Essper Posted June 13, 2013 #27 Posted June 13, 2013 Wiki documentation: http://xpenology.com/wiki/en/building_xpenology Hi Andy928 Thanks for the sharing of this and the creation of the wiki. Could really do with some help if you have a little spare time - I would like to try and combine the NIC drivers in the RS3413xs 3211 kernel with the DS3612xs 3202 kernel. Could you give me a couple of pointers - maybe step by step Mucho thanko Essper
totalnas Posted June 27, 2013 #28 Posted June 27, 2013 FYI, The releases 3202 and 3211 are BINARY COMPATIBLE. Both uses the same Linux kernel for x64: 3.2.30. You can mix modules from both sources, mainly because no modifications from 3202 to 3211 in the kernel.
Schnapps Posted July 18, 2013 #29 Posted July 18, 2013 FYI, The releases 3202 and 3211 are BINARY COMPATIBLE. Both uses the same Linux kernel for x64: 3.2.30. You can mix modules from both sources, mainly because no modifications from 3202 to 3211 in the kernel. Good input! Thanks
Aigor Posted July 19, 2013 #30 Posted July 19, 2013 Hi, have i use only git version or can i use vanilla kernel from synogpl 3202 branch?
Kanedo Posted August 28, 2013 #31 Posted August 28, 2013 I built the kernel, but it sends a SIGTERM half way through booting and shuts down. EDIT: nevermind. had incompatible modules in rd.gz
Rand__ Posted November 4, 2013 #32 Posted November 4, 2013 Does anyone know where the sources for the different (compiled) cgi scripts are located? I am trying to find out how the disks/volumes are managed and am not getting any further from the cli commands alone; so i was trying to do a top down aproach; unfortunately i cant find the source for the cgi scripts... Are those not included in the source code (and where do they come from then)? Thx
tsygam Posted November 4, 2013 #33 Posted November 4, 2013 Does anyone know where the sources for the different (compiled) cgi scripts are located? I am trying to find out how the disks/volumes are managed and am not getting any further from the cli commands alone; so i was trying to do a top down aproach; unfortunately i cant find the source for the cgi scripts... Are those not included in the source code (and where do they come from then)? Thx Synology apps managing disks are not open source
dedligamer Posted November 13, 2013 #34 Posted November 13, 2013 Hello, I want to build my own xpenology with this tutorial: http://xpenology.com/wiki/en/building_xpenology But I stop until I have to use the SetMicropId() function. Can you help me, to use it and in which dir I have to find the output. Thanks.
zslibra Posted December 2, 2013 #35 Posted December 2, 2013 I'm trying to build my own kernel, but I don't know how to patch the original synology kernel from andy's git. please help~~
gnoboot Posted January 8, 2014 #36 Posted January 8, 2014 Modifying DSM 4.3 synobios.ko in Linux. 1. View the source code and look for the second 'ba ff ff ff ff' (25e1) in SetMicropId function using objdump. # objdump -S synobios.ko | less orig: 25da: e8 00 00 00 00 callq 25df 25df: 85 c0 test %eax,%eax 25e1: ba ff ff ff ff mov $0xffffffff,%edx 25e6: 75 c4 jne 25ac 25e8: 0f be 04 24 movsbl (%rsp),%eax 25ec: 31 d2 xor %edx,%edx 25ee: 89 05 00 00 00 00 mov %eax,0x0(%rip) # 25f4 2. Replace the next entry (25e6), change it from '75 c4 0f be 04 24' to '48 31 c0 b0 42 90' using xxd. # xxd -g 1 synobios.ko > synobios.hex # sed -i 's/75 c4 0f be 04 24/48 31 c0 b0 42 90/' synobios.hex # xxd -r synobios.hex > synobios-edited.ko # objdump -S synobios-edited.ko | less edited: 25da: e8 00 00 00 00 callq 25df 25df: 85 c0 test %eax,%eax 25e1: ba ff ff ff ff mov $0xffffffff,%edx 25e6: 48 31 c0 xor %rax,%rax 25e9: b0 42 mov $0x42,%al 25eb: 90 nop 25ec: 31 d2 xor %edx,%edx 25ee: 89 05 00 00 00 00 mov %eax,0x0(%rip) # 25f4 3. To disable the logging message, find '80 7c 24 17 00' (395) and replace the next entry (39a) with 'eb d4' in synobios_poll function. # objdump -S synobios.ko | less orig: 394: c3 retq 395: 80 7c 24 17 00 cmpb $0x0,0x17(%rsp) 39a: 74 d4 je 370 39c: be 24 02 00 00 mov $0x224,%esi # sed -i 's/80 7c 24 17 00 74 d4/80 7c 24 17 00 eb d4/' synobios.hex # xxd -r synobios.hex > synobios-edited.ko # objdump -S synobios-edited.ko | less edited: 394: c3 retq 395: 80 7c 24 17 00 cmpb $0x0,0x17(%rsp) 39a: eb d4 jmp 370 39c: be 24 02 00 00 mov $0x224,%esi
m4dm4n Posted February 22, 2014 #37 Posted February 22, 2014 (edited) I tried to compile 32 bit version myself by directions on this forum. I used 4.3 image bromolow (32bit) and Andys kernel from git. I just turned off x64, included VIA C7 platform, and VIA Rhine drivers in kernel, and while creating bzImage I got this error : arch/x86/kernel/sys_i386_32.c: In function 'sys_SYNOmmap': arch/x86/kernel/sys_i386_32.c:51: error: implicit declaration of function 'sys_mmap2' make[2]: *** [arch/x86/kernel/sys_i386_32.o] Error 1 make[1]: *** [arch/x86/kernel] Error 2 make: *** [arch/x86] Error 2 Edited February 23, 2014 by Guest
gnoboot Posted February 23, 2014 #38 Posted February 23, 2014 Try to use x64 dsgpl source and not bromolow.
