jaesii Posted February 16, 2016 #1 Posted February 16, 2016 Hello, This is my first time using XPEnology. I just installed it on my supermicro disk array server and attempted to create an iSCSI LUN at block level. After completing the wizard, I am told "There is no iSCSI LUN in your system". There is a target but it is offline. If I reboot the system, the LUN appears and the target is online, but there is no LUN mounted to the target. As soon as I try to mount the LUN to the target, it takes the target offline. I have tried replicating this in a virtual machine as well without updating to update 3 and I have the same result. I am able to make a successful iSCSI LUN and mounted target when I create a volume first and choose normal files for the iSCSI LUN. Since im going to use this device as storage for my VMware lab, I need block-level. Has anyone been able to get a block level LUN created and mounted in 5.2-5644 ?
jaesii Posted February 16, 2016 Author #2 Posted February 16, 2016 this may or may not help, but here is some output from the messages log related to iscsi
jaesii Posted February 17, 2016 Author #4 Posted February 17, 2016 That looks like that fixed it. I was using 5644.4 boot image. It looks like the 5644.5 image came out a day after I downloaded .4
