Peter Suh Posted May 12 Share #3301 Posted May 12 1 hour ago, PaulEvo said: Hello all, Hope someone can help me with the right DiskIdxMap and SataPortMap. I made a loader for a 3615xs and 3622xs+ and both show that no disks are found. TC suggests DiskIdxMap = 2 and SataPortMap = 22. The motherboard is an Asus P8H61-I-LX-R2 with an i5-2500. The codes for the drive controllers are 00:1f.2 (8086:1c00) and 00:1f.5 (8086:1c08). Tried a lot of combinations for the mapping, changed BIOS settings for sata like AHCI and IDE, but no luck. What can I do, any ideas ? Regards, Paul https://dlcdnets.asus.com/pub/ASUS/mb/LGA1155/P8H61-I_LX_R2.0/E7989_P8H61-I_LX_R2.pdf If you look at page 31 of this manual, it says that hot plug and ahci are possible. Be sure to enable both options. This will help with disk not being found related to sataportmap. 2 Quote Link to comment Share on other sites More sharing options...
LaBoss Posted May 12 Share #3302 Posted May 12 (edited) Hello i try to update to DSM 7.1 but i need redpill-virtio redpill-load if i try add ./rploader.sh ext broadwellnk-7.1.0-42661 add https://github.com/jumkey/redpill-load/raw/develop/redpill-virtio/rpext-index.json ./rploader.sh ext broadwellnk-7.1.0-42661 add https://github.com/jumkey/redpill-load/raw/develop/redpill-acpid/rpext-index.json and build with ./rploader.sh build broadwellnk-7.1.0-42661 got this error [#] Checking runtime for required tools... [OK] [#] Adding new extension from https://github.com/jumkey/redpill-load/raw/develop/redpill-acpid/rpext-index.json... [#] Downloading remote file https://github.com/jumkey/redpill-load/raw/develop/redpill-acpid/rpext-index.json to /home/tc/redpill-load/custom/extensions/_new_ext_index.tmp_json ########################################################################################################################################################################################## 100.0% [OK] [#] ========================================== jumkey.acpid2 ========================================== [#] Extension name: ACPI Daemon v2 [#] Description: ACPI Daemon v2 that handles power button events [#] To get help visit: https://github.com/jumkey/redpill-load/raw/develop/redpill-acpid [#] Extension preparer/packer: https://github.com/jumkey/redpill-load/raw/develop/redpill-acpid [#] Software author: https://sourceforge.net/projects/acpid2/ [#] Update URL: https://github.com/jumkey/redpill-load/raw/develop/redpill-acpid/rpext-index.json [#] Platforms supported: ds1621p_42218 ds918p_41890 ds3617xs_42218 ds920p_42661 ds918p_25556 ds3622xsp_42218 ds2422p_42218 ds3615xs_41222 ds3615xs_25556 ds920p_42218 ds918p_42218 ds3615xs_42218 [#] ======================================================================================= tc@box:~$ vi user_config.json [#] Extension thethorgroup.virtio index is already up to date [#] Updating thethorgroup.virtio extension... [OK] [#] Checking runtime for required tools... [OK] [#] Updating ds3622xsp_42661 platforms extensions... [-] The extension jumkey.acpid2 was found. However, the extension index has no recipe for ds3622xsp_42661 platform. It may not be [-] supported on that platform, or author didn't updated it for that platform yet. You can try running [-] "ext-manager.sh update" to refresh indexes for all extensions manually. Below are the currently known information about [-] the extension stored locally: [#] ========================================== jumkey.acpid2 ========================================== [#] Extension name: ACPI Daemon v2 [#] Description: ACPI Daemon v2 that handles power button events [#] To get help visit: https://github.com/jumkey/redpill-load/raw/develop/redpill-acpid [#] Extension preparer/packer: https://github.com/jumkey/redpill-load/raw/develop/redpill-acpid [#] Software author: https://sourceforge.net/projects/acpid2/ [#] Update URL: https://github.com/jumkey/redpill-load/raw/develop/redpill-acpid/rpext-index.json [#] Platforms supported: ds1621p_42218 ds918p_41890 ds3617xs_42218 ds920p_42661 ds918p_25556 ds3622xsp_42218 ds2422p_42218 ds3615xs_41222 ds3615xs_25556 ds920p_42218 ds918p_42218 ds3615xs_42218 [#] ======================================================================================= [-] Failed to update recipe for jumkey.acpid2 extension for platform ds3622xsp_42661. The script will terminate as you do not [-] have previously downloaded recipe which can be used if download fails. Try again later. If problem [-] persists contact the extension packer for support (displayed below) [#] ========================================== jumkey.acpid2 ========================================== [#] Extension name: ACPI Daemon v2 [#] Description: ACPI Daemon v2 that handles power button events [#] To get help visit: https://github.com/jumkey/redpill-load/raw/develop/redpill-acpid [#] Extension preparer/packer: https://github.com/jumkey/redpill-load/raw/develop/redpill-acpid [#] Software author: https://sourceforge.net/projects/acpid2/ [#] Update URL: https://github.com/jumkey/redpill-load/raw/develop/redpill-acpid/rpext-index.json [#] Platforms supported: ds1621p_42218 ds918p_41890 ds3617xs_42218 ds920p_42661 ds918p_25556 ds3622xsp_42218 ds2422p_42218 ds3615xs_41222 ds3615xs_25556 ds920p_42218 ds918p_42218 ds3615xs_42218 [#] ======================================================================================= [!] Cannot continue due to previous errors (see above) *** Process will exit *** [!] Failed to update all extensions for ds3622xsp_42661 platform - see errors above *** Process will exit *** FAILED : Loader creation failed check the output for any errors Edited May 12 by LaBoss Quote Link to comment Share on other sites More sharing options...
pocopico Posted May 12 Author Share #3303 Posted May 12 1 minute ago, LaBoss said: ./rploader.sh ext broadwellnk-7.1.0-42661 add https://github.com/jumkey/redpill-load/raw/develop/redpill-virtio/rpext-index.json ./rploader.sh ext broadwellnk-7.1.0-42661 add https://github.com/jumkey/redpill-load/raw/develop/redpill-acpid/rpext-index.json Change both to ./rploader.sh ext broadwellnk-7.1.0-42661 add https://github.com/pocopico/redpill-load/raw/develop/redpill-virtio/rpext-index.json ./rploader.sh ext broadwellnk-7.1.0-42661 add https://github.com/pocopico/redpill-load/raw/develop/redpill-acpid/rpext-index.json 2 Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted May 12 Share #3304 Posted May 12 10 minutes ago, PaulEvo said: Very learnful for me, thanks again for the information. Btw this board was a replacement for a Gigabyte GA-H87N-WIFI. This Gigabyte works well with DSM 7 but the bios get's corrupted every reboot. See below. It's on Proxmox now, working well but I preferred baremetal. I am currently using the same board. For now, it's XPE for backup, what exactly is the problem? It is very difficult to follow and read all those posts. Quote Link to comment Share on other sites More sharing options...
PaulEvo Posted May 12 Share #3305 Posted May 12 11 minutes ago, Peter Suh said: https://dlcdnets.asus.com/pub/ASUS/mb/LGA1155/P8H61-I_LX_R2.0/E7989_P8H61-I_LX_R2.pdf If you look at page 31 of this manual, it says that hot plug and ahci are possible. Be sure to enable both options. This will help with disk not being found related to sataportmap. Thanks Peter. Did a test after enabling hot plug but no luck yet. Will do some more tests with different mapping settings. Regards, Paul Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted May 12 Share #3306 Posted May 12 1 minute ago, PaulEvo said: Thanks Peter. Did a test after enabling hot plug but no luck yet. Will do some more tests with different mapping settings. Regards, Paul My favorite setup so far is to physically install only one disk in sata port 1 and set sataportmap=1 to succeed from dsm installation. After success, increase the disk and sataportmap. Have you tried this method? Quote Link to comment Share on other sites More sharing options...
nemesis122 Posted May 12 Share #3307 Posted May 12 Hi On a Gen8 i saw this also bios reset after reboot i can select user default and the bios will reset to user defaults Maybe you have also this setting on the other hand i have also en asush87iplus MB and there was sometimes a Bios Reset with MBR Loader 1.03 but with Redpill or Tinycore all is working fine thank you again pocopico 1 Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted May 12 Share #3308 Posted May 12 24 minutes ago, PaulEvo said: Very learnful for me, thanks again for the information. Btw this board was a replacement for a Gigabyte GA-H87N-WIFI. This Gigabyte works well with DSM 7 but the bios get's corrupted every reboot. See below. It's on Proxmox now, working well but I preferred baremetal. I searched all the way through that topic. The model mentioned in this topic is the GA-H87M-HD3. It is different from the model we have. Just because the models are similar, it cannot be concluded that the same phenomenon will occur. Quote Link to comment Share on other sites More sharing options...
