs_25556 ds920p_42218 ds920p_42621 ds918p_42218 ds1621p_42621 ds3615xs_42621 ds3615xs_42218 ds3622xsp_42621 [#] ============================================================================ =========== Found Ethernet Interface : pciid 14e4d00001684 Required Extension : tg3 Searching for matching extension for tg3 Found matching extension : "https://raw.githubusercontent.com/pocopico/rp-ext/master/tg3/rpext-index.json" -------------------------------------------------------------------------------- ---------------- Starting loader creation Found tinycore cache folder, linking to home/tc/custom-module Checking user_config.json : Done Entering redpill-load directory Removing bundled exts directories Cache directory OK Found build request for revision greater than 42218 Getting required extraction tool ------------------------------------------------------------------ Checking tinycore cache folder Found tinycore cache folder, linking to home/tc/custom-module Creating temp folder /tmp/synoesp Found custom pat file /home/tc/custom-module/ds3622xsp_42218.pat Processing old pat file to extract required files for extraction Entering synoesp extract rd.gz finish cpio: dev/console: Cannot mknod: Operation not permitted cpio: dev/net/tun: Cannot mknod: Operation not permitted 42506 blocks extract rd mkdir: cannot create directory '/mnt/sdc3/auxfiles': File exists Copying required files to local cache folder for future use Copying usr/lib/libcurl.so.4 to /mnt/sdc3/auxfiles Copying usr/lib/libmbedcrypto.so.5 to /mnt/sdc3/auxfiles Copying usr/lib/libmbedtls.so.13 to /mnt/sdc3/auxfiles Copying usr/lib/libmbedx509.so.1 to /mnt/sdc3/auxfiles Copying usr/lib/libmsgpackc.so.2 to /mnt/sdc3/auxfiles Copying usr/lib/libsodium.so to /mnt/sdc3/auxfiles Copying usr/lib/libsynocodesign-ng-virtual-junior-wins.so.7 to /mnt/sdc3/auxfile s Copying usr/syno/bin/scemd to /mnt/sdc3/auxfiles Copying required libraries to local lib directory Linking lib to lib64 Copying executable Removing temp folder /tmp/synoesp Checking if tools is accessible /bin/syno_extract_system_patch: /usr/local/lib/libcurl.so.4: no version informat ion available (required by /bin/syno_extract_system_patch) Copyright (c) 2003-2021 Synology Inc. All rights reserved. /bin/syno_extract_system_patch PATCH_PATH DEST_PATH Executed succesfully Creating temp folder /tmp/pat Checking for cached pat file Found tinycore cache folder, linking to home/tc/custom-module Could not find pat file locally cached Configdir : /home/tc/redpill-load/config/DS3622xs+/7.1.0-42661 Configfile: /home/tc/redpill-load/config/DS3622xs+/7.1.0-42661/config.json Pat URL : https://global.download.synology.com/download/DSM/release/7.1/42661-1/ DSM_DS3622xs%2B_42661.pat Downloading pat file from URL : https://global.download.synology.com/download/DS M/release/7.1/42661-1/DSM_DS3622xs%2B_42661.pat % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 100 352M 100 352M 0 0 38.4M 0 0:00:09 0:00:09 --:--:-- 45.6M File //mnt/sdc3/auxfiles/ds3622xsp_42661.pat, is encrypted File //mnt/sdc3/auxfiles/ds3622xsp_42661.pat, has been cached but its encrypted, re-running decrypting process Checking for cached pat file Found tinycore cache folder, linking to home/tc/custom-module Found locally cached pat file /home/tc/custom-module/ds3622xsp_42661.pat File /home/tc/custom-module/ds3622xsp_42661.pat, is encrypted Extracting encrypted pat file : /home/tc/custom-module/ds3622xsp_42661.pat to /t mp/pat /bin/syno_extract_system_patch: /usr/local/lib/libcurl.so.4: no version informat ion available (required by /bin/syno_extract_system_patch) Creating unecrypted pat file ds3622xsp_42661.pat to /home/tc/redpill-load/cache folder ./VERSION Pat file sha256sum is : bad4edf3ad0ccc4670b55c1647ada69f7a407332bc029a9c110f1ab 29e7a206a Checking config file existence -> OK Editing config file -> Verifying config file -> OK ! Clearing temp folders Processing add_extensions entries found on custom_config.json file : redpill-m isc Adding extension "https://github.com/pocopico/redpill-load/raw/master/redpill-mi sc/rpext-index.json" [#] Checking runtime for required tools... [OK] [#] Adding new extension from https://github.com/pocopico/redpill-load/raw/maste r/redpill-misc/rpext-index.json... [#] Downloading remote file https://github.com/pocopico/redpill-load/raw/master/ redpill-misc/rpext-index.json to /home/tc/redpill-load/custom/extensions/_new_ex t_index.tmp_json ######################################################################### 100.0% [OK] [#] ========================================== redpill-misc ==================== ====================== [#] Extension name: Misc shell [#] Description: Misc shell [#] To get help visit: https://github.com/pocopico/redpill-load/raw/develop/redp ill-misc [#] Extension preparer/packer: https://github.com/pocopico/redpill-load/raw/deve lop/redpill-misc [#] Software author: https://github.com/pocopico/redpill-load/raw/develop/redpil l-misc [#] Update URL: https://github.com/pocopico/redpill-load/raw/develop/redpill-mis c/rpext-index.json [#] Platforms supported: ds1621p_42218 ds918p_41890 dva3221_42661 ds3617xs_42621 ds3617xs_42218 ds920p_42661 ds918p_42661 ds1621p_42661 ds918p_25556 dva3221_422 18 ds3615xs_42661 ds3622xsp_42661 ds3622xsp_42218 dva3221_42621 ds3615xs_41222 d s918p_42621 ds3617xs_42661 ds3615xs_25556 ds920p_42218 ds920p_42621 ds918p_42218 ds1621p_42621 ds3615xs_42621 ds3615xs_42218 ds3622xsp_42621 [#] ============================================================================ =========== Updating extension : redpill-misc contents for model : ds3622xsp_42661 [#] Checking runtime for required tools... [OK] [#] Updating ds3622xsp_42661 platforms extensions... [#] Downloading remote file https://github.com/pocopico/redpill-load/raw/develop /redpill-misc/recipes/universal.json to /home/tc/redpill-load/custom/extensions/ _ext_new_rcp.tmp_json ######################################################################### 100.0% [#] Filling-in newly downloaded recipe for extension redpill-misc platform ds362 2xsp_42661 [#] Downloading remote file https://github.com/pocopico/redpill-load/raw/develop /redpill-misc/releases/install.sh to /home/tc/redpill-load/custom/extensions/red pill-misc/ds3622xsp_42661/install.sh ######################################################################### 100.0% [#] Verifying /home/tc/redpill-load/custom/extensions/redpill-misc/ds3622xsp_426 61/install.sh file... [OK] [#] Downloading remote file https://github.com/pocopico/redpill-load/raw/develop /redpill-misc/releases/install-all.sh to /home/tc/redpill-load/custom/extensions /redpill-misc/ds3622xsp_42661/install-all.sh ######################################################################### 100.0% [#] Verifying /home/tc/redpill-load/custom/extensions/redpill-misc/ds3622xsp_426 61/install-all.sh file... [OK] [#] Downloading remote file https://github.com/tsl0922/ttyd/releases/download/1. 