andyrav Posted June 14, 2016 Share #1 Posted June 14, 2016 Hi After some help, My Volume1 as a status of NORMAL but it is still saying NUMBER OF DISK FAILED = 1 and DEGRADED. if i Try and swap out the disk that has ERRORS with Smart ABNORMAL when i get NUMBER OF DISK FAILED = 2 and can not repair it. Once i installed the removed disk again it the Volume is NORMAL running DSM 5.2-5644 Update 5 any ideas? cheers Link to comment Share on other sites More sharing options...
sbv3000 Posted June 15, 2016 Share #2 Posted June 15, 2016 how many disks and what is the raid type? is the degrading due to failed system partition? have you tried a repair? can you add a drive and try repair with that? can you backup data then delete/recreate the volume? Link to comment Share on other sites More sharing options...
