dodo-dk Posted April 25 Share #3026 Posted April 25 7 minutes ago, pocopico said: We need a microcontroller hardware (ESP32/ESP8266) and a person who is willing to code for it. Hooks exist already on redpill-lkm I have some ESP32 and ESP8266. My programming skills are not the best. How can i help and with what? Quote Link to comment Share on other sites More sharing options...
pocopico Posted April 25 Author Share #3027 Posted April 25 36 minutes ago, dodo-dk said: I have some ESP32 and ESP8266. My programming skills are not the best. How can i help and with what? PM me to discuss. Quote Link to comment Share on other sites More sharing options...
Davidov Posted April 25 Share #3028 Posted April 25 Hello everyone, I'm sorry to write through a translator because from Ukraine, maybe something is not written so correctly. I assembled a server based on HP Prodesk 600 G3 SFF On the board there is a m2 ssd connector, I inserted 1 disk there, and also bought a PCI m2 card for 2 disks, in total I got 3 NVME disks, 2 disks I made as a cache, 3 disks shows me only can be used for cache. But I would like to use it as a simple SSD drive for VM Vare. It is possible to do something so that it is not recognized as a cache. DS 920 Quote Link to comment Share on other sites More sharing options...
RedCat Posted April 25 Share #3029 Posted April 25 5 hours ago, dodo-dk said: With VirtIO i have : (Proxmox <-> DSM) [ ID] Interval Transfer Bitrate Retr [ 5] 0.00-10.00 sec 31.3 GBytes 26.9 Gbits/sec 0 sender [ 5] 0.00-10.04 sec 31.3 GBytes 26.8 Gbits/sec receiver If you have other VMs in Proxmox that connects to DSM over Network, VirtIO is much faster. Thanks for information. I made test with E1000 card: (Proxmox <-> DSM) [ ID] Interval Transfer Bitrate Retr [ 5] 0.00-10.00 sec 6.72 GBytes 5.78 Gbits/sec 0 sender [ 5] 0.00-10.00 sec 6.72 GBytes 5.77 Gbits/sec receiver Virtio is really faster, but I think E1000 is enough also Maybe i make now loader with virtio in afternoon, I will test it also... Quote Link to comment Share on other sites More sharing options...
pocopico Posted April 25 Author Share #3030 Posted April 25 11 minutes ago, Davidov said: Hello everyone, I'm sorry to write through a translator because from Ukraine, maybe something is not written so correctly. I assembled a server based on HP Prodesk 600 G3 SFF On the board there is a m2 ssd connector, I inserted 1 disk there, and also bought a PCI m2 card for 2 disks, in total I got 3 NVME disks, 2 disks I made as a cache, 3 disks shows me only can be used for cache. But I would like to use it as a simple SSD drive for VM Vare. It is possible to do something so that it is not recognized as a cache. DS 920 Interesting setup, you could try to set the internal_slot@1 to the pci values of your m2 data drives. For instance : tc@box:~$ udevadm info --query path --name nvme0n1 /devices/pci0000:00/0000:00:16.0/0000:0b:00.0/nvme/nvme0/nvme0n1 tc@box:~$ udevadm info --query path --name nvme0n1 | awk -F "\/" '{print $4 ":" $5 }' | awk -F ":" '{print $2 ":" $3 "," $6}' | sed 's/,*$//' 00:16.0,00.0 internal_slot@1 { protocol_type = "sata"; power_pin_gpio = <0x14 0x0>; detect_pin_gpio = <0x23 0x1>; led_type = "lp3943"; ahci { pcie_root = "00:16.0,00.0"; ata_port = <0x0>; }; led_green { led_name = "syno_led0"; }; led_orange { led_name = "syno_led1"; }; }; Quote Link to comment Share on other sites More sharing options...