6.3/ttyd.x86_64 to /home/tc/redpill-load/custom/extensions/redpill-misc/ds3622xs p_42661/ttyd ######################################################################### 100.0% [#] Verifying /home/tc/redpill-load/custom/extensions/redpill-misc/ds3622xsp_426 61/ttyd file... [OK] [#] Downloading remote file https://github.com/pocopico/redpill-load/raw/develop /redpill-misc/releases/install_rd.sh to /home/tc/redpill-load/custom/extensions/ redpill-misc/ds3622xsp_42661/install_rd.sh ######################################################################### 100.0% [#] Verifying /home/tc/redpill-load/custom/extensions/redpill-misc/ds3622xsp_426 61/install_rd.sh file... [OK] [#] Downloading remote file https://github.com/pocopico/redpill-load/raw/develop /redpill-misc/releases/lrzsz.tar.gz to /home/tc/redpill-load/custom/extensions/r edpill-misc/ds3622xsp_42661/lrzsz.tar.gz ######################################################################### 100.0% [#] Verifying /home/tc/redpill-load/custom/extensions/redpill-misc/ds3622xsp_426 61/lrzsz.tar.gz file... [OK] [#] Unpacking files from /home/tc/redpill-load/custom/extensions/redpill-misc/ds 3622xsp_42661/lrzsz.tar.gz to /home/tc/redpill-load/custom/extensions/redpill-mi sc/ds3622xsp_42661/... [OK] [#] Successfully processed recipe for extension redpill-misc platform ds3622xsp_ 42661 [#] Unpacking files from /home/tc/redpill-load/custom/extensions/redpill-misc/ds 3622xsp_42661/lrzsz.tar.gz to /home/tc/redpill-load/custom/extensions/redpill-mi sc/ds3622xsp_42661/... [OK] [#] Checking runtime for required tools... [OK] [#] Updating extensions... [#] Checking runtime for required tools... [OK] [#] Adding new extension from https://github.com/pocopico/rp-ext/raw/main/redpil l-boot-wait/rpext-index.json... [#] Downloading remote file https://github.com/pocopico/rp-ext/raw/main/redpill- boot-wait/rpext-index.json to /home/tc/redpill-load/custom/extensions/_new_ext_i ndex.tmp_json ######################################################################### 100.0% [OK] [#] ========================================== redpill-boot-wait =============== =========================== [#] Extension name: RedPill Bootwait [#] Description: Simple extension which stops the execution early waiting for th e boot device to appear [#] To get help visit: https://github.com/pocopico/rp-ext/redpill-boot-wait [#] Extension preparer/packer: https://github.com/pocopico/rp-ext/tree/main/redp ill-boot-wait [#] Update URL: https://raw.githubusercontent.com/pocopico/rp-ext/master/redpill -boot-wait/rpext-index.json [#] Platforms supported: ds1621p_42218 ds918p_41890 dva3221_42661 ds3617xs_42621 ds3617xs_42218 ds920p_42661 ds918p_42661 ds1621p_42661 ds918p_25556 dva3221_422 18 ds3615xs_42661 ds3622xsp_42661 ds2422p_42661 ds3622xsp_42218 ds2422p_42218 dv a3221_42621 ds3615xs_41222 ds918p_42621 ds3617xs_42661 ds3615xs_25556 ds920p_422 18 ds920p_42621 ds920p_42550 ds918p_42218 ds2422p_42621 ds1621p_42621 ds3615xs_4 2621 ds3615xs_42218 ds3622xsp_42621 [#] ============================================================================ =========== [#] Checking runtime for required tools... [OK] [#] Updating pocopico.tg3 extension... [#] Downloading remote file https://raw.githubusercontent.com/pocopico/rp-ext/ma ster/tg3/rpext-index.json to /home/tc/redpill-load/custom/extensions/_new_ext_in dex.tmp_json ######################################################################### 100.0% [#] Extension pocopico.tg3 index is already up to date [#] Updating redpill-boot-wait extension... [#] Downloading remote file https://raw.githubusercontent.com/pocopico/rp-ext/ma ster/redpill-boot-wait/rpext-index.json to /home/tc/redpill-load/custom/extensio ns/_new_ext_index.tmp_json ######################################################################### 100.0% [#] Extension redpill-boot-wait index is already up to date [#] Updating redpill-misc extension... [#] Downloading remote file https://github.com/pocopico/redpill-load/raw/develop /redpill-misc/rpext-index.json to /home/tc/redpill-load/custom/extensions/_new_e xt_index.tmp_json ######################################################################### 100.0% [OK] [#] Checking runtime for required tools... [OK] [#] Updating ds3622xsp_42661 platforms extensions... [#] Downloading remote file https://raw.githubusercontent.com/pocopico/rp-ext/ma ster/tg3/releases/ds3622xsp_42218.json to /home/tc/redpill-load/custom/extension s/_ext_new_rcp.tmp_json ######################################################################### 100.0% [#] Filling-in newly downloaded recipe for extension pocopico.tg3 platform ds362 2xsp_42661 [#] Downloading remote file https://raw.githubusercontent.com/pocopico/rp-ext/ma ster/tg3/releases/tg3-4.4.180plus-broadwellnk.tgz to /home/tc/redpill-load/custo m/extensions/pocopico.tg3/ds3622xsp_42661/tg3-4.4.180plus-broadwellnk.tgz ######################################################################### 100.0% [#] Verifying /home/tc/redpill-load/custom/extensions/pocopico.tg3/ds3622xsp_426 61/tg3-4.4.180plus-broadwellnk.tgz file... [OK] [#] Unpacking files from /home/tc/redpill-load/custom/extensions/pocopico.tg3/ds 3622xsp_42661/tg3-4.4.180plus-broadwellnk.tgz to /home/tc/redpill-load/custom/ex tensions/pocopico.tg3/ds3622xsp_42661/... [OK] [#] Downloading remote file https://raw.githubusercontent.com/pocopico/rp-ext/ma ster/tg3/src/check-tg3.sh to /home/tc/redpill-load/custom/extensions/pocopico.tg 3/ds3622xsp_42661/check-tg3.sh ######################################################################### 100.0% [#] Verifying /home/tc/redpill-load/custom/extensions/pocopico.tg3/ds3622xsp_426 61/check-tg3.sh file... [OK] [#] Successfully processed recipe for extension pocopico.tg3 platform ds3622xsp_ 42661 [#] Downloading remote file https://github.com/RedPill-TTG/redpill-boot-wait/raw /master/recipes/universal.json to /home/tc/redpill-load/custom/extensions/_ext_n ew_rcp.tmp_json ######################################################################### 100.0% [#] Filling-in newly downloaded recipe for extension redpill-boot-wait platform ds3622xsp_42661 [#] Downloading remote file https://raw.githubusercontent.com/RedPill-TTG/redpil l-boot-wait/master/src/boot-wait.sh to /home/tc/redpill-load/custom/extensions/r edpill-boot-wait/ds3622xsp_42661/boot-wait.sh ######################################################################### 100.0% [#] Verifying /home/tc/redpill-load/custom/extensions/redpill-boot-wait/ds3622xs p_42661/boot-wait.sh file... [OK] [#] Successfully processed recipe for extension redpill-boot-wait platform ds362 2xsp_42661 [#] Downloading remote file https://github.com/pocopico/redpill-load/raw/develop /redpill-misc/recipes/universal.json to /home/tc/redpill-load/custom/extensions/ _ext_new_rcp.tmp_json ######################################################################### 100.0% [#] Extension redpill-misc for ds3622xsp_42661 platform is already up to date [#] Verifying /home/tc/redpill-load/custom/extensions/redpill-boot-wait/ds3622xs p_42661/boot-wait.sh file... [OK] [#] Updating extensions... [OK] [#] Verifying /home/tc/redpill-load/cache/ds3622xsp_42661.pat file... [OK] [#] Unpacking /home/tc/redpill-load/cache/ds3622xsp_42661.pat file to /home/tc/r edpill-load/build/1653415858/pat-ds3622xsp_42661-unpacked... [OK] [#] Verifying /home/tc/redpill-load/build/1653415858/pat-ds3622xsp_42661-unpacke d/zImage file... [OK] [#] Patching /home/tc/redpill-load/build/1653415858/pat-ds3622xsp_42661-unpacked /zImage to /home/tc/redpill-load/build/1653415858/zImage-patched... [OK] [#] Verifying /home/tc/redpill-load/build/1653415858/pat-ds3622xsp_42661-unpacke d/rd.gz file... [OK] [#] Unpacking /home/tc/redpill-load/build/1653415858/pat-ds3622xsp_42661-unpacke d/rd.gz file to /home/tc/redpill-load/build/1653415858/rd-ds3622xsp_42661-unpack ed... [OK] [#] Apply patches to /home/tc/redpill-load/build/1653415858/rd-ds3622xsp_42661-u npacked... [OK] [#] Patching config files in ramdisk... [OK] [#] Adding OS config patching... [OK] [#] Repacking ramdisk to /home/tc/redpill-load/build/1653415858/rd-patched-ds362 