mene Posted January 15, 2016 #1 Posted January 15, 2016 Hello guys, since we don't have QuickConnect ID, how can we setup Cloud Station, Cloud Sync and other packages on xpenology? Also, the last 5 days my xpenology changed 3 times ip address. Is there a way to have always the same ip address?
antihrist2002 Posted January 15, 2016 #2 Posted January 15, 2016 You receiving IP from your ISP. If you need white static IP just ask your ISP about it. It will cost some money. If you have white but dynamic IP. You can use some DDNS service. In DSM go to: Main menu -> External Access ->DDNS. Also if you have router between xpenolygy and internet you will need setup the port forwarding. Why you don't want setup Quick Connect on xpenology? You need generate serial and mac, add them to syslinux.cfg and register new Quick Connect via DSM.
polanskiman Posted January 16, 2016 #3 Posted January 16, 2016 Hello guys, since we don't have QuickConnect ID, how can we setup Cloud Station, Cloud Sync and other packages on xpenology?Also, the last 5 days my xpenology changed 3 times ip address. Is there a way to have always the same ip address? Setup a custom DDNS. Simple, fast and free. Sent from my iPhone using Tapatalk
mene Posted January 16, 2016 Author #4 Posted January 16, 2016 Thanks guys! I finally modified syslinux.cfg and setup Quick connect ID. I tried Cloud Station but I don't like it at all. For 30 gigs of data to sync, it used 90 gigs on volum and another 30 gigs on my pc (plus the 30 gigs of the data). I'm using DS file for remote access from Android and Sync Me app to one way sync photos/videos from the phone to NAS
Bimmermad Posted May 12, 2016 #5 Posted May 12, 2016 Thanks guys!I finally modified syslinux.cfg and setup Quick connect ID. I tried Cloud Station but I don't like it at all. For 30 gigs of data to sync, it used 90 gigs on volum and another 30 gigs on my pc (plus the 30 gigs of the data). I'm using DS file for remote access from Android and Sync Me app to one way sync photos/videos from the phone to NAS Hi could you please provide a guide on how managed to get quick connect to work. I can't register or get an id Sent from my SM-N920C using Tapatalk
brantje Posted May 12, 2016 #6 Posted May 12, 2016 mene wrote:Thanks guys! I finally modified syslinux.cfg and setup Quick connect ID. I tried Cloud Station but I don't like it at all. For 30 gigs of data to sync, it used 90 gigs on volum and another 30 gigs on my pc (plus the 30 gigs of the data). I'm using DS file for remote access from Android and Sync Me app to one way sync photos/videos from the phone to NAS Hi could you please provide a guide on how managed to get quick connect to work. I can't register or get an id Sent from my SM-N920C using Tapatalk You need a valid serial and mac: https://xpenology.us/tutorials/miscellaneous/generate-valid-serial-and-mac Posted via Xpenology.us
AllGamer Posted May 13, 2016 #7 Posted May 13, 2016 Hello guys, since we don't have QuickConnect ID, how can we setup Cloud Station, Cloud Sync and other packages on xpenology?Also, the last 5 days my xpenology changed 3 times ip address. Is there a way to have always the same ip address? Setup a custom DDNS. Simple, fast and free. Sent from my iPhone using Tapatalk indeed, I use Dynu.com it's 100% free, no nag, no advertisements. Unlike no-ip or dyndns those 2 started as free then they became commercial, and make it hell to use their DDNS in a free basis instruction to set DDNS for Dynu in Synology https://www.dynu.com/DynamicDNS/IPUpdat ... ynologyNAS