PaulEvo Posted May 12 Share #3309 Posted May 12 6 minutes ago, Peter Suh said: I searched all the way through that topic. The model mentioned in this topic is the GA-H87M-HD3. It is different from the model we have. Just because the models are similar, it cannot be concluded that the same phenomenon will occur. Hello Peter, interesting, this bios reset was the only explanation I could think of. I tried a lot with this Gigabyte board. Reflash bios, replacement of the battery, different usb key. A different loader. Still at every reboot the system halted because of corruption. It's in Proxmox now and no problems at all. Do you have the same board running baremetal without this corruption issue at reboot? Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted May 12 Share #3310 Posted May 12 2 minutes ago, PaulEvo said: Hello Peter, interesting, this bios reset was the only explanation I could think of. I tried a lot with this Gigabyte board. Reflash bios, replacement of the battery, different usb key. A different loader. Still at every reboot the system halted because of corruption. It's in Proxmox now and no problems at all. Do you have the same board running baremetal without this corruption issue at reboot? I mentioned this in the post below today. The GA-H87N-WIFI has been my main XPE for a long time. It's a DS918+ that hasn't been updated to DSM7 yet, but one of the SHR disks installed in the HBA gets corrupted in the system partition very occasionally. I do not know the exact cause, but it seems that this phenomenon mainly occurs in low-cost ripper disks. Of course it's bare metal and there were no serious errors as you mentioned. 1 Quote Link to comment Share on other sites More sharing options...
PaulEvo Posted May 12 Share #3311 Posted May 12 7 minutes ago, Peter Suh said: I mentioned this in the post below today. The GA-H87N-WIFI has been my main XPE for a long time. It's a DS918+ that hasn't been updated to DSM7 yet, but one of the SHR disks installed in the HBA gets corrupted in the system partition very occasionally. I do not know the exact cause, but it seems that this phenomenon mainly occurs in low-cost ripper disks. Of course it's bare metal and there were no serious errors as you mentioned. Thanks for this clarification. Perhaps it's in my case related to the DSM7 loader. I didn't tests with DSM6 1 Quote Link to comment Share on other sites More sharing options...
Al lex Posted May 12 Share #3312 Posted May 12 On 5/11/2022 at 1:59 PM, Peter Suh said: @pocopico I'm sorry. I certainly didn't mention baremetal @Al lex, isn't that baremetal? The patch you mentioned is for VM only, right? I just built DS918+ using 0.7.0.7 version with HBA, and as captured, the problem I knew continues even now. Is it possible to repair the part of the HBA that can't find the uuid like in the log? junior log (Reveal hidden contents) DiskStation> cat linuxrc.syno.log START /linuxrc.syno.impl Insert basic USB modules... :: Loading module usb-common ... [ OK ] :: Loading module usbcore ... [ OK ] :: Loading module xhci-hcd ... [ OK ] :: Loading module xhci-pci ... [ OK ] :: Loading module usb-storage ... [ OK ] :: Loading kernel modules from extensions ... Loading kmod #0 "e1000e.ko" for pocopico.e1000e (args: ) Loading kmod #0 "raid_class.ko" for pocopico.mpt3sas (args: ) Loading kmod #1 "scsi_transport_sas.ko" for pocopico.mpt3sas (args: ) Loading kmod #2 "mpt3sas.ko" for pocopico.mpt3sas (args: ) :: Loading kernel modules from extensions ... [ OK ] :: Executing "on_boot" custom