Davidov Posted April 25 Share #3031 Posted April 25 2 минуты назад, pocopico сказал: Interesting setup, you could try to set the internal_slot@1 to the pci values of your m2 data drives. For instance : tc@box:~$ udevadm info --query path --name nvme0n1 /devices/pci0000:00/0000:00:16.0/0000:0b:00.0/nvme/nvme0/nvme0n1 tc@box:~$ udevadm info --query path --name nvme0n1 | awk -F "\/" '{print $4 ":" $5 }' | awk -F ":" '{print $2 ":" $3 "," $6}' | sed 's/,*$//' 00:16.0,00.0 internal_slot@1 { protocol_type = "sata"; power_pin_gpio = <0x14 0x0>; detect_pin_gpio = <0x23 0x1>; led_type = "lp3943"; ahci { pcie_root = "00:16.0,00.0"; ata_port = <0x0>; }; led_green { led_name = "syno_led0"; }; led_orange { led_name = "syno_led1"; }; }; Thanks, tell me how to get there step by step to edit Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted April 25 Share #3032 Posted April 25 3 minutes ago, Davidov said: Thanks, tell me how to get there step by step to edit See this guide by @dolbycat. 1 Quote Link to comment Share on other sites More sharing options...
pocopico Posted April 25 Author Share #3033 Posted April 25 1 minute ago, Davidov said: Thanks, tell me how to get there step by step to edit You need to edit the /home/tc/ds920p.dts and then execute : /home/tc/dtc -I dts -O dtb ds920p.dts > ds920p.dtb Finally copy that edited file in redpill-load/custom/extensions/redpill-dtb/ds920p_42661/model_ds920p.dtb and execute : ./rploader.sh build geminilake-7.1.0-42661 manual 1 Quote Link to comment Share on other sites More sharing options...
Davidov Posted April 25 Share #3034 Posted April 25 2 минуты назад, Peter Suh сказал: See this guide by @dolbycat. Today I will try to unsubscribe or it will work, thank you Quote Link to comment Share on other sites More sharing options...
pocopico Posted April 25 Author Share #3035 Posted April 25 6 minutes ago, Davidov said: Today I will try to unsubscribe or it will work, thank you Pay attention to : ./rploader.sh build geminilake-7.1.0-42661 manual Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted April 25 Share #3036 Posted April 25 5 minutes ago, Davidov said: Today I will try to unsubscribe or it will work, thank you This guide was also written by @dolbycat, How to use the tool-chain. Everything has to be adjusted manually. Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted April 25 Share #3037 Posted April 25 (edited) 22 hours ago, Peter Suh said: There seems to be an issue that has changed significantly in the DS920+ build since I fixed 2 bugs with @pocopico yesterday. It seems that only one simple typo ',' in the "rpext-index.json" file caused abnormal builds on the entire platform for a few days. Another is that there was a typo in the USB port mapping part within the DTC (patchdtc function), so it did not work at all. The USB port mapping seems to prevent the boot-wait from taking a timeout for 30 seconds and falling into an error. If the port mapping is good, it usually induces a normal response within 4 to 5 seconds. Because of these two things, DTC seems to be going pretty stable. DS920+ is looking for a supported Intel CPU generation. Everything I've experienced seems to be fine up to Haswell. Yesterday, there was a user report that the 3rd generation was successful, so I plan to test this part more. In Intel 3rd generation, DS920+ can also be installed. https://xpenology.com/forum/topic/60130-redpill-tinycore-loader-installation-guide-for-dsm-71-baremetal/?do=findComment&comment=277494 In the above, there is a case where the intel 3rd generation also tried DS920+ and succeeded. I also did an installation test with the intel 3rd generation today. I tried it with the Lenovo m72e Tiny Intel 3rd generation i5-3470T, which everyone has. As expected, DS918+ was also unable to recognize NIC. However, the DS920+ is recognized by the R8169 NIC driver. It seems to have become more flexible for CPU generations since using DTC. I got a 55% error when installing DSM, so I couldn't upload a finished shot, but there are likely to be enough successful cases. Looking at /var/log, if the installation is successful, boot-wait, which responds within 4-5 seconds, drops to an error after a 30-second timeout. At least in this case, the DSM installation was not successful. TC automatically sets the USB device port to 1-3, 2-3, etc. It feels like there is some sort of incorrect mapping to the ds920p.dts file. In Haswell tested yesterday, whether this mapping matched well or not, there is no boot-wait timeout, and both ds920+ and ds1621+ were installed well. Edited April 25 by Peter Suh Quote Link to comment Share on other sites More sharing options...
use-nas Posted April 25 Share #3038 Posted April 25 How to do? STEALTH_MODE_NORMAL 2 //Hides everything except making the module not unloadable Quote Link to comment Share on other sites More sharing options...
