RedPill Tinycore loader
pocopico
4 minutes ago, pocopico said:
can you rerun only the last build part ?
you mean like this
./rploader.sh update now
./rploader.sh fullupgrade now
./rploader.sh clean now
./rploader.sh build broadwellnk-7.1.0-42661 auto
10 minutes ago, carlozo said:
you mean like this
File //mnt/sda3/auxfiles/ds3622xsp_42661.pat, is  encrypted
File //mnt/sda3/auxfiles/ds3622xsp_42661.pat, has been cached but its encrypted, re-running decrypting process
Checking for cached pat file
Found tinycore cache folder, linking to home/tc/custom-module
Found locally cached pat file /home/tc/custom-module/ds3622xsp_42661.pat
File /home/tc/custom-module/ds3622xsp_42661.pat, is  encrypted
Extracting encrypted pat file : /home/tc/custom-module/ds3622xsp_42661.pat to /tmp/pat
sudo: /bin/syno_extract_system_patch: command not found
extract latest pat
Creating unecrypted pat file ds3622xsp_42661.pat to /home/tc/redpill-load/cache folder
tar: ./VERSION: Not found in archive
tar: Exiting with failure status due to previous errors
Pat file  sha256sum is : 4692a72c93969ff02f79453a9f8ee3ea2ff2332760b3ce32441bb798e4f72b7d
Checking config file existence -> No config file found, please use the proper repo, clean and download again
Hello,
I downloaded and burn tinycore-redpill.v0.4.6 to my USB drive and boot it to my HP Microserver Gen 8 with 4 disks. However, I cannot make it work.
Commands shown below.
My questions:
  1. My system is using Intel(R) Celeron(R) CPU G1610T @ 2.30GHz with 2GB RAM. Is the DS3615xsbromolow-7.0.1-42218 a good choice?
  2. There is no modules.alias.3.json.gz  modules.alias.4.json.gz  latestrploader.sh on my drive. Is it normal?
  3. There are SSL certificate problem: certificate is not yet valid errors. Are they expected?
  4. Do I need the pciid 8086d00001c02 and pciid 102bd00000533 extensions? If yes, how can I locate and include them?
Many thanks!
tc@box:~$ sudo ./rploader.sh update now
Checking Internet Access -> OK
Checking if a newer version exists on the repo -> gzip: modules.alias.3.json.gz: No such file or directory
gzip: modules.alias.4.json.gz: No such file or directory
sha256sum: latestrploader.sh: No such file or directory
There is a newer version of the script on the repo should we use that ? [yY/nN]Y
OK, updating, please re-run after updating
cp: cannot stat '/home/tc/latestrploader.sh': No such file or directory
Updating tinycore loader with latest updates
Backing up files to /mnt/sde3//mydata.tgz
Done.
tc@box:~$
tc@box:~$ sudo ./rploader.sh serialgen DS3615xs now
Serial Number for Model : 1330LWN027197
Mac Address for Model DS3615xs : 00:11:32:C4:8A:21
Should i update the user_config.json with these values ? [Yy/Nn]
Y
tc@box:~$
tc@box:~$ sudo ./rploader.sh satamap now
HBA: 00:1f.2 Disks : 6
SataPortMap=6
DiskIdxMap=00
Y
tc@box:~$
tc@box:~$ sudo ./rploader.sh identifyusb now
Found USB SanDisk SerialNumber: 00003615093021102742
Vendor ID : 0x0781 Product ID : 0x5583
Y
tc@box:~$
tc@box:~$ sudo ./rploader.sh build bromolow-7.0.1-42218 now
Loader source : https://github.com/jumkey/redpill-load.git Loader Branch : develop
Redpill module source : https://github.com/RedPill-TTG/redpill-lkm.git : Redpill module branch : master
Extensions :
Extensions URL :
TOOLKIT_URL : https://sourceforge.net/projects/dsgpl/files/toolkit/DSM7.0/ds.bromolow-7.0.dev.txz/download
TOOLKIT_SHA : a5fbc3019ae8787988c2e64191549bfc665a5a9a4cdddb5ee44c10a48ff96cdd
SYNOKERNEL_URL : https://sourceforge.net/projects/dsgpl/files/Synology%20NAS%20GPL%20Source/25426branch/bromolow-source/linux-3.10.x.txz/download
SYNOKERNEL_SHA : 18aecead760526d652a731121d5b8eae5d6e45087efede0da057413af0b489ed
COMPILE_METHOD : toolkit_dev
TARGET_PLATFORM       : bromolow
TARGET_VERSION    : 7.0.1
TARGET_REVISION : 42218
REDPILL_LKM_MAKE_TARGET : dev-v7
KERNEL_MAJOR : 3
MODULE_ALIAS_FILE= modules.alias.3.json
Done.
