When I connect the Conbee II, this is shown in dmesg
[ 650.481768] usb 1-9: new full-speed USB device number 45 using xhci_hcd
[ 650.838544] PPP generic driver version 2.4.2
[ 650.840364] cdc_acm 1-9:1.0: ttyACM0: USB ACM device
[ 650.841642] usbcore: registered new interface driver cdc_acm
[ 650.841643] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 654.004735] usb 1-9: USB disconnect, device number 45
Joe Bethersonton
I just purchased a ConBee II USB Zigbee gateway, which I want to use in Home-Assistant, which I run in Docker.
When I connect it to the Xpenology server, it shows up in lsusb, but doesn't get assigned to /dev/ttyUSB0.
lsusb
user@nas:~$ lsusb |__usb1 1d6b:0002:0404 09 2.00 480MBit/s 0mA 1IF (Linux 4.4.59+ xhci-hcd xHCI Host Controller 0000:00:14.0) hub |__1-3 f400:f400:0100 00 2.00 480MBit/s 98mA 1IF (LaCie LaCie iamaKey 2105eeb46e4712) |__1-5 10c4:ea60:0100 00 1.10 12MBit/s 100mA 1IF (Silicon Labs CP2102 USB to UART Bridge Controller 0001) |__1-9 1cf1:0030:0100 02 2.01 12MBit/s 100mA 2IFs (dresden elektronik ingenieurtechnik GmbH ConBee II DE2464032) |__1-14 8087:0aa7:0001 e0 2.00 12MBit/s 100mA 2IFs ( ffffffd1ffffffb2ffffffdbffffffad) |__usb2 1d6b:0003:0404 09 3.00 5000MBit/s 0mA 1IF (Linux 4.4.59+ xhci-hcd xHCI Host Controller 0000:00:14.0) hub
I ran the following commands to load the drivers
sudo insmod /lib/modules/usbserial.ko sudo insmod /lib/modules/ftdi_sio.ko
[ 650.481768] usb 1-9: new full-speed USB device number 45 using xhci_hcd [ 650.838544] PPP generic driver version 2.4.2 [ 650.840364] cdc_acm 1-9:1.0: ttyACM0: USB ACM device [ 650.841642] usbcore: registered new interface driver cdc_acm [ 650.841643] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters [ 654.004735] usb 1-9: USB disconnect, device number 45
I don't know how to proceed, can someone help me?
1 answer to this question