scripts ... Running "check-e1000e.sh" for pocopico.e1000e->on_boot Loading module e1000e -> Module e1000e loaded succesfully Ran "check-e1000e.sh" for pocopico.e1000e->on_boot - exit=0 Running "check-mpt3sas.sh" for pocopico.mpt3sas->on_boot Loading module mpt3sas -> Module mpt3sas loaded succesfully Ran "check-mpt3sas.sh" for pocopico.mpt3sas->on_boot - exit=0 Running "boot-wait.sh" for redpill-boot-wait->on_boot Still waiting for boot device (waited 1 of 30 seconds) Still waiting for boot device (waited 2 of 30 seconds) Still waiting for boot device (waited 3 of 30 seconds) Still waiting for boot device (waited 4 of 30 seconds) Still waiting for boot device (waited 5 of 30 seconds) Still waiting for boot device (waited 6 of 30 seconds) Confirmed a valid-looking /dev/synoboot device Ran "boot-wait.sh" for redpill-boot-wait->on_boot - exit=0 Running "install_rd.sh" for redpill-misc->on_boot Starting ttyd, listening on port: 7681 Ran "install_rd.sh" for redpill-misc->on_boot - exit=0 :: Executing "on_boot" custom scripts ... [ OK ] Extensions processed Insert net driver(Mindspeed only)... Starting /usr/syno/bin/synocfgen... /usr/syno/bin/synocfgen returns 0 Insert synorbd kernel module Insert synofsbd kernel module Insert sha256 kernel module Assemble args: -u 2051472f:f71136d6:3017a5a8:c86610be /dev/sda1 /dev/sde1 /dev/sdf1 mdadm: /dev/sde1 has wrong uuid. mdadm: /dev/sdf1 has wrong uuid. mdadm: /dev/md0 has been started with 1 drive (out of 16). Partition Version=9 /sbin/e2fsck exists, checking /dev/md0... e2fsck 1.44.1 (24-Mar-2018) /sbin/e2fsck -yvf returns 0 Mounting /dev/md0 /tmpRoot ------------upgrade Begin upgrade procedure Failed to found any patch No upgrade file found ============upgrade ------------bootup-smallupdate Failed to AssertFileKeyValueEqual value1: /etc.defaults/synoinfo.conf:unique -> synology_apollolake_918+ value2: /tmpRoot/etc.defaults/synoinfo.conf:unique => synology_v1000_1621+ Skip bootup smallupdate, because root is not matched to junior ============bootup-smallupdate Failed to AssertFileKeyValueEqual value1: /etc.defaults/synoinfo.conf:unique -> synology_apollolake_918+ value2: /tmpRoot/etc.defaults/synoinfo.conf:unique => synology_v1000_1621+ Exit on error [7] root not matched with junior... Wed May 11 11:43:42 UTC 2022 /dev/md0 /tmpRoot ext4 rw,relatime,data=ordered lrwxrwxrwx 1 root root 0 May 11 11:43 sda -> ../devices/pci0000:00/0000:00:1f.2/ata1/host0/target0:0:0/0:0:0:0/block/sda lrwxrwxrwx 1 root root 0 May 11 11:43 sde -> ../devices/pci0000:00/0000:00:01.0/0000:01:00.0/host4/port-4:0/end_device-4:0/target4:0:0/4:0:0:0/block/sde lrwxrwxrwx 1 root root 0 May 11 11:43 sdf -> ../devices/pci0000:00/0000:00:01.0/0000:01:00.0/host4/port-4:1/end_device-4:1/target4:0:1/4:0:1:0/block/sdf Sorry for the late answer. It is really baremetal. When I try to monitor DSM 7.1 with zabbix over SNMP I really get the same data for all oids of different HDDS, it worked ok for DSM 6 and Syno didn't change much in SNMP. As you can see the only HDD that gets real value is sda which is connected directly to sata, all other hdds are connected to LSI HBA and get the same value Quote Link to comment Share on other sites More sharing options...
recoco Posted May 13 Share #3313 Posted May 13 On 5/12/2022 at 5:42 AM, pocopico said: can you test with https://raw.githubusercontent.com/pocopico/redpill-load/develop/redpill-virtio/rpext-index.json Got it. I will try again later. Thank you very much! Quote Link to comment Share on other sites More sharing options...