tc@box:~$
tc@box:~$ sudo ./rploader.sh ext bromolow-7.0.1-42218 auto
Extensions :
Extensions URL :
KERNEL_MAJOR : 3
Cloning into 'redpill-lkm'...
fatal: unable to access 'https://github.com/RedPill-TTG/redpill-lkm.git/': SSL certificate problem: certificate is not yet valid
Cloning into 'redpill-load'...
fatal: unable to access 'https://github.com/jumkey/redpill-load.git/': SSL certificate problem: certificate is not yet valid
Testing modules.alias.3.json -> File OK
It looks that you will need the following modules :
Found SATA Controller : pciid 8086d00001c02  Required Extension :
No matching extension
Found VGA Controller : pciid 102bd00000533  Required Extension :
Found Ethernet Interface : pciid 14e4d0000165f Required Extension : tg3.ko
Searching for matching extension for tg3.ko
tc@box:~$
5 hours ago, phone guy said:
does my user_config.json get saved during backup? and does it restored during clean command? or do I need to always replace config with my config for all future updates repairs etc to rploader?
What I noticed when I updated to 7.1 is that the user_config.json was replaced during the "fullupgrade" command. The clean command did not replace my config. The "fullupgrade" command creates a backup of your previous files though somewhere in /home/tc/.../old.xxxx.{date}
  • Confused 1
@Pocopico and All
I’m putting my documentation together for building my 2 new DS3622xs+ ESXI VM’s and had a question about extension URL’s. I noticed throughout this thread various URL’s been used in different forms, so is there a standard we should all use when using the “./rploader.sh ext <platform> add <url>”?
Which is preferred long term:
https://github.com/pocopico/rp-ext/blob/main/<extension>/rpext-index.json
or
https://raw.githubusercontent.com/pocopico/rp-ext/main/<extension>/rpext-index.json
Thanks for all your hard work
@pocopico and All
When adding extensions and doing a build, is there a command, file or folder to check to see what extensions have been added after running a “./rploader.sh build <platform>”.
I would like to check/verify what extensions are added in TCRP after doing a build, either on a standard build or one where I’ve added extensions.
Thanks
@Pocopico and All
I’m putting my list together of what extensions to add for a standard DS3622xs+ ESXI VM build and have come up with the following so far:
#  “ACPI”
./rploader.sh ext broadwellnk-7.1.0-42661 add https://raw.githubusercontent.com/pocopico/rp-ext/main/redpill-acpid/rpext-index.json
# “MPT3SAS”
./rploader.sh ext broadwellnk-7.1.0-42661 add https://raw.githubusercontent.com/pocopico/rp-ext/main/mpt3sas/rpext-index.json
# “PVSCSI”
./rploader.sh ext broadwellnk-7.1.0-42661 add https://raw.githubusercontent.com/pocopico/rp-ext/main/vmw_pvscsi/rpext-index.json
# “VMXNET3”
./rploader.sh ext broadwellnk-7.1.0-42661 add https://raw.githubusercontent.com/pocopico/rp-ext/main/vmxnet3/rpext-index.json
The one I’m not sure about is the “redpill-misc” I can find it in the “redpill-load” repo but not in the “rp-ext” repo, should it be in the “rp-ext” repo? (Just my OCD kicking in that’s all)
./rploader.sh ext broadwellnk-7.1.0-42661 add https://raw.githubusercontent.com/pocopico/redpill-load/master/redpill-misc/rpext-index.json
I’ve seen mention of “Telnet Extension” before, but when I check the “rp-ext” repo there are actually 2 listed, not sure which one to use or if it’s even needed
Extension Name: "Early telnet start" Description : "Simple extension which starts telnet early at boot"
https://raw.githubusercontent.com/pocopico/rp-ext/master/early-telnet/rpext-index.json
https://raw.githubusercontent.com/pocopico/rp-ext/master/raspbi-pill/rpext-index.json
Are there any extension that would be “good to have” on a build for troubleshooting or information purposes?
