extreen Posted May 23 Share #4676 Posted May 23 49 минут назад, pocopico сказал: Лучшим выбором для SCSI-дисков будет DS3622xs +, попробуйте последнюю версию TCRP и посмотрим, что получится I am using v1.1-beta 2a and started my search with 3622. unfortunately, the result is the same. Цитата Using username "tc". tc@10.70.0.16's password: ( '>') /) TC (\ Core is distributed with ABSOLUTELY NO WARRANTY. (/-_--_-\) www.tinycorelinux.net tc@box:~$ ./rploader.sh update now Checking Internet Access -> OK Checking if a newer version exists on the main repo -> Version is current tc@box:~$ ./rploader.sh fullupgrade now Performing a full TCRP upgrade Cloning into 'tinycore-redpill'... remote: Enumerating objects: 1039, done. remote: Counting objects: 100% (1039/1039), done. remote: Compressing objects: 100% (852/852), done. remote: Total 1039 (delta 189), reused 985 (delta 172), pack-reused 0 Receiving objects: 100% (1039/1039), 14.48 MiB | 311.00 KiB/s, done. Resolving deltas: 100% (189/189), done. Please make sure you are using the latest 1GB img before using backup option Current /home/tc size is 38M , try to keep it less than 1GB as it might not fit into your image Should i update the sda with your current files [Yy/Nn] y Backing up home files to sda : Backing up files to /mnt/sda3//mydata.tgz Done. tc@box:~$ ./rploader.sh identifyusb now Found UFD Silicon-Power SerialNumber: 13030692061000000460 Vendor ID : 0x090c Product ID : 0x1000 Should i update the user_config.json with these values ? [Yy/Nn] y tc@box:~$ ./rploader.sh satamap now Found SCSI HBAs, We need to install the SCSI modules scsi-5.10.3-tinycore64 is already installed! Succesfully installed SCSI modules Found SCSI/HBA "02:00.0 Hewlett-Packard Company Smart Array Gen8 Controllers (rev 01)" (12 drives) lspci: -s: Invalid slot number Found SCSI/HBA "" (0 drives) lspci: -s: Invalid slot number Found SCSI/HBA "" (0 drives) lspci: -s: Invalid bus number Found SCSI/HBA "" (0 drives) lspci: -s: Invalid slot number Found SCSI/HBA "" (0 drives) lspci: -s: Invalid slot number Found SCSI/HBA "" (0 drives) lspci: -s: Invalid slot number Found SCSI/HBA "" (0 drives) lspci: -s: Invalid slot number Found SCSI/HBA "" (0 drives) lspci: -s: Invalid slot number Found SCSI/HBA "" (0 drives) lspci: -s: Invalid slot number Found SCSI/HBA "" (0 drives) lspci: -s: Invalid slot number Found SCSI/HBA "" (0 drives) lspci: -s: Invalid slot number Found SCSI/HBA "" (0 drives) Computed settings: SataPortMap=1 DiskIdxMap=00 Should i update the user_config.json with these values ? [Yy/Nn] y Done. tc@box:~$ ./rploader.sh build ds3622xsp-7.2.0-64551 bspatch does not exist, bringing over from repo % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 100 10232 100 10232 0 0 23467 0 --:--:-- --:--:-- --:--:-- 23414 Rploader Version : 0.9.4.5 Quote Link to comment Share on other sites More sharing options...
aarnet Posted May 23 Share #4677 Posted May 23 problems installing ds918p-7.2.0-64561 I think that no update of indexes for ds918p-7.2.0-64561 7.2.0-64551 / 7.2.0-64561 Updating extension : all-modules contents for model : ds918p_64561 [#] Checking runtime for required tools... [OK] [#] Updating ds918p_64561 platforms extensions... [-] The extension all-modules was found. However, the extension index has no recipe for ds918p_64561 platform. It may not be [-] supported on that platform, or author didn't updated it for that platform yet. You can try running [-] "ext-manager.sh update" to refresh indexes for all extensions manually. Below are the currently known information about [-] the extension stored locally: [#] ========================================== all-modules ========================================== [#] Extension name: all-modules [#] Description: Adds All modules Support [#] To get help visit: <todo> [#] Extension preparer/packer: https://github.com/pocopico/tcrp-addons/tree/main/all-modules [#] Software author: https://github.com/pocopico [#] Update URL: https://raw.githubusercontent.com/pocopico/tcrp-addons/main/all-modules/rpext-index.json [#] Platforms supported: dva1622_64551 rs1619xsp_64561 sa6400_64561 rs3618xs_64551 rs3413xsp_64551 rs3621xsp_64551 ds720p_64551 ds1019p_64551 dva3221_42661 ds3617xs_42218 ds1520p_64561 ds920p_42661 sa3600_64561 dva3221_42962 ds1019p_42218 ds918p_42661 ds3622xsp_42962 rs3618xs_42962 ds1621p_64561 dva1622_64561 ds920p_42962 rs1619xsp_64551 dva3219_64551 ds1621p_42661 rs3621xsp_64561 ds720p_64561 ds1019p_64561 ds923p_42962 rs4021xsp_64561 fs2500_64551 ds723p_64561 ds2422p_64561 ds1621xsp_42661 ds3615xs_42661 ds1621p_64551 sa3600_42661 rs1619xsp_42962 ds3622xsp_42661 ds723p_42661 ds2422p_42661 sa6400_42661 sa6400_64551 ds3622xsp_42218 rs3413xsp_42661 ds723p_42962 ds920p_64561 ds2422p_42962 dva3219_64561 rs1221p_42661 rs3413xsp_64561 dva1622_42962 ds923p_64551 ds723p_64551 ds3617xs_64551 sa6400_42962 rs4021xsp_64551 fs2500_42962 rs4021xsp_42962 zendofmodel ds3615xs_42962 ds2422p_64551 sa3600_42962 ds3617xs_42962 fs2500_42661 ds1520p_42218 rs1221p_64551 ds3622xsp_64551 dva3219_42962 ds1520p_64551 ds3617xs_42661 ds1621xsp_42962 ds918p_64551 ds920p_42218 sa3400_42962 sa3400_64561 ds918p_42962 rs1619xsp_42661 rs3618xs_42661 rs3618xs_64561 ds1621xsp_64551 rs1221p_42962 ds3615xs_64561 dva3221_64561 ds920p_64551 dva1622_42661 ds1520p_42962 sa3600_64551 ds918p_42218 rs3621xsp_42962 ds720p_42962 ds1019p_42962 ds923p_42661 dva3219_42661 sa3400_42661 ds3615xs_64551 ds923p_64561 ds3617xs_64561 sa3400_64551 rs3413xsp_42962 ds3615xs_42218 fs2500_64561 ds1621p_42962 dva3221_64551 ds1621xsp_64561 rs1221p_64561 ds1520p_42661 rs4021xsp_42661 ds3622xsp_64561 rs3621xsp_42661 ds720p_42661 ds1019p_42661 [#] ======================================================================================= [-] Failed to update recipe for all-modules extension for platform ds918p_64561. The script will terminate as you do not [-] have previously downloaded recipe which can be used if download fails. Try again later. If problem [-] persists contact the extension packer for support (displayed below) [#] ========================================== all-modules ========================================== [#] Extension name: all-modules [#] Description: Adds All modules Support [#] To get help visit: <todo> [#] Extension preparer/packer: https://github.com/pocopico/tcrp-addons/tree/main/all-modules [#] Software author: https://github.com/pocopico [#] Update URL: https://raw.githubusercontent.com/pocopico/tcrp-addons/main/all-modules/rpext-index.json [#] Platforms supported: dva1622_64551 rs1619xsp_64561 sa6400_64561 rs3618xs_64551 rs3413xsp_64551 rs3621xsp_64551 ds720p_64551 ds1019p_64551 dva3221_42661 ds3617xs_42218 ds1520p_64561 ds920p_42661 sa3600_64561 dva3221_42962 ds1019p_42218 ds918p_42661 ds3622xsp_42962 rs3618xs_42962 ds1621p_64561 dva1622_64561 ds920p_42962 rs1619xsp_64551 dva3219_64551 ds1621p_42661 rs3621xsp_64561 ds720p_64561 ds1019p_64561 ds923p_42962 rs4021xsp_64561 fs2500_64551 ds723p_64561 ds2422p_64561 ds1621xsp_42661 ds3615xs_42661 ds1621p_64551 sa3600_42661 rs1619xsp_42962 ds3622xsp_42661 ds723p_42661 ds2422p_42661 sa6400_42661 sa6400_64551 ds3622xsp_42218 rs3413xsp_42661 ds723p_42962 ds920p_64561 ds2422p_42962 dva3219_64561 rs1221p_42661 rs3413xsp_64561 dva1622_42962 ds923p_64551 ds723p_64551 ds3617xs_64551 sa6400_42962 rs4021xsp_64551 fs2500_42962 rs4021xsp_42962 zendofmodel ds3615xs_42962 ds2422p_64551 sa3600_42962 ds3617xs_42962 fs2500_42661 ds1520p_42218 rs1221p_64551 ds3622xsp_64551 dva3219_42962 ds1520p_64551 ds3617xs_42661 ds1621xsp_42962 ds918p_64551 ds920p_42218 sa3400_42962 sa3400_64561 ds918p_42962 rs1619xsp_42661 rs3618xs_42661 rs3618xs_64561 ds1621xsp_64551 rs1221p_42962 ds3615xs_64561 dva3221_64561 ds920p_64551 dva1622_42661 ds1520p_42962 sa3600_64551 ds918p_42218 rs3621xsp_42962 ds720p_42962 ds1019p_42962 ds923p_42661 dva3219_42661 sa3400_42661 ds3615xs_64551 ds923p_64561 ds3617xs_64561 sa3400_64551 rs3413xsp_42962 ds3615xs_42218 fs2500_64561 ds1621p_42962 dva3221_64551 ds1621xsp_64561 rs1221p_64561 ds1520p_42661 rs4021xsp_42661 ds3622xsp_64561 rs3621xsp_42661 ds720p_42661 ds1019p_42661 [#] ======================================================================================= [!] Cannot continue due to previous errors (see above) *** Process will exit *** [#] Verifying /home/tc/redpill-load/custom/extensions/disks/ds918p_64561/install.sh file... [ERR] [!] Checksum mismatch - expected 7590d9c09eb3a548ee9a838bac70d800f38582372377d9651221fb1e570f912b but computed 7259464898c426743e824a9040917fdc6bef493697a13e4ad22049f98da2e11d *** Process will exit *** Updating extension : misc contents for model : ds918p_64561 [#] Verifying /home/tc/redpill-load/custom/extensions/disks/ds918p_64561/install.sh file... [ERR] [!] Checksum mismatch - expected 7590d9c09eb3a548ee9a838bac70d800f38582372377d9651221fb1e570f912b but computed 7259464898c426743e824a9040917fdc6bef493697a13e4ad22049f98da2e11d *** Process will exit *** Updating extension : misc contents for model : ds918p_64561 [!] Cannot continue due to previous errors (see above) *** Process will exit *** [!] Failed to update all extensions for ds918p_64561 platform - see errors above *** Process will exit *** FAILED : Loader creation failed check the output for any errors 1 Quote Link to comment Share on other sites More sharing options...
