When i started, my Nas continuous beep and stopped at starting service. When i restarted, it have failed
Please help me. Thanks a lot.
Edited by Guest
I would remove the drives and try a 'fresh install' using the same boot usb on a spare hdd, just to make sure there is not a hardware issue.
If thats ok then put the drives back in and try booting up in 'install/upgrade' mode', if that works then you might need to do some file checking as it looks like you have damaged file system on one or more of the drives, could be related to an hdd failure.
if you can get the nas working, take a backup of data before you start messing about :smile:
Thank a lot. It worked. Checking file system (1500 minutes remaining)