alanoo Posted May 13 Share #3314 Posted May 13 Got mine working too, my first try on tinycore as I was still on DSM 6.2. 7.1 42661 DS918+ on Proxmox, using real SN/Mac from the 918+ from the office, compiled with VirtIO Went with passthrough for the SATA controller as the other VMs are only using NVMe Just wondering if we can get RAM Ballooning driver working ? As it's kind of useless to see the VM using 3GB+ of memory when it barely uses 400MB for now (not reinstalled any package yet) Tried to search the forum for it, but apart from some logs that mentions the balloon driver, nothing really clear. Any clue ? Quote Link to comment Share on other sites More sharing options...
phone guy Posted May 13 Share #3315 Posted May 13 On 5/11/2022 at 7:35 PM, flyride said: https://xpenology.com/forum/topic/54545-dsm-7-and-storage-poolarray-functionality/ First THANKS! Second, why did SHR not work this time? This was not the first 3622 build I made, previous builds let me select SHR... This time only RAID modes??? BTW I had to change the .conf in both /etc and /etc.defaults.... I know this because I changed /etc first, reboot, and still no SHR... then I changed /etc.defaults and rebooted, and then I had SHR Quote Link to comment Share on other sites More sharing options...
LaBoss Posted May 13 Share #3316 Posted May 13 22 hours ago, pocopico said: Change both to ./rploader.sh ext broadwellnk-7.1.0-42661 add https://github.com/pocopico/redpill-load/raw/develop/redpill-virtio/rpext-index.json ./rploader.sh ext broadwellnk-7.1.0-42661 add https://github.com/pocopico/redpill-load/raw/develop/redpill-acpid/rpext-index.json Thanks for fast reply, works like a charm thanks Quote Link to comment Share on other sites More sharing options...
facelessone Posted May 13 Share #3317 Posted May 13 On 5/12/2022 at 3:31 AM, flyride said: With DS920+, if the second drive was not physically present in the machine when you built the loader, it probably won't be recognized. I just posted some contextual information in the Tutorials section here: https://xpenology.com/forum/topic/61634-dsm-7x-loaders-and-platforms/ You can try to rebuild the DS920+ loader with both drives connected, or you can go back to DS918+. The rebuild is probably a better choice for you so that you don't deal with the difficulty of backrevving. On 5/12/2022 at 12:38 PM, pocopico said: If the dtb was not patched correclty by rploader then your next best option would be to manual patch the model.dtb The process is not that difficult but its a two step process. Boot DSM and login with ssh or by http://<yourip>:7681 if you are in junior mode and provide the following info fdisk -l ls /sys/block cat /sys/block/*/device/*block*info Thanks you guys. You are great. I have decided to give DS918+ another try, or more like 10 tries to be correct. I finally manged to install DS918 with "SataPortMap": "1" and only one disk inside. I made a fresh install on a cleaned drive and will move my data around and configure stuff later on. Later I build a loader again with "SataPortMap": "4" and it boots now and detects other drives. I moved back the drive from DS920+ install with data on and it recovered the pool with no problems. Still one drive to move from DS3615xs later but I belive it will go without problems. Quote Link to comment Share on other sites More sharing options...
howudodat Posted May 13 Share #3318 Posted May 13 Trying to isntall 3622xs+ on proxmox using the below steps: create the guest: # set vm id id=930 ver=0.4.6 # create image directory, download and uncomporess mkdir -p /var/lib/vz/images/${id} curl --location https://github.com/pocopico/tinycore-redpill/raw/main/tinycore-redpill.v${ver}.img.gz --output /var/lib/vz/images/${id}/tinycore-redpill.img.gz gzip --decompress /var/lib/vz/images/${id}/tinycore-redpill.img.gz --keep # create disk for sata0 pvesm alloc local-lvm ${id} vm-${id}-disk-0 100G # create vm qm create ${id} \ --args "-drive 'if=none,id=synoboot,format=raw,file=/var/lib/vz/images/${id}/tinycore-redpill.img' -device 'qemu-xhci,addr=0x18' -device 'usb-storage,drive=synoboot,bootindex=5'" \ --cores 2 \ --cpu host \ --machine q35 \ --memory 2048 \ --name DSM \ install tcrp: ./rploader.sh update now ./rploader.sh fullupgrade now ./rploader.sh serialgen DS3622xs+ ./rploader.sh identifyusb now ./rploader.sh satamap now ./rploader.sh build broadwellnk-7.0.1-42218 ./rploader.sh clean now ./rploader.sh ext broadwellnk-7.1.0-42661 add https://github.com/pocopico/redpill-load/raw/develop/redpill-virtio/rpext-index.json ./rploader.sh ext broadwellnk-7.1.0-42661 add https://github.com/pocopico/redpill-load/raw/develop/redpill-acpid/rpext-index.json ./rploader.sh build broadwellnk-7.1.0-42661 GRUB shows: RedPill DS3622xs v7.1.0-42661 Beta (USB, Verbose) * RedPill DS3622xs v7.1.0-42661 Beta (SATA, Verbose) TinyCore ... Afterwards when I go to the web page I see: Welcome! Set up your Synology DS3622xs+ now I click on Install and it prompts me for a pat file So I select and install the pat downloaded from synology and I get error: Failed to install the file is probably corrupt Questions: 1. What is the difference in GRUB between the USB and SATA entries? 2. Are these the right steps to install on proxmox? 3. Why is it asking to install a pat file when it seems that tcrp is downloading that file already for me? 4. and of course, how to fix the error 1 Quote Link to comment Share on other sites More sharing options...