Dvalin21 Posted May 23 Share #4678 Posted May 23 Question, with 7.2 being released and I know you guys are working on this (Great, Great job and thank you for all the efforts by the way) will all platforms using "friend" be able to just run the update from settings update or will we have to rebuild the platform specifically for 7.2? Thanks. Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted May 23 Share #4679 Posted May 23 (edited) 3 hours ago, Dvalin21 said: Question, with 7.2 being released and I know you guys are working on this (Great, Great job and thank you for all the efforts by the way) will all platforms using "friend" be able to just run the update from settings update or will we have to rebuild the platform specifically for 7.2? Thanks. of course. 7.1 and 7.2 have different Linux kernel versions. Edited May 23 by Peter Suh 1 Quote Link to comment Share on other sites More sharing options...
extreen Posted Tuesday at 01:09 PM Share #4680 Posted Tuesday at 01:09 PM Tell me please. After the complete installation procedure: Цитата ./rploader.sh update now ./rploader.sh fullupgrade now ./rploader.sh identifyusb now ./rploader.sh satamap now ./rploader.sh serialgen DS3622xs+ realmac ./rploader.sh build ds3622xsp-7.2.0-64561 ./rploader.sh backup exitcheck.sh reboot I'm changing the user_config.json parameters manually SataPortMap. Do I need to follow the steps: Цитата ./rploader.sh serialgen DS3622xs+ realmac ./rploader.sh build ds3622xsp-7.2.0-64561 ./rploader.sh backup exitcheck.sh reboot I'm trying to choose the parameters so that DSM can see my disks. Quote Link to comment Share on other sites More sharing options...
kgymac Posted Wednesday at 04:52 AM Share #4681 Posted Wednesday at 04:52 AM 15 hours ago, extreen said: Tell me please. After the complete installation procedure: I'm changing the user_config.json parameters manually SataPortMap. Do I need to follow the steps: I'm trying to choose the parameters so that DSM can see my disks. Try ./rploader.sh ext ds3622xsp-7.2.0-64561 auto ./rploader.sh satamap now /rploader.sh build ds3622xsp-7.2.0-64561 withfriend Quote Link to comment Share on other sites More sharing options...
pocopico Posted Wednesday at 05:22 PM Author Share #4682 Posted Wednesday at 05:22 PM On 5/23/2023 at 9:50 AM, aarnet said: problems installing ds918p-7.2.0-64561 I think that no update of indexes for ds918p-7.2.0-64561 7.2.0-64551 / 7.2.0-64561 Updating extension : all-modules contents for model : ds918p_64561 [#] Checking runtime for required tools... [OK] [#] Updating ds918p_64561 platforms extensions... [-] The extension all-modules was found. However, the extension index has no recipe for ds918p_64561 platform. It may not be [-] supported on that platform, or author didn't updated it for that platform yet. You can try running [-] "ext-manager.sh update" to refresh indexes for all extensions manually. Below are the currently known information about [-] the extension stored locally: [#] ========================================== all-modules ========================================== [#] Extension name: all-modules [#] Description: Adds All modules Support [#] To get help visit: <todo> [#] Extension preparer/packer: https://github.com/pocopico/tcrp-addons/tree/main/all-modules [#] Software author: https://github.com/pocopico [#] Update URL: https://raw.githubusercontent.com/pocopico/tcrp-addons/main/all-modules/rpext-index.json [#] Platforms supported: dva1622_64551 rs1619xsp_64561 sa6400_64561 rs3618xs_64551 rs3413xsp_64551 rs3621xsp_64551 ds720p_64551 ds1019p_64551 dva3221_42661 ds3617xs_42218 ds1520p_64561 ds920p_42661 sa3600_64561 dva3221_42962 ds1019p_42218 ds918p_42661 ds3622xsp_42962 rs3618xs_42962 ds1621p_64561 dva1622_64561 ds920p_42962 rs1619xsp_64551 dva3219_64551 ds1621p_42661 rs3621xsp_64561 ds720p_64561 ds1019p_64561 ds923p_42962 rs4021xsp_64561 fs2500_64551 ds723p_64561 ds2422p_64561 ds1621xsp_42661 ds3615xs_42661 ds1621p_64551 sa3600_42661 rs1619xsp_42962 ds3622xsp_42661 ds723p_42661 ds2422p_42661 sa6400_42661 sa6400_64551 ds3622xsp_42218 rs3413xsp_42661 ds723p_42962 ds920p_64561 ds2422p_42962 dva3219_64561 rs1221p_42661 rs3413xsp_64561 dva1622_42962 ds923p_64551 ds723p_64551 ds3617xs_64551 sa6400_42962 rs4021xsp_64551 fs2500_42962 rs4021xsp_42962 zendofmodel ds3615xs_42962 ds2422p_64551 sa3600_42962 ds3617xs_42962 fs2500_42661 ds1520p_42218 rs1221p_64551 ds3622xsp_64551 dva3219_42962 ds1520p_64551 ds3617xs_42661 ds1621xsp_42962 ds918p_64551 ds920p_42218 sa3400_42962 sa3400_64561 ds918p_42962 rs1619xsp_42661 rs3618xs_42661 rs3618xs_64561 ds1621xsp_64551 rs1221p_42962 ds3615xs_64561 dva3221_64561 ds920p_64551 dva1622_42661 ds1520p_42962 sa3600_64551 ds918p_42218 rs3621xsp_42962 ds720p_42962 ds1019p_42962 ds923p_42661 dva3219_42661 sa3400_42661 ds3615xs_64551 ds923p_64561 ds3617xs_64561 sa3400_64551 rs3413xsp_42962 ds3615xs_42218 fs2500_64561 ds1621p_42962 dva3221_64551 ds1621xsp_64561 rs1221p_64561 ds1520p_42661 rs4021xsp_42661 ds3622xsp_64561 rs3621xsp_42661 ds720p_42661 ds1019p_42661 [#] ======================================================================================= [-] Failed to update recipe for all-modules extension for platform ds918p_64561. The script will terminate as you do not [-] have previously downloaded recipe which can be used if download fails. Try again later. If problem [-] persists contact the extension packer for support (displayed below) [#] ========================================== all-modules ========================================== [#] Extension name: all-modules [#] Description: Adds All modules Support [#] To get help visit: <todo> [#] Extension preparer/packer: https://github.com/pocopico/tcrp-addons/tree/main/all-modules [#] Software author: https://github.com/pocopico [#] Update URL: https://raw.githubusercontent.com/pocopico/tcrp-addons/main/all-modules/rpext-index.json [#] Platforms supported: dva1622_64551 rs1619xsp_64561 sa6400_64561 rs3618xs_64551 rs3413xsp_64551 rs3621xsp_64551 ds720p_64551 ds1019p_64551 dva3221_42661 ds3617xs_42218 ds1520p_64561 ds920p_42661 sa3600_64561 dva3221_42962 ds1019p_42218 ds918p_42661 ds3622xsp_42962 rs3618xs_42962 ds1621p_64561 dva1622_64561 ds920p_42962 rs1619xsp_64551 dva3219_64551 ds1621p_42661 rs3621xsp_64561 ds720p_64561 ds1019p_64561 ds923p_42962 rs4021xsp_64561 fs2500_64551 ds723p_64561 ds2422p_64561 ds1621xsp_42661 ds3615xs_42661 ds1621p_64551 sa3600_42661 rs1619xsp_42962 ds3622xsp_42661 ds723p_42661 ds2422p_42661 sa6400_42661 sa6400_64551 ds3622xsp_42218 rs3413xsp_42661 ds723p_42962 ds920p_64561 ds2422p_42962 dva3219_64561 rs1221p_42661 rs3413xsp_64561 dva1622_42962 ds923p_64551 ds723p_64551 ds3617xs_64551 sa6400_42962 rs4021xsp_64551 fs2500_42962 rs4021xsp_42962 zendofmodel ds3615xs_42962 ds2422p_64551 sa3600_42962 ds3617xs_42962 fs2500_42661 ds1520p_42218 rs1221p_64551 ds3622xsp_64551 dva3219_42962 ds1520p_64551 ds3617xs_42661 ds1621xsp_42962 ds918p_64551 ds920p_42218 sa3400_42962 sa3400_64561 ds918p_42962 rs1619xsp_42661 rs3618xs_42661 rs3618xs_64561 ds1621xsp_64551 rs1221p_42962 ds3615xs_64561 dva3221_64561 ds920p_64551 dva1622_42661 ds1520p_42962 sa3600_64551 ds918p_42218 rs3621xsp_42962 ds720p_42962 ds1019p_42962 ds923p_42661 dva3219_42661 sa3400_42661 ds3615xs_64551 ds923p_64561 ds3617xs_64561 sa3400_64551 rs3413xsp_42962 ds3615xs_42218 fs2500_64561 ds1621p_42962 dva3221_64551 ds1621xsp_64561 rs1221p_64561 ds1520p_42661 rs4021xsp_42661 ds3622xsp_64561 rs3621xsp_42661 ds720p_42661 ds1019p_42661 [#] ======================================================================================= [!] Cannot continue due to previous errors (see above) *** Process will exit *** [#] Verifying /home/tc/redpill-load/custom/extensions/disks/ds918p_64561/install.sh file... [ERR] [!] Checksum mismatch - expected 7590d9c09eb3a548ee9a838bac70d800f38582372377d9651221fb1e570f912b but computed 7259464898c426743e824a9040917fdc6bef493697a13e4ad22049f98da2e11d *** Process will exit *** Updating extension : misc contents for model : ds918p_64561 [#] Verifying /home/tc/redpill-load/custom/extensions/disks/ds918p_64561/install.sh file... [ERR] [!] Checksum mismatch - expected 7590d9c09eb3a548ee9a838bac70d800f38582372377d9651221fb1e570f912b but computed 7259464898c426743e824a9040917fdc6bef493697a13e4ad22049f98da2e11d *** Process will exit *** Updating extension : misc contents for model : ds918p_64561 [!] Cannot continue due to previous errors (see above) *** Process will exit *** [!] Failed to update all extensions for ds918p_64561 platform - see errors above *** Process will exit *** FAILED : Loader creation failed check the output for any errors fixed 3 Quote Link to comment Share on other sites More sharing options...
tdse13 Posted Wednesday at 07:29 PM Share #4683 Posted Wednesday at 07:29 PM I am trying to build a new loader for ds918p-7.2.0-64561 with a new stick since the update did not work. But I receive the following message: h: line 52: /home/tc/redpill-load/config/_common/_common/v7.2.0/ramdisk-001-disable-root-pwd.patch: No such file or directory [!] One of the patches - /home/tc/redpill-load/config/_common/_common/v7.2.0/ramdisk-001-disable-root-pwd.patch - failed to apply *** Process will exit *** Any idea how to fix it? Thank you. Quote Link to comment Share on other sites More sharing options...
pocopico Posted Wednesday at 07:51 PM Author Share #4684 Posted Wednesday at 07:51 PM 21 minutes ago, tdse13 said: I am trying to build a new loader for ds918p-7.2.0-64561 with a new stick since the update did not work. But I receive the following message: h: line 52: /home/tc/redpill-load/config/_common/_common/v7.2.0/ramdisk-001-disable-root-pwd.patch: No such file or directory [!] One of the patches - /home/tc/redpill-load/config/_common/_common/v7.2.0/ramdisk-001-disable-root-pwd.patch - failed to apply *** Process will exit *** Any idea how to fix it? Thank you. fixed Quote Link to comment Share on other sites More sharing options...
olegL Posted Wednesday at 08:43 PM Share #4685 Posted Wednesday at 08:43 PM (edited) Hello. I'm trying to build a loader for version 7.2.0-64561. I used the latest version of tinycore-redpill.v0.9.4.6. I am getting an errors: The extension pocopico.r8101 was found. However, the extension index has no recipe for ds3622xsp_64561 platform. and Failed to update recipe for pocopico.r8101 extension for platform ds3622xsp_64561. Cannot continue due to previous errors (see above) *** Process will exit *** [!] Failed to update all extensions for ds3622xsp_64561 platform - see errors above What could be the problem? Previously, version 7.1.1-42962 successfully worked on this hardware (Pentium G630T,Intel B75 Chipset ). full console LOG in attachment. error 7.2-64561.txt Edited Wednesday at 08:44 PM by olegL Quote Link to comment Share on other sites More sharing options...
tdse13 Posted Wednesday at 09:01 PM Share #4686 Posted Wednesday at 09:01 PM Same here ds918p-7.2.0-64561 but with this message: The extension pocopico.r8168 was found. However, the extension index has no recipe for ds918p_64561 platform. Quote Link to comment Share on other sites More sharing options...