2xsp_42661.gz... [OK] [#] Bundling extensions... [#] Checking runtime for required tools... [OK] [#] Dumping ds3622xsp_42661 platform extensions to /home/tc/redpill-load/build/1 653415858/custom-initrd/exts... [OK] [#] Packing custom ramdisk layer to /home/tc/redpill-load/build/1653415858/custo m.gz... [OK] [#] Generating GRUB config... [OK] [#] Creating loader image at loader.img... [OK] [#] Cleaning up... [OK] Mounting /dev/sdc1 to localdiskp1 /dev/sdc2 localdiskp2 Creating tinycore entry menuentry 'Tiny Core Image Build' { savedefault set root=(hd0,msdos3) echo Loading Linux... linux /vmlinuz64 loglevel=3 cde waitusb=5 vga=791 echo Loading initramfs... initrd /corepure64.gz echo Booting TinyCore for loader creation } Entries in Localdisk bootloader : ======================================================================= menuentry 'RedPill DS3622xs v7.1.0-42661 Beta (USB, Verbose)' { menuentry 'RedPill DS3622xs v7.1.0-42661 Beta (SATA, Verbose)' { menuentry 'Tiny Core Image Build' { Caching files for future use No adequate space on TCRP loader partition /mnt/sdc3 to cache pat file Found /mnt/sdc3/auxfiles/ds3622xsp_42218.pat /mnt/sdc3/auxfiles/ds3622xsp_42661.pat file Do you want me to remove older cached pat files and cache current ? [yY/nN] : y Found /home/tc/redpill-load/cache/ds3622xsp_42661.pat, copying to cache director y : /mnt/sdc3/auxfiles Saving user session for future use. Saving current extensions -> OK ! Saving current user_config.json -> OK ! tc@box:~$ ./rploader.sh clean now; rm -rf /mnt/sdb3/auxfiles; rm -rf /home/tc/cu stom-module; ./rploader.sh backup now; Clearing local redpill files Please make sure you are using the latest 1GB img before using backup option Current /home/tc size is 3.8M , try to keep it less than 1GB as it might not fit into your image Should i update the sdc with your current files [Yy/Nn] y Backing up home files to sdc : Backing up files to /mnt/sdc3//mydata.tgz Done. tc@box:~$ Quote Link to comment Share on other sites More sharing options...
Juga Posted May 24, 2022 Share #293 Posted May 24, 2022 17 hours ago, Peter Suh said: In @pocopico's 0.4.6 img for legacy, the first partition is increased from 48mb to 96mb to secure space for the dtc utility to be copied, and it is an image that has been fully upgraded to the latest version 0.7.1.7. Download it from the Google link below, decompress the gz and record it on a new USB stick. And rploader.sh on my Github repo blocks the patchdtc function so that there are no errors like the log above, and also blocks the update of rploader.sh itself. https://drive.google.com/file/d/1Jxr0znrDxkqIhcbFPTyll44VwdvuPBu-/view?usp=sharing tc@box:~$ curl --location "https://github.com/PeterSuh-Q3/tinycore-redpill/raw/main/rploader.sh" --output rploader.sh Lastly, before processing the build action, please add the following jumkey.dtb ext first. mkdir /mnt/"$(mount | grep -i optional | grep cde | awk -F / '{print $3}' | uniq | cut -c 1-3)3"/auxfiles; sudo ln -s /mnt/"$(mount | grep -i optional | grep cde | awk -F / '{print $3}' | uniq | cut -c 1-3)3"/auxfiles /home/tc/custom-module; ./rploader.sh ext geminilake-7.1.0-42661 add https://github.com/jumkey/redpill-load/raw/develop/redpill-dtb/rpext-index.json ./rploader.sh build geminilake-7.1.0-42661 ./rploader.sh backup now P.S : For ds920+ using dtc, it takes a little longer to check the ip from nic. This work!! @Peter Suh thank you very much!!! The only thing was that it does not recognize the nvme disk. why? try this ? Quote Is the recognition of four disks using TC auto-mapping? You can also manually map the pcie_root/ata_port part of the ds920p.dts file, which of the two methods did you use? And, if possible, rather than using dts for 1621, It would be better to add ports 5 and 6 to the existing ds920p.dts as below. And, avoid automatic build of TC and need manual build. If you want to use my "m shell", you need to build 2 times. 1. Preserve "redpill-load" directory with ./my.sh DS920+ noclean 2. Edit the ./redpill-load/ds920p.dts 3.Back up the directory with cp -r ./redpill-load ./redpill-load-bak 4.Complete the final build with ./my.sh DS920+ manual Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted May 25, 2022 Author Share #294 Posted May 25, 2022 On 5/24/2022 at 11:17 AM, Peter Suh said: In @pocopico's 0.4.6 img for legacy, the first partition is increased from 48mb to 96mb to secure space for the dtc utility to be copied, and it is an image that has been fully upgraded to the latest version 0.7.1.7. Download it from the Google link below, decompress the gz and record it on a new USB stick. And rploader.sh on my Github repo blocks the patchdtc function so that there are no errors like the log above, and also blocks the update of rploader.sh itself. https://drive.google.com/file/d/1Jxr0znrDxkqIhcbFPTyll44VwdvuPBu-/view?usp=sharing tc@box:~$ curl --location "https://github.com/PeterSuh-Q3/tinycore-redpill/raw/main/rploader.sh" --output rploader.sh Lastly, before processing the build action, please add the following jumkey.dtb ext first. mkdir /mnt/"$(mount | grep -i optional | grep cde | awk -F / '{print $3}' | uniq | cut -c 1-3)3"/auxfiles; sudo ln -s /mnt/"$(mount | grep -i optional | grep cde | awk -F / '{print $3}' | uniq | cut -c 1-3)3"/auxfiles /home/tc/custom-module; ./rploader.sh ext geminilake-7.1.0-42661 add https://github.com/jumkey/redpill-load/raw/develop/redpill-dtb/rpext-index.json ./rploader.sh build geminilake-7.1.0-42661 ./rploader.sh backup now P.S : For ds920+ using dtc, it takes a little longer to check the ip from nic. [NOTICE] Distribute M SHELL (my.sh) for DS920+, DS1621+. The function has been modified so that the new function dtc upx (sata port automatic mapping) of jumkey can be used. DS920+, DS1621+ can now be built with M SHELL. Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted May 25, 2022 Author Share #295 Posted May 25, 2022 6 hours ago, Juga said: This work!! @Peter Suh thank you very much!!! The only thing was that it does not recognize the nvme disk. why? try this ? Since the use of dtc is now all aligned with jumkey's automation mapping, to use nvme, you have to process everything manually. The process of modifying model_ds920p.dts and compiling as model_ds920p.dtb is necessary. Edit dts file should include both sata port and nvme port of internal_slot. Compilation goes through the following process. ./dtc -I dts -O dtb -o model_ds920p.dtb model_ds920p.dts I will check again or ask jumkey to tell you in which directory location the finally created model_ds920p.dtb should be in order for the script below to work. Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted May 25, 2022 Author Share #296 Posted May 25, 2022 9 hours ago, Juga said: This work!! @Peter Suh thank you very much!!! The only thing was that it does not recognize the nvme disk. why? try this ? It seems to be under development and testing now so that jumkey can automatically detect up to nvme cache as dtc. If you wait a little bit, it might be resolved automatically. Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted May 25, 2022 Author Share #297 Posted May 25, 2022 (edited) 15 hours ago, Juga said: This work!! @Peter Suh thank you very much!!! The only thing was that it does not recognize the nvme disk. why? try this ? According to the post below, it was reported that both HDD and NVMe Cache were recognized normally in dtc. Try the build again with the command below. ./rploader.sh clean now ./rploader.sh ext geminilake-7.1.0-42661 add https://github.com/jumkey/redpill-load/raw/test/redpill-dtb/rpext-index.json ./rploader.sh build geminilake-7.1.0-42661 Edited May 25, 2022 by Peter Suh 1 Quote Link to comment Share on other sites More sharing options...
