Glupikocz Posted December 27, 2021 #1 Posted December 27, 2021 Hi, XPENOLOGY does not work on the 61H2-AD motherboard on all the other ones, but I would like to do XPENOLOGY on it. Everything turns on but the network does not search for a computer with XPENOLOGY. As if the network card did not support this solution and I have intel 1000mb Quote
Glupikocz Posted December 28, 2021 Author #2 Posted December 28, 2021 I have Intel Corporation 82579V Gigabit Network Quote
IG-88 Posted December 28, 2021 #3 Posted December 28, 2021 board/cpu seems to old for 918+ (4th gen needed and yours is 2nd/3rd gen) so use 3615 or 3617 https://xpenology.com/forum/topic/13333-tutorialreference-6x-loaders-and-platforms/ drivers for intel nic should work with the extra driver pack (added extra.lzma) https://xpenology.com/forum/forum/91-additional-compiled-modules/ i'd suggest just using the loader from jun as it comes and making no mods of any kind, if its found in network them mod the grub.cfg for your usb's vid/pid thats the minimum for installing a dsm to disk (booting and finding it in network does not depend on usb vid/pid) Quote
Glupikocz Posted December 30, 2021 Author #4 Posted December 30, 2021 It actually works and is there any solution to put more than 1 virtual machine or do you need to purchase licenses? Quote
IG-88 Posted December 30, 2021 #5 Posted December 30, 2021 10 hours ago, Glupikocz said: It actually works and please be more specific how, other readers might have the same problem and at least a hint of what you did might help 10 hours ago, Glupikocz said: is there any solution to put more than 1 virtual machine or do you need to purchase licenses? no, not as far as i'm aware of it (i dont use vmm) i'd suggest reading this https://kb.synology.com/en-global/DSM/tutorial/How_many_virtual_machines_can_I_run_on_my_Synology_NAS Quote
Glupikocz Posted December 30, 2021 Author #6 Posted December 30, 2021 (edited) Quote please be more specific how, other readers might have the same problem and at least a hint of what you did might help I have installed loader version 1.02B with .PAT 3615xs with version 6.1.7 DSM Edited December 30, 2021 by Glupikocz Quote