ner0 Posted Thursday at 12:45 AM Share #4687 Posted Thursday at 12:45 AM (edited) I need some help figuring out why a VM with DSM shuts down as soon as I try to access the web interface (after DSM installation). Quick summary: Host: - CPU: Intel i7 3370K - Hypervisor: VMware Workstation 16.x Guest: - 8 GB RAM; - 1 CPU, 4 cores; - 1 SATA HDD with TCRP image (tinycore-redpill.v0.9.4.6.vmdk); - 1 SATA HDD with 25GB (for DSM); - 1 Ethernet adapter, bridge mode (tried e1000, e1000e, vmxnet3); I tried 2 models (DS920+ and DS3622xs+), using DSM v7.1.1 build 42962; tried the usual manual route from SSH and also using the HTML builder. In both cases I can start the installation fine, but it is suspiciously quick in my opinion; goes from 0% to 8%, then after 5 seconds jumps to 40%, 55%, 56%, 57%, 58%, 59%, and restarts leaving the browser with a 10min. countdown. After restarting, whenever I try to load DSM web page I immediately get a 502 error - white page with Synology logo and the message "Sorry, the page you are looking for is not found." and then the VM just shuts down after 3 seconds. Note: After "installing", on next boot friend reports "Ramdisk upgrade has been detected zImage upgrade has been detected". I did have some other minor issues before this but was able to find information that pointed me in teh right direction, but this one has me completely stumped, especially due to the lack of verbosity (afaik). Can this be due to the nature of the platform combination with VM and TCRP support for those being shaky/recent? Do I need to include any special module during the build? I am unsure if there is something that I'm doing wrong here, I've only ever installed on baremetal but this time I'm trying to use virtual for testing purposes. I'd be glad to provide more details or logging info if anyone cares to help out. Anyway, appreciate any help I can get. Thanks. test.mp4 Edited Thursday at 01:54 AM by ner0 added short example video Quote Link to comment Share on other sites More sharing options...
extreen Posted Thursday at 02:43 AM Share #4688 Posted Thursday at 02:43 AM 21 час назад, kgymac сказал: Try ./rploader.sh ext ds3622xsp-7.2.0-64561 auto ./rploader.sh satamap now /rploader.sh build ds3622xsp-7.2.0-64561 withfriend Execution error Цитата tc@box:~$ ./rploader.sh update now Checking Internet Access -> OK Checking if a newer version exists on the main repo -> Version is current tc@box:~$ ./rploader.sh fullupgrade now Performing a full TCRP upgrade Cloning into 'tinycore-redpill'... remote: Enumerating objects: 1083, done. remote: Counting objects: 100% (1083/1083), done. remote: Compressing objects: 100% (875/875), done. remote: Total 1083 (delta 207), reused 1037 (delta 193), pack-reused 0 Receiving objects: 100% (1083/1083), 15.91 MiB | 1.05 MiB/s, done. Resolving deltas: 100% (207/207), done. Please make sure you are using the latest 1GB img before using backup option Current /home/tc size is 44M , try to keep it less than 1GB as it might not fit into your image Should i update the sda with your current files [Yy/Nn] y Backing up home files to sda : Backing up files to /mnt/sda3//mydata.tgz Done. tc@box:~$ ./rploader.sh identifyusb now Found KINGSTON DT SerialNumber: F46D0461E35FAC51C96409D1 Vendor ID : 0x0951 Product ID : 0x1642 Should i update the user_config.json with these values ? [Yy/Nn] y tc@box:~$ ./rploader.sh serialgen DS3622xs+ realmac Serial Number for Model = 2040SQRAVA4YZ Mac Address for Model DS3622xs+ = 00:11:32:F1:6D:F7 Real Mac Address : D8:9D:67:27:BC:5C Notice : realmac option is requested, real mac will be used Should i update the user_config.json with these values ? [Yy/Nn] y tc@box:~$ ./rploader.sh ext ds3622xsp-7.2.0-64561 auto bspatch does not exist, bringing over from repo % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 100 10232 100 10232 0 0 28032 0 --:--:-- --:--:-- --:--:-- 27956 Rploader Version : 0.9.4.6 Loader source : https://github.com/pocopico/redpill-load.git Loader Branch : develop Redpill module source : https://github.com/pocopico/redpill-lkm.git : Redpill module branch : master Extensions : all-modules eudev disks misc Extensions URL : "https://github.com/pocopico/tcrp-addons/raw/main/all-modules/rpext-index.json", "https://github.com/pocopico/tcrp-addons/raw/main/eudev/rpext-index.json", "https://github.com/pocopico/tcrp-addons/raw/main/disks/rpext-index.json", "https://github.com/pocopico/tcrp-addons/raw/main/misc/rpext-index.json" TOOLKIT_URL : https://sourceforge.net/projects/toolkit-me/files/ds.broadwellnk-7.2.dev.txz/download TOOLKIT_SHA : 0d9edca67d9e7e14c2529bbb58341b623936124d5264f71f1e4acbacf3ea202d SYNOKERNEL_URL : https://sourceforge.net/projects/dsgpl/files/Synology NAS GPL Source/25426branch/broadwellnk-source/linux-4.4.x.txz/download SYNOKERNEL_SHA : d3e85eb80f16a83244fcae6016ab6783cd8ac55e3af2b4240455261396e1e1be COMPILE_METHOD : toolkit_dev TARGET_PLATFORM : ds3622xsp TARGET_VERSION : 7.2.0 TARGET_REVISION : 64561 REDPILL_LKM_MAKE_TARGET : dev-v7 KERNEL_MAJOR : 4 MODULE_ALIAS_FILE : modules.alias.4.json SYNOMODEL : ds3622xsp_64561 MODEL : DS3622xs+ Local Cache Folder : /mnt/sda3/auxfiles DATE Internet : 25052023 Local : 25052023 Checking Internet Access -> OK Cloning into 'redpill-lkm'... remote: Enumerating objects: 1649, done. remote: Counting objects: 100% (1649/1649), done. remote: Compressing objects: 100% (620/620), done. remote: Total 1649 (delta 1016), reused 1579 (delta 996), pack-reused 0 Receiving objects: 100% (1649/1649), 5.81 MiB | 2.75 MiB/s, done. Resolving deltas: 100% (1016/1016), done. Cloning into 'redpill-load'... remote: Enumerating objects: 3775, done. remote: Counting objects: 100% (610/610), done. remote: Compressing objects: 100% (315/315), done. remote: Total 3775 (delta 332), reused 564 (delta 289), pack-reused 3165 Receiving objects: 100% (3775/3775), 121.63 MiB | 1021.00 KiB/s, done. Resolving deltas: 100% (1886/1886), done. Testing modules.alias.4.json -> File OK ------------------------------------------------------------------------------------------------ It looks that you will need the following modules : Found VGA Controller : pciid 102bd00000533 Required Extension : No matching extension [#] Checking runtime for required tools... [OK] [#] Adding new extension from https://raw.githubusercontent.com/pocopico/rp-ext/master/hpsa/rpext-index.json... [#] Downloading remote file https://raw.githubusercontent.com/pocopico/rp-ext/master/hpsa/rpext-index.json to /home/tc/redpill-load/custom/extensions/_new_ext_index.tmp_json ######################################################################## 100.0% [OK] [#] ========================================== pocopico.hpsa ========================================== [#] Extension name: hpsa [#] Description: Adds Support [#] To get help visit: <todo> [#] Extension preparer/packer: https://github.com/pocopico/rp-ext/tree/main/hpsa [#] Software author: https://github.com/pocopico [#] Update URL: https://raw.githubusercontent.com/pocopico/rp-ext/master/hpsa/rpext-index.json [#] Platforms supported: ds1621p_42218 ds1621p_42951 ds918p_41890 dva3221_42661 ds3617xs_42621 ds3617xs_42218 ds920p_42661 dva3221_42962 ds918p_42661 ds3622xsp_42962 ds3617xs_42951 dva1622_42218 dva1622_42621 ds920p_42962 ds1621p_42661 dva1622_42951 ds918p_25556 dva3221_42218 ds3615xs_42661 dva3221_42951 ds3622xsp_42661 ds2422p_42661 ds3622xsp_42218 ds2422p_42962 rs4021xsp_42621 dva1622_42962 ds2422p_42218 rs4021xsp_42962 dva3221_42621 ds3615xs_42962 ds3617xs_42962 ds3615xs_41222 ds920p_42951 rs4021xsp_42218 ds2422p_42951 ds918p_42621 ds3617xs_42661 ds3615xs_25556 ds920p_42218 rs4021xsp_42951 ds920p_42621 ds918p_42962 ds3615xs_42951 ds3622xsp_42951 dva1622_42661 ds918p_42218 ds2422p_42621 ds1621p_42621 ds3615xs_42621 ds3615xs_42218 ds1621p_42962 ds3622xsp_42621 rs4021xsp_42661 [#] ======================================================================================= Found SAS Controller : pciid 103cd0000323b Required Extension : hpsa hpsa hpsa hpsa hpsa hpsa hpsa hpsa hpsa Searching for matching extension for hpsa Found matching extension : "https://raw.githubusercontent.com/pocopico/rp-ext/master/hpsa/rpext-index.json" [#] Checking runtime for required tools... [OK] [#] Adding new extension from https://raw.githubusercontent.com/pocopico/rp-ext/master/tg3/rpext-index.json... [#] Downloading remote file https://raw.githubusercontent.com/pocopico/rp-ext/master/tg3/rpext-index.json to /home/tc/redpill-load/custom/extensions/_new_ext_index.tmp_json ######################################################################## 100.0% [OK] [#] ========================================== pocopico.tg3 ========================================== [#] Extension name: tg3 [#] Description: Adds Broadcom Tigon3 ethernet driver Support [#] To get help visit: <todo> [#] Extension preparer/packer: https://github.com/pocopico/rp-ext/tree/main/tg3 [#] Software author: https://github.com/pocopico [#] Update URL: https://raw.githubusercontent.com/pocopico/rp-ext/master/tg3/rpext-index.json [#] Platforms supported: ds1621p_42218 ds1621p_42951 dva3221_42661 ds3617xs_42621 ds3617xs_42218 ds920p_42661 dva3221_42962 ds918p_42661 ds3622xsp_42962 ds3617xs_42951 dva1622_42218 dva1622_42621 ds920p_42962 ds1621p_42661 dva1622_42951 ds918p_25556 dva3221_42218 ds3615xs_42661 dva3221_42951 ds3622xsp_42661 ds2422p_42661 ds3622xsp_42218 ds2422p_42962 rs4021xsp_42621 dva1622_42962 ds2422p_42218 rs4021xsp_42962 dva3221_42621 ds3615xs_42962 ds3617xs_42962 ds920p_42951 rs4021xsp_42218 ds2422p_42951 endofmodel ds918p_42621 ds3617xs_42661 ds3615xs_25556 ds920p_42218 rs4021xsp_42951 ds920p_42621 ds918p_42962 ds3615xs_42951 ds3622xsp_42951 dva1622_42661 ds918p_42218 ds2422p_42621 ds1621p_42621 ds918p_42951 ds3615xs_42621 ds3615xs_42218 ds1621p_42962 ds3622xsp_42621 rs4021xsp_42661 [#] ======================================================================================= Found Ethernet Interface : pciid 14e4d00001657 Required Extension : tg3 Searching for matching extension for tg3 Found matching extension : "https://raw.githubusercontent.com/pocopico/rp-ext/master/tg3/rpext-index.json" [#] Checking runtime for required tools... [OK] [#] Adding new extension from https://raw.githubusercontent.com/pocopico/rp-ext/master/tg3/rpext-index.json... [#] Downloading remote file https://raw.githubusercontent.com/pocopico/rp-ext/master/tg3/rpext-index.json to /home/tc/redpill-load/custom/extensions/_new_ext_index.tmp_json ######################################################################## 100.0% [!] Extension is already added (index exists at /home/tc/redpill-load/custom/extensions/pocopico.tg3/pocopico.tg3.json). For more info use "ext-manager.sh info pocopico.tg3" *** Process will exit *** Found Ethernet Interface : pciid 14e4d00001657 Required Extension : tg3 Searching for matching extension for tg3 Found matching extension : "https://raw.githubusercontent.com/pocopico/rp-ext/master/tg3/rpext-index.json" [#] Checking runtime for required tools... [OK] [#] Adding new extension from https://raw.githubusercontent.com/pocopico/rp-ext/master/tg3/rpext-index.json... [#] Downloading remote file