Peter Suh Posted April 17 Share #2676 Posted April 17 1 minute ago, hendry said: did u mean, when i run this command ./rploader.sh ext bromolow-7.1.0-42661 add https://github.com/jimmyGALLAND/redpill-ext/raw/master/acpid/rpext-index.json means, it doesn't find the recipe for DS3615xs which cause these errors ? that command i use to add virtio-9p drivers inside redpill kernel. Also, is it necessary to add this part manually as a part? TC automatically adds ACPI in the build process and uses the one from Pocopico. Remove this part. ./rploader.sh ext bromolow-7.0.1-42218 add https://github.com/jimmyGALLAND/redpill-ext/raw/master/acpid/rpext-index.json Quote Link to comment Share on other sites More sharing options...
hendry Posted April 17 Share #2677 Posted April 17 1 minute ago, Peter Suh said: Also, is it necessary to add this part manually as a part? TC automatically adds ACPI in the build process and uses the one from Pocopico. Remove this part. ./rploader.sh ext bromolow-7.0.1-42218 add https://github.com/jimmyGALLAND/redpill-ext/raw/master/acpid/rpext-index.json if i remove this part, then the loader does not have virtio drivers.. Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted April 17 Share #2678 Posted April 17 6 minutes ago, hendry said: if i remove this part, then the loader does not have virtio drivers.. As far as I know, we use ext below for Sata, no? ./rploader.sh ext bromolow-7.0.1-42218 add https://raw.githubusercontent.com/pocopico/rp-ext/master/vmw_pvscsi/rpext-index.json Quote Link to comment Share on other sites More sharing options...
hendry Posted April 17 Share #2679 Posted April 17 4 minutes ago, Peter Suh said: As far as I know, we use ext below for Sata, no? ./rploader.sh ext bromolow-7.0.1-42218 add https://raw.githubusercontent.com/pocopico/rp-ext/master/vmw_pvscsi/rpext-index.json not really sure.. but u can find it on this site Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted April 17 Share #2680 Posted April 17 (edited) 4 minutes ago, hendry said: not really sure.. but u can find it on this site If so, replace it with the acpid of the pocopico. ./rploader.sh ext bromolow-7.0.1-42218 add https://github.com/pocopico/redpill-load/raw/develop/redpill-acpid/rpext-index.json Edited April 17 by Peter Suh Quote Link to comment Share on other sites More sharing options...
dodo-dk Posted April 17 Share #2681 Posted April 17 25 minutes ago, hendry said: so, before build the loader, what should i do ? execute this command ? ./rploader.sh ext bromolow-7.1.0-42661 add https://github.com/pocopico/redpill-load/blob/master/redpill-virtio/rpext-index.json Yes, this is right for virtio drivers in Proxmox. But ACPI/Powerbutton doesnt work with 7.1. Quote Link to comment Share on other sites More sharing options...
hendry Posted April 17 Share #2682 Posted April 17 1 minute ago, Peter Suh said: If so, replace it with the acpid of the pocopico. ./rploader.sh ext bromolow-7.0.1-42218 add https://github.com/pocopico/redpill-load/raw/develop/redpill-acpid/rpext-index.json this is for DSM 7.1 not 7.0.1 since building loader for 7.0.1 success and running fine.. what does this command means ? it adds acpid drivers ? and how about virtio ? Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted April 17 Share #2683 Posted April 17 3 minutes ago, hendry said: this is for DSM 7.1 not 7.0.1 since building loader for 7.0.1 success and running fine.. what does this command means ? it adds acpid drivers ? and how about virtio ? To be exact, you can follow the version and revision. However, just because you use 7.0.1 ext, This does not prevent the use of 42661 ext in 7.1 builds. This is because the addition of the above ext only imports json, the environmental file, and all revisions are prepared in this json file. Quote Link to comment Share on other sites More sharing options...
