Problem with the CIFS
CKE
I try to connect my DS3615(XPEnoboot 5.2-5592.2) to a remote folder on a Synology DS1812+
I've used Mount Remote Folder before with great success on my DS3615, but now I can't make it work at all. I get "Failed to connect to the remote folder. Please make sure the remote server is accessible via CIFS protocol."
A different synology available on my network, Mount Remote Folder successfully to the DS3615.
Any Ideas to fix this?
Thanks,
CKE
Do you have a workgroup configured?
Are you connecting to IP or name?
Is SMB2 enabled and are all settings (File services - Windows file services - advanced settings) identical on all machines?
Otherwise it is worth checking etc/smb.conf is the same on all devices or try mounting the share from the terminal as you might see the error message.
I'm not sure if Samba logging is working on Synology but I find you get much more detail generally using syslog to one of the NASs.
