endestur 0 Posted February 22 Share Posted February 22 (edited) Hi there, After using Synology for 6 years I build a Proxmox server for some smart home stuff and also switched to Expenology for my DS214play I had. Yesterday I had a power outage but everything started right up afterwards. Only to notice now that I can login to Expenology but nothing is there... No volume, no storage pool. I used this tutorial to make it initially: I made some screenshots of everything to give additional info. Any info or pointers about what I can do to restore the volume? Of course I made the mistake to not have regular backups. The last one I got it couple of months old because I was still in the process of setting up a backup plan/schedule. The problem disk is /dev/sdi . Edited February 22 by endestur Quote Link to post Share on other sites
jj-lolo 0 Posted March 1 Share Posted March 1 were you able to find a solution? my volume crashed but my storage pool is normal Quote Link to post Share on other sites
Dfds 87 Posted March 1 Share Posted March 1 @jj-lolorather than asking the same question in other peoples threads you would be better off creating your own thread if you have a problem. 1 Quote Link to post Share on other sites
