epicurean Posted June 3, 2016 Share #1 Posted June 3, 2016 On one of the volumes on my xpenology 5.2 (its a VM on esxi), 1 hard drive keeps getting "unallocated". I go into manage, put it back it, and it does its repair. After a few hours, that same drive gets kick out again. what can be the cause? and how do I remedy it? These 6 drives are 6 TB HGST in hybrid raid mode much thanks for any help Link to comment Share on other sites More sharing options...
elmuziko Posted June 3, 2016 Share #2 Posted June 3, 2016 I have an N54L and once upon a time tried a 6 drive RAID using the 4 main ports, the onboard, then an additional PCI RAID card. I had the same problem. As soon as I removed the PCI drive, everything started working properly. I assume it's down to speeds? PCI card delivers data at a different rate to the rest and so dropped off from time to time. With that in mind, are all 6 devices using the same hardware SATA ports? All on the same mobo or RAID card? Link to comment Share on other sites More sharing options...
AllGamer Posted June 3, 2016 Share #3 Posted June 3, 2016 That brings up a good point, since PCI 32bit maxes out at 133 MByte/s It'll be best not to mix the 4 drives on the PCI controller, with the 4~6 drives from the onBoard SATA controller. Keep them as 2 separate Volumes, and use drive grouping to keep them as 2 separate set of drives. Link to comment Share on other sites More sharing options...
epicurean Posted June 6, 2016 Author Share #4 Posted June 6, 2016 Well, I kind of eliminated this problem by added an additional 2 more drives (one of which acts as a spare). Its behaving now. Noted on the point of different volumes on different HBA controllers. Make good sense too Link to comment Share on other sites More sharing options...