Thanks
Edited by OzTechGeek
8 hours ago, RedCat said:
I added the acpi extension to loader:
./rploader.sh ext apollolake-7.1.0-42661 add https://github.com/pocopico/redpill-load/raw/master/redpill-acpid/rpext-index.json
The build is successfull, it write acpi2 added to loader
I start the dsm 7.1, it boot, but the power button dont work. If I press it, the dsm dont halt.
I tired it before under 7.0.1, there it worked
Same here on Proxmox
This happens when the PAT download is interrupted, you need to clean and start again
extract latest pat
It seems that some drivers are incompatible with 7.1, I had issues updating a Microserver Gen8 with a mellanox Connext x 3 shutting down after installation, so I disabled the card, built the loader so that it does not include the mellanox driver, updated and then reenabled the card, after this the system booted up with no issues
I had to redo one of my nas box (serial num issue) and on the first build, I forgot to check the user config, which got replaced with "stock" config I think after building the 701 image since I did a clean before building 7.1 image, so I had to rebuild 7.1 again with my user config... but if it does a backup, I just assumed clean replaced your files? I guess not... lesson learned, verify user config before issuing each build command.
On 3/22/2022 at 9:20 PM, VRx666 said:
I've been trying to install DS3615xs DS3617xs DS3622xs+ in VM (qemu/kvm).
On DS3615xs ethernet port (e1000e) is flapping, can't get ip address. DS3622xs+ same problem.
DS3617xs is ok., but when instaling OS always get at 55% possibly a corrupted file.
less /var/log/synoupdate.log
2022/03/22 12:11:04     Start of the update...
2022/03/22 12:11:04     Upgrade from version 7.0.1.42218 to version 7.0.1.42218
2022/03/22 12:11:05     Failed to accomplish the update! (errno = 21)
VID/PID set correctly, Sataportmap set correctly. PAT file checksum coresponds with sum for pat file which was used to build loader.
@gadreel @seanone could You post some VM configuration for Unraid?
There where a lot of problems on Unraid even with 6.2 and Jun's loader, but no one wants to share their knowledge.
I don't know is this a community forum.
Someone asked on Unraid forum, but noone answered, same here.
This is my 6.23 DSM VM xml with jun's bootloader:
<?xml version='1.0' encoding='UTF-8'?>
<domain type='kvm' id='10'>
  <name>DSM</name>
  <uuid>78a62f00-77c6-25de-686f-ebb133618c16</uuid>
  <metadata>
    <vmtemplate xmlns="unraid" name="Linux" icon="favicon.png" os="linux"/>
  </metadata>
  <memory unit='KiB'>8388608</memory>
  <currentMemory unit='KiB'>8388608</currentMemory>
  <memoryBacking>
    <nosharepages/>
  </memoryBacking>
  <vcpu placement='static'>4</vcpu>
  <cputune>
    <vcpupin vcpu='0' cpuset='6'/>
    <vcpupin vcpu='1' cpuset='16'/>
    <vcpupin vcpu='2' cpuset='7'/>
    <vcpupin vcpu='3' cpuset='17'/>
  </cputune>
  <resource>
    <partition>/machine</partition>
  </resource>
  <os>
    <type arch='x86_64' machine='pc-q35-6.1'>hvm</type>
  </os>
  <features>
    <acpi/>
    <apic/>
  </features>
  <cpu mode='host-passthrough' check='none' migratable='on'>
    <topology sockets='1' dies='1' cores='2' threads='2'/>
    <cache mode='passthrough'/>
  </cpu>
  <clock offset='utc'>
    <timer name='rtc' tickpolicy='catchup'/>
    <timer name='pit' tickpolicy='delay'/>
    <timer name='hpet' present='no'/>
  </clock>
  <on_poweroff>destroy</on_poweroff>
  <on_reboot>restart</on_reboot>
  <on_crash>restart</on_crash>
  <devices>
    <emulator>/usr/local/sbin/qemu</emulator>
    <disk type='file' device='disk'>
      <driver name='qemu' type='raw' cache='writeback'/>
      <source file='/mnt/user/domains/DSM/DS918+_6.23-25426-1.04b-with_sn-unraid.img' index='3'/>
      <backingStore/>
      <target dev='hdc' bus='sata'/>
