berwhale Posted February 27, 2016 Share #1 Posted February 27, 2016 Hi, I have a problem mounting remote folders to access media files in Plex. See the servers involved in my sig below. I'm trying to connect a VM running DSM and Plex on the T20 to a CIFS share on the physical DSM box. I created a shared folder on the VM and then remote mounted the share on the physical. This appears to work, but when I try to access the share in File Station it just gets stuck with a 'Loading...' prompt (I'm connecting using the admin account). I've setup a test share on another DSM VM and I can connect to that fine (I copied a couple of MKVs there and Plex was able to find, index and play them perfectly). When I first tried this, the physical box was running an older version of DSM, but I've now upgraded to the latest version and update and the problem persists. I created a new share on the physical server and copied 4 or 5 MKVs there. This seemed to be working, as I could browse the files via File Station. However, as soon as I pointed Plex at it, it went crazy slow and I was unable to browse via File Station or see anything in my Plex library. I always end-up rebooting the DSM VM to clear the remote mount. If I try to remove it via the GUI or console, it always hangs or tells me that the mount is in use. Any ideas? Link to comment Share on other sites More sharing options...
berwhale Posted February 27, 2016 Author Share #2 Posted February 27, 2016 Update: Set both Windows File Services to SMB3 and ensured that Jumbo Frames with an MTU of 9000 was set on both setups - still doesn't work Link to comment Share on other sites More sharing options...
