lambrd 0 Posted March 17 Share Posted March 17 I've got two machines 1. is a intel with dual 5690 cpu the other is a amd 5800, both are running proxmox 7.0. Did a redpill install on the amd chose host computer pretty much base things. The install was for a DS3615xs and all went well. At this point everything for the most part is up and running fine, using harddrive passthrough I have 4 drives up and working and holding test data. Went to do a install on the intel machine and have seen some very unexpected results and was hoping someone could explain it. Did the redpill setup just like the amd, chose the DS3615xs and did everything just like I had done with the amd. The vm boots and loads and looks like it should be loading the DS3615xs but when I do the find.sysnology it comes up as DS918+, don't know why and have reloaded this several times. I believe that some of this might come from the fact that the amd has a lsi-9300 8-port card and the intel is using a adaptec 79065(i think) raid card in it mode. Any way i've included two files here if anyone what's to have a look. Synology Web Assistant.pdf boot seq.txt Quote Link to post Share on other sites
taiziccf 5 Posted March 28 Share Posted March 28 you sure you used the correct loader? Quote Link to post Share on other sites
Indio 2 Posted April 10 Share Posted April 10 Did you generated a valid serial? Quote Link to post Share on other sites