https://raw.githubusercontent.com/pocopico/rp-ext/master/tg3/rpext-index.json to /home/tc/redpill-load/custom/extensions/_new_ext_index.tmp_json ######################################################################## 100.0% [!] Extension is already added (index exists at /home/tc/redpill-load/custom/extensions/pocopico.tg3/pocopico.tg3.json). For more info use "ext-manager.sh info pocopico.tg3" *** Process will exit *** Found Ethernet Interface : pciid 14e4d00001657 Required Extension : tg3 Searching for matching extension for tg3 Found matching extension : "https://raw.githubusercontent.com/pocopico/rp-ext/master/tg3/rpext-index.json" [#] Checking runtime for required tools... [OK] [#] Adding new extension from https://raw.githubusercontent.com/pocopico/rp-ext/master/tg3/rpext-index.json... [#] Downloading remote file https://raw.githubusercontent.com/pocopico/rp-ext/master/tg3/rpext-index.json to /home/tc/redpill-load/custom/extensions/_new_ext_index.tmp_json ######################################################################## 100.0% [!] Extension is already added (index exists at /home/tc/redpill-load/custom/extensions/pocopico.tg3/pocopico.tg3.json). For more info use "ext-manager.sh info pocopico.tg3" *** Process will exit *** Found Ethernet Interface : pciid 14e4d00001657 Required Extension : tg3 Searching for matching extension for tg3 Found matching extension : "https://raw.githubusercontent.com/pocopico/rp-ext/master/tg3/rpext-index.json" Found VGA Controller : pciid 10ded00000422 Required Extension : No matching extension ------------------------------------------------------------------------------------------------ tc@box:~$ ./rploader.sh satamap now Found SCSI HBAs, We need to install the SCSI modules scsi-5.10.3-tinycore64 is already installed! Succesfully installed SCSI modules Found SCSI/HBA "02:00.0 Hewlett-Packard Company Smart Array Gen8 Controllers (rev 01)" (12 drives) lspci: -s: Invalid slot number Found SCSI/HBA "" (0 drives) lspci: -s: Invalid slot number Found SCSI/HBA "" (0 drives) lspci: -s: Invalid bus number Found SCSI/HBA "" (0 drives) lspci: -s: Invalid slot number Found SCSI/HBA "" (0 drives) lspci: -s: Invalid slot number Found SCSI/HBA "" (0 drives) lspci: -s: Invalid slot number Found SCSI/HBA "" (0 drives) lspci: -s: Invalid slot number Found SCSI/HBA "" (0 drives) lspci: -s: Invalid slot number Found SCSI/HBA "" (0 drives) lspci: -s: Invalid slot number Found SCSI/HBA "" (0 drives) lspci: -s: Invalid slot number Found SCSI/HBA "" (0 drives) lspci: -s: Invalid slot number Found SCSI/HBA "" (0 drives) Computed settings: SataPortMap=1 DiskIdxMap=00 Should i update the user_config.json with these values ? [Yy/Nn] y Done. tc@box:~$ ./rploader.sh build ds3622xsp-7.2.0-64561 withfriend Rploader Version : 0.9.4.6 Loader source : https://github.com/pocopico/redpill-load.git Loader Branch : develop Redpill module source : https://github.com/pocopico/redpill-lkm.git : Redpill module branch : master Extensions : all-modules eudev disks misc Extensions URL : "https://github.com/pocopico/tcrp-addons/raw/main/all-modules/rpext-index.json", "https://github.com/pocopico/tcrp-addons/raw/main/eudev/rpext-index.json", "https://github.com/pocopico/tcrp-addons/raw/main/disks/rpext-index.json", "https://github.com/pocopico/tcrp-addons/raw/main/misc/rpext-index.json" TOOLKIT_URL : https://sourceforge.net/projects/toolkit-me/files/ds.broadwellnk-7.2.dev.txz/download TOOLKIT_SHA : 0d9edca67d9e7e14c2529bbb58341b623936124d5264f71f1e4acbacf3ea202d SYNOKERNEL_URL : https://sourceforge.net/projects/dsgpl/files/Synology NAS GPL Source/25426branch/broadwellnk-source/linux-4.4.x.txz/download SYNOKERNEL_SHA : d3e85eb80f16a83244fcae6016ab6783cd8ac55e3af2b4240455261396e1e1be COMPILE_METHOD : toolkit_dev TARGET_PLATFORM : ds3622xsp TARGET_VERSION : 7.2.0 TARGET_REVISION : 64561 REDPILL_LKM_MAKE_TARGET : dev-v7 KERNEL_MAJOR : 4 MODULE_ALIAS_FILE : modules.alias.4.json SYNOMODEL : ds3622xsp_64561 MODEL : DS3622xs+ Local Cache Folder : /mnt/sda3/auxfiles DATE Internet : 25052023 Local : 25052023 Checking Internet Access -> OK Checking if a newer version exists on the main repo -> Version is current Redpill sources already downloaded, pulling latest Already up to date. Loader sources already downloaded, pulling latest Already up to date. withfriend option set, My friend will be added No extra build option or static specified, using default <static> Using static compiled redpill extension Removing any old redpill.ko modules Looking for redpill for : ds3622xsp_64561 Getting file https://raw.githubusercontent.com/pocopico/rp-ext/master/redpillprod/releases/redpill-4.4.302plus-broadwellnk.tgz Extracting module Getting file https://raw.githubusercontent.com/pocopico/rp-ext/master/redpillprod/src/check-redpill.sh Got redpill-linux-v4.4.302+.ko Starting loader creation Found tinycore cache folder, linking to home/tc/custom-module Checking user_config.json : Done Entering redpill-load directory Removing bundled exts directories Cache directory OK Found build request for revision greater than 42218 Downloading extractor v2 % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 100 389M 100 389M 0 0 8965k 0 0:00:44 0:00:44 --:--:-- 8707k Creating temp folder /tmp/pat Checking for cached pat file Found tinycore cache folder, linking to home/tc/custom-module Could not find pat file locally cached Configdir : /home/tc/redpill-load/config/DS3622xs+/7.2.0-64561 Configfile: /home/tc/redpill-load/config/DS3622xs+/7.2.0-64561/config.json Pat URL : https://global.download.synology.com/download/DSM/release/7.2/64561/DSM_DS3622xs%2B_64561.pat Downloading pat file from URL : https://global.download.synology.com/download/DSM/release/7.2/64561/DSM_DS3622xs%2B_64561.pat % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 100 366M 100 366M 0 0 8956k 0 0:00:41 0:00:41 --:--:-- 10.2M File //mnt/sda3/auxfiles/ds3622xsp_64561.pat, is encrypted File //mnt/sda3/auxfiles/ds3622xsp_64561.pat, has been cached but its encrypted, re-running decrypting process Checking for cached pat file Found tinycore cache folder, linking to home/tc/custom-module Found locally cached pat file /home/tc/custom-module/ds3622xsp_64561.pat File /home/tc/custom-module/ds3622xsp_64561.pat, is encrypted Extracting encrypted pat file : /home/tc/custom-module/ds3622xsp_64561.pat to /tmp/pat option -f with value `/home/tc/custom-module/ds3622xsp_64561.pat' option -C with value `/tmp/pat' 0 Creating unecrypted pat file ds3622xsp_64561.pat to /home/tc/redpill-load/cache folder VERSION Pat file sha256sum is : e7fdcd9777d1a64af6f41edd3e836e801dd33b0c91c7e046e9ec4a68073f43cb Checking config file existence -> OK Editing config file -> Verifying config file -> OK ! Clearing temp folders Processing add_extensions entries found on /home/tc/custom_config2.json file : all-modules eudev disks misc Adding extension "https://github.com/pocopico/tcrp-addons/raw/main/all-modules/rpext-index.json", [#] Checking runtime for required tools... [OK] [#] Adding new extension from https://github.com/pocopico/tcrp-addons/raw/main/all-modules/rpext-index.json... [#] Downloading remote file https://github.com/pocopico/tcrp-addons/raw/main/all-modules/rpext-index.json to /home/tc/redpill-load/custom/extensions/_new_ext_index.tmp_json ######################################################################################################################################################################################################## 100.0% [OK] [#] ========================================== all-modules ========================================== [#] Extension name: all-modules [#] Description: Adds All modules Support [#] To get help visit: <todo> [#] Extension preparer/packer: https://github.com/pocopico/tcrp-addons/tree/main/all-modules [#] Software author: https://github.com/pocopico [#] Update URL: https://raw.githubusercontent.com/pocopico/tcrp-addons/main/all-modules/rpext-index.json [#] Platforms supported: dva1622_64551 rs1619xsp_64561 sa6400_64561 rs3618xs_64551 rs3413xsp_64551 rs3621xsp_64551 ds720p_64551 ds1019p_64551 dva3221_42661 ds3617xs_42218 ds1520p_64561 ds920p_42661 sa3600_64561 dva3221_42962 ds1019p_42218 ds918p_42661 ds3622xsp_42962 rs3618xs_42962 ds1621p_64561 dva1622_64561 ds920p_42962 rs1619xsp_64551 dva3219_64551 ds1621p_42661 rs3621xsp_64561 ds720p_64561 ds1019p_64561 ds923p_42962 rs4021xsp_64561 fs2500_64551 ds723p_64561 ds2422p_64561 ds1621xsp_42661 ds3615xs_42661 ds1621p_64551 sa3600_42661 rs1619xsp_42962 ds3622xsp_42661 ds723p_42661 ds2422p_42661 sa6400_42661 sa6400_64551 ds3622xsp_42218 rs3413xsp_42661 ds723p_42962 ds920p_64561 ds2422p_42962 dva3219_64561 rs1221p_42661 rs3413xsp_64561 dva1622_42962 ds923p_64551 ds723p_64551 ds918p_64561 ds3617xs_64551 sa6400_42962 rs4021xsp_64551 fs2500_42962 rs4021xsp_42962 zendofmodel ds3615xs_42962 ds2422p_64551 sa3600_42962 ds3617xs_42962 fs2500_42661 ds1520p_42218 rs1221p_64551 ds3622xsp_64551 dva3219_42962 ds1520p_64551 ds3617xs_42661 ds1621xsp_42962 ds918p_64551 ds920p_42218 sa3400_42962 sa3400_64561 ds918p_42962 rs1619xsp_42661 rs3618xs_42661 rs3618xs_64561 ds1621xsp_64551 rs1221p_42962 ds3615xs_64561 dva3221_64561 ds920p_64551 dva1622_42661 ds1520p_42962 sa3600_64551 ds918p_42218 rs3621xsp_42962 ds720p_42962 ds1019p_42962 ds923p_42661 dva3219_42661 sa3400_42661 ds3615xs_64551 ds923p_64561 ds3617xs_64561 sa3400_64551 rs3413xsp_42962 ds3615xs_42218 fs2500_64561 ds1621p_42962 dva3221_64551 ds1621xsp_64561 rs1221p_64561 ds1520p_42661 rs4021xsp_42661 ds3622xsp_64561 rs3621xsp_42661 ds720p_42661 ds1019p_42661 [#] ======================================================================================= Adding extension "https://github.com/pocopico/tcrp-addons/raw/main/eudev/rpext-index.json", [#] Checking runtime for required tools... [OK] [#] Adding new extension from https://github.com/pocopico/tcrp-addons/raw/main/eudev/rpext-index.json... [#] Downloading remote file https://github.com/pocopico/tcrp-addons/raw/main/eudev/rpext-index.json to /home/tc/redpill-load/custom/extensions/_new_ext_index.tmp_json ######################################################################################################################################################################################################## 100.0% [OK] [#] ========================================== eudev ========================================== [#] Extension name: Eudev binaries [#] Description: Eudev binaries will assist with auto module loading [#] To get help visit: https://github.com/pocopico/tcrp-addons/main/eudev/ [#] Extension preparer/packer: https://github.com/pocopico/tcrp-addons/main/eudev/ [#] Software author: https://github.com/pocopico/tcrp-addons/main/eudev/ [#] Update URL: https://raw.githubusercontent.com/pocopico/tcrp-addons/main/eudev/rpext-index.json [#] Platforms supported: dva1622_64551 ds1621p_42218 rs1619xsp_64561 sa6400_64561 rs3618xs_64551 rs3413xsp_64551 rs3621xsp_64551 ds720p_64551 ds1019p_64551 dva3221_42661 ds3617xs_42218 ds1520p_64561 ds920p_42661 sa3600_64561 dva3221_42962 ds1019p_42218 ds918p_42661 ds3622xsp_42962 rs3618xs_42962 ds1621p_64561 dva1622_64561 ds920p_42962 rs1619xsp_64551 dva3219_64551 ds1621p_42661 