twinkie Posted June 11, 2016 #1 Posted June 11, 2016 Hello, I try to move xpenoboot from USB to EFI partition on SSD in my NAS in order to boot, but experienced problem with boot from UEFI as XPEnoboot stuck at some point in loading kernel. I first installed Windows 10 on my SSD boot disk, which created first recovery partition and second EFI partition, then I installed latest debian distribution which installed to the rest of disk and added EFI files for GRUB into EFI fat32 partition. My efi partition is on /dev/sda2 which is by default mounted in debian on /boot/EFI Now in order to boot syslinux to load XPEnoboot I needed to install syslinux into EFI partition. So first I downloaded lastest syslinux from https://www.kernel.org/pub/linux/utils/ ... ting/6.04/ Then from archive syslinux I took syslinux files for efi64 architecture following guide https://wiki.archlinux.org/index.php/sy ... I_Syslinux Created folder /boot/efi/EFI/syslinux and copied files from syslinux 6.04 into it : syslinux.efi – syslinux efi loader ldlinux.elf ldlinux.e64 zImage – from XPEnoboot USB And additional support files from syslinux distribution, not all are necessary : hdt.c32 chain.c32 libcom32.c32 libgpl.c32 libmenu.c32 libutil.c32 menu.c32 syslinux.cfg vesamenu.c32 I modified syslinux.cfg as follows added path to zImage of XPEnoboot on EFI partition UI menu.c32 PROMPT 0 TIMEOUT 50 DEFAULT xpenology MENU TITLE XPEnoboot 5.2-5644.4-df9e09c LABEL xpenology MENU LABEL XPEnology DSM 5.2-5644 KERNEL /EFI/syslinux/zImage APPEND root=/dev/md0 ihd_num=0 netif_num=4 syno_hw_version=DS3615xs sn=xmac1=xxxmac2=xxx vid=0x0EA0 pid=0x2168 loglevel=0 vga=0x305 LABEL debug MENU LABEL XPEnology DSM 5.2-5644 Debug KERNEL /EFI/syslinux/zImage APPEND root=/dev/md0 ihd_num=0 netif_num=4 syno_hw_version=DS3615xs sn=xx mac1=xxx mac2=xxx vid=0x0EA0 pid=0x2168 loglevel=0 vga=0x305 debug=1 LABEL install MENU LABEL XPEnology DSM 5.2-5644 Install/Upgrade KERNEL /EFI/syslinux/zImage APPEND root=/dev/md0 ihd_num=0 netif_num=4 syno_hw_version=DS3615xs sn=xxx mac1=xxx mac2=xxx vid=0x0EA0 pid=0x2168 loglevel=0 vga=0x305 upgrade=5.2-5644 As my EFI partition is on /dev/sda2 i modified command to add Syslinux option to UEFI boot menu efibootmgr -c -d /dev/sda -p 2 -l /EFI/syslinux/syslinux.efi -L "Syslinux" Now I was able to boot Syslinux from UEFI and then load XPEnoboot. Syslinux loaded XPEnoboot but only black screen show up and boot stop. When I tried DEBUG mode I could see XPEnoboot kernel messages loading but then it stuck at some point. Any idea how to make xpenoboot boting from partition on UEFI systém ?
