This network card is not working with XPEnoboot:
Intel® 82562V-2 10/100 Network Connection
Is it just a driver problem?
Because is not included in the compatibility list even though many other similar cards are there.
The error I get is: eth0 not running
Best regards,
Andrea
thats a old card so probably the drivers are not included. Can you swap for a newer gigabit card?
Propably, yes.
To check run  grep /proc/modules and check if the correspondending module is loaded.
Posted via MyXpenology