m4dm4n Posted February 23, 2014 #39 Posted February 23, 2014 Try to use x64 dsgpl source and not bromolow. I used "gcc421_glibc236_x86-GPL.tgz" , and I still get the same error...
gnoboot Posted February 23, 2014 #40 Posted February 23, 2014 Did you get synogpl-3776-x64.tbz? Have you also tried using /source/linux-3.x/synoconfigs/x86 or /source/linux-3.x/synoconfigs/x86_64 config?
m4dm4n Posted February 23, 2014 #41 Posted February 23, 2014 Did you get synogpl-3776-x64.tbz? Have you also tried using /source/linux-3.x/synoconfigs/x86 or /source/linux-3.x/synoconfigs/x86_64 config? I used gcc420_glibc236_x64-GPL.tgz (extracted to /usr/local) synogpl-3776-x64.tbz (extracted to /usr/local/x86_64-linux-gnu/) andys kernel from github Used menuconfig , turned off x64, used VIA C7 platform and Centaur support, and included VIA Rhine drivers. Can you explain those synoconfigs with more details ? After menuconfig, and modules building. m4dm4n@m4dm4n-virtual-machine /usr/local/linux-3.x $ sudo make ARCH=x86 CROSS_COMPILE=/usr/local/x86_64-linux-gnu/bin/x86_64-linux-gnu- bzImage CHK include/linux/version.h CHK include/generated/utsrelease.h CALL scripts/checksyscalls.sh CHK include/generated/compile.h CC arch/x86/kernel/sys_i386_32.o arch/x86/kernel/sys_i386_32.c: In function 'sys_SYNOmmap': arch/x86/kernel/sys_i386_32.c:51: error: implicit declaration of function 'sys_mmap2' make[2]: *** [arch/x86/kernel/sys_i386_32.o] Error 1 make[1]: *** [arch/x86/kernel] Error 2 make: *** [arch/x86] Error 2
m4dm4n Posted February 25, 2014 #42 Posted February 25, 2014 I would like to BUMP this post , since I'm very interested in details of the story, so I could build something for myself and for this forum,too. Obviously, wiki from the first post in thread isnt't informative enough.
gnoboot Posted February 26, 2014 #43 Posted February 26, 2014 Well, it's not easy if you haven't tried to compile your own kernel from Linux distribution. Once you know how to do it, then you can try again. Aside from Andy's original patch, you still need to figure out how to detect/enable drives that are not fully supported by DSM. I spent a week or two before having a working kernel, and it was built from scratch including Andy's patch which I ported from 4.1 to 4.3 kernel. I've even have to learn how to use synology toolkit to make my life easier. Good luck on your endeavor.
