TinyCore RedPill Loader (TCRP)
pocopico
On 6/3/2022 at 12:06 PM, pocopico said:
No need to recreate the loader. It will be a two stage update process.
First update to update2 from DSM GUI
Second boot into TCRP and run
./rploader.sh update now
./rploader.sh fullupgrade now
./rploader.sh backup
./rploader.sh postupdate <yourplatform>
Thanks,
I followed your instruction and successfully updated my DSM.
I have a question about update, two times I pressed "Y" and I had a one command "permission denied"
The new smallupdate version will be  : 7.1-42661-2
Do you want to use this for the loader ? [yY/nN] : y
Recreating ramdisk
cpio: ./etc/shadow: Cannot open: Permission denied
52183 blocks
Adding fake sign
1+0 records in
1+0 records out
68 bytes copied, 3.2531e-05 s, 2.1 MB/s
Putting ramdisk back to the loader partition sdc1
Removing temp ramdisk space
Done
Saving user session for future use. Saving current extensions  -> OK !
Saving current user_config.json  -> OK !
tc@box:~$ sudo reboot
tc@box:~$
Do I need to worry about this?
And second question during the boot I still have GRUB screen with:
RedPill DS3622xs v7.1.0-42661 Beta (USB Verbose)
Is it possible to remove the name "beta"?
Thank you for your support.
1 hour ago, MajkelP said:
Thanks,
Recreating ramdisk
52183 blocks
Adding fake sign
1+0 records in
1+0 records out
Done
tc@box:~$
When you are in that screen you can press "e" and change the grub file.
10 hours ago, flyride said:
You can force a DSM reinstall but retain Storage Pools and Volumes with synodsdefault --reinstall
This can be executed from junior mode shell (serial console).
https://xpenology.com/forum/topic/9392-general-faq/?do=findComment&comment=89619
This will lose all system settings but not data.  If you have a dss backup most of it can be restored.
I don't know how to make it just do a patch.
So for today I went the "easy route":
- I made a backup from the TCRP before testing to build a new loader without the typo in the loader-script.
- I attached the backup as SATA0:0 on my VM.
- DSM boots fine for now into 7.1 U2 (of course with the error on the 2.nd NIC and some error messages at boot, but this wont hurt for now).
- So I am able to make a full backup now. :-)
I will work on this issue again at the weekend if I got more time for this issue.
I remember some old information about boot and mounting e.g. an Linux Live ISO, mounting the 2.4 GByte-RAID1 where DSM is installed and change some files to be able to "simulate" an upgrade situation again. But I do not know what files to change exactly anymore...
In the worst case I can wipe the 2.4 Gbyte-RAID1 and make a full "new installation". But I will test this scenario first on another test-installation. :-)
I am back in business!! :D :D
In the end the solution was easy!
With the typo in the script rploader.sh the DiskIdxMap is not correct.
So the first time (with the typo) i got:
Computed settings:
SataPortMap=126
DiskIdxMap=000103
As I only have 1 VMDK (as a single virtual SSD) as data disk and 4 HDDs on the physical internal SATA-Controller of the Microserver Gen8 this even works and I was able to do the upgrade from DSM 6.2U3 to DSM 7.1.
The step where things went a little bit wrong were as I updated to DSM 7.1U2. I have to boot after the update into TCRP again and fire up:
sudo ./rploader.sh update
sudo ./rploader.sh postupdate broadwellnk-7.1.0-42661
exitcheck.sh reboot
Then I read about the type in rploader.sh and recognize my fault about the missing second NIC in the user_config.json.
I added the second NIC, repaired the rploader.sh and got this (new & correct) satamap in the end:
Computed settings:
SataPortMap=126
DiskIdxMap=100002
Then I compiled the loader again:
sudo ./rploader.sh clean
sudo ./rploader.sh fullupgrade
sudo ./rploader.sh listmods broadwellnk-7.1.0-42661
sudo ./rploader.sh build broadwellnk-7.1.0-42661
sudo ./rploader.sh backup
exitcheck.sh reboot
After the next reboot I got the page "Welcome back: Click here to migrate your diskstation".
