soultaco Posted July 2, 2016 #1 Posted July 2, 2016 Hi all, supernoob here and need some help. I searched the forums with no search results but if I google the subject on this thread then I do get a link to here but it was a dead end (nothing helpful) I have a Microserver n40L, put 5.2-5644.5 on a usb stick and after installed and up and running, got the wizard and created account, updated to DSM 6.0.1-7393. I started with just one disk, it shows up initialized and status is good but when I try to create a simple volume I get "failed to apply settings". I loaded another disk, it shows up as not initialized but I get the same error when trying to create a volume. Both disks are good, I can load them into my windows box, format them, do whatever but cant seem to do anything with either in DSM. Im sure Im doing something wrong but that's what I need help with. All the "getting started" doesnt really have a trouble shooting section. Any pointers appreciated.
soultaco Posted July 2, 2016 Author #2 Posted July 2, 2016 Got it, stayed on the same dsm instead of upgrading.
