Buenas,
Cual es la mejor configuración de transmisión funcione correctamente e el synology? Algún manual para su instalación?
Nexus 6 with Tapatalk
Yo lo tengo configurado a la vez que Download Station.
Uso transmision para trackers privados --que requieren mantener los archivos compartidos durante más tiempo-- y DS para trackers públicos.
Estas son mis notas sobre la configuración:
AÑADIR PACKAGE SOURCE A PACKAGE CENTER
http://packages.synocommunity.com/
Instalar desde el Package Center
CAMBIAR CONFIGURACION
* Stop the Transmission service
* SSH to your NAS as root
* cd /volume1/@appstore/transmission/var
* vi settings.json
* modify the download-dir line to change the download destination. Alternatively, you can break the downloads into complete and incomplete by setting incomplete-dir to where you want incomplete torrents to go, and incomplete-dir-enabled to true.
* setting the watch-dir directory will let you upload to a particular directory (typically 'incoming') and transmission will scan that dir for new .torrent files, and add them when they appear.
* save the settings.json file
* make sure the directories you specify exist, and are read/write capable by user transmission
* Run the Transmission service
EJEMPLOS DE COMANDOS
NAS> /usr/local/transmission/bin/transmission-remote --auth miusuario:????--list
ID Done Have ETA Up Down Ratio Status Name
1 100% 77.48 GB Unknown 0.0 0.0 0.2 Idle la que se avecina
2 100% 9.95 GB Unknown 0.0 0.0 0.2 Idle La Venus de las Pieles 2013 BDRip 1080p DTS-FaViO.mkv
3 100% 14.05 GB Unknown 0.0 0.0 0.1 Idle Al.Encuentro.De.Mr.Banks.1080p.DTS.DTS-HD.Dual.Bluray.2013.[TRCKHD].mkv
4 100% 24.68 GB Unknown 0.0 0.0 0.2 Idle Rebeldes.(La.obra.completa).BDremux.1080p.DTS.DTS-HD.Dual.Bluray.1983.[TRCKHD].mkv
5 100% 1.59 GB 6 days 0.0 0.0 0.6 Idle Ocho Apellidos Vascos [DVD Rip][AC3 2.0 Español Castellano][2014]
6 100% 34.78 GB Unknown 0.0 0.0 0.6 Idle Hasta.que.llegó.su.hora.BDremux.1080p.AC3.DTS-HD.Dual.Bluray.1968.[TRCKHD].mkv
7 100% 5.04 GB Unknown 0.0 0.0 0.0 Idle Juego de Tronos XXX.2014.BR-720p.AC3.ING.GrupoD69M.xBytes.mkv
8 100% 19.79 GB Unknown 0.0 0.0 0.3 Idle Speed.BDREMUX.1080p.DTS.DTS-HD.Dual.Bluray.1994.mkv
9 100% 2.15 GB Unknown 0.0 0.0 0.0 Idle Juego.De.Tronos.S04E08.1080p.AC3.Dual.HDTV.2014.mkv
Sum: 189.5 GB 0.0 0.0
NAS> /usr/local/transmission/bin/transmission-remote --auth miusuario:????--torrent 1 --info
NAME
Name: la que se avecina
Hash: 3327f1c1429b33ced1a31b65022bfcf19c147dcc
Magnet: magnet:?xt=urn:btih:3327f1c1429b33ced1a31b65022bfcf19c147dcc&dn=la%20que%20se%20avecina&tr=http%3A%2F%2Fwww.xbytes.li%2Fannounce.php%3Fpasskey%3Dc665adb591628db73b4eb9563605cd60
TRANSFER
State: Idle
Percent Done: 100%
ETA: 0 seconds (0 seconds)
Download Speed: 0 kB/s
Upload Speed: 0 kB/s
Have: 77.48 GB (77.48 GB verified)
Availability: 100%
Total size: 77.48 GB (77.48 GB wanted)
Downloaded: 77.49 GB
Uploaded: 21.06 GB
Ratio: 0.2
Corrupt DL: None
Peers: connected to 0, uploading to 0, downloading from 0
HISTORY
Date added: Sat May 31 20:12:01 2014
Date finished: Mon Jun 2 02:30:47 2014
Date started: Wed Jun 4 19:32:56 2014
Latest activity: Wed Jun 4 00:03:54 2014
Downloading Time: 17 hours (63732 seconds)
Seeding Time: 2 days (175808 seconds)
ORIGINS
Date created: Wed May 28 13:03:11 2014
Public torrent: Yes
Creator: uTorrent/2040
Piece Count: 18474
Piece Size: 4.00 MiB
LIMITS & BANDWIDTH
Download Limit: Unlimited
Upload Limit: Unlimited
Ratio Limit: Default
Honors Session Limits: Yes
Peer limit: 60
Bandwidth Priority: Normal
SCRIPT AUTOMATIZACION
Preparar script y ejecutarlo mediante cron, para dejar de compartir descargas que han cumplido los requisitos del tracker privado.