RedCat Posted April 25 Share #3039 Posted April 25 I tired again 920+ 7.1 install on proxmox. I made loader, boot, I show and upload pat file. It goed to 100% install and reboot. It starts counting down from 10 minutes. And counting and counting... And 00:00 And nothing happend. Has anyone already installed 920+ on proxmox? Quote Link to comment Share on other sites More sharing options...
techfriend63 Posted April 25 Share #3040 Posted April 25 17 hours ago, Dvalin21 said: Has anyone written steps to do the build in Virtual box?@Peter Suh Sent from my HD1925 using Tapatalk To setup in Virtualbox I followed these steps: 1- create a new VM. 2- From "tinycore-redpill", use the provided vmdk file "tinycore-redpill.v0.4.6.vmdk" and copy it to to the VM Directory. 3- Use the copied file as SATA HDD. 4- Add at least one more SATA HDD. 5- Start the VM. 6- SSh into the VM and run the following commands: - ./rploader.sh update now - ./rploader.sh fullupgrade now - ./rploader.sh serialgen DS3622xs+ - ./rploader.sh satamap now - ./rploader.sh identifyusb now NOT NEEDED FOR VIRTUALBOX. 7- Add EXT for "e1000": - ./rploader.sh ext broadwellnk-7.1.0-42661 add https://raw.githubusercontent.com/pocopico/rp-ext/master/e1000/rpext-index.json 8- Build: - ./rploader.sh build broadwellnk-7.1.0-42661 auto 9- check and copy the MAC address in the "user_config.json" file: - cat user_config.json 10- Backup, Clean and poweroff the VM. - ./rploader.sh backup now - ./rploader.sh clean now - sudo poweroff 11- Change the MAC address for the VM with the address copied from the "user_config.jsin" file. 12- Start the VM and complete setup. 5 1 Quote Link to comment Share on other sites More sharing options...
phone guy Posted April 25 Share #3041 Posted April 25 9 hours ago, dodo-dk said: Install on DSM the Package SynoCli Monitor Tools from SynoCommunity. Than login over SSH to DSM and execute the command: iperf3 -s It shows now the listening Port. Now login over SSH to Proxmox and execute the command iperf3 -c xxx.xxx.xxx.xxx (IP from DSM) On Proxmox you need the Package iperf3 too (apt update && apt install iperf3) Thats all. Since virtio is faster than e1000 nic in proxmox/dsm, would creating bridge to bond multiple nic in proxmox be beneficial? I use LAG on my real synology boxes, bonding all 4 1gbe nic to managed switch using IEEE 802.3ad Dynamic link aggregation. I wanted to create a similar bond in proxmox, but obviously at the proxmox level to distribute to benefit of LAG to all vm's running, including DSM. Do you have instructions for that in ProxMox? and am I correct in my assumption? That would benefit network bandwidth for all vm's running on proxmox? Quote Link to comment Share on other sites More sharing options...
phone guy Posted April 25 Share #3042 Posted April 25 Quick little post with some great tips for proxmox... easy updates, removes nag screen, etc... Quote Link to comment Share on other sites More sharing options...
phone guy Posted April 25 Share #3043 Posted April 25 (edited) 13 hours ago, dodo-dk said: Install on DSM the Package SynoCli Monitor Tools from SynoCommunity. Than login over SSH to DSM and execute the command: iperf3 -s It shows now the listening Port. Now login over SSH to Proxmox and execute the command iperf3 -c xxx.xxx.xxx.xxx (IP from DSM) On Proxmox you need the Package iperf3 too (apt update && apt install iperf3) Thats all. Huge difference in network speed between e1000 vs VirtIO E1000 nic set in Proxmox # e1000 nic in proxmox with e1000/e drivers in DSM # ./rploader.sh ext broadwellnk-7.1.0-42661 add https://raw.githubusercontent.com/pocopico/rp-ext/master/e1000/rpext-index.json # ./rploader.sh ext broadwellnk-7.1.0-42661 add https://raw.githubusercontent.com/pocopico/rp-ext/master/e1000e/rpext-index.json # I added had to both to get nic to communicate? [ ID] Interval Transfer Bitrate