hendry Posted April 17 Share #2684 Posted April 17 1 minute ago, dodo-dk said: Yes, this is right for virtio drivers in Proxmox. But ACPI/Powerbutton doesnt work with 7.1. then this command is correct to add virtio drivers support on 7.1 ? i plan to run this loader on xpenology docker from uxora. Quote Link to comment Share on other sites More sharing options...
dodo-dk Posted April 17 Share #2685 Posted April 17 (edited) This for ACPID, but under Proxmox it does not work. ./rploader.sh ext bromolow-7.1.0-42661 add https://raw.githubusercontent.com/pocopico/redpill-load/master/redpill-acpid/rpext-index.json This for virtio Drivers ./rploader.sh ext bromolow-7.1.0-42661 add https://raw.githubusercontent.com/pocopico/redpill-load/master/redpill-virtio/rpext-index.json Edit: Sorry now its right Edited April 17 by dodo-dk Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted April 17 Share #2686 Posted April 17 (edited) 2 minutes ago, dodo-dk said: This for ACPID, but under Proxmox it does not work. ./rploader.sh ext bromolow-7.0.1-42218 add https://raw.githubusercontent.com/pocopico/redpill-load/master/redpill-acpid/rpext-index.json This for virtio Drivers ./rploader.sh ext bromolow-7.0.1-42218 add https://raw.githubusercontent.com/pocopico/redpill-load/master/redpill-virtio/rpext-index.json In some platform, ext below is helpful to prevent sudden power down, but is there such a report in VM? ./rploader.sh ext bromolow-7.1.0-42661 add https://github.com/pocopico/redpill-load/raw/develop/redpill-misc/rpext-index.json Edited April 17 by Peter Suh Quote Link to comment Share on other sites More sharing options...
dodo-dk Posted April 17 Share #2687 Posted April 17 (edited) Yes, but this was done/add automatically on loader build Edited April 17 by dodo-dk Quote Link to comment Share on other sites More sharing options...
Oli5 Posted April 17 Share #2688 Posted April 17 Disk missing My values are: SataPortMap=61 DiskIdxMap=0001 SynologyNAS> fdisk -l Disk /dev/sdd: 466 GB, 500107862016 bytes, 976773168 sectors 60801 cylinders, 255 heads, 63 sectors/track Units: sectors of 1 * 512 = 512 bytes Device Boot StartCHS EndCHS StartLBA EndLBA Sectors Size Id Type Disk /dev/sdf: 447 GB, 480103981056 bytes, 937703088 sectors 58369 cylinders, 255 heads, 63 sectors/track Units: sectors of 1 * 512 = 512 bytes Device Boot StartCHS EndCHS StartLBA EndLBA Sectors Size Id Type Disk /dev/sdb: 238 GB, 256060514304 bytes, 500118192 sectors 31130 cylinders, 255 heads, 63 sectors/track Units: sectors of 1 * 512 = 512 bytes Device Boot StartCHS EndCHS StartLBA EndLBA Sectors Size Id Type Disk /dev/synoboot: 15 GB, 16078864384 bytes, 31404032 sectors 15334 cylinders, 64 heads, 32 sectors/track Units: sectors of 1 * 512 = 512 bytes Any ideas ? Quote Link to comment Share on other sites More sharing options...
IG-88 Posted April 17 Share #2689 Posted April 17 11 hours ago, blackmix said: Yeah, thanks. The 24 is there.. in the dashboard template that doesn't show, I didn't know about this new feature because in versions 6.x it didn't recognize all the cores. if had it different in 6.x you either had a match by accident or you installed package moddind the behavior 11 hours ago, blackmix said: Where is there a post talking about editing the dashboard? it would be interesting to have a possibility to edit and put more things there by editing the dsm api and putting more infos from nas you can have the real info shown with this https://xpenology.com/forum/topic/13030-dsm-5x6x7x-cpu-name-cores-infomation-change-tool/ 1 Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted April 17 Share #2690 Posted April 17 5 minutes ago, IG-88 said: if had it different in 6.x you either had a match by accident or you installed package moddind the behavior you can have the real info shown with this https://xpenology.com/forum/topic/13030-dsm-5x6x7x-cpu-name-cores-infomation-change-tool/ I wondered whose topic it was, but it belonged to my friend @FOXBI This person works very close to me in Korea. ^^ Quote Link to comment Share on other sites More sharing options...