Itay1778 Posted May 13 Share #3319 Posted May 13 Hi, everyone. I am trying to install DSM 7.1 on bare metal with the help of this guide: But I seem to be stuck on this screen: Don't really know what to do... I tried to figure out how to maybe fix it through the previous pages here, but without success Motherboard model: asrock h91m-plus The SATA controller supports up to 6 ports but the board has 4 ports and all ports are connected with HDDs What to do? And another question when I make a change in user_config.json I need to do build again to save it? Quote Link to comment Share on other sites More sharing options...
docop1 Posted May 13 Share #3320 Posted May 13 @howudodat for prox : do this in the Gui. upload the .img into vz/dump. vm i440fx/seabios/2cor-4g/Virtioscsi default/ Sata0:22g min /sata1: bootloaderpil.46 sata 1 is assign via 1 cli cmd. : qimport vmid ...bootloaderpill.img nothing usb. no touch to args. Quote Link to comment Share on other sites More sharing options...
docop1 Posted May 13 Share #3321 Posted May 13 Question about network : with an ethernet card passthroug to a vm in esxi.. i think i'm missing something. While i did install the proper driver during the build, like for a 3622 and 3617. The card do not show up in the info center and neither in the network interface. Do i have to add an extra line in the user_config.json as : for the 3617 having max 4mac, putting "mac5": "001xxrandom", will automaticaly map the 10g card to the mac5 ? i try this just by booting and setting with ,e, option, but it don't show up. A previous test with an usbnic show with the above that can work.. but with an network card .. not sure here. Also Thanks for all great packages ! Quote Link to comment Share on other sites More sharing options...
flyride Posted May 13 Share #3322 Posted May 13 55 minutes ago, howudodat said: Questions: 1. What is the difference in GRUB between the USB and SATA entries? 2. Are these the right steps to install on proxmox? 3. Why is it asking to install a pat file when it seems that tcrp is downloading that file already for me? 4. and of course, how to fix the error - Grub USB is to support a USB key for boot, or an emulated USB key image if desired when virtualized. - SATA USB is a disk image specifically for VMware as there is no way to emulate a USB key or boot from it. I don't know if it works on Proxmox. - PAT file needs to be downloaded by the loader in order to create the loader. DSM install also needs to use the PAT file. You can download the necessary pat files and host locally, and push to TCRP install if you don't like pulling it from the internet repeatedly. - See answer #2, you probably need to emulate or use a physical USB key. Look for folks that have installed on proxmox. Documentation on this will improve. I'm working on a general installation document and a VMware addendum. Typically others pitch in with variants for the other hypervisors. 1 Quote Link to comment Share on other sites More sharing options...
howudodat Posted May 13 Share #3323 Posted May 13 I have tried with both emulating a usb drive: -args "-drive 'if=none,id=synoboot,format=raw,file=/var/lib/vz/images/${id}/tinycore-redpill.img' -device 'qemu-xhci,addr=0x18' -device 'usb-storage,drive=synoboot,bootindex=5'" and I have tried by coping the img into sata 1: sata0: local-lvm:vm-930-disk-0,size=100G sata1: local-lvm:vm-930-disk-1,size=1G both get an error from the web setup: at 43% Failed to install DSM, file is probably corrupted Quote Link to comment Share on other sites More sharing options...
