Jordax 0 Posted January 31 Share Posted January 31 (edited) Hello, community. Tried to install Xpenology on AMD Athlon II X3 420e - unsuccessfully. Used DS916p 6.1 Jun's Mod V1.02b. Ip address was not obtained by the machine. Realised that my LAN adapter or CPU are probably not supported. Please, advice on the right versions of DSM and Loader. Edited January 31 by Jordax Quote Link to post Share on other sites
IG-88 1,034 Posted January 31 Share Posted January 31 (edited) i'd say try loader 1.01 with dsm 6.0, all the old drivers for different sata/pata controllers where still working in that version, later kernel source changes broke them in 6.1 916/918 need newer cpu's (features) intel 4th gen minimum, your Athlon II X3 is to old for these versions https://xpenology.com/forum/topic/13333-tutorialreference-6x-loaders-and-platforms/ also you should read the post just below yours https://xpenology.com/forum/topic/54015-bootable-for-3615-and-3617-but-not-ds918/ if you still have trouble then you need to write more about the board you are using Edited January 31 by IG-88 Quote Link to post Share on other sites
