TinyCore RedPill Loader (TCRP)
pocopico
1 hour ago, WiteWulf said:
@J3d1UK it's an extra invocation of rploader before you build, eg:
(this is the example held within the rploader script itself)
Just run rploader.sh with no arguments to see the help, it'll show you the syntax for adding, removing and listing mods
In the above example "ext" specifies you're doing something with extensions (drivers mostly, but there's other stuff supported but this method)), followed by the target platform (apollolake-7.0.1-42218 in this case), then "add" (you're adding an extension) and finally the URI of the json file for the extension.
You'd probably want something more like the following (I'm not guaranteeing this will work, please check it an adapt it to your own needs):
Hi Mate,
Cheers for the reply, yep, added that manually a few days ago (although it had already added and built it in - hence why it was working correctly when creating a hardware RAID in the BIOS) It appears whatever version of the HPSA driver is being added via the pocopico repository isn't suitable for the P840AR controller on a 3622xs-7.1.1-42962  sadly, as soon as it gets to installing the PAT it simply crashes the card (when in HBA mode).  I can only presume the DS3615xs image build is using an older version of this driver? - Again, works fine with that one!
EDIT: Just tried an older version of DSM DS3622xs-7.0.1-42218 - Installs fine.....so its the recent images that are broken (for me)
So the question is - What is different between 7.0.1 and 7.1.1 images that are being built...
Edited by J3d1UK
Does baremetal based on ds3622xs+ not support intel quicksync for HW video transcoding(for plex)?
EDIT: ignore. guess i found the answer on the DSM 7 loaders page, theres a table there that shows this model not support intel quicksync.
A follow up question. Can quicksync support be enabled in the ds3622 model somehow?
Edited by alirz1
Short answer is no unfortunately.
Hi All,
SLOW TRANSFER SPEEDS
Trying to transfer my data from my old NAS (HP Microserver Gen 8 - Baremetal)  to my New NAS (HP DL380 G9 12 Bay LFF - ESXI).
Both have the same 10GBE X520-T2 card in them (aswell as the built in cards), patch cable between them, have them both running a DS3622xs 7.1.1-42962 image.
I have set the IP addresses on a different range for both X520-T2 cards within Synology (192.168.5.x)
Mounted a virtual folder in the new NAS from the old on in Filestation using CIFS (\\192.168.1.x\Backupfolder)
When i try and transfer from the Mounted folder to the new folder in diskstation to migrate the data (by dragging and dropping) I get an initial transfer speed of 160MB/s - after around 3-4 minutes that then drops to 60 mb/s (ish).
I have enabled MTU 9000 on both network cards in DSM (and also i in ESXI for the virtual card) - link speed showing at 10000mbps as it should, jumbo packets enabled.
I have around 20TB to transfer so this isn't acceptable - any ideas? - I cannot run both machine as baremetal sadly as the DS3622xs image simply kernel panicks the P840AR HBA when trying to instal the .pat (thats why ive had to settle for virtual)
@J3d1UK I honestly don't know why it's working inconsistently between DSM versions for you. However, you may have more success asking outside of the TCRP thread. While you're *using* TCRP as your boot loader, I'm not convinced it's completely to blame for your problem. Post a detailed description of your problem in General Installation subforum and you may get more eyes, including people who have similar hardware.
Nobody answers any questions outside of the thread, i've tried before when i first ever installed Juns loader on a Microserver N54L and then a Microserver Gen 8, and I did that here 2 days ago https://xpenology.com/forum/topic/65689-ds3622xs-image-crashes-hp-dl380-gen9-p840ar-hba/- It seems nobody can / will help - They appear to be concentrating on getting the menus looking nicer...or adding a new way of doing exactly the same job that's already available but called something slightly different, or a different .sh version of it (Which is fine, its their own time and they are helping most people).  For clarity - The server has run for many years perfectly at work (For MUCH more intensive things)- in an ESXI environment, and is running now in ESXI perfectly, the drives have all been checked as perfect, and its happily running now - its the kernel / driver....and compatibility with the server hardware I would imagine (I can recreate the problem on another server with the same spec, processor, More RAM but using a P440ar RAID card and 24 x SFF drive bays - I'm lucky enough to have both, free from work)but given I'm using proper server grade hardware and not some cobbled together 20 year old parts which most people wont have access to - I would imagine its not an easy problem to fix or diagnose.
So, to confirm, its doesn't work on 2 different DL380 Gen9 Servers, with slightly different RAID cards and different drives - Both work with RAID enabled and singular RAID 0 created for each drive, both Kernel panic when HBA mode is enabled and you install the .pat file after loader creation.
The fact it works fine on the 3615xs "End of life image" means something has been changed in the newer images (3622xs+) and not changed in the 3615xs - Sadly i'm just not intellegent enough to know what that is or how i would go about rectifying it!
Edited by J3d1UK
3 hours ago, J3d1UK said:
Hi All,
Try doing  doing the copy using rsync?
35 minutes ago, J3d1UK said:
Sadly not, same outcome - great suggestion that I had not tried however, so I appreciate the suggestion.
Its possible your issues are with the RAID card drivers. For what its worth, i have two generic baremetal xpenology units, regular intel i3, 4GB ram, both running TCRP and on DSM 7.1.x DSM. I sync them using rsync and i dont seem to have any issues with speed. They are on gigabit LAN and rsync easily mantains the 100-120MBMB/s betweent he two units.
Im not too familiar with HW raid cards. But is it possible to not use the HW raid and just use synology's software raid for the drives?
Sadly not, the kernel for 3622xs crashes the Raid card when in HBA mode - but you are probably onto something - this project certainly doesnt seem to like my hardware (edit:  Ive just tried ubuntu booted from USB on the microserver to to a ubuntu boot CD mounted in esxi and all was very speedy and stable, so more than likely xpenology again sadly - its appears to hate me)
I guess another way you could test is, if you have two usb3 external drives or usb3 flash drives. You can plug and mount one on each server within dsm and then do a file copy between the usb drives. This would bypass the raid drives but you would still be within dsm/xpenology and verify if transfer speeds are limited by the loader. Just a thought.
8 hours ago, altas said:
@J3d1UK
i had similar issue with my HP GEN9 DL160 and
P440 RaidCard.. i switched back to ESXI Host on the DL160.
and i noticed the same Speed Issue as i started to transfer the Data.
as i use this as only Storage System and not Productiv its OK for me
Yep, it does seem to be a limitation sadly, Looks like I will just set up rsync and wait a long time for the data to sync / copy over from one to the other - OR finally take the plunge into a supported system, sadly as time has gone on it appears Xpenology isnt feasible anymore given the amount of little problems that appear, which is a shame as I love the Synology Surveillance station and how it integrates with Home assistant.
I contemplated this but the USB drives I have, in ideal situations transfer at around 80mb/s MAX so wouldnt really show any meaningful information - I do have a couple of spare nvme drives I could try with, but I would imagine that those are nigh on impossible to get working with Xpenology.
Good Evening.
I have loaded up an ESXI7 vm with tinycore, followed the guides etc and got it to the point where its loaded and detects my 100gb virtual hard disk on sata 1:0 but after i install it reboots and then it tells me ive moved my drives and asks to recover and at that point its in a loop, everytime i reboot it asks to recover.
Does anyone know how to get past this point??
Thanks.