      <boot order='1'/>
      <alias name='sata0-0-2'/>
      <address type='drive' controller='0' bus='0' target='0' unit='2'/>
    </disk>
    <disk type='block' device='disk'>
      <source dev='/dev/disk/by-id/ata-TOSHIBA_AABBCCDDEE' index='2'/>
      <backingStore/>
      <target dev='hdd' bus='sata'/>
      <alias name='sata0-0-3'/>
      <address type='drive' controller='0' bus='0' target='0' unit='3'/>
    </disk>
      <source dev='/dev/disk/by-id/ata-ST2000DM006-AABBCCDDEE' index='1'/>
      <backingStore/>
      <target dev='hde' bus='sata'/>
      <alias name='sata0-0-4'/>
      <address type='drive' controller='0' bus='0' target='0' unit='4'/>
    </disk>
    <controller type='sata' index='0'>
      <alias name='ide'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x1f' function='0x2'/>
    </controller>
    <controller type='pci' index='0' model='pcie-root'>
      <alias name='pcie.0'/>
    </controller>
    <controller type='pci' index='1' model='pcie-root-port'>
      <model name='pcie-root-port'/>
      <target chassis='1' port='0x10'/>
      <alias name='pci.1'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x0' multifunction='on'/>
    </controller>
    <controller type='pci' index='2' model='pcie-to-pci-bridge'>
      <model name='pcie-pci-bridge'/>
      <alias name='pci.2'/>
      <address type='pci' domain='0x0000' bus='0x01' slot='0x00' function='0x0'/>
    </controller>
    <controller type='pci' index='3' model='pcie-root-port'>
      <target chassis='3' port='0x11'/>
      <alias name='pci.3'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x1'/>
    </controller>
    <controller type='pci' index='4' model='pcie-root-port'>
      <target chassis='4' port='0x12'/>
      <alias name='pci.4'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x2'/>
    </controller>
    <controller type='pci' index='5' model='pcie-root-port'>
      <target chassis='5' port='0x13'/>
      <alias name='pci.5'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x3'/>
    </controller>
    <controller type='virtio-serial' index='0'>
      <alias name='virtio-serial0'/>
      <address type='pci' domain='0x0000' bus='0x03' slot='0x00' function='0x0'/>
    </controller>
    <controller type='usb' index='0' model='ich9-ehci1'>
      <alias name='usb'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x07' function='0x7'/>
    </controller>
    <controller type='usb' index='0' model='ich9-uhci1'>
      <alias name='usb'/>
      <master startport='0'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x07' function='0x0' multifunction='on'/>
    </controller>
    <controller type='usb' index='0' model='ich9-uhci2'>
      <alias name='usb'/>
      <master startport='2'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x07' function='0x1'/>
    </controller>
    <controller type='usb' index='0' model='ich9-uhci3'>
      <alias name='usb'/>
      <master startport='4'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x07' function='0x2'/>
    </controller>
    <interface type='bridge'>
      <mac address='00:11:32:44:55:66'/>
      <source bridge='br0'/>
      <target dev='vnet10'/>
      <model type='vmxnet3'/>
      <alias name='net0'/>
      <address type='pci' domain='0x0000' bus='0x02' slot='0x01' function='0x0'/>
    </interface>
    <serial type='pty'>
      <source path='/dev/pts/2'/>
      <target type='isa-serial' port='0'>
        <model name='isa-serial'/>
      </target>
      <alias name='serial0'/>
    </serial>
    <console type='pty' tty='/dev/pts/2'>
      <target type='serial' port='0'/>
    </console>
    <channel type='unix'>
      <source mode='bind' path='/var/lib/libvirt/qemu/channel/target/domain-10-DSM/org.qemu.guest_agent.0'/>
      <target type='virtio' name='org.qemu.guest_agent.0' state='disconnected'/>