Juga Posted May 25, 2022 Share #298 Posted May 25, 2022 It worked perfect. Thanks again!!! With the dtc upx of jumkey if I connect a new drive does it automatically detect it? or only reboot? Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted May 26, 2022 Author Share #299 Posted May 26, 2022 16 minutes ago, Juga said: It worked perfect. Thanks again!!! With the dtc upx of jumkey if I connect a new drive does it automatically detect it? or only reboot? Yes, that's right. This has been confirmed several times. 1 Quote Link to comment Share on other sites More sharing options...
ulissessantos Posted May 26, 2022 Share #300 Posted May 26, 2022 On 5/23/2022 at 5:05 PM, pocopico said: can you please post the output of the loader creation from TCRP ? tc@box:~$ ./rploader.sh update now Checking Internet Access -> OK Checking if a newer version exists on the repo -> Found newversion : 0.7.1.7 Current version : 0.7.1.7 There is a newer version of the script on the repo should we use that ? [yY/nN]y OK, updating, please re-run after updating Updating tinycore loader with latest updates Backing up files to /mnt/sdc3//mydata.tgz Done. tc@box:~$ ./rploader.sh fullupgrade now Performing a full TCRP upgrade Warning some of your local files will be moved to /home/tc/old/xxxx.2022-May-24- 18-06 Updating custom_config.json % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 100 33806 100 33806 0 0 67477 0 --:--:-- --:--:-- --:--:-- 67477 Updating custom_config_jun.json % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 100 8940 100 8940 0 0 17738 0 --:--:-- --:--:-- --:--:-- 17738 Updating global_config.json % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 100 5692 100 5692 0 0 11932 0 --:--:-- --:--:-- --:--:-- 11932 Updating modules.alias.3.json.gz mv: cannot stat 'modules.alias.3.json.gz': No such file or directory % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 100 5591 100 5591 0 0 18824 0 --:--:-- --:--:-- --:--:-- 18824 Updating modules.alias.4.json.gz mv: cannot stat 'modules.alias.4.json.gz': No such file or directory % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 100 89007 100 89007 0 0 225k 0 --:--:-- --:--:-- --:--:-- 225k Updating rpext-index.json % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 100 211k 100 211k 0 0 375k 0 --:--:-- --:--:-- --:--:-- 1230k Updating user_config.json % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 100 431 100 431 0 0 872 0 --:--:-- --:--:-- --:--:-- 872 Updating dtc % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 100 146k 100 146k 0 0 268k 0 --:--:-- --:--:-- --:--:-- 464k Updating rploader.sh % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 100 88522 100 88522 0 0 229k 0 --:--:-- --:--:-- --:--:-- 229k Updating ds1621p.dts % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 100 3026 100 3026 0 0 5887 0 --:--:-- --:--:-- --:--:-- 5887 Updating ds920p.dts % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0 100 2423 100 2423 0 0 4714 0 --:--:-- --:--:-- --:--:-- 4714 Please make sure you are using the latest 1GB img before using backup option Current /home/tc size is 3.8M , try to keep it less than 1GB as it might not fit into your image Should i update the sdc with your current files [Yy/Nn] y Backing up home files to sdc : Backing up files to /mnt/sdc3//mydata.tgz Done. tc@box:~$ ./rploader.sh serialgen DS3622xs+ Serial Number for Model : 2150SQRAKJT3B Mac Address for Model DS3622xs+ : 00:11:32:61:9E:67 Should i update the user_config.json with these values ? [Yy/Nn] y tc@box:~$ ./rploader.sh identifyusb now Found Verbatim STORE SerialNumber: 0173000000021AAB Vendor ID : 0x18a5 Product ID : 0x0302 Should i update the user_config.json with these values ? [Yy/Nn] y tc@box:~$ /rploader.sh satamap now -sh: /rploader.sh: not found tc@box:~$ ./rploader.sh satamap now Found "00:1f.2 Intel Corporation 82801IBM/IEM (ICH9M/ICH9M-E) 4 port SATA Contro ller [AHCI mode] (rev 03)" 2 drive(s) connected. How many ports does this controller have? [0-9] <2> 2 Recommended settings: SataPortMap=2 DiskIdxMap=00 Should i update the user_config.json with these values ? [Yy/Nn] y Done. tc@box:~$ ./rploader.sh build broadwellnk-7.0.1-42218 Rploader Version : 0.7.1.7 Loader source : https://github.com/pocopico/redpill-load.git Loader Branch : dev elop Redpill module source : https://github.com/pocopico/redpill-lkm.git : Redpill mo dule branch : master Extensions : Extensions URL : TOOLKIT_URL : https://sourceforge.net/projects/dsgpl/files/toolkit/DSM7.0/ds.bro adwellnk-7.0.dev.txz/download TOOLKIT_SHA : 0d9edca67d9e7e14c2529bbb58341b623936124d5264f71f1e4acbacf3ea202d SYNOKERNEL_URL : https://sourceforge.net/projects/dsgpl/files/Synology NAS G PL%20Source/25426branch/broadwellnk-source/linux-4.4.x.txz/download SYNOKERNEL_SHA : d3e85eb80f16a83244fcae6016ab6783cd8ac55e3af2b4240455261396e1e1b e COMPILE_METHOD : toolkit_dev TARGET_PLATFORM : broadwellnk TARGET_VERSION : 7.0.1 TARGET_REVISION : 42218 REDPILL_LKM_MAKE_TARGET : dev-v7 KERNEL_MAJOR : 4 MODULE_ALIAS_FILE : modules.alias.4.json SYNOMODEL : ds3622xsp_42218 MODEL : DS3622xs+ Local Cache Folder : /mnt/sdc3/auxfiles DATE Internet : 24052022 Local : 24052022 Checking Internet Access -> OK Checking if a newer version exists on the repo -> Version is current Cloning into 'redpill-lkm'... remote: Enumerating objects: 1253, done. remote: Counting objects: 100% (325/325), done. remote: Compressing objects: 100% (41/41), done. remote: Total 1253 (delta 302), reused 284 (delta 283), pack-reused 928 Receiving objects: 100% (1253/1253), 469.84 KiB | 2.13 MiB/s, done. Resolving deltas: 100% (865/865), done. Cloning into 'redpill-load'... remote: Enumerating objects: 1994, done. remote: Total 1994 (delta 0), reused 0 (delta 0), pack-reused 1994 Receiving objects: 100% (1994/1994), 114.70 MiB | 11.30 MiB/s, done. Resolving deltas: 100% (937/937), done. No extra build option or static specified, using default <static> Using static compiled redpill extension Removing any old redpill.ko modules Looking for redpill for : ds3622xsp_42218 Getting file https://raw.githubusercontent.com/pocopico/rp-ext/master/redpill/re leases/redpill-4.4.180plus-broadwellnk.tgz Extracting module Getting file https://raw.githubusercontent.com/pocopico/rp-ext/master/redpill/sr c/check-redpill.sh Got redpill-linux-v4.4.180+.ko Testing modules.alias.4.json -> File OK -------------------------------------------------------------------------------- ---------------- It looks that you will need the following modules : Found SATA Controller : pciid 8086d00002929 Required Extension : ahci Searching for matching extension for ahci Found VGA Controller : pciid 10ded000006e9 Required Extension : No matching extension [#] Checking runtime for required tools... [OK] [#] Adding new extension from https://raw.githubusercontent.com/pocopico/rp-ext/ master/tg3/rpext-index.json... [#] Downloading remote file https://raw.githubusercontent.com/pocopico/rp-ext/ma ster/tg3/rpext-index.json to /home/tc/redpill-load/custom/extensions/_new_ext_in dex.tmp_json ######################################################################## 100.0% [OK] [#] ========================================== pocopico.tg3 ==================== ====================== [#] Extension