TinyCore RedPill Loader (TCRP)
pocopico
25 minutes ago, titoum said:
i don't really share this point of view tbh...
It might be better to have people that really want to have those version on a BareMetal testing it and reporting/fixing.
As you mentioned, he should be quite overloaded already so asking for more from a person doing that during free time doesn't make sense.
Do you know what pre-test means?
The developed program has a minimal test of the developer himself.
If even this is not an environment for @pocopico to help, I will not make any more unreasonable demands.
13 hours ago, Bose321 said:
Can someone help me with getting it to work on Unraid? After building it does seem to build. but it seems like there is no network attached. I only see lo when I do ifconfig on the cli. I've tried both virtio and virtio-net and br0 and virtual br0. Even tried adding two interfaces.
The weird thing is that I do see the eth0 and eth1 interfaces when I am in the loader... But not after building in DSM.
Also tried to add this, but not working: https://github.com/jumkey/redpill-load/raw/develop/redpill-virtio/rpext-index.json
Just tried to set it to e1000 in Unraid (via de XML editor), and again in the loader I see the e1000 interface, and I've got internet and an IP address and it works, but after building again only a lo adapter. During the build I even see that it does say to load the e1000 adapter for ethernet. What's wrong here?
On 4/7/2022 at 8:45 AM, coint_cho said:
Ok, looks like my NIC is the issue here.. F1BD4BDE-66DF-408B-A76D-421A566CAA16.thumb.jpeg.82ed462b54e8a921369c6d2e94c5bae5.jpeg
And looks like there’s some other issues as well, is there any solutions to any of these? If these are Ethernet based errors, maybe switching to vmxnet3 would help? Or virtio?
I have the same error, how to fix?
21 hours ago, alienman said:
Hi @Indio,
The module is running. It's sufficient to see in the dmesg log of the DSM the lines "... smart_shim.c:818> Handling ioctl ...". So until here, all is right installed.
Regarding your problem, I see that all seems OK with the HD. What's the problem now? Remember that I'm using VMWARE ESXi and not PROMOX. So I don't know how to enable VIRTUAL SSD in the qemu configuration. However, I feel it can be enabled. Search in the documentation about how to mark a virtual harddisk as SSD.
Regards.
Hi again, the main problem is that proxmox only allow 6 sata drives to be passthrough to an VM, so, if I want more than 6 I have to try to add them as SCSI instead of SATA, and as SCSI they don't show in DSM :sad:.
21 hours ago, RedwinX said:
VMware ESXi didn't work for me. The only worked version installed for me is 7.0.1-42218 (918+ but whatever version), and I didn't remember how I did... The only think I know/see is that it's mandatory to have 2 network interfaces to get 1 working (5 for 3622xs+).
Current working version (7.0.1) has 2 network insterface and it work. BIOS mode and that's it... 1 vmdk (convert with v2v converter) in SATA 0:0 and 1 disk of DATA (4To thin provisioning) in SATA 0:1.
Cannot reproduce a working VM with same configuration with current redpill-loader, 7.0.1 or 7.1. Try many platform, not working. No visible error at boot (serial console). First boot and install are ok. But said that the system is in repair state after first reboot.
@pocopicoI'm wondering if the kernel has not change, because the RC version has disapear, but have the same build number. Do you think I have to regenerate the BSP ?
Regenerating now, and compare the 2 files... I will let you know
EDIT : same binary...
And just for information, I'm on ESXi 7.0u2. @pocopicoCannot boot with your vmdk tinycore, it said that it's an incorrect format. The only way to get a working version is to convert the img to vmdk (v2v converter)
Found solution. Please make a 6.7u2 compatibility VM in order to work, and don't fogot like me that the new 7.1 build is 661 and not 621. So make a new bsp etc... Works fine now
A few hours ago, the ds3622xs+ bsp was shown, so I finished building with TCRP using the bsp.
It was successful by modifying the Intel ext of the pocopico.
It was possible to jump to 7.0.1-42218 -> 7.1.0-42661 by two step update.
I think it's because misc and boot-wait are not ready at the moment
There is a file corruption phenomenon in 56% of the pat file installation.
AD0D0A49-B95D-47E7-A14A-1F3688B95E03_1_105_c.thumb.jpeg.a17c8c71b65385dd405ed35e0bb182f0.jpeg
3 minutes ago, coint_cho said:
No idea, still waiting on a potential fix from pocopico probably, if I had to guess it's just an issue with the VM? No idea
Oh, I just tested a switching from qemu64 CPU to host in Proxmox and I'm instantly dropped into the web UI and currently it's done being setup... Well that was a stupid fix, if I had to guess it's probably something to do with DS3622xs requiring a specific CPU function flag and qemu64 just doesn't have that? As qemu64 is designed to have bare minimal CPU flags afaik. My host cpu is E3-1275 v6 for reference. image.thumb.png.717f5083ac56824580c635130d03b07a.png
I'll be attempting a Tinycore build for my existing setup (3615xs w/ 6.2.3-25426 Update 3).  I have three 4TB drives installed.  Should I leave them as is, or format and remove all partitions before I start?  They're JBOD.  It would be nice if I didn't have to do a restore, but I can go either way since I have everything backed up.
3 часа назад, Peter Suh сказал:
to fix it, you need to disconnect the Internet connection during installation
Leave them as is. Backup is always recommended
Edited by pocopico
Awesome!!  what is bsp?