      <alias name='channel0'/>
      <address type='virtio-serial' controller='0' bus='0' port='1'/>
    </channel>
    <input type='tablet' bus='usb'>
      <alias name='input0'/>
      <address type='usb' bus='0' port='1'/>
    </input>
    <input type='mouse' bus='ps2'>
      <alias name='input1'/>
    </input>
    <input type='keyboard' bus='ps2'>
      <alias name='input2'/>
    </input>
    <graphics type='vnc' port='5901' autoport='yes' websocket='5701' listen='0.0.0.0' keymap='en-us'>
      <listen type='address' address='0.0.0.0'/>
    </graphics>
    <audio id='1' type='none'/>
    <video>
      <model type='qxl' ram='65536' vram='65536' vgamem='16384' heads='1' primary='yes'/>
      <alias name='video0'/>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x0'/>
    </video>
    <memballoon model='virtio'>
      <alias name='balloon0'/>
      <address type='pci' domain='0x0000' bus='0x04' slot='0x00' function='0x0'/>
    </memballoon>
  </devices>
  <seclabel type='dynamic' model='dac' relabel='yes'>
    <label>+0:+100</label>
    <imagelabel>+0:+100</imagelabel>
  </seclabel>
</domain>
Early telnet is not required anymore. Please note that ttyd (that is included in redpill-misc) rendered this extension obsolete.
to access TTYD while in junior mode : open your browser in http://<yourip>:7681 the user is root.
Please note that when you do a fullupgrade the overwritten files will be moved to /home/tc/old
But never replaced automatically? so we have to manually move them back as needed. Good to know... A great option would be restore. Or check during build command if /tc/old/user_config.json exists, ask if we want to use its config file... just a suggestion.
under 7.1 for me the ttyd connection is resettet every second.
@pocopico When I migrated from 6.2.3 to 7.0.1 the tinycore image was at version 0.4.4.
Updating from 7.0.1 to 7.1, I run the update now and fullugrade commands on the existing 0.4.4 image and did not download the image version 0.4.6.
Everything went well I just want to know if there is an issue if I remain on 0.4.4...
Edited by gadreel
dsm 7.1  918+  install step ,first step format disk failed.  error log:
Check new disk...
umount: can't unmount /volume1: Invalid argument
raidtool destroy 0
Not found /dev/md0
raidtool destroy 1
Not found /dev/md1
[CREATE] Raidtool initsys
[CREATE][failed] Raidtool initsys
Install on unraid, disk 1 is loader ,disk 2 is virtual as sata device .
Edited by muziling
On my N54L, it seems to have a problem with USB drivers (or other, I'm not an expert)
  • the control panel doesn't find my bluetooth.
  • And it doesn't find my inverter (eaton ellipse pro 650).
image.thumb.png.4addafbdf7fa61737defcfd7ab7c2d33.pngimage.png.df4612e285027d8d4d23dce6b7af34eb.png
Is this working for someone?
Edited by mitch55
I am going to build another box, this time an LSI sas card. Brand doesnt matter right? LSI 9211 8i IT mode (fujitsu brand if that matters). That should work as an 8 port card either in a vm/proxmox build or just a dedicated nas box, correct?
23 hours ago, blindspot said:
Hello,
I have a ASUS X550J laptop and can't figure out sata map. It has 2 sata ports, one for hdd and one for odd, but the lspci says it has a 6-port sata controller.
The pic bellow is with sataportmap=6 and diskidxmap=00. If I set sataportmap=2 and diskidxmap=00 it says no hdd found. Any ideea? Thanks
@pocopico I had similar problem as @blindspot did.... I used the satamap command and got "sataportmap=2 and diskidxmap=00" and got similar error build 3622xs 7.1.0-42661.
I changed sataportmap=1 and was able to see 1 hdd. I removed sataportmap line and was able to see 2 hdd. The board has 4 ports, couldn't get 3 and 4 to show a connected hdd.
Was there ever a solution to this problem?