rs3621xsp_64561 ds720p_64561 ds1019p_64561 ds923p_42962 rs4021xsp_64561 fs2500_64551 ds723p_64561 ds2422p_64561 dva3221_42218 ds1621xsp_42661 ds3615xs_42661 ds1621p_64551 sa3600_42661 rs1619xsp_42962 ds3622xsp_42661 ds723p_42661 ds2422p_42661 sa6400_42661 sa6400_64551 ds3622xsp_42218 rs3413xsp_42661 ds723p_42962 ds920p_64561 ds2422p_42962 dva3219_64561 rs1221p_42661 rs3413xsp_64561 dva1622_42962 ds923p_64551 ds723p_64551 ds918p_64561 ds3617xs_64551 sa6400_42962 ds2422p_42218 rs4021xsp_64551 fs2500_42962 rs4021xsp_42962 zendofmodel ds3615xs_42962 ds2422p_64551 sa3600_42962 ds3617xs_42962 fs2500_42661 ds1520p_42218 rs4021xsp_42218 rs1221p_64551 ds3622xsp_64551 dva3219_42962 dva3219_42218 ds1520p_64551 ds3617xs_42661 ds1621xsp_42962 ds918p_64551 ds920p_42218 sa3400_42962 sa3400_64561 ds918p_42962 rs1619xsp_42661 rs3618xs_42661 rs3618xs_64561 ds1621xsp_64551 rs1221p_42962 ds3615xs_64561 dva3221_64561 ds920p_64551 dva1622_42661 ds1520p_42962 sa3600_64551 ds918p_42218 rs3621xsp_42962 ds720p_42962 ds1019p_42962 ds923p_42661 dva3219_42661 sa3400_42661 ds1621xsp_42218 ds3615xs_64551 ds923p_64561 ds3617xs_64561 sa3400_64551 rs3413xsp_42962 ds3615xs_42218 fs2500_64561 ds1621p_42962 dva3221_64551 ds1621xsp_64561 rs1221p_64561 ds1520p_42661 rs4021xsp_42661 ds3622xsp_64561 rs3621xsp_42661 ds720p_42661 ds1019p_42661 fs2500_42218 [#] ======================================================================================= Adding extension "https://github.com/pocopico/tcrp-addons/raw/main/disks/rpext-index.json", [#] Checking runtime for required tools... [OK] [#] Adding new extension from https://github.com/pocopico/tcrp-addons/raw/main/disks/rpext-index.json... [#] Downloading remote file https://github.com/pocopico/tcrp-addons/raw/main/disks/rpext-index.json to /home/tc/redpill-load/custom/extensions/_new_ext_index.tmp_json ######################################################################################################################################################################################################## 100.0% [OK] [#] ========================================== disks ========================================== [#] Extension name: Disks [#] Description: All in one solution for disk issues [#] To get help visit: https://github.com/pocopico/tcrp-addons/main/disks/ [#] Extension preparer/packer: https://github.com/pocopico/tcrp-addons/main/disks/ [#] Software author: https://github.com/pocopico/tcrp-addons/main/disks/ [#] Update URL: https://raw.githubusercontent.com/pocopico/tcrp-addons/main/disks/rpext-index.json [#] Platforms supported: dva1622_64551 ds1621p_42218 rs1619xsp_64561 sa6400_64561 rs3618xs_64551 rs3413xsp_64551 rs3621xsp_64551 ds720p_64551 ds1019p_64551 dva3221_42661 ds3617xs_42218 ds1520p_64561 ds920p_42661 sa3600_64561 dva3221_42962 ds1019p_42218 ds918p_42661 ds3622xsp_42962 rs3618xs_42962 ds1621p_64561 dva1622_64561 ds920p_42962 rs1619xsp_64551 dva3219_64551 ds1621p_42661 rs3621xsp_64561 ds720p_64561 ds1019p_64561 ds923p_42962 rs4021xsp_64561 fs2500_64551 ds723p_64561 ds2422p_64561 dva3221_42218 ds1621xsp_42661 ds3615xs_42661 ds1621p_64551 sa3600_42661 rs1619xsp_42962 ds3622xsp_42661 ds723p_42661 ds2422p_42661 sa6400_42661 sa6400_64551 ds3622xsp_42218 rs3413xsp_42661 ds723p_42962 ds920p_64561 ds2422p_42962 dva3219_64561 rs1221p_42661 rs3413xsp_64561 dva1622_42962 ds923p_64551 ds723p_64551 ds918p_64561 ds3617xs_64551 sa6400_42962 ds2422p_42218 rs4021xsp_64551 fs2500_42962 rs4021xsp_42962 zendofmodel ds3615xs_42962 ds2422p_64551 sa3600_42962 ds3617xs_42962 fs2500_42661 ds1520p_42218 rs4021xsp_42218 rs1221p_64551 ds3622xsp_64551 dva3219_42962 dva3219_42218 ds1520p_64551 ds3617xs_42661 ds1621xsp_42962 ds918p_64551 ds920p_42218 sa3400_42962 sa3400_64561 ds918p_42962 rs1619xsp_42661 rs3618xs_42661 rs3618xs_64561 ds1621xsp_64551 rs1221p_42962 ds3615xs_64561 dva3221_64561 ds920p_64551 dva1622_42661 ds1520p_42962 sa3600_64551 ds918p_42218 rs3621xsp_42962 ds720p_42962 ds1019p_42962 ds923p_42661 dva3219_42661 sa3400_42661 ds1621xsp_42218 ds3615xs_64551 ds923p_64561 ds3617xs_64561 sa3400_64551 rs3413xsp_42962 ds3615xs_42218 fs2500_64561 ds1621p_42962 dva3221_64551 ds1621xsp_64561 rs1221p_64561 ds1520p_42661 rs4021xsp_42661 ds3622xsp_64561 rs3621xsp_42661 ds720p_42661 ds1019p_42661 fs2500_42218 [#] ======================================================================================= Adding extension "https://github.com/pocopico/tcrp-addons/raw/main/misc/rpext-index.json" [#] Checking runtime for required tools... [OK] [#] Adding new extension from https://github.com/pocopico/tcrp-addons/raw/main/misc/rpext-index.json... [#] Downloading remote file https://github.com/pocopico/tcrp-addons/raw/main/misc/rpext-index.json to /home/tc/redpill-load/custom/extensions/_new_ext_index.tmp_json ######################################################################################################################################################################################################## 100.0% [OK] [#] ========================================== misc ========================================== [#] Extension name: Misc shell [#] Description: Misc shell [#] To get help visit: https://raw.githubusercontent.com/pocopico/tcrp-addons/main/misc [#] Extension preparer/packer: https://raw.githubusercontent.com/pocopico/tcrp-addons/main/misc [#] Software author: https://raw.githubusercontent.com/pocopico/tcrp-addons/main/misc [#] Update URL: https://raw.githubusercontent.com/pocopico/tcrp-addons/main/misc/rpext-index.json [#] Platforms supported: dva1622_64551 ds1621p_42218 rs1619xsp_64561 sa6400_64561 rs3618xs_64551 rs3413xsp_64551 rs3621xsp_64551 ds720p_64551 ds1019p_64551 dva3221_42661 ds3617xs_42218 ds1520p_64561 ds920p_42661 sa3600_64561 dva3221_42962 ds1019p_42218 ds918p_42661 ds3622xsp_42962 rs3618xs_42962 ds1621p_64561 dva1622_64561 ds920p_42962 rs1619xsp_64551 dva3219_64551 ds1621p_42661 rs3621xsp_64561 ds720p_64561 ds1019p_64561 ds923p_42962 rs4021xsp_64561 fs2500_64551 ds723p_64561 ds2422p_64561 dva3221_42218 ds1621xsp_42661 ds3615xs_42661 ds1621p_64551 sa3600_42661 rs1619xsp_42962 ds3622xsp_42661 ds723p_42661 ds2422p_42661 sa6400_42661 sa6400_64551 ds3622xsp_42218 rs3413xsp_42661 ds723p_42962 ds920p_64561 ds2422p_42962 dva3219_64561 rs1221p_42661 rs3413xsp_64561 dva1622_42962 rs3413xsp_42218 ds923p_64551 ds723p_64551 ds918p_64561 ds3617xs_64551 sa6400_42962 ds2422p_42218 rs4021xsp_64551 fs2500_42962 rs4021xsp_42962 zendofmodel ds3615xs_42962 ds2422p_64551 sa3600_42962 ds3617xs_42962 fs2500_42661 rs3618xs_42218 ds1520p_42218 rs4021xsp_42218 rs1221p_64551 ds3622xsp_64551 dva3219_42962 dva3219_42218 ds1520p_64551 ds3617xs_42661 ds1621xsp_42962 ds918p_64551 ds920p_42218 sa3400_42962 sa3400_64561 ds918p_42962 rs1619xsp_42661 rs3618xs_42661 rs3618xs_64561 ds1621xsp_64551 rs1221p_42962 ds3615xs_64561 dva3221_64561 ds920p_64551 dva1622_42661 ds1520p_42962 sa3600_64551 ds918p_42218 rs3621xsp_42962 ds720p_42962 ds1019p_42962 ds923p_42661 dva3219_42661 sa3400_42661 ds1621xsp_42218 ds3615xs_64551 ds923p_64561 ds3617xs_64561 sa3400_64551 rs3413xsp_42962 ds3615xs_42218 fs2500_64561 ds1621p_42962 dva3221_64551 ds1621xsp_64561 rs1221p_64561 ds1520p_42661 rs4021xsp_42661 ds3622xsp_64561 rs3621xsp_42661 ds720p_42661 ds1019p_42661 fs2500_42218 [#] ======================================================================================= Updating extension : all-modules contents for model : ds3622xsp_64561 [#] Checking runtime for required tools... [OK] [#] Updating ds3622xsp_64561 platforms extensions... [#] Downloading remote file https://raw.githubusercontent.com/pocopico/tcrp-addons/main/all-modules/releases/broadwellnk.json to /home/tc/redpill-load/custom/extensions/_ext_new_rcp.tmp_json ######################################################################################################################################################################################################## 100.0% [#] Filling-in newly downloaded recipe for extension all-modules platform ds3622xsp_64561 [#] Downloading remote file https://github.com/pocopico/redpill-modules/releases/latest/download/broadwellnk-4.4.180.tgz to /home/tc/redpill-load/custom/extensions/all-modules/ds3622xsp_64561/broadwellnk-4.4.180.tgz ######################################################################################################################################################################################################## 100.0% [#] Verifying /home/tc/redpill-load/custom/extensions/all-modules/ds3622xsp_64561/broadwellnk-4.4.180.tgz file... [OK] [#] Downloading remote file https://github.com/pocopico/redpill-modules/releases/latest/download/broadwellnk-4.4.302.tgz to /home/tc/redpill-load/custom/extensions/all-modules/ds3622xsp_64561/broadwellnk-4.4.302.tgz ######################################################################################################################################################################################################## 100.0% [#] Verifying /home/tc/redpill-load/custom/extensions/all-modules/ds3622xsp_64561/broadwellnk-4.4.302.tgz file... [OK] [#] Downloading remote file https://github.com/pocopico/redpill-modules/releases/latest/download/firmware.tgz to /home/tc/redpill-load/custom/extensions/all-modules/ds3622xsp_64561/firmware.tgz ######################################################################################################################################################################################################## 100.0% [#] Verifying /home/tc/redpill-load/custom/extensions/all-modules/ds3622xsp_64561/firmware.tgz file... [OK] [#] Downloading remote file https://raw.githubusercontent.com/pocopico/tcrp-addons/main/all-modules/src/install.sh to /home/tc/redpill-load/custom/extensions/all-modules/ds3622xsp_64561/install.sh ######################################################################################################################################################################################################## 100.0% [#] Verifying /home/tc/redpill-load/custom/extensions/all-modules/ds3622xsp_64561/install.sh file... [OK] [#] Downloading remote file https://raw.githubusercontent.com/pocopico/tcrp-addons/main/all-modules/auxfiles/kmod to /home/tc/redpill-load/custom/extensions/all-modules/ds3622xsp_64561/kmod ######################################################################################################################################################################################################## 100.0% [#] Verifying /home/tc/redpill-load/custom/extensions/all-modules/ds3622xsp_64561/kmod file... [OK] [#] Successfully processed recipe for extension all-modules platform ds3622xsp_64561 [#] Verifying /home/tc/redpill-load/custom/extensions/all-modules/ds3622xsp_64561/kmod file... [OK] Updating extension : eudev contents for model : ds3622xsp_64561 [#] Checking runtime for required tools... [OK] [#] Updating ds3622xsp_64561 platforms extensions... [#] Downloading remote file https://raw.githubusercontent.com/pocopico/tcrp-addons/main/eudev/recipes/universal.json to /home/tc/redpill-load/custom/extensions/_ext_new_rcp.tmp_json ######################################################################################################################################################################################################## 100.0% [#] Filling-in newly downloaded recipe for extension eudev platform ds3622xsp_64561 [#] Downloading remote file https://raw.githubusercontent.com/pocopico/tcrp-addons/master/eudev/releases/eudev.tgz to /home/tc/redpill-load/custom/extensions/eudev/ds3622xsp_64561/eudev.tgz ######################################################################################################################################################################################################## 100.0% [#] Verifying /home/tc/redpill-load/custom/extensions/eudev/ds3622xsp_64561/eudev.tgz file... [OK] [#] Downloading remote file https://raw.githubusercontent.com/pocopico/tcrp-addons/master/eudev/releases/install.sh to /home/tc/redpill-load/custom/extensions/eudev/ds3622xsp_64561/install.sh ######################################################################################################################################################################################################## 100.0% [#] Verifying /home/tc/redpill-load/custom/extensions/eudev/ds3622xsp_64561/install.sh file... [OK] [#] Successfully processed recipe for extension eudev platform ds3622xsp_64561 [#] Verifying /home/tc/redpill-load/custom/extensions/eudev/ds3622xsp_64561/install.sh file... [OK] Updating extension : disks contents for model : ds3622xsp_64561 [#] Checking runtime for required tools... [OK] [#] Updating ds3622xsp_64561 platforms extensions... [#] Downloading remote file https://raw.githubusercontent.com/pocopico/tcrp-addons/main/disks/recipes/universal.json to /home/tc/redpill-load/custom/extensions/_ext_new_rcp.tmp_json ######################################################################################################################################################################################################## 100.0% [#] Filling-in newly downloaded recipe for extension disks platform ds3622xsp_64561 [#] Downloading remote file https://raw.githubusercontent.com/pocopico/tcrp-addons/main/disks/releases/dtc to /home/tc/redpill-load/custom/extensions/disks/ds3622xsp_64561/dtc ######################################################################################################################################################################################################## 100.0% [#] Verifying /home/tc/redpill-load/custom/extensions/disks/ds3622xsp_64561/dtc file... [OK] [#] Downloading remote file https://raw.githubusercontent.com/pocopico/tcrp-addons/main/disks/releases/install.sh to /home/tc/redpill-load/custom/extensions/disks/ds3622xsp_64561/install.sh ######################################################################################################################################################################################################## 100.0% [#] Verifying /home/tc/redpill-load/custom/extensions/disks/ds3622xsp_64561/install.sh file... [OK] [#] Downloading remote file https://raw.githubusercontent.com/pocopico/tcrp-addons/main/disks/releases/readlink to /home/tc/redpill-load/custom/extensions/disks/ds3622xsp_64561/readlink ######################################################################################################################################################################################################## 100.0% [#] Verifying /home/tc/redpill-load/custom/extensions/disks/ds3622xsp_64561/readlink file... [OK] [#] Downloading remote file https://raw.githubusercontent.com/pocopico/tcrp-addons/main/disks/releases/sed to /home/tc/redpill-load/custom/extensions/disks/ds3622xsp_64561/sed ######################################################################################################################################################################################################## 100.0% [#] Verifying /home/tc/redpill-load/custom/extensions/disks/ds3622xsp_64561/sed file... [OK] [#] Successfully processed recipe for extension disks platform ds3622xsp_64561 [#] Verifying /home/tc/redpill-load/custom/extensions/disks/ds3622xsp_64561/sed file... [OK] Updating extension : misc contents for model : ds3622xsp_64561 [#] Checking runtime for required tools... [OK] [#] Updating ds3622xsp_64561 platforms extensions... [#] Downloading remote file https://raw.githubusercontent.com/pocopico/tcrp-addons/main/misc/recipes/universal.json to /home/tc/redpill-load/custom/extensions/_ext_new_rcp.tmp_json ######################################################################################################################################################################################################## 100.0% [#] Filling-in newly downloaded recipe for extension misc platform ds3622xsp_64561 [#] Downloading remote file https://raw.githubusercontent.com/pocopico/tcrp-addons/master/misc/releases/install-all.sh to /home/tc/redpill-load/custom/extensions/misc/ds3622xsp_64561/install-all.sh ######################################################################################################################################################################################################## 100.0% [#] Verifying /home/tc/redpill-load/custom/extensions/misc/ds3622xsp_64561/install-all.sh file... [OK] [#] Downloading remote file https://raw.githubusercontent.com/pocopico/tcrp-addons/master/misc/releases/ttyd.tar.gz to /home/tc/redpill-load/custom/extensions/misc/ds3622xsp_64561/ttyd.tar.gz ######################################################################################################################################################################################################## 100.0% [#] Verifying /home/tc/redpill-load/custom/extensions/misc/ds3622xsp_64561/ttyd.tar.gz file... [OK] [#] Unpacking files from /home/tc/redpill-load/custom/extensions/misc/ds3622xsp_64561/ttyd.tar.gz to /home/tc/redpill-load/custom/extensions/misc/ds3622xsp_64561/... [OK] [#] Downloading remote file https://raw.githubusercontent.com/pocopico/tcrp-addons/master/misc/releases/install_rd.sh to /home/tc/redpill-load/custom/extensions/misc/ds3622xsp_64561/install_rd.sh ######################################################################################################################################################################################################## 100.0% [#] Verifying /home/tc/redpill-load/custom/extensions/misc/ds3622xsp_64561/install_rd.sh file... [OK] [#] Downloading remote file https://raw.githubusercontent.com/pocopico/tcrp-addons/master/misc/releases/lrzsz.tar.gz to /home/tc/redpill-load/custom/extensions/misc/ds3622xsp_64561/lrzsz.tar.gz ######################################################################################################################################################################################################## 100.0% [#] Verifying /home/tc/redpill-load/custom/extensions/misc/ds3622xsp_64561/lrzsz.tar.gz file... [OK] [#] Unpacking files from /home/tc/redpill-load/custom/extensions/misc/ds3622xsp_64561/lrzsz.tar.gz to /home/tc/redpill-load/custom/extensions/misc/ds3622xsp_64561/... [OK] [#] Successfully processed recipe for extension misc platform ds3622xsp_64561 [#] Unpacking files from /home/tc/redpill-load/custom/extensions/misc/ds3622xsp_64561/lrzsz.tar.gz to /home/tc/redpill-load/custom/extensions/misc/ds3622xsp_64561/... [OK] [#] Checking runtime for required tools... [OK] [#] Updating extensions... [#] Checking runtime for required tools... [OK] [#] Adding new extension from https://github.com/pocopico/tcrp-addons/raw/main/boot-wait/rpext-index.json... [#] Downloading remote file https://github.com/pocopico/tcrp-addons/raw/main/boot-wait/rpext-index.json to /home/tc/redpill-load/custom/extensions/_new_ext_index.tmp_json ######################################################################################################################################################################################################## 100.0% [OK] [#] ========================================== thethorgroup.boot-wait ========================================== [#] Extension name: RedPill Bootwait [#] Description: Simple extension which stops the execution early waiting for the boot device to appear [#] To get help visit: https://github.com/RedPill-TTG/redpill-boot-wait [#] Extension preparer/packer: https://github.com/RedPill-TTG/redpill-boot-wait [#] Update URL: https://raw.githubusercontent.com/pocopico/tcrp-addons/main/boot-wait/rpext-index.json [#] Platforms supported: dva1622_64551 ds1621p_42218 sa6400_64561 rs3618xs_64551 rs3413xsp_64551 ds1019p_64551 dva3221_42661 ds3617xs_42218 ds1520p_64561 ds920p_42661 sa3600_64561 dva3221_42962 ds1019p_42218 ds918p_42661 ds3622xsp_42962 rs3618xs_42962 ds1621p_64561 dva1622_64561 ds920p_42962 dva3219_64551 ds1621p_42661 ds1019p_64561 ds923p_42962 rs4021xsp_64561 fs2500_64551 ds723p_64561 ds2422p_64561 dva3221_42218 ds1621xsp_42661 ds3615xs_42661 ds1621p_64551 sa3600_42661 ds3622xsp_42661 ds723p_42661 ds2422p_42661 sa6400_42661 sa6400_64551 ds3622xsp_42218 rs3413xsp_42661 ds723p_42962 ds920p_64561 ds2422p_42962 dva3219_64561 rs3413xsp_64561 dva1622_42962 rs3413xsp_42218 ds923p_64551 ds723p_64551 ds918p_64561 ds3617xs_64551 sa6400_42962 ds2422p_42218 rs4021xsp_64551 fs2500_42962 rs4021xsp_42962 zendofmodel ds3615xs_42962 ds2422p_64551 sa3600_42962 ds3617xs_42962 rs3618xs_42218 fs2500_42661 ds1520p_42218 rs4021xsp_42218 ds3622xsp_64551 dva3219_42962 dva3219_42218 ds1520p_64551 ds3617xs_42661 ds1621xsp_42962 ds918p_64551 ds920p_42218 ds918p_42962 rs3618xs_42661 rs3618xs_64561 ds1621xsp_64551 ds3615xs_64561 dva3221_64561 ds920p_64551 dva1622_42661 ds1520p_42962 sa3600_64551 ds918p_42218 ds1019p_42962 ds923p_42661 dva3219_42661 ds1621xsp_42218 ds3615xs_64551 ds923p_64561 ds3617xs_64561 rs3413xsp_42962 ds3615xs_42218 fs2500_64561 ds1621p_42962 dva3221_64551 ds1621xsp_64561 ds1520p_42661 rs4021xsp_42661 ds3622xsp_64561 ds1019p_42661 fs2500_42218 [#] ======================================================================================= [#] Checking runtime for required tools... [OK] [#] Updating all-modules extension... [#] Downloading remote file https://raw.githubusercontent.com/pocopico/tcrp-addons/main/all-modules/rpext-index.json to /home/tc/redpill-load/custom/extensions/_new_ext_index.tmp_json ######################################################################################################################################################################################################## 100.0% [#] Extension all-modules index is already up to date [#] Updating disks extension... [#] Downloading remote file https://raw.githubusercontent.com/pocopico/tcrp-addons/main/disks/rpext-index.json to /home/tc/redpill-load/custom/extensions/_new_ext_index.tmp_json ######################################################################################################################################################################################################## 100.0% [#] Extension disks index is already up to date [#] Updating eudev extension... [#] Downloading remote