I don't know exactly what BSP is.
The final version came up and I just used it.
The link below seems to be an action related to this, but I don't know how to turn it.
I'd appreciate it if you could let me know if anyone knows.
https://github.com/dogodefi/redpill-load/actions
Edited by Peter Suh
Migration succeeded with two bootloaders.
Use 7.1.0-42661 (regular version) as a manual DSM update on 7.0.1-42118
During the reboot process, I replaced it with the 7.1.0-42661 bootloader that I built yesterday
The update is working well.
The PC1 for my XPENOLOGY test I used yesterday was changed to PC2 because I kept getting this 56% error last time.
I should proceed with the installation again after HDD CLEAR instead of updating the migration.
727758959_2022-04-099_34_09.thumb.png.3623f741a5f2bbaa4c2f09466a8b68b6.png1513773540_2022-04-099_34_19.thumb.png.2efb0067e7e7a2c3bf22800c124ac67e.png
Before the official version of @pocopico comes out, anyone who wants to try it first should try it.
Download "tc.zip" from the Google link below, copy it from the window to the TC
You can destroy the existing tc folder and unzip the file you just received and replace it.
Permission adjustment is also required, so please follow the command below.
The Intel driver/misc/boot-wait is already in the adjusted state and should not be downloaded again.
Do not use actions such as update/clean/fullupgrade.
Even if you ask if you want to check the internet and change it to a new version, you have to do N.
Realtek r8169 is not included, so if you need it, please download it.
You only need to carry out the three builds below.
https://drive.google.com/file/d/1mjv2knHo2aWICnQD_6xbeUirIlgWYICM/view?usp=sharing
scp  [download path]/tc.zip  tc@192.168.1.2:/home
cd /home
sudo rm -rf tc
unzip tc
cd tc
chmod -R 755 *
(Already included and omitted)
./rploader.sh ext broadwellnk-7.0.1-42218 add https://raw.githubusercontent.com/PeterSuh-Q3/rp-ext/master/igb/rpext-index.json
./rploader.sh ext broadwellnk-7.0.1-42218 add https://raw.githubusercontent.com/PeterSuh-Q3/rp-ext/master/e1000e/rpext-index.json
(Run if necessary)
./rploader.sh ext broadwellnk-7.0.1-42218 add https://raw.githubusercontent.com/PeterSuh-Q3/rp-ext/master/mpt3sas/rpext-index.json
./rploader.sh ext broadwellnk-7.0.1-42218 add https://raw.githubusercontent.com/PeterSuh-Q3/rp-ext/master/r8169/rpext-index.json
(Repeat twice, type y for all questions)
./rploader.sh build broadwellnk-7.0.1-42218 manual
(This question needs to come up)
Want to use firmware files from /home/tc/custom-module/*.pat ? [yY/nN] :
y
./rploader.sh ext broadwellnk-7.1.0-42661 add https://github.com/PeterSuh-Q3/redpill-load/raw/develop/redpill-misc/rpext-index.json
./rploader.sh ext broadwellnk-7.1.0-42661 add https://github.com/PeterSuh-Q3/redpill-ext/blob/master/redpill-boot-wait/rpext-index.json
./rploader.sh ext broadwellnk-7.1.0-42661 add https://raw.githubusercontent.com/PeterSuh-Q3/rp-ext/master/igb/rpext-index.json
./rploader.sh ext broadwellnk-7.1.0-42661 add https://raw.githubusercontent.com/PeterSuh-Q3/rp-ext/master/e1000e/rpext-index.json
(recovering redpill.ko, type y for all questions)
cp *load/ext/*lkm/redpill-linux-v4.4.180+.ko ./redpill.ko
cp *load/ext/*lkm/redpill-linux-v4.4.180+.ko ./custom-module/redpill.ko
./rploader.sh build broadwellnk-7.1.0-42661 manual
Edited by Peter Suh
You don't have to worry about the 56% and 57% stop. I think it's because it's a muxed sata board
On another board, considering the muxed sata, the sataportmap was shortened, adjusted, and the 7.1 official new installation was successfully.
Normal installation is over 61%.
cd /home
sudo rm -rf tc
unzip tc
cd tc
chmod -R 755 *
(Run if necessary)
y
Maybe VM can do it with this.
./rploader.sh ext broadwellnk-7.0.1-42218 add https://raw.githubusercontent.com/PeterSuh-Q3/rp-ext/master/vmxnet3/rpext-index.json
The issue with vmxnet3, is that it doesn't really work for some reason. I was testing it before with my 42621 installation, and for some reason it's reporting back in Xpenology as a gigabit link, but it's only a 100mb link, and even with an assigned IP, I can't reach the box as well.
cd /home
sudo rm -rf tc
unzip tc
cd tc
chmod -R 755 *
(Run if necessary)
y
Google Drive's tc.zip was deleted due to permission issues and replaced with the following tc.tgz.
https://drive.google.com/file/d/1Msg-dBHns__GexG0WcA6qdS6RI30YqH_/view?usp=sharing
scp  [download path]/tc.tgz  tc@192.168.1.2:/home
cd /home
sudo rm -rf tc
tar -xvf tc.tgz
cd tc
  • Thanks 2
image.thumb.png.b35e2b082e5b2796c2a2598d7a824c51.pngimage.png.c56e3c2e6b9496171e0258d563bd3431.png
Either it'll have to be rtl8139 or e1000