name: tg3 [#] Description: Adds Broadcom Tigon3 ethernet driver Support [#] To get help visit: <todo> [#] Extension preparer/packer: https://github.com/pocopico/rp-ext/tree/main/tg3 [#] Software author: https://github.com/pocopico [#] Update URL: https://raw.githubusercontent.com/pocopico/rp-ext/master/tg3/rpe xt-index.json [#] Platforms supported: ds1621p_42218 ds918p_41890 dva3221_42661 ds3617xs_42621 ds3617xs_42218 ds920p_42661 ds918p_42661 ds1621p_42661 ds918p_25556 dva3221_422 18 ds3615xs_42661 ds3622xsp_42661 ds3622xsp_42218 dva3221_42621 ds3615xs_41222 d s918p_42621 ds3617xs_42661 ds3615xs_25556 ds920p_42218 ds920p_42621 ds918p_42218 ds1621p_42621 ds3615xs_42621 ds3615xs_42218 ds3622xsp_42621 [#] ============================================================================ =========== Found Ethernet Interface : pciid 14e4d00001684 Required Extension : tg3 Searching for matching extension for tg3 Found matching extension : "https://raw.githubusercontent.com/pocopico/rp-ext/master/tg3/rpext-index.json" -------------------------------------------------------------------------------- ---------------- Starting loader creation Found tinycore cache folder, linking to home/tc/custom-module Checking user_config.json : Done Entering redpill-load directory Removing bundled exts directories Cache directory OK Want to use firmware files from /home/tc/custom-module/*.pat ? [yY/nN] : y cp: cannot stat '/home/tc/custom-module/*42218*.pat': No such file or directory Processing add_extensions entries found on custom_config.json file : [#] Checking runtime for required tools... [OK] [#] Updating extensions... [#] Checking runtime for required tools... [OK] [#] Adding new extension from https://github.com/pocopico/rp-ext/raw/main/redpil l-boot-wait/rpext-index.json... [#] Downloading remote file https://github.com/pocopico/rp-ext/raw/main/redpill- boot-wait/rpext-index.json to /home/tc/redpill-load/custom/extensions/_new_ext_i ndex.tmp_json ######################################################################### 100.0% [OK] [#] ========================================== redpill-boot-wait =============== =========================== [#] Extension name: RedPill Bootwait [#] Description: Simple extension which stops the execution early waiting for th e boot device to appear [#] To get help visit: https://github.com/pocopico/rp-ext/redpill-boot-wait [#] Extension preparer/packer: https://github.com/pocopico/rp-ext/tree/main/redp ill-boot-wait [#] Update URL: https://raw.githubusercontent.com/pocopico/rp-ext/master/redpill -boot-wait/rpext-index.json [#] Platforms supported: ds1621p_42218 ds918p_41890 dva3221_42661 ds3617xs_42621 ds3617xs_42218 ds920p_42661 ds918p_42661 ds1621p_42661 ds918p_25556 dva3221_422 18 ds3615xs_42661 ds3622xsp_42661 ds2422p_42661 ds3622xsp_42218 ds2422p_42218 dv a3221_42621 ds3615xs_41222 ds918p_42621 ds3617xs_42661 ds3615xs_25556 ds920p_422 18 ds920p_42621 ds920p_42550 ds918p_42218 ds2422p_42621 ds1621p_42621 ds3615xs_4 2621 ds3615xs_42218 ds3622xsp_42621 [#] ============================================================================ =========== [#] Checking runtime for required tools... [OK] [#] Updating pocopico.tg3 extension... [#] Downloading remote file https://raw.githubusercontent.com/pocopico/rp-ext/ma ster/tg3/rpext-index.json to /home/tc/redpill-load/custom/extensions/_new_ext_in dex.tmp_json ######################################################################### 100.0% [#] Extension pocopico.tg3 index is already up to date [#] Updating redpill-boot-wait extension... [#] Downloading remote file https://raw.githubusercontent.com/pocopico/rp-ext/ma ster/redpill-boot-wait/rpext-index.json to /home/tc/redpill-load/custom/extensio ns/_new_ext_index.tmp_json ######################################################################### 100.0% [#] Extension redpill-boot-wait index is already up to date [#] Updating redpill-boot-wait extension... [OK] [#] Checking runtime for required tools... [OK] [#] Updating ds3622xsp_42218 platforms extensions... [#] Downloading remote file https://raw.githubusercontent.com/pocopico/rp-ext/ma ster/tg3/releases/ds3622xsp_42218.json to /home/tc/redpill-load/custom/extension s/_ext_new_rcp.tmp_json ######################################################################### 100.0% [#] Filling-in newly downloaded recipe for extension pocopico.tg3 platform ds362 2xsp_42218 [#] Downloading remote file https://raw.githubusercontent.com/pocopico/rp-ext/ma ster/tg3/releases/tg3-4.4.180plus-broadwellnk.tgz to /home/tc/redpill-load/custo m/extensions/pocopico.tg3/ds3622xsp_42218/tg3-4.4.180plus-broadwellnk.tgz ######################################################################### 100.0% [#] Verifying /home/tc/redpill-load/custom/extensions/pocopico.tg3/ds3622xsp_422 18/tg3-4.4.180plus-broadwellnk.tgz file... [OK] [#] Unpacking files from /home/tc/redpill-load/custom/extensions/pocopico.tg3/ds 3622xsp_42218/tg3-4.4.180plus-broadwellnk.tgz to /home/tc/redpill-load/custom/ex tensions/pocopico.tg3/ds3622xsp_42218/... [OK] [#] Downloading remote file https://raw.githubusercontent.com/pocopico/rp-ext/ma ster/tg3/src/check-tg3.sh to /home/tc/redpill-load/custom/extensions/pocopico.tg 3/ds3622xsp_42218/check-tg3.sh ######################################################################### 100.0% [#] Verifying /home/tc/redpill-load/custom/extensions/pocopico.tg3/ds3622xsp_422 18/check-tg3.sh file... [OK] [#] Successfully processed recipe for extension pocopico.tg3 platform ds3622xsp_ 42218 [#] Downloading remote file https://github.com/RedPill-TTG/redpill-boot-wait/raw /master/recipes/universal.json to /home/tc/redpill-load/custom/extensions/_ext_n ew_rcp.tmp_json ######################################################################### 100.0% [#] Filling-in newly downloaded recipe for extension redpill-boot-wait platform ds3622xsp_42218 [#] Downloading remote file https://raw.githubusercontent.com/RedPill-TTG/redpil l-boot-wait/master/src/boot-wait.sh to /home/tc/redpill-load/custom/extensions/r edpill-boot-wait/ds3622xsp_42218/boot-wait.sh ######################################################################### 100.0% [#] Verifying /home/tc/redpill-load/custom/extensions/redpill-boot-wait/ds3622xs p_42218/boot-wait.sh file... [OK] [#] Successfully processed recipe for extension redpill-boot-wait platform ds362 2xsp_42218 [#] Verifying /home/tc/redpill-load/custom/extensions/redpill-boot-wait/ds3622xs p_42218/boot-wait.sh file... [OK] [#] Updating extensions... [OK] [#] PAT file /home/tc/redpill-load/cache/ds3622xsp_42218.pat not found - downloa ding from https://global.download.synology.com/download/DSM/release/7.0.1/42218/ DSM_DS3622xs+_42218.pat % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 100 345M 100 345M 0 0 18.6M 0 0:00:18 0:00:18 --:--:-- 19.1M [#] Verifying /home/tc/redpill-load/cache/ds3622xsp_42218.pat file... [OK] [#] Unpacking /home/tc/redpill-load/cache/ds3622xsp_42218.pat file to /home/tc/r edpill-load/build/1653415716/pat-ds3622xsp_42218-unpacked... [OK] [#] Verifying /home/tc/redpill-load/build/1653415716/pat-ds3622xsp_42218-unpacke d/zImage file... [OK] [#] Patching /home/tc/redpill-load/build/1653415716/pat-ds3622xsp_42218-unpacked /zImage to /home/tc/redpill-load/build/1653415716/zImage-patched... [OK] [#] Verifying /home/tc/redpill-load/build/1653415716/pat-ds3622xsp_42218-unpacke d/rd.gz file... [OK] [#] Unpacking /home/tc/redpill-load/build/1653415716/pat-ds3622xsp_42218-unpacke d/rd.gz file to /home/tc/redpill-load/build/1653415716/rd-ds3622xsp_42218-unpack ed... [OK] [#] Apply patches to /home/tc/redpill-load/build/1653415716/rd-ds3622xsp_42218-u npacked... [OK] [#] Patching config files in ramdisk... [OK] [#] Adding OS config patching... [OK] [#] Repacking ramdisk to /home/tc/redpill-load/build/1653415716/rd-patched-ds362 2xsp_42218.gz... [OK] [#] Bundling extensions... [#] Checking runtime for required tools... [OK] [#] Dumping ds3622xsp_42218 platform extensions to /home/tc/redpill-load/build/1 653415716/custom-initrd/exts... [OK] [#] Packing custom ramdisk layer to /home/tc/redpill-load/build/1653415716/custo m.gz... [OK] [#] Generating GRUB config... [OK] [#] Creating loader image at loader.img... [OK] [#] Cleaning up... [OK] Mounting /dev/sdc1 to localdiskp1 /dev/sdc2 localdiskp2 Creating tinycore entry menuentry 'Tiny Core Image Build' { savedefault set root=(hd0,msdos3) echo Loading Linux... linux /vmlinuz64 loglevel=3 cde waitusb=5 vga=791 echo Loading initramfs... initrd /corepure64.gz echo Booting TinyCore for loader creation } Entries in Localdisk bootloader : ======================================================================= menuentry 'RedPill DS3622xs v7.0.1-42218 Beta (USB, Verbose)' { menuentry 'RedPill DS3622xs v7.0.1-42218 Beta (SATA, Verbose)' { menuentry 'Tiny Core Image Build' { Caching files for future use Found /home/tc/redpill-load/cache/ds3622xsp_42218.pat, copying to cache director y : /mnt/sdc3/auxfiles Saving user session for future use. Saving current extensions -> OK ! Saving current user_config.json -> OK ! tc@box:~$ ./rploader.sh clean now Clearing local redpill files tc@box:~$ ./rploader.sh build broadwellnk-7.1.0-42661 Rploader Version : 0.7.1.7 Loader source : https://github.com/pocopico/redpill-load.git Loader Branch : dev elop Redpill module source : https://github.com/pocopico/redpill-lkm.git : Redpill mo dule branch : master Extensions : redpill-misc Extensions URL : "https://github.com/pocopico/redpill-load/raw/master/redpill-mi sc/rpext-index.json" TOOLKIT_URL : https://sourceforge.net/projects/dsgpl/files/toolkit/DSM7.0/ds.bro adwellnk-7.0.dev.txz/download TOOLKIT_SHA : 0d9edca67d9e7e14c2529bbb58341b623936124d5264f71f1e4acbacf3ea202d SYNOKERNEL_URL : https://sourceforge.net/projects/dsgpl/files/Synology NAS G PL%20Source/25426branch/broadwellnk-source/linux-4.4.x.txz/download SYNOKERNEL_SHA : d3e85eb80f16a83244fcae6016ab6783cd8ac55e3af2b4240455261396e1e1b e COMPILE_METHOD : toolkit_dev TARGET_PLATFORM : broadwellnk TARGET_VERSION : 7.1.0 TARGET_REVISION : 42661 REDPILL_LKM_MAKE_TARGET : dev-v7 KERNEL_MAJOR : 4 MODULE_ALIAS_FILE : modules.alias.4.json SYNOMODEL : ds3622xsp_42661 MODEL : DS3622xs+ Local Cache Folder : /mnt/sdc3/auxfiles DATE Internet : 24052022 Local : 24052022 Checking Internet Access -> OK Checking if a newer version exists on the repo -> Version is current Cloning into 'redpill-lkm'... remote: Enumerating objects: 1253, done. remote: Counting objects: 100% (325/325), done. remote: Compressing objects: 100% (41/41), done. remote: Total 1253 (delta 302), reused 284 (delta 283), pack-reused 928 Receiving objects: 100% (1253/1253), 469.84 KiB | 2.10 MiB/s, done. Resolving deltas: 100% (865/865), done. Cloning into 'redpill-load'... remote: Enumerating objects: 1994, done. remote: Total 1994 (delta 0), reused 0 (delta 0), pack-reused 1994 Receiving objects: 100% (1994/1994), 114.70 MiB | 8.61 MiB/s, done. Resolving deltas: 100% (940/940), done. No extra build option or static specified, using default <static> Using static compiled redpill extension Removing any old redpill.ko modules Looking for redpill for : ds3622xsp_42661 Getting file https://raw.githubusercontent.com/pocopico/rp-ext/master/redpill/re leases/redpill-4.4.180plus-broadwellnk.tgz Extracting module Getting file https://raw.githubusercontent.com/pocopico/rp-ext/master/redpill/sr c/check-redpill.sh Got redpill-linux-v4.4.180+.ko Testing modules.alias.4.json -> File OK -------------------------------------------------------------------------------- ---------------- It looks that you will need the following modules : Found SATA Controller : pciid 8086d00002929 Required Extension : ahci Searching for matching extension for ahci Found VGA Controller : pciid 10ded000006e9 Required Extension : No matching extension [#] Checking runtime for required tools... [OK] [#] Adding new extension from https://raw.githubusercontent.com/pocopico/rp-ext/ master/tg3/rpext-index.json... [#] Downloading remote file https://raw.githubusercontent.com/pocopico/rp-ext/ma ster/tg3/rpext-index.json to /home/tc/redpill-load/custom/extensions/_new_ext_in dex.tmp_json ######################################################################## 100.0% [OK] [#] ========================================== pocopico.tg3 ==================== ====================== [#] Extension name: tg3 [#] Description: Adds Broadcom Tigon3 ethernet driver Support [#] To get help visit: <todo> [#] Extension preparer/packer: https://github.com/pocopico/rp-ext/tree/main/tg3 [#] Software author: https://github.com/pocopico [#] Update URL: https://raw.githubusercontent.com/pocopico/rp-ext/master/tg3/rpe xt-index.json [#] Platforms supported: ds1621p_42218 ds918p_41890 dva3221_42661 ds3617xs_42621 ds3617xs_42218 ds920p_42661 ds918p_42661 ds1621p_42661 ds918p_25556 dva3221_422 18 ds3615xs_42661 ds3622xsp_42661 ds3622xsp_42218 dva3221_42621 ds3615xs_41222 d s918p_42621 ds3617xs_42661 ds3615xs_25556 ds920p_42218 ds920p_42621 ds918p_42218 ds1621p_42621 ds3615xs_42621 ds3615xs_42218 ds3622xsp_42621 [#] ============================================================================ =========== Found Ethernet Interface : pciid 14e4d00001684 Required Extension : tg3 Searching for matching extension for tg3 Found matching extension : "https://raw.githubusercontent.com/pocopico/rp-ext/master/tg3/rpext-index.json" -------------------------------------------------------------------------------- ---------------- Starting loader creation Found tinycore cache folder, linking to home/tc/custom-module Checking user_config.json : Done Entering redpill-load directory Removing bundled exts directories Cache directory OK Found build request for revision greater than 42218 Getting required extraction tool ------------------------------------------------------------------ Checking tinycore cache folder Found tinycore cache folder, linking to home/tc/custom-module Creating temp folder /tmp/synoesp Found custom pat file /home/tc/custom-module/ds3622xsp_42218.pat Processing old pat file to extract required files for extraction Entering synoesp extract rd.gz finish cpio: dev/console: Cannot mknod: Operation not permitted cpio: dev/net/tun: Cannot mknod: Operation not permitted 42506 blocks extract rd mkdir: cannot create directory '/mnt/sdc3/auxfiles': File exists Copying required files to local cache folder for future use Copying usr/lib/libcurl.so.4 to /mnt/sdc3/auxfiles Copying usr/lib/libmbedcrypto.so.5 to /mnt/sdc3/auxfiles Copying usr/lib/libmbedtls.so.13 to /mnt/sdc3/auxfiles Copying usr/lib/libmbedx509.so.1 to /mnt/sdc3/auxfiles Copying usr/lib/libmsgpackc.so.2 to /mnt/sdc3/auxfiles Copying usr/lib/libsodium.so to /mnt/sdc3/auxfiles Copying usr/lib/libsynocodesign-ng-virtual-junior-wins.so.7 to /mnt/sdc3/auxfile s Copying usr/syno/bin/scemd to /mnt/sdc3/auxfiles Copying required libraries to local lib directory Linking lib to lib64 Copying executable Removing temp folder /tmp/synoesp Checking if tools is accessible /bin/syno_extract_system_patch: /usr/local/lib/libcurl.so.4: no version informat ion available (required by /bin/syno_extract_system_patch) Copyright (c) 2003-2021 Synology Inc. All rights reserved. /bin/syno_extract_system_patch PATCH_PATH DEST_PATH Executed succesfully Creating temp folder /tmp/pat Checking for cached pat file Found tinycore cache folder, linking to home/tc/custom-module Could not find pat file locally cached Configdir : /home/tc/redpill-load/config/DS3622xs+/7.1.0-42661 Configfile: /home/tc/redpill-load/config/DS3622xs+/7.1.0-42661/config.json Pat URL : https://global.download.synology.com/download/DSM/release/7.1/42661-1/ DSM_DS3622xs%2B_42661.pat Downloading pat file from URL : https://global.download.synology.com/download/DS M/release/7.1/42661-1/DSM_DS3622xs%2B_42661.pat % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 100 352M 100 352M 0 0 38.4M 0 0:00:09 0:00:09 --:--:-- 45.6M File //mnt/sdc3/auxfiles/ds3622xsp_42661.pat, is encrypted File //mnt/sdc3/auxfiles/ds3622xsp_42661.pat, has been cached but its encrypted, re-running decrypting process Checking for cached pat file Found tinycore cache folder, linking to home/tc/custom-module Found locally cached pat file /home/tc/custom-module/ds3622xsp_42661.pat File /home/tc/custom-module/ds3622xsp_42661.pat, is encrypted Extracting encrypted pat file : /home/tc/custom-module/ds3622xsp_42661.pat to /t mp/pat /bin/syno_extract_system_patch: /usr/local/lib/libcurl.so.4: no version informat ion available (required by /bin/syno_extract_system_patch) Creating unecrypted pat file ds3622xsp_42661.pat to /home/tc/redpill-load/cache folder ./VERSION Pat file sha256sum is : bad4edf3ad0ccc4670b55c1647ada69f7a407332bc029a9c110f1ab 29e7a206a Checking config file existence -> OK Editing config file -> Verifying config file -> OK ! Clearing temp folders Processing add_extensions entries found on custom_config.json file : redpill-m isc Adding extension "https://github.com/pocopico/redpill-load/raw/master/redpill-mi sc/rpext-index.json" [#] Checking runtime for required tools... [OK] [#] Adding new extension from https://github.com/pocopico/redpill-load/raw/maste r/redpill-misc/rpext-index.json... [#] Downloading remote file https://github.com/pocopico/redpill-load/raw/master/ redpill-misc/rpext-index.json to /home/tc/redpill-load/custom/extensions/_new_ex t_index.tmp_json ######################################################################### 100.0% [OK] [#] ========================================== redpill-misc ==================== ====================== [#] Extension name: Misc shell [#] Description: Misc shell [#] To get help visit: https://github.com/pocopico/redpill-load/raw/develop/redp ill-misc [#] Extension preparer/packer: https://github.com/pocopico/redpill-load/raw/deve lop/redpill-misc [#] Software author: https://github.com/pocopico/redpill-load/raw/develop/redpil l-misc [#] Update URL: https://github.com/pocopico/redpill-load/raw/develop/redpill-mis c/rpext-index.json [#] Platforms supported: ds1621p_42218 ds918p_41890 dva3221_42661 ds3617xs_42621 ds3617xs_42218 ds920p_42661 ds918p_42661 ds1621p_42661 ds918p_25556 dva3221_422 18 ds3615xs_42661 ds3622xsp_42661 ds3622xsp_42218 dva3221_42621 ds3615xs_41222 d s918p_42621 ds3617xs_42661 ds3615xs_25556 ds920p_42218 ds920p_42621 ds918p_42218 ds1621p_42621 ds3615xs_42621 ds3615xs_42218 ds3622xsp_42621 [#] ============================================================================ =========== Updating extension : redpill-misc contents for model : ds3622xsp_42661 [#] Checking runtime for required tools... [OK] [#] Updating ds3622xsp_42661 platforms extensions... [#] Downloading remote file https://github.com/pocopico/redpill-load/raw/develop /redpill-misc/recipes/universal.json to /home/tc/redpill-load/custom/extensions/ _ext_new_rcp.tmp_json ######################################################################### 100.0% [#] Filling-in newly downloaded recipe for extension redpill-misc platform ds362 2xsp_42661 [#] Downloading remote file https://github.com/pocopico/redpill-load/raw/develop /redpill-misc/releases/install.sh to /home/tc/redpill-load/custom/extensions/red pill-misc/ds3622xsp_42661/install.sh ######################################################################### 100.0% [#] Verifying /home/tc/redpill-load/custom/extensions/redpill-misc/ds3622xsp_426 61/install.sh file... [OK] [#] Downloading remote file https://github.com/pocopico/redpill-load/raw/develop /redpill-misc/releases/install-all.sh to /home/tc/redpill-load/custom/extensions /redpill-misc/ds3622xsp_42661/install-all.sh ######################################################################### 100.0% [#] Verifying /home/tc/redpill-load/custom/extensions/redpill-misc/ds3622xsp_426 61/install-all.sh file... [OK] [#] Downloading remote file https://github.com/tsl0922/ttyd/releases/download/1. 6.3/ttyd.x86_64 to /home/tc/redpill-load/custom/extensions/redpill-misc/ds3622xs p_42661/ttyd ######################################################################### 100.0% [#] Verifying /home/tc/redpill-load/custom/extensions/redpill-misc/ds3622xsp_426 61/ttyd file... [OK] [#] Downloading remote file https://github.com/pocopico/redpill-load/raw/develop /redpill-misc/releases/install_rd.sh to /home/tc/redpill-load/custom/extensions/ redpill-misc/ds3622xsp_42661/install_rd.sh ######################################################################### 100.0% [#] Verifying /home/tc/redpill-load/custom/extensions/redpill-misc/ds3622xsp_426 61/install_rd.sh file... [OK] [#] Downloading remote file https://github.com/pocopico/redpill-load/raw/develop /redpill-misc/releases/lrzsz.tar.gz to /home/tc/redpill-load/custom/extensions/r edpill-misc/ds3622xsp_42661/lrzsz.tar.gz ######################################################################### 100.0% [#] Verifying /home/tc/redpill-load/custom/extensions/redpill-misc/ds3622xsp_426 61/lrzsz.tar.gz file... [OK] [#] Unpacking files from /home/tc/redpill-load/custom/extensions/redpill-misc/ds 3622xsp_42661/lrzsz.tar.gz to /home/tc/redpill-load/custom/extensions/redpill-mi sc/ds3622xsp_42661/... [OK] [#] Successfully processed recipe for extension redpill-misc platform ds3622xsp_ 42661 [#] Unpacking files from /home/tc/redpill-load/custom/extensions/redpill-misc/ds 3622xsp_42661/lrzsz.tar.gz to /home/tc/redpill-load/custom/extensions/redpill-mi sc/ds3622xsp_42661/... [OK] [#] Checking runtime for required tools... [OK] [#] Updating extensions... [#] Checking runtime for required tools... [OK] [#] Adding new extension from https://github.com/pocopico/rp-ext/raw/main/redpil l-boot-wait/rpext-index.json... [#] Downloading remote file https://github.com/pocopico/rp-ext/raw/main/redpill- boot-wait/rpext-index.json to /home/tc/redpill-load/custom/extensions/_new_ext_i ndex.tmp_json ######################################################################### 100.0% [OK] [#] ========================================== redpill-boot-wait =============== =========================== [#] Extension name: RedPill Bootwait [#] Description: Simple extension which stops the execution early waiting for th e boot device to appear [#] To get help visit: https://github.com/pocopico/rp-ext/redpill-boot-wait [#] Extension preparer/packer: https://github.com/pocopico/rp-ext/tree/main/redp ill-boot-wait [#] Update URL: https://raw.githubusercontent.com/pocopico/rp-ext/master/redpill -boot-wait/rpext-index.json [#] Platforms supported: ds1621p_42218 ds918p_41890 dva3221_42661 