Help to setup NVME in DS3622xs+ inside Proxmox
Indio
Hi all,
I am trying to follow some guides here in the forum how to setup the SSD cache in my NAS but without success.
I have Proxmox 7.1-7 with an VM of DS3622xs+ (DSM 7.0.1-42218) with redpill.
The NVME in Proxmox was passthrough by PCI and in the DSM console is visible with address 0000:00:10.0:
user@NAS:~$ lspci
0000:00:00.0 Host bridge: Intel Corporation 440FX - 82441FX PMC [Natoma] (rev 02)
0000:00:01.0 ISA bridge: Intel Corporation 82371SB PIIX3 ISA [Natoma/Triton II]
0000:00:01.1 IDE interface: Intel Corporation 82371SB PIIX3 IDE [Natoma/Triton II]
0000:00:01.2 USB controller: Intel Corporation 82371SB PIIX3 USB [Natoma/Triton II] (rev 01)
0000:00:01.3 Bridge: Intel Corporation 82371AB/EB/MB PIIX4 ACPI (rev 03)
0000:00:02.0 VGA compatible controller: Red Hat, Inc. Virtio GPU (rev 01)
0000:00:03.0 Unclassified device [00ff]: Red Hat, Inc. Virtio memory balloon
0000:00:05.0 SCSI storage controller: Broadcom / LSI 53c895a
0000:00:07.0 SATA controller: Intel Corporation 82801IR/IO/IH (ICH9R/DO/DH) 6 port SATA Controller [AHCI mode] (rev 02)
0000:00:0b.0 SATA controller: Intel Corporation 82801IR/IO/IH (ICH9R/DO/DH) 6 port SATA Controller [AHCI mode] (rev 02)
0000:00:10.0 Non-Volatile memory controller: Micron/Crucial Technology P2 NVMe PCIe SSD (rev 01)
0000:00:12.0 Ethernet controller: VMware VMXNET3 Ethernet Controller (rev 01)
0000:00:1e.0 PCI bridge: Red Hat, Inc. QEMU PCI-PCI bridge
0000:00:1f.0 PCI bridge: Red Hat, Inc. QEMU PCI-PCI bridge
0001:09:00.0 SATA controller: Marvell Technology Group Ltd. 88SE9235 PCIe 2.0 x2 4-port SATA 6 Gb/s Controller (rev 11)
0001:0c:00.0 SATA controller: Marvell Technology Group Ltd. 88SE9235 PCIe 2.0 x2 4-port SATA 6 Gb/s Controller (rev 11)
In the file /etc.defaults/extensionPorts I changed to the nvme address:
[pci]
pci1="0000:00:10.0"
In fact, in the OS is clear that is connected:
user@NAS:~# nvme list
Node             SN                   Model                                    Namespace Usage                      Format           FW Rev
/dev/nvme0n1     2113E591230F         CT1000P2SSD8                             1           1.00  TB /   1.00  TB    512   B +  0 B   P2CR033
The problem is that in the DSM nothing apears:
1995175981_Capturadeecr2022-04-09s11_23_24.thumb.png.7a9d1e78101b3f7c4f221ec243bc7657.png
Any suggestion how to add an SSD cache or what is the problem with my setup?
Thank you.
11 hours ago, pocopico said:
I need to check but I think that etc.defaults it gets overwritten if it’s not on the rd.gz you can add the file during creation if you add it In the user_config.json
Hi @pocopico, thank you once again.
Can you please show me an example how can add the file in user_config.json?
Thank you.
Thank you.
You need to read the following to understand
https://github.com/pocopico/redpill-load/blob/master/FOR_DEVS.md
"extra": {
"compress_rd": false,
"ramdisk_copy":
"redpill-linux-v4.4.180+.ko": "usr/lib/modules/rp.ko"
you can add an extra line to the user_config.json about your file and where you need it to be copied.
e.g.
"extensionPorts" : "/etc/extensionPorts"
the file should be placed inside /home/tc/redpill-load/ext/ directore and named extensionPorts
Mine is DS918+ Redpill run as VM on proxmox
my ssd is NVMe SamsungEvo 970 250GB
Assuming that's you have
by following this tutorial (https://dannyda.com/2020/08/26/how-to-passthrough-hdd-ssd-physical-disks-to-vm-on-proxmox-vepve/)
the command that I send to proxmox is
qm set 586 -sata1 /dev/disk/by-id/nvme-Samsung_SSD_970_EVO_250GB_S465NB0K540387X,serial=S465NB0K540387X,cache=none,ssd=1,backup=0,discard=on,replicate=0
 according to tutorial 586 is my VM id, so change it.
image.thumb.png.6fb27407ca43300ac8171ecabaed7157.pngimage.thumb.png.49bef7e6393c54409da6dff9b70cfb0a.png
Edited by bigbearXL
edit link
"extra": {
"ramdisk_copy":
e.g.
Hi again, @pocopico I made the changes you suggested, but I think I did something wrong:
I don't like the error code RIP 😁
[    3.181638] RIP  [<ffffffff8140651d>] ata_host_start.part.44+0x1bd/0x1e0
[    3.181638]  RSP <ffff880526203bc8>
[    3.181638] CR2: 0000000000000120
[    3.181638] ---[ end trace 1444ecca4539818b ]---
[    3.274699] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000009
[    3.274699]
[    3.275671] Kernel Offset: disabled
[    3.275671] ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000009
[    3.275671]
Thank you @bigbearXL but proxmox has sata limitations in the number of drives you can have in a VM. I have all full:1061153758_Capturadeecr2022-04-11s16_33_10.thumb.png.a28b90a1cc8c8009400331b1b7f07b4f.png
I am trying to add them as SCSI but was not successful.
I see, and yep SCSI won't works in this case
How about this ?  https://forum.proxmox.com/threads/limit-on-number-of-pass-through-sata-drives.28979/#post-311466
@cferra, I have in proxmox with passthrough.
Cool - if you have it working - 7.1 isn’t a major leap forward so I imagine after making the required edits again it will function.
I would disable any cache prior to update though otherwise your volume will crash without that cache
I don't know if I was clear @cferra, I was not able to make the nvme appear on DSM, only appears on the in the linux OS of the DSM as shown in my first post.