Retr Cwnd [ 5] 0.00-1.00 sec 439 MBytes 3.68 Gbits/sec 0 816 KBytes [ 5] 1.00-2.00 sec 485 MBytes 4.07 Gbits/sec 19 1.26 MBytes [ 5] 2.00-3.00 sec 508 MBytes 4.26 Gbits/sec 14 1.14 MBytes [ 5] 3.00-4.00 sec 516 MBytes 4.33 Gbits/sec 17 1.03 MBytes [ 5] 4.00-5.00 sec 510 MBytes 4.28 Gbits/sec 0 1.34 MBytes [ 5] 5.00-6.00 sec 488 MBytes 4.09 Gbits/sec 24 1.22 MBytes [ 5] 6.00-7.00 sec 409 MBytes 3.43 Gbits/sec 151 1.14 MBytes [ 5] 7.00-8.00 sec 505 MBytes 4.24 Gbits/sec 25 1.01 MBytes [ 5] 8.00-9.00 sec 480 MBytes 4.03 Gbits/sec 0 1.21 MBytes [ 5] 9.00-10.00 sec 440 MBytes 3.69 Gbits/sec 0 1.21 MBytes - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bitrate Retr [ 5] 0.00-10.00 sec 4.67 GBytes 4.01 Gbits/sec 250 sender [ 5] 0.00-10.00 sec 4.66 GBytes 4.00 Gbits/sec receiver VirtIO nic set in proxmox #VirtIO nic set in Proxmox VirtIO drivers in DSM # ./rploader.sh ext broadwellnk-7.1.0-42661 add https://raw.githubusercontent.com/pocopico/redpill-load/master/redpill-virtio/rpext-index.json [ ID] Interval Transfer Bitrate Retr Cwnd [ 5] 0.00-1.00 sec 3.06 GBytes 26.3 Gbits/sec 141 868 KBytes [ 5] 1.00-2.00 sec 3.08 GBytes 26.5 Gbits/sec 1 868 KBytes [ 5] 2.00-3.00 sec 3.04 GBytes 26.1 Gbits/sec 0 868 KBytes [ 5] 3.00-4.00 sec 3.03 GBytes 26.0 Gbits/sec 2 868 KBytes [ 5] 4.00-5.00 sec 3.04 GBytes 26.1 Gbits/sec 1 868 KBytes [ 5] 5.00-6.00 sec 3.03 GBytes 26.1 Gbits/sec 0 868 KBytes [ 5] 6.00-7.00 sec 3.04 GBytes 26.1 Gbits/sec 0 868 KBytes [ 5] 7.00-8.00 sec 3.03 GBytes 26.1 Gbits/sec 0 868 KBytes [ 5] 8.00-9.00 sec 3.00 GBytes 25.7 Gbits/sec 0 868 KBytes [ 5] 9.00-10.00 sec 2.93 GBytes 25.2 Gbits/sec 0 1020 KBytes - - - - - - - - - - - - - - - - - - - - - - - - - [ ID] Interval Transfer Bitrate Retr [ 5] 0.00-10.00 sec 30.3 GBytes 26.0 Gbits/sec 145 sender [ 5] 0.00-10.00 sec 30.3 GBytes 26.0 Gbits/sec receiver Thank You! @RedCat@IG-88@dodo-dk Edited April 25 by phone guy 1 Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted April 26 Share #3044 Posted April 26 (edited) 7 hours ago, techfriend63 said: To setup in Virtualbox I followed these steps: 1- create a new VM. 2- From "tinycore-redpill", use the provided vmdk file "tinycore-redpill.v0.4.6.vmdk" and copy it to to the VM Directory. 3- Use the copied file as SATA HDD. 4- Add at least one more SATA HDD. 5- Start the VM. 6- SSh into the VM and run the following commands: - ./rploader.sh update now - ./rploader.sh fullupgrade now - ./rploader.sh serialgen DS3622xs+ - ./rploader.sh satamap now - ./rploader.sh identifyusb now NOT NEEDED FOR VIRTUALBOX. 7- Add EXT for "e1000": - ./rploader.sh ext broadwellnk-7.1.0-42661 add https://raw.githubusercontent.com/pocopico/rp-ext/master/e1000/rpext-index.json 8- Build: - ./rploader.sh build broadwellnk-7.1.0-42661 auto 9- check and copy the MAC address in the "user_config.json" file: - cat user_config.json 10- Backup, Clean and poweroff the VM. - ./rploader.sh backup now - ./rploader.sh clean now - sudo poweroff 11- Change the MAC address for the VM with the address copied from the "user_config.jsin" file. 12- Start the VM and complete setup. It's an installation guide that I really needed. If only the post remains like this, it will be forgotten later. Like me, why don't you register this post as a separate topic in the tutorial & guide? The new topic will be officially registered after days of administrative approval. p.s : - ./rploader.sh build broadwellnk-7.1.0-42661 auto The last auto is a non-existent option. It's the same effect as writing nothing down. Edited April 26 by Peter Suh Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted April 26 Share #3045 Posted April 26 15 hours ago, techfriend63 said: To setup in Virtualbox I followed these steps: 1- create a new VM. 2- From "tinycore-redpill", use the provided vmdk file "tinycore-redpill.v0.4.6.vmdk" and copy it to to the VM Directory. 