#!/bin/sh
## Script for tranmission on synology
## Problems:
## * The custom package of tranmission on synology machines does not run scripts after completion [1]
## * Couchpotato Server does not appear to activate the postprocessing once a torrent has finished downloading
## Solution:
## * In the synology taskplanner I set up a task to run every 2 hours to run this script
## Script:
## 1) check which torrents are finished downloading
## 2) remove completed torrents from transmission
## 3) run Couchpotato renamer if completed torrents are found
## 4) If there are no torrents in torrent list, clean up download directory
## !!This option is disabled by default, because it uncareful usage may delete all data!!
## Prerequisites:
## * Synology machine (currently tested on Synology DS411j, DSM 4.2-3211)
## * Transmission & Couchpotato Server (SPK's obtained from SynoCommunity repository)
## * Enable Couchpotato Renamer, but set so that it never runs [3]
## Warning: Regarding 4)
## * My transmission downloads to a temporary directory. Movies that have finished downloading are
## moved to $DOWNLOADDIR. Thus if all movies have been processed this folder contains no more movies and can be safely deleted
## * the Couchpotato renamer will need some time to process. Therefor do not set up the taskplanner to run to often. Every 1 or 2 hours is sufficient
## Referencias:
## https://forum.transmissionbt.com/viewto ... =2&t=13970
## https://forum.transmissionbt.com/viewto ... =2&t=11468
## https://couchpota.to/forum/viewtopic.ph ... 9db1#p7330
## https://forum.transmissionbt.com/viewto ... 792#p64792
## https://forum.transmissionbt.com/viewto ... =1&t=13427
## date: 9 may 2013
# Inputs
USER="miusuario"
PASSWORD="????"
TRANSMISSION="/usr/local/transmission/bin/transmission-remote --auth $USER:$PASSWORD"
DESCARGADO_SEEDING="/volume1/descargas/030_DESCARGADO_SEEDING"
DESCARGADO_OFFLINE="/volume1/descargas/040_DESCARGADO_OFFLINE"
COMPLETADOS_BORRAR_TORRENT=1
COMPLETADOS_MOVER_A_OFFLINE=1
COMPLETADOS_TIEMPO_SIEMBRA=`expr 86400 \* 2` # Máximo 2 dias en segundos
# COUCHPOTATOURL=localhost
# COUCHPOTATOPORT=5050
# COUCHPOTATOAPI=couchpotatoapi
# Initialize
LISTA_COMPLETADOS=""
echo ""
echo "++++++ PROCESAR TORRENTS DESCARGADOS Y SEMBRADOS +++++"
echo "`date`"
echo "++++++++++++++++++++++++++++++++++++++++++++++++++++++"
# Lista de Torrents
TORRENTLIST=`$TRANSMISSION --list | sed -e '1d;$d;s/^ *//' | cut -s -d" " -f 1 | sed "s/[^0-9]//"`
for TORRENTID in $TORRENTLIST ; do
DL_COMPLETED=`$TRANSMISSION --torrent $TORRENTID --info | grep "Percent Done: 100%"`
STATE_FINISHED=`$TRANSMISSION --torrent $TORRENTID --info | grep "State: Stopped\|Finished\|Idle"`
# ------- Comprobamos tiempo de siembra
ALCANZADO_TIEMPO_SIEMBRA=0
TORRENTNAME="`$TRANSMISSION --torrent $TORRENTID --info | grep "Name:" | sed -e 's/ *Name: *//'`"
# Es una carpeta, recorrer ficheros
if [ -d "$DESCARGADO_SEEDING/$TORRENTNAME" ]; then
LASTMODIFIED=0
find "$DESCARGADO_SEEDING/$TORRENTNAME" | while read FILE ; do
AGE=`stat "$FILE" -c%Y`
if [ $AGE -gt $LASTMODIFIED ]; then
LASTMODIFIED=$AGE
fi
done
# Es un fichero unico
else
LASTMODIFIED=`stat "$DESCARGADO_SEEDING/$TORRENTNAME" -c%Y`
fi
TIME=`date +%s`
DIFF=`expr $TIME - $LASTMODIFIED`
# Se ha alcanzado el tiempo maximo de siembra COMPLETADOS_TIEMPO_SIEMBRA
if [ $DIFF -gt $COMPLETADOS_TIEMPO_SIEMBRA ]; then
ALCANZADO_TIEMPO_SIEMBRA=1
fi
if [ "$DL_COMPLETED" != "" ] && [ "$STATE_FINISHED" != "" ] && [ "$ALCANZADO_TIEMPO_SIEMBRA" -eq 1 ]; then
echo "Torrent #$TORRENTID: completado."
