The fix suggested was to recreate the db with /usr/syno/sbin/synosnmpcd -r but my problem here's kinda different, here's what I get with a grep from the logs.
synosnmpcd: db_handler_class.cpp:512 Error: cannot check database exist or not.
synosnmpcd: main.cpp:116 Cannot Drop the dababase
synosnmpcd: main.cpp:121 delete the DB over
synosnmpcd: pgsql.c (96) Failed to connect to (null), user: postgres, pass:xxx, db:synosnmp. (FATAL: database "synosnmp" does not exist
synosnmpcd: db_handler_class.cpp:951 Error: Connect failed
And from here I really couldn't find anything else to help me.
Jacopo Bassan 0
it's been some time that I can't get the network tab on Resource Monitor to work.
The "Rete" (italian for network) infos are always at 0, but the network is working properly so I think it's just a resource monitor related problem.
After some digging around I found some articles like this https://q1f4mmprz7gko.wordpress.com/2014/05/22/fixing-a-broken-resource-monitor-in-dsm-5-0/ which even if it's for DSM 5.0 and I've DSM 6.1.7 the parts related to SNMP database being the problem seems pointing me in the right direction.
Anyone here maybe knows how I can fix it?
Thanks!
3 answers to this question