file https://raw.githubusercontent.com/pocopico/tcrp-addons/main/eudev/rpext-index.json to /home/tc/redpill-load/custom/extensions/_new_ext_index.tmp_json ######################################################################################################################################################################################################## 100.0% [#] Extension eudev index is already up to date [#] Updating misc extension... [#] Downloading remote file https://raw.githubusercontent.com/pocopico/tcrp-addons/main/misc/rpext-index.json to /home/tc/redpill-load/custom/extensions/_new_ext_index.tmp_json ######################################################################################################################################################################################################## 100.0% [#] Extension misc index is already up to date [#] Updating pocopico.hpsa extension... [#] Downloading remote file https://raw.githubusercontent.com/pocopico/rp-ext/master/hpsa/rpext-index.json to /home/tc/redpill-load/custom/extensions/_new_ext_index.tmp_json ######################################################################################################################################################################################################## 100.0% [#] Extension pocopico.hpsa index is already up to date [#] Updating pocopico.tg3 extension... [#] Downloading remote file https://raw.githubusercontent.com/pocopico/rp-ext/master/tg3/rpext-index.json to /home/tc/redpill-load/custom/extensions/_new_ext_index.tmp_json ######################################################################################################################################################################################################## 100.0% [#] Extension pocopico.tg3 index is already up to date [#] Updating thethorgroup.boot-wait extension... [#] Downloading remote file https://raw.githubusercontent.com/pocopico/tcrp-addons/main/boot-wait/rpext-index.json to /home/tc/redpill-load/custom/extensions/_new_ext_index.tmp_json ######################################################################################################################################################################################################## 100.0% [#] Extension thethorgroup.boot-wait index is already up to date [#] Updating thethorgroup.boot-wait extension... [OK] [#] Checking runtime for required tools... [OK] [#] Updating ds3622xsp_64561 platforms extensions... [#] Downloading remote file https://raw.githubusercontent.com/pocopico/tcrp-addons/main/all-modules/releases/broadwellnk.json to /home/tc/redpill-load/custom/extensions/_ext_new_rcp.tmp_json ######################################################################################################################################################################################################## 100.0% [#] Extension all-modules for ds3622xsp_64561 platform is already up to date [#] Downloading remote file https://raw.githubusercontent.com/pocopico/tcrp-addons/main/disks/recipes/universal.json to /home/tc/redpill-load/custom/extensions/_ext_new_rcp.tmp_json ######################################################################################################################################################################################################## 100.0% [#] Extension disks for ds3622xsp_64561 platform is already up to date [#] Downloading remote file https://raw.githubusercontent.com/pocopico/tcrp-addons/main/eudev/recipes/universal.json to /home/tc/redpill-load/custom/extensions/_ext_new_rcp.tmp_json ######################################################################################################################################################################################################## 100.0% [#] Extension eudev for ds3622xsp_64561 platform is already up to date [#] Downloading remote file https://raw.githubusercontent.com/pocopico/tcrp-addons/main/misc/recipes/universal.json to /home/tc/redpill-load/custom/extensions/_ext_new_rcp.tmp_json ######################################################################################################################################################################################################## 100.0% [#] Extension misc for ds3622xsp_64561 platform is already up to date [-] The extension pocopico.hpsa was found. However, the extension index has no recipe for ds3622xsp_64561 platform. It may not be [-] supported on that platform, or author didn't updated it for that platform yet. You can try running [-] "ext-manager.sh update" to refresh indexes for all extensions manually. Below are the currently known information about [-] the extension stored locally: [#] ========================================== pocopico.hpsa ========================================== [#] Extension name: hpsa [#] Description: Adds Support [#] To get help visit: <todo> [#] Extension preparer/packer: https://github.com/pocopico/rp-ext/tree/main/hpsa [#] Software author: https://github.com/pocopico [#] Update URL: https://raw.githubusercontent.com/pocopico/rp-ext/master/hpsa/rpext-index.json [#] Platforms supported: ds1621p_42218 ds1621p_42951 ds918p_41890 dva3221_42661 ds3617xs_42621 ds3617xs_42218 ds920p_42661 dva3221_42962 ds918p_42661 ds3622xsp_42962 ds3617xs_42951 dva1622_42218 dva1622_42621 ds920p_42962 ds1621p_42661 dva1622_42951 ds918p_25556 dva3221_42218 ds3615xs_42661 dva3221_42951 ds3622xsp_42661 ds2422p_42661 ds3622xsp_42218 ds2422p_42962 rs4021xsp_42621 dva1622_42962 ds2422p_42218 rs4021xsp_42962 dva3221_42621 ds3615xs_42962 ds3617xs_42962 ds3615xs_41222 ds920p_42951 rs4021xsp_42218 ds2422p_42951 ds918p_42621 ds3617xs_42661 ds3615xs_25556 ds920p_42218 rs4021xsp_42951 ds920p_42621 ds918p_42962 ds3615xs_42951 ds3622xsp_42951 dva1622_42661 ds918p_42218 ds2422p_42621 ds1621p_42621 ds3615xs_42621 ds3615xs_42218 ds1621p_42962 ds3622xsp_42621 rs4021xsp_42661 [#] ======================================================================================= [-] Failed to update recipe for pocopico.hpsa extension for platform ds3622xsp_64561. The script will terminate as you do not [-] have previously downloaded recipe which can be used if download fails. Try again later. If problem [-] persists contact the extension packer for support (displayed below) [#] ========================================== pocopico.hpsa ========================================== [#] Extension name: hpsa [#] Description: Adds Support [#] To get help visit: <todo> [#] Extension preparer/packer: https://github.com/pocopico/rp-ext/tree/main/hpsa [#] Software author: https://github.com/pocopico [#] Update URL: https://raw.githubusercontent.com/pocopico/rp-ext/master/hpsa/rpext-index.json [#] Platforms supported: ds1621p_42218 ds1621p_42951 ds918p_41890 dva3221_42661 ds3617xs_42621 ds3617xs_42218 ds920p_42661 dva3221_42962 ds918p_42661 ds3622xsp_42962 ds3617xs_42951 dva1622_42218 dva1622_42621 ds920p_42962 ds1621p_42661 dva1622_42951 ds918p_25556 dva3221_42218 ds3615xs_42661 dva3221_42951 ds3622xsp_42661 ds2422p_42661 ds3622xsp_42218 ds2422p_42962 rs4021xsp_42621 dva1622_42962 ds2422p_42218 rs4021xsp_42962 dva3221_42621 ds3615xs_42962 ds3617xs_42962 ds3615xs_41222 ds920p_42951 rs4021xsp_42218 ds2422p_42951 ds918p_42621 ds3617xs_42661 ds3615xs_25556 ds920p_42218 rs4021xsp_42951 ds920p_42621 ds918p_42962 ds3615xs_42951 ds3622xsp_42951 dva1622_42661 ds918p_42218 ds2422p_42621 ds1621p_42621 ds3615xs_42621 ds3615xs_42218 ds1621p_42962 ds3622xsp_42621 rs4021xsp_42661 [#] ======================================================================================= [!] Cannot continue due to previous errors (see above) *** Process will exit *** [!] Failed to update all extensions for ds3622xsp_64561 platform - see errors above *** Process will exit *** FAILED : Loader creation failed check the output for any errors Quote Link to comment Share on other sites More sharing options...
pocopico Posted Thursday at 06:25 AM Author Share #4689 Posted Thursday at 06:25 AM (edited) 9 hours ago, olegL said: Hello. I'm trying to build a loader for version 7.2.0-64561. I used the latest version of tinycore-redpill.v0.9.4.6. I am getting an errors: The extension pocopico.r8101 was found. However, the extension index has no recipe for ds3622xsp_64561 platform. and Failed to update recipe for pocopico.r8101 extension for platform ds3622xsp_64561. Cannot continue due to previous errors (see above) *** Process will exit *** [!] Failed to update all extensions for ds3622xsp_64561 platform - see errors above What could be the problem? Previously, version 7.1.1-42962 successfully worked on this hardware (Pentium G630T,Intel B75 Chipset ). full console LOG in attachment. error 7.2-64561.txt 47.04 kB · 1 download Can you try skipping the use of listmods and just run the build after that ? Also can you try using the HTML version of the builder by accessing your IP from a browser ? Same goes for you @extreen Edited Thursday at 06:26 AM by pocopico Quote Link to comment Share on other sites More sharing options...
pocopico Posted Thursday at 06:31 AM Author Share #4690 Posted Thursday at 06:31 AM 5 hours ago, ner0 said: I need some help figuring out why a VM with DSM shuts down as soon as I try to access the web interface (after DSM installation). Quick summary: Host: - CPU: Intel i7 3370K - Hypervisor: VMware Workstation 16.x Guest: - 8 GB RAM; - 1 CPU, 4 cores; - 1 SATA HDD with TCRP image (tinycore-redpill.v0.9.4.6.vmdk); - 1 SATA HDD with 25GB (for DSM); - 1 Ethernet adapter, bridge mode (tried e1000, e1000e, vmxnet3); I tried 2 models (DS920+ and DS3622xs+), using DSM v7.1.1 build 42962; tried the usual manual route from SSH and also using the HTML builder. In both cases I can start the installation fine, but it is suspiciously quick in my opinion; goes from 0% to 8%, then after 5 seconds jumps to 40%, 55%, 56%, 57%, 58%, 59%, and restarts leaving the browser with a 10min. countdown. After restarting, whenever I try to load DSM web page I immediately get a 502 error - white page with Synology logo and the message "Sorry, the page you are looking for is not found." and then the VM just shuts down after 3 seconds. Note: After "installing", on next boot friend reports "Ramdisk upgrade has been detected zImage upgrade has been detected". I did have some other minor issues before this but was able to find information that pointed me in teh right direction, but this one has me completely stumped, especially due to the lack of verbosity (afaik). Can this be due to the nature of the platform combination with VM and TCRP support for those being shaky/recent? Do I need to include any special module during the build? I am unsure if there is something that I'm doing wrong here, I've only ever installed on baremetal but this time I'm trying to use virtual for testing purposes. I'd be glad to provide more details or logging info if anyone cares to help out. Anyway, appreciate any help I can get. Thanks. test.mp4 If you want to build a pre 7.2 version it would be better to try v9.4.4 without updating the rploader.sh 1 Quote Link to comment Share on other sites More sharing options...