gnoboot Posted March 14, 2014 #44 Posted March 14, 2014 This patch works well with dsgpl-4.3 source code. It also works with dsgpl-5.0 source code but you have to manually edit the relevant files. Go start build your own kernel and if ever you give back to this community. You can't please everyone, some of them are blood sucking leeches! --- drivers/ata/libata-core.c.orig 2014-01-06 02:42:49.946152467 +0800 +++ drivers/ata/libata-core.c 2014-01-06 02:51:38.822224108 +0800 @@ -7359,7 +7359,7 @@ EXPORT_SYMBOL(funcSYNOSendDiskPortDisEvent); #endif /* MY_ABC_HERE */ -#ifdef MY_DEF_HERE +#if (defined(MY_DEF_HERE) || defined(XPENOLOGY)) int (*funcSYNOSendEboxRefreshEvent)(int portIndex) = NULL; EXPORT_SYMBOL(funcSYNOSendEboxRefreshEvent); #endif --- include/linux/syno_user.h.orig 2014-01-06 02:42:49.948152589 +0800 +++ include/linux/syno_user.h 2014-01-06 03:01:35.815989363 +0800 @@ -4,6 +4,11 @@ #define __SYNO_USER_H_ /** + * XPEnology project + */ +#define XPENOLOGY + +/** * Dsc: Synology multimedia server feature. For indexing video, photo, * music. * Ref: libsynosdk, lnxnetatalk, lnxsdk, rsync, samba, smbftpd --- kernel/sysctl.c.orig 2014-01-06 02:42:49.955153014 +0800 +++ kernel/sysctl.c 2014-01-06 02:56:38.044634463 +0800 @@ -228,7 +228,7 @@ int (*funcSYNOGetHwCapability)(CAPABILITY *) = NULL; EXPORT_SYMBOL(funcSYNOGetHwCapability); -#ifdef MY_DEF_HERE +#if (defined(MY_DEF_HERE) || defined(XPENOLOGY)) EUNIT_PWRON_TYPE (*funcSynoEunitPowerctlType)(void) = NULL; EXPORT_SYMBOL(funcSynoEunitPowerctlType); #endif --- drivers/ata/sata_mv.c.orig 2013-08-24 17:37:08.000000000 +0800 +++ drivers/ata/sata_mv.c 2014-01-07 17:11:57.921748538 +0800 @@ -3692,6 +3692,7 @@ /*FIXME - Too brutal and directly, should separate into levels*/ void syno_sata_mv_gpio_write(u8 blFaulty, const unsigned short hostnum) { +#ifndef XPENOLOGY struct Scsi_Host *shost = scsi_host_lookup(hostnum); struct ata_port *ap = NULL; void __iomem *host_mmio = NULL; @@ -3724,9 +3725,10 @@ writel(gpio_value, host_mmio + GPIO_CTL_DATA); scsi_host_put(shost); - END: +#endif /* XPENOLOGY */ return; + } EXPORT_SYMBOL(syno_sata_mv_gpio_write); #endif --- drivers/pci/quirks.c.orig 2014-02-16 07:28:49.702724291 -0800 +++ drivers/pci/quirks.c 2014-02-16 07:30:58.599035923 -0800 @@ -618,7 +618,9 @@ ( pin < 0 || pin >= 96 ) || NULL == pValue ) { +#ifndef XPENOLOGY printk("parameter error. gpiobase=%08X, pin=%d, pValue=%p\n", gpiobase, pin, pValue); +#endif /* XPENOLOGY */ goto END; } --- fs/compat_ioctl.c.orig 2014-02-16 07:32:49.409608822 -0800 +++ fs/compat_ioctl.c 2014-02-16 07:34:43.256789001 -0800 @@ -1760,12 +1760,14 @@ sprintf(buf,"'%c'", (cmd>>_IOC_TYPESHIFT) & _IOC_TYPEMASK); if (!isprint(buf[1])) sprintf(buf, "%02x", buf[1]); +#ifndef XPENOLOGY compat_printk("ioctl32(%s:%d): Unknown cmd fd(%d) " "cmd(%08x){t:%s;sz:%u} arg(%08x) on %s\n", current->comm, current->pid, (int)fd, (unsigned int)cmd, buf, (cmd >> _IOC_SIZESHIFT) & _IOC_SIZEMASK, (unsigned int)arg, fn); +#endif if (path) free_page((unsigned long)path); --- drivers/tty/vt/vt.c.orig +++ drivers/tty/vt/vt.c @@ -2474,7 +2474,7 @@ int vt_kmsg_redirect(int new) return kmsg_con; } -#ifndef MY_ABC_HERE +#ifdef MY_ABC_HERE /* * Console on virtual terminal * @@ -2574,7 +2574,7 @@ quit: } #endif -#ifndef MY_ABC_HERE +#ifdef MY_ABC_HERE static struct tty_driver *vt_console_device(struct console *c, int *index) { *index = c->index ? c->index-1 : fg_console; @@ -2942,7 +2942,7 @@ static int __init con_init(void) console_unlock(); -#ifndef MY_ABC_HERE +#ifdef MY_ABC_HERE #ifdef CONFIG_VT_CONSOLE register_console(&vt_console_driver); #endif --- drivers/scsi/sd.c.orig 2014-02-15 16:28:48.148339650 -0800 +++ drivers/scsi/sd.c 2014-02-15 16:30:15.022585662 -0800 @@ -3006,6 +3006,11 @@ { struct scsi_device *sdp = to_scsi_device(dev); +#ifdef XPENOLOGY + printk(KERN_DEBUG "%s: disk driver '%s'", __FUNCTION__, + sdp->host->hostt->name); +#endif + // iscsi #ifdef MY_ABC_HERE if(strcmp(sdp->host->hostt->name, "iSCSI Initiator over TCP/IP") == 0){ @@ -3036,12 +3041,19 @@ if (SYNO_PORT_TYPE_SATA == sdp->host->hostt->syno_port_type) { // else treat as internal disks + printk(KERN_DEBUG "%s: SATA syno_port_type %x\n", __FUNCTION__, + sdp->host->hostt->syno_port_type); return SYNO_DISK_SATA; } // sas disks if (SYNO_PORT_TYPE_SAS == sdp->host->hostt->syno_port_type) { + printk(KERN_DEBUG "%s: SAS syno_port_type %x", __FUNCTION__, + sdp->host->hostt->syno_port_type); return SYNO_DISK_SAS; } +#ifdef XPENOLOGY + printk(KERN_DEBUG "syno_disk_type_get: Got UNKNOWN port type %x\n", sdp->host->hostt->syno_port_type); +#endif return SYNO_DISK_UNKNOWN; } #endif @@ -3210,7 +3222,7 @@ #endif // try at most 5 times while (want_idx != index && - (SYNO_DISK_SATA == sdkp->synodisktype) && iRetry < 15) { + (SYNO_DISK_SATA == sdkp->synodisktype) && iRetry < 5) { /* Sometimes raid is not release all scsi disk yet. Try to delay and reget */ printk("want_idx %d index %d. delay and reget\n", want_idx, index); @@ -3295,6 +3307,8 @@ error = sd_format_disk_name(SYNO_SATA_DEVICE_PREFIX, index, gd->disk_name, DISK_NAME_LEN); break; case SYNO_DISK_USB: + error = sd_format_disk_name(SYNO_SATA_DEVICE_PREFIX, index, gd->disk_name, DISK_NAME_LEN); + break; default: #ifdef SYNO_SAS_DISK_NAME if (1 == g_is_sas_model) { @@ -3303,6 +3317,10 @@ } #endif error = sd_format_disk_name(SYNO_SATA_DEVICE_PREFIX, index, gd->disk_name, DISK_NAME_LEN); +#ifdef XPENOLOGY + printk(KERN_DEBUG "sd_probe: Got UNKNOWN disk %s with index %x\n", gd->disk_name, index); + gd->systemDisk = 1; +#endif break; } #else
costib Posted March 14, 2014 #45 Posted March 14, 2014 ... some of them are blood sucking leeches! At least you could discard those having less then 5 or 10 posts on this forum and just registered, asking directly for releases...
ZeroCool Posted March 14, 2014 #46 Posted March 14, 2014 I've pathed the kernel,and compilned it successfully,but it seems I need much time to make the kernel run on my nas
dtowell Posted March 15, 2014 #47 Posted March 15, 2014 Wiki documentation: http://xpenology.com/wiki/en/building_xpenology This documentation seems to be empty. Do I need a password or something?
gnoboot Posted March 15, 2014 #48 Posted March 15, 2014 Wiki documentation: http://xpenology.com/wiki/en/building_xpenology This documentation seems to be empty. Do I need a password or something? Something is fishy.... Try google cache or internet archive.
ZeroCool Posted March 15, 2014 #49 Posted March 15, 2014 Wiki documentation: http://xpenology.com/wiki/en/building_xpenology This documentation seems to be empty. Do I need a password or something? Click 'showpagesouce' can see the article
vlotho Posted April 12, 2014 #50 Posted April 12, 2014 i have this error when i make the kernel after the "make ARCH=x86_64 CROSS_COMPILE=/usr/local/x86_64-linux-gnu/bin/x86_64-linux-gnu- menuconfig" command: root@gilles-EP31-DS3L:/home/gilles/Téléchargements/linux-3.x# make CHK include/linux/version.h CHK include/generated/utsrelease.h make[1]: « include/generated/mach-types.h » est à jour. CALL scripts/checksyscalls.sh CHK include/generated/compile.h CC arch/arm/mach-armadaxp/core.o arch/arm/mach-armadaxp/core.c: In function 'eth_init': arch/arm/mach-armadaxp/core.c:785:9: error: 'mv88fx_neta' undeclared (first use in this function) arch/arm/mach-armadaxp/core.c:785:9: note: each undeclared identifier is reported only once for each function it appears in arch/arm/mach-armadaxp/core.c: At top level: arch/arm/mach-armadaxp/core.c:1545:1: warning: function declaration isn't a prototype [-Wstrict-prototypes] make[1]: *** [arch/arm/mach-armadaxp/core.o] Erreur 1 make: *** [arch/arm/mach-armadaxp] Erreur 2