ds3617xs_42621 ds3617xs_42218 ds920p_42661 ds918p_42661 ds1621p_42661 ds918p_25556 dva3221_422 18 ds3615xs_42661 ds3622xsp_42661 ds2422p_42661 ds3622xsp_42218 ds2422p_42218 dv a3221_42621 ds3615xs_41222 ds918p_42621 ds3617xs_42661 ds3615xs_25556 ds920p_422 18 ds920p_42621 ds920p_42550 ds918p_42218 ds2422p_42621 ds1621p_42621 ds3615xs_4 2621 ds3615xs_42218 ds3622xsp_42621 [#] ============================================================================ =========== [#] Checking runtime for required tools... [OK] [#] Updating pocopico.tg3 extension... [#] Downloading remote file https://raw.githubusercontent.com/pocopico/rp-ext/ma ster/tg3/rpext-index.json to /home/tc/redpill-load/custom/extensions/_new_ext_in dex.tmp_json ######################################################################### 100.0% [#] Extension pocopico.tg3 index is already up to date [#] Updating redpill-boot-wait extension... [#] Downloading remote file https://raw.githubusercontent.com/pocopico/rp-ext/ma ster/redpill-boot-wait/rpext-index.json to /home/tc/redpill-load/custom/extensio ns/_new_ext_index.tmp_json ######################################################################### 100.0% [#] Extension redpill-boot-wait index is already up to date [#] Updating redpill-misc extension... [#] Downloading remote file https://github.com/pocopico/redpill-load/raw/develop /redpill-misc/rpext-index.json to /home/tc/redpill-load/custom/extensions/_new_e xt_index.tmp_json ######################################################################### 100.0% [OK] [#] Checking runtime for required tools... [OK] [#] Updating ds3622xsp_42661 platforms extensions... [#] Downloading remote file https://raw.githubusercontent.com/pocopico/rp-ext/ma ster/tg3/releases/ds3622xsp_42218.json to /home/tc/redpill-load/custom/extension s/_ext_new_rcp.tmp_json ######################################################################### 100.0% [#] Filling-in newly downloaded recipe for extension pocopico.tg3 platform ds362 2xsp_42661 [#] Downloading remote file https://raw.githubusercontent.com/pocopico/rp-ext/ma ster/tg3/releases/tg3-4.4.180plus-broadwellnk.tgz to /home/tc/redpill-load/custo m/extensions/pocopico.tg3/ds3622xsp_42661/tg3-4.4.180plus-broadwellnk.tgz ######################################################################### 100.0% [#] Verifying /home/tc/redpill-load/custom/extensions/pocopico.tg3/ds3622xsp_426 61/tg3-4.4.180plus-broadwellnk.tgz file... [OK] [#] Unpacking files from /home/tc/redpill-load/custom/extensions/pocopico.tg3/ds 3622xsp_42661/tg3-4.4.180plus-broadwellnk.tgz to /home/tc/redpill-load/custom/ex tensions/pocopico.tg3/ds3622xsp_42661/... [OK] [#] Downloading remote file https://raw.githubusercontent.com/pocopico/rp-ext/ma ster/tg3/src/check-tg3.sh to /home/tc/redpill-load/custom/extensions/pocopico.tg 3/ds3622xsp_42661/check-tg3.sh ######################################################################### 100.0% [#] Verifying /home/tc/redpill-load/custom/extensions/pocopico.tg3/ds3622xsp_426 61/check-tg3.sh file... [OK] [#] Successfully processed recipe for extension pocopico.tg3 platform ds3622xsp_ 42661 [#] Downloading remote file https://github.com/RedPill-TTG/redpill-boot-wait/raw /master/recipes/universal.json to /home/tc/redpill-load/custom/extensions/_ext_n ew_rcp.tmp_json ######################################################################### 100.0% [#] Filling-in newly downloaded recipe for extension redpill-boot-wait platform ds3622xsp_42661 [#] Downloading remote file https://raw.githubusercontent.com/RedPill-TTG/redpil l-boot-wait/master/src/boot-wait.sh to /home/tc/redpill-load/custom/extensions/r edpill-boot-wait/ds3622xsp_42661/boot-wait.sh ######################################################################### 100.0% [#] Verifying /home/tc/redpill-load/custom/extensions/redpill-boot-wait/ds3622xs p_42661/boot-wait.sh file... [OK] [#] Successfully processed recipe for extension redpill-boot-wait platform ds362 2xsp_42661 [#] Downloading remote file https://github.com/pocopico/redpill-load/raw/develop /redpill-misc/recipes/universal.json to /home/tc/redpill-load/custom/extensions/ _ext_new_rcp.tmp_json ######################################################################### 100.0% [#] Extension redpill-misc for ds3622xsp_42661 platform is already up to date [#] Verifying /home/tc/redpill-load/custom/extensions/redpill-boot-wait/ds3622xs p_42661/boot-wait.sh file... [OK] [#] Updating extensions... [OK] [#] Verifying /home/tc/redpill-load/cache/ds3622xsp_42661.pat file... [OK] [#] Unpacking /home/tc/redpill-load/cache/ds3622xsp_42661.pat file to /home/tc/r edpill-load/build/1653415858/pat-ds3622xsp_42661-unpacked... [OK] [#] Verifying /home/tc/redpill-load/build/1653415858/pat-ds3622xsp_42661-unpacke d/zImage file... [OK] [#] Patching /home/tc/redpill-load/build/1653415858/pat-ds3622xsp_42661-unpacked /zImage to /home/tc/redpill-load/build/1653415858/zImage-patched... [OK] [#] Verifying /home/tc/redpill-load/build/1653415858/pat-ds3622xsp_42661-unpacke d/rd.gz file... [OK] [#] Unpacking /home/tc/redpill-load/build/1653415858/pat-ds3622xsp_42661-unpacke d/rd.gz file to /home/tc/redpill-load/build/1653415858/rd-ds3622xsp_42661-unpack ed... [OK] [#] Apply patches to /home/tc/redpill-load/build/1653415858/rd-ds3622xsp_42661-u npacked... [OK] [#] Patching config files in ramdisk... [OK] [#] Adding OS config patching... [OK] [#] Repacking ramdisk to /home/tc/redpill-load/build/1653415858/rd-patched-ds362 2xsp_42661.gz... [OK] [#] Bundling extensions... [#] Checking runtime for required tools... [OK] [#] Dumping ds3622xsp_42661 platform extensions to /home/tc/redpill-load/build/1 653415858/custom-initrd/exts... [OK] [#] Packing custom ramdisk layer to /home/tc/redpill-load/build/1653415858/custo m.gz... [OK] [#] Generating GRUB config... [OK] [#] Creating loader image at loader.img... [OK] [#] Cleaning up... [OK] Mounting /dev/sdc1 to localdiskp1 /dev/sdc2 localdiskp2 Creating tinycore entry menuentry 'Tiny Core Image Build' { savedefault set root=(hd0,msdos3) echo Loading Linux... linux /vmlinuz64 loglevel=3 cde waitusb=5 vga=791 echo Loading initramfs... initrd /corepure64.gz echo Booting TinyCore for loader creation } Entries in Localdisk bootloader : ======================================================================= menuentry 'RedPill DS3622xs v7.1.0-42661 Beta (USB, Verbose)' { menuentry 'RedPill DS3622xs v7.1.0-42661 Beta (SATA, Verbose)' { menuentry 'Tiny Core Image Build' { Caching files for future use No adequate space on TCRP loader partition /mnt/sdc3 to cache pat file Found /mnt/sdc3/auxfiles/ds3622xsp_42218.pat /mnt/sdc3/auxfiles/ds3622xsp_42661.pat file Do you want me to remove older cached pat files and cache current ? [yY/nN] : y Found /home/tc/redpill-load/cache/ds3622xsp_42661.pat, copying to cache director y : /mnt/sdc3/auxfiles Saving user session for future use. Saving current extensions -> OK ! Saving current user_config.json -> OK ! tc@box:~$ ./rploader.sh clean now; rm -rf /mnt/sdb3/auxfiles; rm -rf /home/tc/cu stom-module; ./rploader.sh backup now; Clearing local redpill files Please make sure you are using the latest 1GB img before using backup option Current /home/tc size is 3.8M , try to keep it less than 1GB as it might not fit into your image Should i update the sdc with your current files [Yy/Nn] y Backing up home files to sdc : Backing up files to /mnt/sdc3//mydata.tgz Done. tc@box:~$ Quote Link to comment Share on other sites More sharing options...