dodo-dk Posted April 17 Share #2691 Posted April 17 (edited) For the Proxmox ACPID / Powerbutton Problem: I found out that the Powerbutton is working if i manually insmod the button.ko I hope @pocopico can integrate it in his acpid package, its from https://github.com/jimmyGALLAND/redpill-ext/tree/master/acpid/modules Tested under ds3617xs_42661 Wish you all a Happy Easter Edited April 17 by dodo-dk 1 Quote Link to comment Share on other sites More sharing options...
pocopico Posted April 17 Author Share #2692 Posted April 17 (edited) 1 hour ago, dodo-dk said: For the Proxmox ACPID / Powerbutton Problem: I found out that the Powerbutton is working if i manually insmod the button.ko I hope @pocopico can integrate it in his acpid package, its from https://github.com/jimmyGALLAND/redpill-ext/tree/master/acpid/modules Tested under ds3617xs_42661 Wish you all a Happy Easter Good to know ! Do you mind dropping me a PM about required steps for acpid? I want to have a solid solution for that. Edited April 17 by pocopico Quote Link to comment Share on other sites More sharing options...
hendry Posted April 17 Share #2693 Posted April 17 (edited) How to get the .pat file downloded from the redpill build script into pc ? and where's the resulted bootloader img file ? Edited April 17 by hendry Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted April 17 Share #2694 Posted April 17 3 minutes ago, hendry said: How to get the .pat file downloded from the redpill build script into pc ? and where's the resulted bootloader img file ? It is recommended to use Util that supports sftp. In MacOS I use portx. Quote Link to comment Share on other sites More sharing options...
hendry Posted April 17 Share #2695 Posted April 17 1 minute ago, Peter Suh said: It is recommended to use Util that supports sftp. In MacOS I use portx. tried winscp but always getting incorrect mac packet when downloading the file.. i also didn't find the .img file as the result of bootloader created. which folder is it ? Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted April 17 Share #2696 Posted April 17 7 minutes ago, hendry said: tried winscp but always getting incorrect mac packet when downloading the file.. i also didn't find the .img file as the result of bootloader created. which folder is it ? I wasn't interested in it because TC took care of it, so there was no reason to download it and use it, but when I looked it up, it's here. /home/tc/redpill-load/loader.img Quote Link to comment Share on other sites More sharing options...
hendry Posted April 17 Share #2697 Posted April 17 2 minutes ago, Peter Suh said: I wasn't interested in it because TC took care of it, so there was no reason to download it and use it, but when I looked it up, it's here. /home/tc/redpill-load/loader.img why no reason not to download the .pat file from tc ? the pat file is used to install DSM right ? Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted April 17 Share #2698 Posted April 17 2 minutes ago, hendry said: why no reason not to download the .pat file from tc ? the pat file is used to install DSM right ? I mean the img file. Quote Link to comment Share on other sites More sharing options...
hendry Posted April 17 Share #2699 Posted April 17 (edited) 6 minutes ago, Peter Suh said: I mean the img file. but the .pat file, how to download it from tc ? i have used winscp & filezilla but always download failed.. can i mount shared folder using cifs or nfs type inside tc ? Edited April 17 by hendry Quote Link to comment Share on other sites More sharing options...
Peter Suh Posted April 17 Share #2700 Posted April 17 Just now, hendry said: but the .pat file, how to download it from tc ? i have used winscp & filezilla but always download failed.. By the way, isn't the pat file on the Sinology download homepage more convenient to download? Is it to use the decrypted pat file? It's no use. To install the 7.1 pat file, you must use the original file, the encrypted file on the Synology download page. Quote Link to comment Share on other sites More sharing options...