LISTA_COMPLETADOS="$LISTA_COMPLETADOS $TORRENTID"
else
echo "Torrent #$TORRENTID: no completado. Lo ignoramos"
fi
done
if [ "$LISTA_COMPLETADOS" != "" ]; then
echo "Torrents finalizados y sembrados: "$LISTA_COMPLETADOS
fi
for TORRENTID in $LISTA_COMPLETADOS ; do
echo "Tratando torrent $TORRENTID : $TORRENTNAME"
if [ $COMPLETADOS_BORRAR_TORRENT -eq 1 ] ; then
$TRANSMISSION --torrent $TORRENTID --remove
if [ $? -eq 0 ] ; then
echo "... torrent borrado en transmission"
else
echo "ERROR AL BORRAR TORRENT"
fi
else
echo "... no borramos torrent (desactivado)"
fi
if [ $COMPLETADOS_MOVER_A_OFFLINE -eq 1 ] ; then
if [ -f "$DESCARGADO_SEEDING/$TORRENTNAME" -o -d "$DESCARGADO_SEEDING/$TORRENTNAME"] ; then
mv "$DESCARGADO_SEEDING/$TORRENTNAME" "$DESCARGADO_OFFLINE"
echo "... fichero movido a $DESCARGADO_OFFLINE"
else
echo "ERROR AL MOVER FICHERO"
fi
else
echo "... ERROR NO SE HA ENCONTRADO EL FICHERO."
fi
else
echo "... no movemos fichero (desactivado)"
fi
done
# # Activate Couchpotato renamer
# if [ $RUNCOUCHPOTATOPOSTPROCESS == "TRUE" ]; then
# echo Run Couchpotato renamer
# # start couchpotato postprocessing script
# curl http://$COUCHPOTATOURL:$COUCHPOTATOPORT ... amer.scan/
# printf "\n"
# fi
echo "++++++++++++++++++++++++++ FINISHED ++++++++++++++++++++++++++"
Gracias. Solucionado.
El problema era al instalar, los directorios donde se ponia las descargas incompletas y demás estaban en un directorio que no permitía modifcación por el usuario en si. Los he cambiado y todo ok.
Edito ese fichero con la app Config File Editor 1.4 que va muy bien !
Gracias!!!!!!!!!
  • 5 months later...
* vi settings.json
NAME
TRANSFER
State: Idle
Percent Done: 100%
Availability: 100%
Uploaded: 21.06 GB
Ratio: 0.2
Corrupt DL: None
HISTORY
ORIGINS
Public torrent: Yes
Piece Count: 18474
LIMITS & BANDWIDTH
Peer limit: 60
#!/bin/sh
## Problems:
## Solution:
## Script:
## Prerequisites:
## Referencias:
## date: 9 may 2013
# Inputs
USER="miusuario"
PASSWORD="????"
# Initialize
echo ""
echo "`date`"
# Lista de Torrents
LASTMODIFIED=0
LASTMODIFIED=$AGE
fi
done
else
fi
TIME=`date +%s`
fi
else
fi
done
fi
else
fi
else
fi
else
fi
else
fi
else
fi
done
# printf "\n"
# fi
Hola, y por qué no mola Download Station para los trackers privados?
Es que estoy en DSM desde ayer, y estoy tratando de empaparme!
Muchas gracias.
  • 2 months later...
* vi settings.json
NAME
TRANSFER
State: Idle
Percent Done: 100%
Availability: 100%
Uploaded: 21.06 GB
Ratio: 0.2
Corrupt DL: None
HISTORY
ORIGINS
Public torrent: Yes
Piece Count: 18474
LIMITS & BANDWIDTH
Peer limit: 60
#!/bin/sh
## Problems:
## Solution:
## Script:
## Prerequisites:
## Referencias:
## date: 9 may 2013
# Inputs
USER="miusuario"
PASSWORD="????"
# Initialize
echo ""
echo "`date`"
# Lista de Torrents
LASTMODIFIED=0
LASTMODIFIED=$AGE
fi
done
else
fi
TIME=`date +%s`
fi
else
fi
done
fi
else
fi
else
fi
else
fi
else
fi
else
fi
done
# printf "\n"
# fi
Muchas gracias.
Depende de los requisitos de tu trackers. El transmisión es más personalizable posiblemente que el ds. Además, transmission instalas la versión que quieras y/o la versión que el trackers te diga.