extreen Posted Thursday at 06:41 AM Share #4691 Posted Thursday at 06:41 AM 10 минут назад, pocopico сказал: Можете ли вы попробовать отказаться от использования listmods и просто запустить сборку после этого? Также можете ли вы попробовать использовать HTML-версию конструктора, получив доступ к своему IP-адресу из браузера? То же самое касается и вас @extreen I follow the standard instructions as described everywhere (version ds3622xsp-7.1.1-42951). I get an error: Could not determine if file //mnt/sda3/auxfiles/ds3622xsp_42951.pat is encrypted or not, maybe corrupted the assembly is interrupted I follow the standard instructions as described everywhere (version ds3622xsp-7.2.0-64561). It is going, but I get an error for the absence of hard drives. ./rploader.sh update now ./rploader.sh fullupgrade now ./rploader.sh identifyusb now ./rploader.sh satamap now ./rploader.sh serialgen DS3622xs+ realmac ./rploader.sh build ds3622xsp-7.1.1-42951 ./rploader.sh backup exitcheck.sh reboot Цитата tc@box:~$ ./rploader.sh update now Checking Internet Access -> OK Checking if a newer version exists on the main repo -> Version is current tc@box:~$ ./rploader.sh fullupgrade now Performing a full TCRP upgrade Cloning into 'tinycore-redpill'... remote: Enumerating objects: 1083, done. remote: Counting objects: 100% (1083/1083), done. remote: Compressing objects: 100% (875/875), done. remote: Total 1083 (delta 207), reused 1037 (delta 193), pack-reused 0 Receiving objects: 100% (1083/1083), 15.91 MiB | 4.10 MiB/s, done. Resolving deltas: 100% (207/207), done. Please make sure you are using the latest 1GB img before using backup option Current /home/tc size is 44M , try to keep it less than 1GB as it might not fit into your image Should i update the sda with your current files [Yy/Nn] y Backing up home files to sda : Backing up files to /mnt/sda3//mydata.tgz Done. tc@box:~$ ./rploader.sh identifyusb now Found JetFlash Mass SerialNumber: PFYPE08R Vendor ID : 0x8564 Product ID : 0x1000 Should i update the user_config.json with these values ? [Yy/Nn] y tc@box:~$ ./rploader.sh build ds3622xsp-7.1.1-42951 bspatch does not exist, bringing over from repo % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 100 10232 100 10232 0 0 21957 0 --:--:-- --:--:-- --:--:-- 21957 Rploader Version : 0.9.4.6 Loader source : https://github.com/pocopico/redpill-load.git Loader Branch : develop Redpill module source : https://github.com/pocopico/redpill-lkm.git : Redpill module branch : master Extensions : all-modules eudev disks misc Extensions URL : "https://github.com/pocopico/tcrp-addons/raw/main/all-modules/rpext-index.json", "https://github.com/pocopico/tcrp-addons/raw/main/eudev/rpext-index.json", "https://github.com/pocopico/tcrp-addons/raw/main/disks/rpext-index.json", "https://github.com/pocopico/tcrp-addons/raw/main/misc/rpext-index.json" TOOLKIT_URL : https://sourceforge.net/projects/dsgpl/files/toolkit/DSM7.0/ds.broadwellnk-7.0.dev.txz/download TOOLKIT_SHA : 0d9edca67d9e7e14c2529bbb58341b623936124d5264f71f1e4acbacf3ea202d SYNOKERNEL_URL : https://sourceforge.net/projects/dsgpl/files/Synology NAS GPL Source/25426branch/broadwellnk-source/linux-4.4.x.txz/download SYNOKERNEL_SHA : d3e85eb80f16a83244fcae6016ab6783cd8ac55e3af2b4240455261396e1e1be COMPILE_METHOD : toolkit_dev TARGET_PLATFORM : ds3622xsp TARGET_VERSION : 7.1.1 TARGET_REVISION : 42951 REDPILL_LKM_MAKE_TARGET : dev-v7 KERNEL_MAJOR : 4 MODULE_ALIAS_FILE : modules.alias.4.json SYNOMODEL : ds3622xsp_42951 MODEL : DS3622xs+ Local Cache Folder : /mnt/sda3/auxfiles DATE Internet : 25052023 Local : 25052023 Checking Internet Access -> OK Checking if a newer version exists on the main repo -> Version is current Cloning into 'redpill-lkm'... remote: Enumerating objects: 1649, done. remote: Counting objects: 100% (1649/1649), done. remote: Compressing objects: 100% (620/620), done. remote: Total 1649 (delta 1016), reused 1579 (delta 996), pack-reused 0 Receiving objects: 100% (1649/1649), 5.81 MiB | 2.09 MiB/s, done. Resolving deltas: 100% (1016/1016), done. Cloning into 'redpill-load'... remote: Enumerating objects: 3775, done. remote: Counting objects: 100% (610/610), done. remote: Compressing objects: 100% (315/315), done. remote: Total 3775 (delta 333), reused 563 (delta 289), pack-reused 3165 Receiving objects: 100% (3775/3775), 121.64 MiB | 921.00 KiB/s, done. Resolving deltas: 100% (1884/1884), done. No extra build option or static specified, using default <static> Using static compiled redpill extension Removing any old redpill.ko modules Looking for redpill for : ds3622xsp_42951 Getting file https://raw.githubusercontent.com/pocopico/rp-ext/master/redpillprod/releases/redpill-4.4.180plus-broadwellnk.tgz Extracting module Getting file https://raw.githubusercontent.com/pocopico/rp-ext/master/redpillprod/src/check-redpill.sh Got redpill-linux-v4.4.180+.ko Starting loader creation Found tinycore cache folder, linking to home/tc/custom-module Checking user_config.json : Done Entering redpill-load directory Removing bundled exts directories Cache directory OK Found build request for revision greater than 42218 Downloading extractor v2 % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 100 389M 100 389M 0 0 7255k 0 0:00:54 0:00:54 --:--:-- 7972k Creating temp folder /tmp/pat Checking for cached pat file Found tinycore cache folder, linking to home/tc/custom-module Could not find pat file locally cached Configdir : /home/tc/redpill-load/config/DS3622xs+/7.1.1-42951 Configfile: /home/tc/redpill-load/config/DS3622xs+/7.1.1-42951/config.json Pat URL : https://global.download.synology.com/download/DSM/release/7.1.1/42951/DSM_DS3622xs%2B_42951.pat Downloading pat file from URL : https://global.download.synology.com/download/DSM/release/7.1.1/42951/DSM_DS3622xs%2B_42951.pat % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 100 3322 100 3322 0 0 1244 0 0:00:02 0:00:02 --:--:-- 1244 Could not determine if file //mnt/sda3/auxfiles/ds3622xsp_42951.pat is encrypted or not, maybe corrupted -rwxrwxrwx 1 root root 3322 May 25 06:22 //mnt/sda3/auxfiles/ds3622xsp_42951.pat 041 Quote Link to comment Share on other sites More sharing options...
olegL Posted Thursday at 06:23 PM Share #4692 Posted Thursday at 06:23 PM 11 часов назад, pocopico сказал: Can you try skipping the use of listmods and just run the build after that ? Also can you try using the HTML version of the builder by accessing your IP from a browser ? I had no idea that I could use a browser. Yes, it worked through the browser. I ran version 7.2. Thank you! 1 Quote Link to comment Share on other sites More sharing options...
ner0 Posted Thursday at 06:23 PM Share #4693 Posted Thursday at 06:23 PM 11 hours ago, pocopico said: If you want to build a pre 7.2 version it would be better to try v9.4.4 without updating the rploader.sh While this doesn't seem to have made it better or worse, I've build and installed about 15 instances in the past 2 hours and only a couple did not go through completely for unrelated reasons. I seem to be doing exactly the same things I did yesterday, but today almost everything is installing flawlessly. One issue I had was TCRP Friend presenting one IP address on screen while DSM was actually using another. This is not really a failure, but at least could constitute a bug. Here's a screenshot of that: The second issue I had was actually a bad cmdline in the loader, which happened to be built through HTML Builder (although most worked fine), here's a screenshot: Anyway, I don't know how or why I kept banging my head and having the VM always shutdown, today it hasn't happened once so everything seems to be working fine. Thank you! 1 Quote Link to comment Share on other sites More sharing options...
pocopico Posted Thursday at 06:35 PM Author Share #4694 Posted Thursday at 06:35 PM 10 minutes ago, ner0 said: While this doesn't seem to have made it better or worse, I've build and installed about 15 instances in the past 2 hours and only a couple did not go through completely for unrelated reasons. I seem to be doing exactly the same things I did yesterday, but today almost everything is installing flawlessly. One issue I had was TCRP Friend presenting one IP address on screen while DSM was actually using another. This is not really a failure, but at least could constitute a bug. Here's a screenshot of that: The second issue I had was actually a bad cmdline in the loader, which happened to be built through HTML Builder (although most worked fine), here's a screenshot: Anyway, I don't know how or why I kept banging my head and having the VM always shutdown, today it hasn't happened once so everything seems to be working fine. Thank you! If you can remember which versions and platforms you've tested it would help a lot with narrowing my testing scope Quote Link to comment Share on other sites More sharing options...
ner0 Posted Thursday at 06:36 PM Share #4695 Posted Thursday at 06:36 PM Just now, pocopico said: If you can remember which versions and platforms you've tested it would help a lot with narrowing my testing scope Only the 2 mentioned in my initial comment: 17 hours ago, ner0 said: I tried 2 models (DS920+ and DS3622xs+), using DSM v7.1.1 build 42962 Quote Link to comment Share on other sites More sharing options...
pocopico Posted Thursday at 06:37 PM Author Share #4696 Posted Thursday at 06:37 PM 12 minutes ago, olegL said: I had no idea that I could use a browser. Yes, it worked through the browser. I ran version 7.2. Thank you! I havent announce it yet , i was waiting for most issues to be fixed, but at the moment it looks that most issues have been fixed. Quote Link to comment Share on other sites More sharing options...
ner0 Posted Thursday at 06:44 PM Share #4697 Posted Thursday at 06:44 PM (edited) 22 minutes ago, ner0 said: The second issue I had was actually a bad cmdline in the loader, which happened to be built through HTML Builder This has happened a second time now. Things that might be of note: - Target model and DSM: DS920+ & DSM v7.1.1 build 42962 - Build process failed to start the first time with a config corrupt message, says to reset model - I select the model and version again, and I also insert custom MAC (Synology, but different than the generated) - Build process doesn't seem to present errors, although I did not save the log. After restarting, once again the boot fails with cmdline parameter cuting after dom_szmax=1024 NOTE: Custom MAC appears to have been ignored Edited Thursday at 06:47 PM by ner0 Quote Link to comment Share on other sites More sharing options...
marchidaniele Posted Friday at 01:45 PM Share #4698 Posted Friday at 01:45 PM On 5/20/2023 at 9:22 AM, marchidaniele said: Hi all, I have a problem with disk recognition. This is my scenario: I have a 2U server rack with 12bay connected to an LSI 3008 controller. VMware ESXi 7.0.3 is installed in the server. DSM is installed in a virtual machine with the LSI controller in passthrough. I followed this guide: https://xpenology.com/forum/topic/62547-tutorial-install-dsm-7x-with-tinycore-redpill-tcrp-loader-on-esxi/ So I have 2 SATA controllers and the LSI 3008 controller where the physical disks are connected. At the moment I have only 3 disks connected (/dev/sdn, /dev/sdo and /dev/sdp) and they are recognized. If I add a disk (can I do it hotplug?) I see it via shell ssh, but DSM does not see it. In my case I added a WD red 3TB disk as a test and the system recognizes it as /dev/sdq root@NAStore:~# fdisk -l |grep /dev/sd Disk /dev/sda: 21 GiB, 22548578304 bytes, 44040192 sectors /dev/sda1 8192 16785407 16777216 8G fd Linux raid autodetect /dev/sda2 16785408 20979711 4194304 2G fd Linux raid autodetect Disk /dev/sdn: 14.6 TiB, 16000900661248 bytes, 31251759104 sectors /dev/sdn1 8192 16785407 16777216 8G Linux RAID /dev/sdn2 16785408 20979711 4194304 2G Linux RAID /dev/sdn3 21241856 31251554303 31230312448 14.6T Linux RAID Disk /dev/sdo: 14.6 TiB, 16000900661248 bytes, 31251759104 sectors /dev/sdo1 8192 16785407 16777216 8G Linux RAID /dev/sdo2 16785408 20979711 4194304 2G Linux RAID /dev/sdo3 21241856 31251554303 31230312448 14.6T Linux RAID Disk /dev/sdp: 14.6 TiB, 16000900661248 bytes, 31251759104 sectors /dev/sdp1 8192 16785407 16777216 8G Linux RAID /dev/sdp2 16785408 20979711 4194304 2G Linux RAID /dev/sdp3 21241856 31251554303 31230312448 14.6T Linux RAID Disk /dev/sdq: 2.7 TiB, 3000592982016 bytes, 5860533168 sectors Question: why do the unit letters of the LSI controller start from sdn for me? What did I do wrong? At this moment I have install DSM 7.1.1-42962 Update 5 with TCRP 0.9.4.4 Can you help me out so I can see the other disks (potentially 9 more of 12 supported by the server)? Thanks For solve my problem I have edit grub at start of bootloader. I have tried various values of: - DiskIdxMap=000001 (for 3 controller) or 1E1F00 with maxdisks=16 - SataPortMap=118 or 11@ (suggested by ./rploader) the problem now is that I can't get the disks to start from position 1, but they always start common from position 3. Question: the LSI controller is seen by DSM as SCSI, should I add the sas parameter to the grub? What values should I use to get the 16TB disks started from sda? Another question of questions: how do I change the parameters of the user_config file into TinyRed without redoing the build? Thanks Quote Link to comment Share on other sites More sharing options...
Kaneske Posted Friday at 02:38 PM Share #4699 Posted Friday at 02:38 PM (edited) For me once 188 0C0008 worked for Two LSI HBA, since I am on ARPL now it just works without Mapping them separately, I think 1 00 is the Value in SataPortConfig and DiskIdxMap @AuxXxilium could give more info about mapping HBA in RedPill Edited Friday at 02:38 PM by Kaneske Quote Link to comment Share on other sites More sharing options...
marchidaniele Posted Friday at 03:14 PM Share #4700 Posted Friday at 03:14 PM My platform is VMware. 1st controller SATA with disk on loader 0:0 2nd controller SATA with 1 disk 21GB per DSM 1:0 3rd controller passthrough LSI 3008 with disks Add SasPortConfig parameter on boot? With which values? Quote Link to comment Share on other sites More sharing options...
