humancaviar Posted June 20, 2016 Share #1 Posted June 20, 2016 Hello, was wondering if anyone had any experience recovering a volume crash after healthy disks are randomly dropped from SHR volume. After system partition issues and a reboot, two healthy disks were dropped from my volume rendering it useless. I have confirmed that all of the raid partitions for the volume are still on those disks. They appear as initialized disks in the storage manager. I have backups but there was interim data that I would love to recover. Manually adding the disks back into the raid with mdadm is not an option because... mdadm --examine /dev/sdg mdadm: No md superblock detected on /dev/sdg. mdadm --examine /dev/sdh mdadm: No md superblock detected on /dev/sdh. Boot Ubuntu, attempt recovery (how to do?)? Attempt fresh install/update? Any ideas would be greatly appreciated. Current version: DSM 5.2-5644 Update 3 ###fdisk output for disks### fdisk /dev/sdg -l Disk /dev/sdg: 2000.3 GB, 2000398934016 bytes 255 heads, 63 sectors/track, 243201 cylinders Units = cylinders of 16065 * 512 = 8225280 bytes Device Boot Start End Blocks Id System /dev/sdg1 1 311 2490240 fd Linux raid autodetect Partition 1 does not end on cylinder boundary /dev/sdg2 311 572 2097152 fd Linux raid autodetect Partition 2 does not end on cylinder boundary /dev/sdg3 588 243201 1948788912 f Win95 Ext'd (LBA) /dev/sdg5 589 243189 1948684480 fd Linux raid autodetect fdisk /dev/sdh -l Disk /dev/sdh: 2000.3 GB, 2000398934016 bytes 255 heads, 63 sectors/track, 243201 cylinders Units = cylinders of 16065 * 512 = 8225280 bytes Device Boot Start End Blocks Id System /dev/sdh1 1 311 2490240 fd Linux raid autodetect Partition 1 does not end on cylinder boundary /dev/sdh2 311 572 2097152 fd Linux raid autodetect Partition 2 does not end on cylinder boundary /dev/sdh3 588 243201 1948788912 f Win95 Ext'd (LBA) /dev/sdh5 589 243189 1948684480 fd Linux raid autodetect Link to comment Share on other sites More sharing options...
AllGamer Posted June 21, 2016 Share #2 Posted June 21, 2016 sounds like you had the same problem this guy had and still trying to resuscitate his SHR volume viewtopic.php?f=2&t=16297 Link to comment Share on other sites More sharing options...
humancaviar Posted June 21, 2016 Author Share #3 Posted June 21, 2016 I ended up saying F-it, zeroing the disks and going to restore backup. After doing some research, it seems that old RAID data on previously used disks can cause issues like this. Fully zeroing should prevent it from happening in the future. Link to comment Share on other sites More sharing options...
AllGamer Posted June 21, 2016 Share #4 Posted June 21, 2016 interesting revelation. Personally I stick to known to work old school RAID types, I never trusted this Hybrid RAID business introduced by Synology Link to comment Share on other sites More sharing options...