3- Use the copied file as SATA HDD. 4- Add at least one more SATA HDD. 5- Start the VM. 6- SSh into the VM and run the following commands: - ./rploader.sh update now - ./rploader.sh fullupgrade now - ./rploader.sh serialgen DS3622xs+ - ./rploader.sh satamap now - ./rploader.sh identifyusb now NOT NEEDED FOR VIRTUALBOX. 7- Add EXT for "e1000": - ./rploader.sh ext broadwellnk-7.1.0-42661 add https://raw.githubusercontent.com/pocopico/rp-ext/master/e1000/rpext-index.json 8- Build: - ./rploader.sh build broadwellnk-7.1.0-42661 auto 9- check and copy the MAC address in the "user_config.json" file: - cat user_config.json 10- Backup, Clean and poweroff the VM. - ./rploader.sh backup now - ./rploader.sh clean now - sudo poweroff 11- Change the MAC address for the VM with the address copied from the "user_config.jsin" file. 12- Start the VM and complete setup. Thanks to you, I succeeded in installing TCRP in Virtual BOX on my MacBook. There was no problem until the loader was created I didn't know how to get the ip of nic. There was a phenomenon that the ip of dhcp increased by 1 whenever new mac was added When adding virtual hdd, don't make it too small. I think it was more than 24GB, but I don't know the exact figure. Quote Link to comment Share on other sites More sharing options...
Bobbenoster Posted April 26 Share #3046 Posted April 26 On 4/25/2022 at 12:22 PM, dodo-dk said: I have some ESP32 and ESP8266. My programming skills are not the best. How can i help and with what? Same here... Have some esp8266 boards... If you tell me what you are looking for them I can gauge how far I would be out of my depth... Quote Link to comment Share on other sites More sharing options...
NooL Posted April 26 Share #3047 Posted April 26 17 hours ago, phone guy said: Quick little post with some great tips for proxmox... easy updates, removes nag screen, etc... Any chance of an updated guide on how to install it to proxmox? 7.1 that is 1 Quote Link to comment Share on other sites More sharing options...
chickey Posted April 26 Share #3048 Posted April 26 On 4/25/2022 at 11:12 AM, pocopico said: We need a microcontroller hardware (ESP32/ESP8266) and a person who is willing to code for it. Hooks exist already on redpill-lkm Are you wanting to periodically read in the startup time and then have the ESP send a magic packet at the appropriate time? Quote Link to comment Share on other sites More sharing options...
Bobbenoster Posted April 26 Share #3049 Posted April 26 1 hour ago, chickey said: Are you wanting to periodically read in the startup time and then have the ESP send a magic packet at the appropriate time? relays were mentioned in the original post so I believe the idea is a physical trigger of the power button at a scheduled time (presumably only if the machine is not already on) with some kind of communication (I'd venture serial comms) to the esp chip to set the automatic startup time... Quote Link to comment Share on other sites More sharing options...
IG-88 Posted April 26 Share #3050 Posted April 26 7 hours ago, Peter Suh said: Thanks to you, I succeeded in installing TCRP in Virtual BOX on my MacBook. There was no problem until the loader was created I didn't know how to get the ip of nic. the main thing with virtualbox war usually to have the same mac in the vm and the dsm config (aka grub.cfg) i use ich9 as chipset as its a sata/ahci chipset by default, the rest is the same as with the vm config for 6.2.3 one sata controller, 1st disk is the loader network is bridged and Intel 1000MT Desktop (thas the e1000 extension in the rp loader) i guess all the intel nic's in virtual box will work as they are all 8254x and thats all e1000 when it comes to the driver its also handy to configure the com1 port to have access to the log when booting putty as terminal 2 Quote Link to comment Share on other sites More sharing options...
