Hello to all,
I recently discovered xpenology and I find it a fantastic project! But I have a volume hard disk problem and i don't find a solution!! :oops:
Configuration:
Mac mini i5 with OS Capitan, virtualized DSM with VirtualBox. ISO 5644 is the basis on which I was able to install the Beta 6 DSM :twisted: (fantastic)
Everything works perfectly, I access from outside of my network via port forwarding but ....
When I try to install any package, it say that there are no volumes and asks me to create one. :?:
In storage manager, in overview, i can see the disk (where is installed DSM) of 8 Gb, but i can't use it for download package!
But if I press on volume says "There are no volumes in the system," I press create, and any settings fails to create the volume.
If i add a new virtual hard disk (VMDK of 8 Gb for example) it compare in the overview, but in the volume same problem...i can't format!
Maybe something wrong in creating the virtual hard disk?
Please help me..
I'm amazed that dsm6 even boots. Let's hope this means official support for dsm6 is easier work for the devs!
Sent from my ONE E1003 using Tapatalk