howudodat Posted May 14 Share #3324 Posted May 14 58 minutes ago, howudodat said: I have tried with both emulating a usb drive: -args "-drive 'if=none,id=synoboot,format=raw,file=/var/lib/vz/images/${id}/tinycore-redpill.img' -device 'qemu-xhci,addr=0x18' -device 'usb-storage,drive=synoboot,bootindex=5'" and I have tried by coping the img into sata 1: sata0: local-lvm:vm-930-disk-0,size=100G sata1: local-lvm:vm-930-disk-1,size=1G both get an error from the web setup: at 43% Failed to install DSM, file is probably corrupted ok, if I stop at 7.0.1-42218 it installs fine Quote Link to comment Share on other sites More sharing options...
phone guy Posted May 14 Share #3325 Posted May 14 5 hours ago, howudodat said: Trying to isntall 3622xs+ on proxmox using the below steps: create the guest: # set vm id id=930 ver=0.4.6 # create image directory, download and uncomporess mkdir -p /var/lib/vz/images/${id} curl --location https://github.com/pocopico/tinycore-redpill/raw/main/tinycore-redpill.v${ver}.img.gz --output /var/lib/vz/images/${id}/tinycore-redpill.img.gz gzip --decompress /var/lib/vz/images/${id}/tinycore-redpill.img.gz --keep # create disk for sata0 pvesm alloc local-lvm ${id} vm-${id}-disk-0 100G # create vm qm create ${id} \ --args "-drive 'if=none,id=synoboot,format=raw,file=/var/lib/vz/images/${id}/tinycore-redpill.img' -device 'qemu-xhci,addr=0x18' -device 'usb-storage,drive=synoboot,bootindex=5'" \ --cores 2 \ --cpu host \ --machine q35 \ --memory 2048 \ --name DSM \ install tcrp: ./rploader.sh update now ./rploader.sh fullupgrade now ./rploader.sh serialgen DS3622xs+ ./rploader.sh identifyusb now ./rploader.sh satamap now ./rploader.sh build broadwellnk-7.0.1-42218 ./rploader.sh clean now ./rploader.sh ext broadwellnk-7.1.0-42661 add https://github.com/pocopico/redpill-load/raw/develop/redpill-virtio/rpext-index.json ./rploader.sh ext broadwellnk-7.1.0-42661 add https://github.com/pocopico/redpill-load/raw/develop/redpill-acpid/rpext-index.json ./rploader.sh build broadwellnk-7.1.0-42661 GRUB shows: RedPill DS3622xs v7.1.0-42661 Beta (USB, Verbose) * RedPill DS3622xs v7.1.0-42661 Beta (SATA, Verbose) TinyCore ... Afterwards when I go to the web page I see: Welcome! Set up your Synology DS3622xs+ now I click on Install and it prompts me for a pat file So I select and install the pat downloaded from synology and I get error: Failed to install the file is probably corrupt Questions: 1. What is the difference in GRUB between the USB and SATA entries? 2. Are these the right steps to install on proxmox? 3. Why is it asking to install a pat file when it seems that tcrp is downloading that file already for me? 4. and of course, how to fix the error 4 hours ago, flyride said: - Grub USB is to support a USB key for boot, or an emulated USB key image if desired when virtualized. - SATA USB is a disk image specifically for VMware as there is no way to emulate a USB key or boot from it. I don't know if it works on Proxmox. - PAT file needs to be downloaded by the loader in order to create the loader. DSM install also needs to use the PAT file. You can download the necessary pat files and host locally, and push to TCRP install if you don't like pulling it from the internet repeatedly. - See answer #2, you probably need to emulate or use a physical USB key. Look for folks that have installed on proxmox. Documentation on this will improve. I'm working on a general installation document and a VMware addendum. Typically others pitch in with variants for the other hypervisors. I just posted a tutorial guide with step by step instructions and pictures on how to setup and install on Proxmox. The thread is waiting for approval from the moderators. I actually did it side by side as I wrote it to verify each and every step. And it all worked 100%.. I will post the link, however I dont know how long it will be until its approved. 2 Quote Link to comment Share on other sites More sharing options...
