Ulysses Posted January 5, 2022 Share #1 Posted January 5, 2022 Hi Guys... I have a onld Synology 2415+ (12 bay) harfware... I works pretty well except the fact I have plex installed on it and it does not support HW Transcoding... I'm thinking about replacing the original Synology motherboard and use my xpenology setup on it... running the Intel 8400 with integrated GPU. 32GB, etc..etc... My question is: My synology NAS uses a PCIe backplane connector to the HDDs.... Does XPENology work if I connect this backplate board to my PCIe mobo ? are the XPEnology going to recognize my original synology backplane for SATA connectivity to HDDs ? Thanks in advance! Quote Link to comment Share on other sites More sharing options...
IG-88 Posted January 6, 2022 Share #2 Posted January 6, 2022 (edited) On 1/5/2022 at 10:28 PM, Ulysses said: My question is: My synology NAS uses a PCIe backplane connector to the HDDs.... Does XPENology work if I connect this backplate board to my PCIe mobo ? even if it looks like a pcie connector it might be something different in general if its pcie and there is sata connected you would see chips like on a pcie sata card like marvel 88se9215 so look for chips like this on the board and the backplane, if the chips are not on the backplane then the connector might be used differently and its a sata custom connection, connecting that to a pcie might have very "interesting" consequences that can even end in a small fire or popping capacitors (wear thick gloves and eye/face protection if you don't care and just want to pop it in so see what happens - i really not suggest just doing that, can be dangerous) Quote are the XPEnology going to recognize my original synology backplane for SATA connectivity to HDDs ? if its a pcie to sata and a backplane in one then it might work, synology usually uses ahci sata chips and thats supported by the synology kernel used in xpenology ootb and even if you would need a driver there are plenty in the additional extra.lzma you can download here if you name the chips on the board we can tell you if it need a extra driver Edited January 7, 2022 by IG-88 Quote Link to comment Share on other sites More sharing options...
Ulysses Posted January 7, 2022 Author Share #3 Posted January 7, 2022 4 hours ago, IG-88 said: even if it looks like a pcie connector it might be something different in general if its pcie and there is sata connected you would see chips like on a pcie sata card like marvel 88se915 so look for chips like this on the board and the backplane, if the chips are not on the backplane then the connector might be used differently and its a sata custom connection, connection that to a pcie might have very "interesting" consequences that can even end in a small fire or popping capacitors (wear thick gloves and eye/face protection if you dont care and just want to pop it in so see what happens - i really not suggest just doing that, can be dangerous) if its a pcie to sata and a backplane in one then it might work, synology usually uses ahci sata chips and thats supported by the synology kernel used in xpenology ootb and even if you would need a driver there are plenty in the additional extra.lzma you can download here if you name the chips on the board we can tell you if it need a extra driver Thanks IG-88.... I will disasembly my 2415+ tomorrow and take some pictures from the backplane... I'll post them here ... 1 Quote Link to comment Share on other sites More sharing options...
arden Posted January 5 Share #4 Posted January 5 (edited) Did you ever get around to trying this? I tried it with a ds2411+ but the system just power cycles after a few seconds, I think its when power is sent to the backplane that causes the psu to reset. The backplane Model is a Tower BP Ver 1.2 (08-04XXTBP12) and its got a chip with a sticker on it labeled Tower BP V1.00 Edited January 5 by arden adding images Quote Link to comment Share on other sites More sharing options...
IG-88 Posted January 6 Share #5 Posted January 6 On 1/5/2023 at 1:07 AM, arden said: The backplane Model is a Tower BP Ver 1.2 (08-04XXTBP12) and its got a chip with a sticker on it labeled Tower BP V1.00 BP might be "BackPlane" so not much out of this, peel off the sticker and look for the chip's markings Quote Link to comment Share on other sites More sharing options...
arden Posted January 13 Share #6 Posted January 13 Found this post - https://forum.ixbt.com/topic.cgi?id=109:291-75 which identifies the chip as some programable chip (altera max II chip), so just replacing it may not matter due to this, so as its most likely blown, moved on and using the case without the backplane. New raid cards should be arriving Sunday and I'll get everything hooked up with 4 additional drives int eh back of the unit due to the extra room Quote Link to comment Share on other sites More sharing options...
IG-88 Posted January 16 Share #7 Posted January 16 On 1/13/2023 at 6:22 PM, arden said: Found this post - https://forum.ixbt.com/topic.cgi?id=109:291-75 which identifies the chip as some programable chip (altera max II chip), so just replacing it may not matter due to this, so as its most likely blown, moved on and using the case without the backplane. New raid cards should be arriving Sunday and I'll get everything hooked up with 4 additional drives int eh back of the unit due to the extra room the slot, even looking like pcie might not be one, the syno systems are custom builds and are not bound to conventional hardware layouts, so it might be some custom layout transporting sata ans power signals instead of pcie, thats the reason to look for chips on the board and the backplane, if the sata chip/controller is an the main board and there is no such thing on the backplane it might indicate that its not rally a pcie slot, so check at least some basic stuff like power and ground signals and compare pcie and the slot on the board Quote Link to comment Share on other sites More sharing options...