And here is the trick:
- DO NOT JUST REBOOT into DSM after click on "Migrate"!
- Reboot again in TCRP and run (once again):
exitcheck.sh reboot
The "postupdate"-command will throw a lot of messages about a lot of existing files and folders. But in the end there will be the message:
Recreating ramdisk
52185 blocks
Adding fake sign
The next boot will be successfully and the NAS will be normal, stable and functional. :-)
So i learned: If a minor patch is installed on top of a major DSM-Release, one have to boot into TCRP again and run the "postupdate"-function again even after a "Migration" when changing e.g. the NIC-Settings and recreating the whole boot-loader.
I still have some error messages but I got these also on my other installations:
root@diskstation:~# systemctl list-units --state failed
  UNIT                           LOAD   ACTIVE SUB    DESCRIPTION
● syno-oob-check-status.service  loaded failed failed Out of Band Management Status Check
● synoindex-checkpackage.service loaded failed failed synoindex check if there are any synoindex-related packages
● SynoInitEth.service            loaded failed failed Adjust NIC sequence
LOAD   = Reflects whether the unit definition was properly loaded.
ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
SUB    = The low-level unit activation state, values depend on unit type.
3 loaded units listed. Pass --all to see loaded but inactive units, too.
To show all installed unit files use 'systemctl list-unit-files'.
Do someone knows if these failing services are important or irrelevant?
The NICs are running fine and I miss nothing and can't see anything which is not running correctly. :-)
Edited by Balrog
added informations
I have a question about the reboot. My box is running headless and since I closed my home lab, it's a bit of pain to move it to a monitor and give it a network connection.
Creating the loader and installing DSM is fine headless, but getting back to TCRP later needs a console to change the boot option.
Can anyone think of a straightforward way (I can only think of complicated) to change the next boot to TCRP without a console?
1 minute ago, Shogi said:
Hi@all
 I have successfully updated an HP N54L with DSM7.1.0-42661-2. Unfortunately the power button doesn't work yet. Could someone give me a tip?
You need the acpi extension. Look through flyride's tutorial for how to do it.
However, I didn't find it for DS3615xs and so I migrated to DS3622xs+
1 minute ago, billat29 said:
Sie benötigen die acpi-Erweiterung. Sehen Sie sich das Tutorial von flyride an, um zu erfahren, wie es geht.
Ich habe es jedoch nicht für DS3615xs gefunden und bin daher zu DS3622xs+ migriert
I also took the DS3622xs+. unfortunately I can't get any further
I did this.
./rploader.sh ext broadwellnk-7.1.0-42661 add https://github.com/jimmyGALLAND/redpill-ext/raw/master/acpid/rpext-index.json
3 minutes ago, billat29 said:
I did this.
I'll try it right away
Are the commands correct?
[DS3622xs+]
./rploader.sh serialgen DS3622xs+
./rploader.sh identifyusb now
./rploader.sh satamap now
./rploader.sh build broadwellnk-7.0.1-42218
./rploader.sh clean now
./rploader.sh clean now; rm -rf /mnt/sdb3/auxfiles; rm -rf /home/tc/custom-module; ./rploader.sh backup now;
after Update 7.1.0-42661-1
i followed the below steps as suggested:
downloaded from synology the 7.1.0-42661 update 2
then do manual update inside DSM
or am I doing something wrong?
I can't say for sure. I can make the following observations:
1. The parameter now is no longer required.
2. I used the realmac option for serialgen this enabled WOL for me.
3. I didn't do the intermediate 7.0.1 step or clean
4. I didn't do any step after the 7.1 build.
5. I didn't apply any update.
and.. can you post any follow up in the installation section? This doesn't really belong here.
Edited by billat29
I have some news about the failing services and how to disable them (mostly):
Since DSM 7.1, the system does not shutdown automatically after the time I setup under Hardware&Energy
WoL does work, but I think, the HDDs not going into sleeping mode.
Does someone has the same?
I am now on the latest 7.1 U2, it was working with 7.0.1
I use a second HP Server only for backup, and it always startet bevor the backup job and after that, it was shutting down.
Edited by mpuff
Hi, wrote some time ago for r8125 problem...
I aded r8125 to broadwellnk-7.0.1-42661
./rploader.sh ext broadwellnk-7.0.1-42661 add https://raw.githubusercontent.com/pocopico/rp-ext/master/r8125/rpext-index.json
and rebuilt the image:
It looks that you will need the following modules :
Found VGA Controller : pciid 8086d00000162  Required Extension : i915
Searching for matching extension for i915
Found SATA Controller : pciid 8086d00001c02  Required Extension : ahci
Searching for matching extension for ahci
Found Ethernet Interface : pciid 10ecd00008125 Required Extension :
No matching extension
[#] Checking runtime for required tools... [OK]
[#] Adding new extension from https://raw.githubusercontent.com/pocopico/rp-ext/master/r8169/rpext-index.json...
[#] Downloading remote file https://raw.githubusercontent.com/pocopico/rp-ext/master/r8169/rpext-index.json to /home/tc/redpill-load/custom/extensions/_new_ext_index.tmp_json
######################################################################## 100.0%
[OK]
[#] ========================================== pocopico.r8169 ==========================================
[#] Extension name: r8169
[#] Description: Adds RealTek RTL-8169 Gigabit Ethernet driver Support
[#] To get help visit: <todo>
[#] Extension preparer/packer: https://github.com/pocopico/rp-ext/tree/main/r8169
[#] Software author: https://github.com/pocopico
[#] Update URL: https://raw.githubusercontent.com/pocopico/rp-ext/master/r8169/rpext-index.json
[#] Platforms supported: ds1621p_42218 ds918p_41890 dva3221_42661 ds3617xs_42621 ds3617xs_42218 ds920p_42661 ds918p_42661 ds1621p_42661 ds918p_25556 dva3221_42218 ds3615xs_42661 ds3622xsp_42661 ds3622xsp_42218 dva3221_42621 ds3615xs_41222 ds918p_42621 ds3617xs_42661 ds3615xs_25556 ds920p_42218 ds920p_42621 ds918p_42218 ds1621p_42621 ds3615xs_42621 ds3615xs_42218 ds3622xsp_42621
Found Ethernet Interface : pciid 10ecd00008168 Required Extension : r8169
Searching for matching extension for r8169
Found matching extension :
"https://raw.githubusercontent.com/pocopico/rp-ext/master/r8169/rpext-index.json"
Starting loader creation
As tou can see in logs I have "No matching extension" for pciid 10ec00008125 (r8125 I suppose).
I also have a r8168 recognized as r8169 and it works.
Can someone help me with r8125, please?
Thanks!
Thanks!
You can manually add the extension
Hi there,
I currently have a DVA3221 which works perfectly, except for the shutdown button, which refuses to shut down the NAS.
I wanted to integrate "redpill-acpid" but the DVA3221 model is not included.
Citation
Could you help me please ?
Thanks a lot
Hello good morning, I get this error when I go to put the command:
"./rploader.sh build apollolake-7.1.0-42661" after I have done the commands: "./rploader.sh update now" , "./rploader.sh serialgen DS3622xs+ realmac"  , "./rploader.sh satamap now" , "./rploader.sh identifyusb now" . I attach screenshots, if you can help me, I've been struggling with this for days.
Can anyone help me getting the shutdown and reboot commands to work on Unraid? (qemu I believe).
I've tried the acpi addon but that didn't help. I'm still on 0.4.6 so I'm not sure what has changed and if it's worth upgrading?
I'm running the DS3617xs since that's the only one that wanted to boot at the time.
Le 14/06/2022 à 14:35, scfrancis a dit :
Hi there,
Thanks a lot
Hello everyone, anyone to help me?
@pocopico ?? 😊
